path: root/fs/nfs/write.c
2007-10-09NFS: Remove nfs_begin_data_update/nfs_end_data_updateTrond Myklebust
The lower level routines in fs/nfs/proc.c, fs/nfs/nfs3proc.c and fs/nfs/nfs4proc.c should already be dealing with the revalidation issues. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Replace file->private_data with calls to nfs_file_open_context()Trond Myklebust
2007-10-09NFS: Fall back to synchronous writes when a background write errors...Trond Myklebust
This helps prevent huge queues of background writes from building up whenever the server runs out of disk or quota space, or if someone changes the file access modes behind our backs. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Writeback optimisationTrond Myklebust
Schedule writes using WB_SYNC_NONE first, then come back for a second pass using WB_SYNC_ALL. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Clean up NFS writeback flush codeTrond Myklebust
The only user of nfs_sync_mapping_range() is nfs_getattr(), which uses it to flush out the entire inode without sending a commit. We therefore replace nfs_sync_mapping_range with a more appropriate helper. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Clean up nfs_writepages()Trond Myklebust
Just call write_cache_pages directly instead of hacking the writeback control structure in order to find out if we were called from writepages() or directly from the VM. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Clean up write code...Trond Myklebust
The addition of nfs_page_mkwrite means that We should no longer need to create requests inside nfs_writepage() Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-09-01NFS: Fix a write request leak in nfs_invalidate_page()Trond Myklebust
Ryusuke Konishi says: The recent truncate_complete_page() clears the dirty flag from a page before calling a_ops->invalidatepage(), ^^^^^^ static void truncate_complete_page(struct address_space *mapping, struct page *page) { ... cancel_dirty_page(page, PAGE_CACHE_SIZE); <--- Inserted here at kernel 2.6.20 if (PagePrivate(page)) do_invalidatepage(page, 0); ---> will call a_ops->invalidatepage() ... } and this is disturbing nfs_wb_page_priority() from calling nfs_writepage_locked() that is expected to handle the pending request (=nfs_page) associated with the page. int nfs_wb_page_priority(struct inode *inode, struct page *page, int how) { ... if (clear_page_dirty_for_io(page)) { ret = nfs_writepage_locked(page, &wbc); if (ret < 0) goto out; } ... } Since truncate_complete_page() will get rid of the page after a_ops->invalidatepage() returns, the request (=nfs_page) associated with the page becomes a garbage in nfs_inode->nfs_page_tree. ------------------------ Fix this by ensuring that nfs_wb_page_priority() recognises that it may also need to clear out non-dirty pages that have an nfs_page associated with them. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10NFS: Replace NFS_I(inode)->req_lock with inode->i_lockTrond Myklebust
There is no justification for keeping a special spinlock for the exclusive use of the NFS writeback code. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10NFS: Remove the redundant 'dirty' and 'commit' lists from nfs_inodeTrond Myklebust
2007-07-10NFS cleanup: speed up nfs_scan_commit using radix tree tagsTrond Myklebust
Add a tag for requests that are waiting for a COMMIT Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10NFS cleanup: Rename NFS_PAGE_TAG_WRITEBACK to NFS_PAGE_TAG_LOCKEDTrond Myklebust
2007-07-10NFS: Convert struct nfs_page to use krefsTrond Myklebust
2007-07-10NFS: Replace vfsmount and dentry in nfs_open_context with struct pathTrond Myklebust
2007-07-10NFS: Don't mark a written page as uptodate until it is on diskTrond Myklebust
The write may fail, so we should not mark the page as uptodate until we are certain that the data has been accepted and written to disk by the server. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-24NFS: Avoid a deadlock situation on writeTrond Myklebust
When processes are allowed to attempt to lock a non-contiguous range of nfs write requests, it is possible for generic_writepages to 'wrap round' the address space, and call writepage() on a request that is already locked by the same process. We avoid the deadlock by checking if the page index is contiguous with the list of nfs write requests that is already held in our nfs_pageio_descriptor prior to attempting to lock a new request. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-14NFS: Fix some 'sparse' warnings...Trond Myklebust
- fs/nfs/dir.c:610:8: warning: symbol 'nfs_llseek_dir' was not declared. Should it be static? - fs/nfs/dir.c:636:5: warning: symbol 'nfs_fsync_dir' was not declared. Should it be static? - fs/nfs/write.c:925:19: warning: symbol 'req' shadows an earlier one - fs/nfs/write.c:61:6: warning: symbol 'nfs_commit_rcu_free' was not declared. Should it be static? - fs/nfs/nfs4proc.c:793:5: warning: symbol 'nfs4_recover_expired_lease' was not declared. Should it be static? Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-14NFS: use zero_user_pageNate Diller
Use zero_user_page() instead of the newly deprecated memclear_highpage_flush(). Signed-off-by: Nate Diller <nate.diller@gmail.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-08nfs: fix congestion control: use atomic_longsPeter Zijlstra
Change the atomic_t in struct nfs_server to atomic_long_t in anticipation of machines that can handle 8+TB of (4K) pages under writeback. However I suspect other things in NFS will start going *bang* by then. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30NFS: Use pgoff_t in structures and functions that pass page cache offsetsTrond Myklebust
2007-04-30NFS: Clean up nfs_sync_mapping_wait()Trond Myklebust
It has no business touching wbc->pages_skipped. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30NFS: Fix a buffer overflow in the allocation of struct nfs_read/writedataTrond Myklebust
2007-04-30NFS: Fix a race when doing NFS write coalescingTrond Myklebust
Currently we do write coalescing in a very inefficient manner: one pass in generic_writepages() in order to lock the pages for writing, then one pass in nfs_flush_mapping() and/or nfs_sync_mapping_wait() in order to gather the locked pages for coalescing into RPC requests of size "wsize". In fact, it turns out there is actually a deadlock possible here since we only start I/O on the second pass. If the user signals the process while we're in nfs_sync_mapping_wait(), for instance, then we may exit before starting I/O on all the requests that have been queued up. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30NFS: Another cleanup of the read/write request coalescing codeTrond Myklebust
2007-04-30NFS: Cleanup the coalescing codeTrond Myklebust
2007-04-30NFS: Don't wait for congestion in nfs_update_request()Trond Myklebust
It is redundant, and will interfere with the call to balance_dirty_pages_ratelimited_nr in generic_file_write(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30NFS: Fix nfs_set_page_dirty()Trond Myklebust
Be more careful about testing page->mapping. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-20NFS: Fix race in nfs_set_page_dirtyTrond Myklebust
Protect nfs_set_page_dirty() against races with nfs_inode_add_request. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-20NFS: Fix the 'desynchronized value of nfs_i.ncommit' errorTrond Myklebust
Redirtying a request that is already marked for commit will screw up the accounting for NR_UNSTABLE_NFS as well as nfs_i.ncommit. Ensure that all requests on the commit queue are labelled with the PG_NEED_COMMIT flag, and avoid moving them onto the dirty list inside nfs_page_mark_flush(). Also inline nfs_mark_request_dirty() into nfs_page_mark_flush() for atomicity reasons. Avoid dropping the spinlock until we're done marking the request in the radix tree and have added it to the ->dirty list. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-20NFS: Don't clear PG_writeback until after we've processed unstable writesTrond Myklebust
Ensure that we don't release the PG_writeback lock until after the page has either been redirtied, or queued on the nfs_inode 'commit' list. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-20NFS: clean up the unstable write codeTrond Myklebust
Get rid of the inlined #ifdefs. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-15NFS: Fix a list corruption problemTrond Myklebust
We must remove the request from whatever list it is currently on before we can add it to the dirty list. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-14NFS: Ensure PG_writeback is cleared when writeback failsTrond Myklebust
If the writebacks are cancelled via nfs_cancel_dirty_list, or due to the memory allocation failing in nfs_flush_one/nfs_flush_multi, then we must ensure that the PG_writeback flag is cleared. Also ensure that we actually own the PG_writeback flag whenever we schedule a new writeback by making nfs_set_page_writeback() return the value of test_set_page_writeback(). The PG_writeback page flag ends up replacing the functionality of the PG_FLUSHING nfs_page flag, so we rip that out too. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] nfs: fix congestion controlPeter Zijlstra
The current NFS client congestion logic is severly broken, it marks the backing device congested during each nfs_writepages() call but doesn't mirror this in nfs_writepage() which makes for deadlocks. Also it implements its own waitqueue. Replace this by a more regular congestion implementation that puts a cap on the number of active writeback pages and uses the bdi congestion waitqueue. Also always use an interruptible wait since it makes sense to be able to SIGKILL the process even for mounts without 'intr'. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Christoph Lameter <clameter@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12NFS: Don't use ClearPageUptodate() when writeback failsTrond Myklebust
ClearPageUptodate() will just cause races here. What we really want to do is to invalidate the page cache. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-02-03NFS: fix print format for tk_pidChuck Lever
The tk_pid field is an unsigned short. The proper print format specifier for that type is %5u, not %4d. Also clean up some miscellaneous print formatting nits. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-02-03NFS: Fixup some outdated comments...Trond Myklebust
2007-02-03NFS: nfs_writepages() cleanupTrond Myklebust
Strip out the call to nfs_commit_inode(), and allow that to be done by nfs_write_inode(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-02-03NFS: Micro-optimisation for nfs_wb_page()Trond Myklebust
2007-02-03NFS: Ensure that ->writepage() uses flush_stable() when reclaiming pagesTrond Myklebust
2006-12-08[PATCH] nfs: change uses of f_{dentry,vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the nfs client code. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07Merge branch 'master' of /home/trondmy/kernel/linux-2.6/ into merge_linusTrond Myklebust
2006-12-07[PATCH] slab: remove SLAB_NOFSChristoph Lameter
SLAB_NOFS is an alias of GFP_NOFS. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-06NFS: Clean up calls to mark_inode_dirty() part 2Trond Myklebust
2006-12-06NFS: Fix up the dirty page accountingTrond Myklebust
There is now no reason to account for the dirty pages in the NFS code, since the VM code will now do it for us via __set_page_dirty_nobuffers(), and set_page_writeback(). We still need to keep the accounting of stable writes, though. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-12-06NFS: Ensure the inode is marked as dirty if we break out of nfs_wb_all()Trond Myklebust
2006-12-06NFS: Ensure we only call set_page_writeback() under the page lockTrond Myklebust
