Now that we have access to the pointer, clear it immediately after
the put, instead of in caller.
Signed-off-by: Fred Isaman <iisaman@netapp.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
This will make it possible to clear the lseg pointer in the same
function as it is put, instead of in the caller nfs_pageio_doio().
Allows the pnfs filelayout driver to write to the data servers.
Note that COMMIT to data servers will be implemented in a future
patch. To avoid improper behavior, for the moment any WRITE to a data
server that would also require a COMMIT to the data server is sent
NFS_FILE_SYNC.
Signed-off-by: Andy Adamson <andros@citi.umich.edu>
Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com>
Signed-off-by: Fred Isaman <iisaman@citi.umich.edu>
Signed-off-by: Mingyang Guo <guomingyang@nrchpc.ac.cn>
Signed-off-by: Oleg Drokin <green@linuxhacker.ru>
Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com>
Signed-off-by: Andy Adamson <andros@netapp.com>
Signed-off-by: Benny Halevy <bhalevy@panasas.com>
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Signed-off-by: J. Bruce Fields <bfields@fieldses.org>
Signed-off-by: Mike Sager <sager@netapp.com>
Signed-off-by: Tao Guo <guotao@nrchpc.ac.cn>
We grab the lseg sent in from the doio function and attach it to
each struct nfs_write_data created. This is how the lseg will be
sent to the layout driver.
Reorder nfs_write_rpcsetup, preparing for a pnfs entry point.
Move the pnfs_update_layout call location to nfs_pageio_do_add_request().
Grab the lseg sent in the doio function to nfs_read_rpcsetup and attach
it to each nfs_read_data so it can be sent to the layout driver.
Add a pg_test layout driver hook which is used to avoid coelescing I/O across
layout stripes.
The return values are not used by any callers.
I've been adding in more artificial delays in the NFSv4 commit and close
codepaths to uncover races. The kernel I'm testing has the patch to
close the race in __rpc_wait_for_completion_task that's in Trond's
cthon2011 branch. The reproducer I've been using does this in a loop:
mkdir("DIR");
fd = open("DIR/FILE", O_WRONLY|O_CREAT|O_EXCL, 0644);
write(fd, "abcdefg", 7);
close(fd);
unlink("DIR/FILE");
rmdir("DIR");
The above reproducer shouldn't result in any silly-renaming. However,
when I add a "msleep(100)" just after the nfs_commit_clear_lock call in
nfs_commit_release, I can almost always force one to occur. If I can
force it to occur with that, then it can happen without that delay
given the right timing.
nfs_commit_inode waits for the NFS_INO_COMMIT bit to clear when called
with FLUSH_SYNC set. nfs_commit_rpcsetup on the other hand does not wait
for the task to complete before putting its reference to it, so the last
reference get put in rpc_release task and gets queued to a workqueue.
In this situation, the last open context reference may be put by the
COMMIT release instead of the close() syscall. The close() syscall
returns too quickly and the unlink runs while the d_count is still
high since the COMMIT release hasn't put its dentry reference yet.
Fix this by having rpc_commit_rpcsetup wait for the RPC call to complete
before putting the task reference when FLUSH_SYNC is set. With this, the
last reference is put by the process that's initiating the FLUSH_SYNC
commit and the race is closed.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Cleanup of the allocated list entries should not call
put_nfs_open_context() on each entry, as the context will
always be NULL, causing an oops.
When a nfs_page is freed, nfs_free_request is called which also calls
nfs_clear_request to clean out the lock and open contexts and free the
pagecache page.
However, a couple of places in the nfs code call nfs_clear_request
themselves. What happens here if the refcount on the request is still high?
We'll be releasing contexts and freeing pointers while the request is
possibly still in use.
Remove those bare calls to nfs_clear_context. That should only be done when
the request is being freed.
Note that when doing this, we need to watch out for tests of req->wb_page.
Previously, nfs_set_page_tag_locked() and nfs_clear_page_tag_locked()
would check the value of req->wb_page to figure out if the page is mapped
into the nfsi->nfs_page_tree. We now indicate the page is mapped using
the new bit PG_MAPPED in req->wb_flags .
Reported-by: Jeff Layton <jlayton@redhat.com>
This removes more dead code that was somehow missed by commit 0d99519efef
(writeback: remove unused nonblocking and congestion checks). There are
no behavior change except for the removal of two entries from one of the
ext4 tracing interface.
The nonblocking checks in ->writepages are no longer used because the
flusher now prefer to block on get_request_wait() than to skip inodes on
IO congestion. The latter will lead to more seeky IO.
The nonblocking checks in ->writepage are no longer used because it's
redundant with the WB_SYNC_NONE check.
We no long set ->nonblocking in VM page out and page migration, because
a) it's effectively redundant with WB_SYNC_NONE in current code
b) it's old semantic of "Don't get stuck on request queues" is mis-behavior:
that would skip some dirty inodes on congestion and page out others, which
is unfair in terms of LRU age.
Inspired by Christoph Hellwig. Thanks!
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Sage Weil <sage@newdream.net>
Cc: Steve French <sfrench@samba.org>
Cc: Chris Mason <chris.mason@oracle.com>
WB_SYNC_NONE is supposed to mean "don't wait on anything". That should
also include not waiting for COMMIT calls to complete.
WB_SYNC_NONE is also implied when wbc->nonblocking and
wbc->for_background are set, so we can replace those checks in
nfs_commit_unstable_pages with a check for WB_SYNC_NONE.
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
Having to explicitly initialize sr_slotid to NFS4_MAX_SLOT_TABLE
resulted in numerous bugs. Keeping the current slot as a pointer
to the slot table is more straight forward and robust as it's
implicitly set up to NULL wherever the seq_res member is initialized
to zeroes.
git://git.linux-nfs.org/projects/trondmy/nfs-2.6
* 'nfs-for-2.6.36' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (42 commits)
NFS: NFSv4.1 is no longer a "developer only" feature
NFS: NFS_V4 is no longer an EXPERIMENTAL feature
NFS: Fix /proc/mount for legacy binary interface
NFS: Fix the locking in nfs4_callback_getattr
SUNRPC: Defer deleting the security context until gss_do_free_ctx()
SUNRPC: prevent task_cleanup running on freed xprt
SUNRPC: Reduce asynchronous RPC task stack usage
SUNRPC: Move the bound cred to struct rpc_rqst
SUNRPC: Clean up of rpc_bindcred()
SUNRPC: Move remaining RPC client related task initialisation into clnt.c
SUNRPC: Ensure that rpc_exit() always wakes up a sleeping task
SUNRPC: Make the credential cache hashtable size configurable
SUNRPC: Store the hashtable size in struct rpc_cred_cache
NFS: Ensure the AUTH_UNIX credcache is allocated dynamically
NFS: Fix the NFS users of rpc_restart_call()
SUNRPC: The function rpc_restart_call() should return success/failure
NFSv4: Get rid of the bogus RPC_ASSASSINATED(task) checks
NFSv4: Clean up the process of renewing the NFSv4 lease
NFSv4.1: Handle NFS4ERR_DELAY on SEQUENCE correctly
NFS: nfs_rename() should not have to flush out writebacks
nfs_commit_inode() needs to be defined irrespectively of whether or not
we are supporting NFSv3 and NFSv4.
Allow the compiler to optimise away code in the NFSv2-only case by
converting it into an inlined stub function.
Reported-and-tested-by: Ingo Molnar <mingo@elte.hu>
See https://bugzilla.kernel.org/show_bug.cgi?id=16056
If other processes are blocked waiting for kswapd to free up some memory so
that they can make progress, then we cannot allow kswapd to block on those
processes.
Cc: stable@kernel.org
This patch fixes bugzilla entry 14501:
https://bugzilla.kernel.org/show_bug.cgi?id=14501
In anticipation of the day when we have per-filesystem sessions, and also
in order to allow the session to change in the event of a filesystem
migration event.
J.R. Okajima reports that the call to sync_inode() in nfs_wb_page() can
deadlock with other writeback flush calls. It boils down to the fact
that we cannot ever call writeback_single_inode() while holding a page
lock (even if we do set nr_to_write to zero) since another process may
already be waiting in the call to do_writepages(), and so will deny us
the I_SYNC lock.
If we exit from nfs_commit_inode() without ensuring that the COMMIT rpc
call has been completed, we must re-mark the inode as dirty. Otherwise,
future calls to sync_inode() with the WB_SYNC_ALL flag set will fail to
ensure that the data is on the disk.
Neil Brown reports that he is seeing the BUG_ON(ret == 0) trigger in
nfs_page_async_flush. According to the trace in
https://bugzilla.novell.com/show_bug.cgi?id=599628
the problem appears to be due to nfs_wb_page() not waiting for the
PG_writeback flag to clear.
There is a ditto problem in nfs_wb_page_cancel()
Commit 2c61be0a9478258f77b66208a0c4b1f5f8161c3c (NFS: Ensure that the WRITE
and COMMIT RPC calls are always uninterruptible) exposed a race on file
close. In order to ensure correct close-to-open behaviour, we want to wait
for all outstanding background commit operations to complete.
This patch adds an inode flag that indicates if a commit operation is under
way, and provides a mechanism to allow ->write_inode() to wait for its
completion if this is a data integrity flush.
We always want to ensure that WRITE and COMMIT completes, whether or not
the user presses ^C. Do this by making the call asynchronous, and allowing
the user to do an interruptible wait for rpc_task completion.
This patch fixes a race which occurs due to the fact that we release the
PG_writeback flag while still holding the nfs_page locked.
Since writeback_single_inode() checks the inode->i_state flags _before_ it
flushes out the data, we need to ensure that the I_DIRTY_DATASYNC flag is
already set. Otherwise we risk not seeing a call to write_inode(), which
again means that we break fsync() et al...
Now that we have correct COMMIT semantics in writeback_single_inode, we can
reduce and simplify nfs_wb_all(). Also replace nfs_wb_nocommit() with a
call to filemap_write_and_wait(), which doesn't need to hold the
inode->i_mutex.
With that done, we can eliminate nfs_write_mapping() altogether.
In all cases we should be able to just remove the request and call
cancel_dirty_page().
Since nfs_scan_list() doesn't wait for locked pages, we have a race in
which it is possible to end up with an inode that needs to send a COMMIT,
but which does not have the I_DIRTY_DATASYNC flag set.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Wu Fengguang <fengguang.wu@intel.com>
If the caller is doing a non-blocking flush, and there are still writebacks
pending on the wire, we can usually defer the COMMIT call until those
writes are done.
Also ensure that we honour the wbc->nonblocking flag.
In order to know when we should do opportunistic commits of the unstable
writes, when the VM is doing a background flush, we add a field to count
the number of unstable writes.
The sole purpose of nfs_write_inode is to commit unstable writes, so
move it into fs/nfs/write.c, and make nfs_commit_inode static.
The symbol nfs_commitdata_release is only used locally
in this file. Make it static to prevent the following sparse warning:
warning: symbol 'nfs_commitdata_release' was not declared. Should it be static?
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Reviewed-by: Chuck Lever <chuck.lever@oracle.com>
The call to migrate_page() will cause the page->private field to be
cleared.
Also fix up the locking around the page->private transfer, so that we ensure
that calls to nfs_page_find_request() don't end up racing.
Finally, fix up a double free bug: nfs_unlock_request() already calls
nfs_release_request() for us...
Reported-by: Wu Fengguang <fengguang.wu@intel.com>
Tested-by: Andi Kleen <andi@firstfloor.org>
While Linux provided an O_SYNC flag basically since day 1, it took until
Linux 2.4.0-test12pre2 to actually get it implemented for filesystems,
since that day we had generic_osync_around with only minor changes and the
great "For now, when the user asks for O_SYNC, we'll actually give
O_DSYNC" comment. This patch intends to actually give us real O_SYNC
semantics in addition to the O_DSYNC semantics. After Jan's O_SYNC
patches which are required before this patch it's actually surprisingly
simple, we just need to figure out when to set the datasync flag to
vfs_fsync_range and when not.
This patch renames the existing O_SYNC flag to O_DSYNC while keeping it's
numerical value to keep binary compatibility, and adds a new real O_SYNC
flag. To guarantee backwards compatiblity it is defined as expanding to
both the O_DSYNC and the new additional binary flag (__O_SYNC) to make
sure we are backwards-compatible when compiled against the new headers.
This also means that all places that don't care about the differences can
just check O_DSYNC and get the right behaviour for O_SYNC, too - only
places that actuall care need to check __O_SYNC in addition. Drivers and
network filesystems have been updated in a fail safe way to always do the
full sync magic if O_DSYNC is set. The few places setting O_SYNC for
lower layers are kept that way for now to stay failsafe.
We enforce that O_DSYNC is set when __O_SYNC is set early in the open path
to make sure we always get these sane options.
Note that parisc really screwed up their headers as they already define a
O_DSYNC that has always been a no-op. We try to repair it by using it for
the new O_DSYNC and redefinining O_SYNC to send both the traditional
O_SYNC numerical value _and_ the O_DSYNC one.
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Grant Grundler <grundler@parisc-linux.org>
Cc: Andreas Dilger <adilger@sun.com>
Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Acked-by: Ulrich Drepper <drepper@redhat.com>
Also rename it: it is used in generic code, and so should not have a 'nfs4'
prefix.
We no longer need to maintain a distinction between nfs41_sequence_done and
nfs41_sequence_free_slot.
This fixes a number of slot table leakages in the NFSv4.1 code.
nfs41_sequence_free_slot can be called multiple times on SEQUENCE operation
errors.
No reason to inline nfs4_restart_rpc
Reported-by: Trond Myklebust <trond.myklebust@netapp.com>
nfs_writeback_done and nfs_readpage_retry call nfs4_restart_rpc outside the
error handler, and the slot is not freed prior to restarting in the rpc_prepare
state during session reset.
Fix this by moving the call to nfs41_sequence_free_slot from the error
path of nfs41_sequence_done into nfs4_restart_rpc, and by removing the test
for NFS4CLNT_SESSION_SETUP.
Always free slot and goto the rpc prepare state on async errors.
It will lower the flush priority for NFS, and maybe more in future.
Cc: Jens Axboe <jens.axboe@oracle.com>
It's only set, it's never checked. Kill it.
Acked-by: Jan Kara <jack@suse.cz>
fs/nfs/nfs4xdr.c
We can't call nfs_readdata_release()/nfs_writedata_release() without
first initialising and referencing args.context. Doing so inside
nfs_direct_read_schedule_segment()/nfs_direct_write_schedule_segment()
causes an Oops.
We should rather be calling nfs_readdata_free()/nfs_writedata_free() in
those cases.
Looking at the O_DIRECT code, the "struct nfs_direct_req" is already
referencing the nfs_open_context for us. Since the readdata and writedata
structures carry a reference to that, we can simplify things by getting rid
of the extra nfs_open_context references, so that we can replace all
instances of nfs_readdata_release()/nfs_writedata_release().
Reported-by: Catalin Marinas <catalin.marinas@arm.com>
Tested-by: Catalin Marinas <catalin.marinas@arm.com>
