path: root/fs/nfs/read.c
2011-11-10NFS: Revert pnfs ugliness from the generic NFS read code pathTrond Myklebust
pNFS-specific code belongs in the pnfs layer. It should not be hijacking generic NFS read or write code paths. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-10-19NFS: Get rid of the nfs_rdata_mempoolTrond Myklebust
We don't need a mempool in order to guarantee reliable NFS read performance. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-10-19NFS: Don't rely on PageError in nfs_readpage_release_partialTrond Myklebust
Don't rely on the PageError flag to tell us if one of the partial reads of the page failed. Instead, replace that with a dedicated flag in the struct nfs_page. Then clean out redundant uses of the PageError flag: the VM no longer checks it for reads. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-10-19NFS: Get rid of unnecessary calls to ClearPageError() in read codeTrond Myklebust
The generic file read code does that for us anyway. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-10-19NFS: Get rid of nfs_restart_rpc()Trond Myklebust
It can trivially be replaced with rpc_restart_call_prepare. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-10-18pnfs: recoalesce when ld read pagelist failsPeng Tao
For pnfs pagelist read failure, we need to pg_recoalesce and resend IO to mds. Signed-off-by: Peng Tao <peng_tao@emc.com> Signed-off-by: Jim Rees <rees@umich.edu> Cc: stable@kernel.org [3.0] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-25Merge branch 'master' into devel and apply fixup from Stephen Rothwell:Stephen Rothwell
vfs/nfs: fixup for nfs_open_context change Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-20nfs_open_context doesn't need struct path eitherAl Viro
just dentry, please... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-15NFS: Clean up - simplify the switch to read/write-through-MDSTrond Myklebust
Use nfs_pageio_reset_read_mds and nfs_pageio_reset_write_mds instead of completely reinitialising the struct nfs_pageio_descriptor. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-15NFS: Move the pnfs read code into pnfs.cTrond Myklebust
...and ensure that we recoalese to take into account differences in block sizes when falling back to read through the MDS. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-15NFS: Use the nfs_pageio_descriptor->pg_bsize in the read/write requestTrond Myklebust
Instead of looking up the rsize and wsize, the routines that generate the RPC requests should really be using the pg_bsize, since that is what we use when deciding whether or not to coalesce write requests... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-15NFS: Cache rpc_ops in struct nfs_pageio_descriptorTrond Myklebust
2011-07-15NFS: Clean up: split out the RPC transmission from nfs_pagein_multi/oneTrond Myklebust
...and do the same for nfs_flush_multi/one. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-15NFS: fix return value of nfs_pagein_one/nfs_flush_onePeng Tao
Signed-off-by: Peng Tao <peng_tao@emc.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-12NFS: Clean up nfs_read_rpcsetup and nfs_write_rpcsetupTrond Myklebust
Split them up into two parts: one which sets up the struct nfs_read/write_data, the other which sets up the actual RPC call or pNFS call. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-12NFSv4.1: File layout only supports whole file layoutsAndy Adamson
Ask for whole file layouts. Until support for layout segments is fully supported in the file layout code, discard non-whole file layouts. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-12NFSv4.1: Fall back to ordinary i/o through the mds if we have no layout segmentTrond Myklebust
2011-07-12NFSv4.1: Add an initialisation callback for pNFSTrond Myklebust
Ensure that we always get a layout before setting up the i/o request. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-12NFS: Cleanup of the nfs_pageio code in preparation for a pnfs bugfixTrond Myklebust
We need to ensure that the layouts are set up before we can decide to coalesce requests. To do so, we want to further split up the struct nfs_pageio_descriptor operations into an initialisation callback, a coalescing test callback, and a 'do i/o' callback. This patch cleans up the existing callback methods before adding the 'initialisation' callback. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-05-29NFSv4.1: unify pnfs_pageio_init functionsBenny Halevy
Use common code for pnfs_pageio_init_{read,write} and use a common generic pg_test function. Note that this function always assumes the the layout driver's pg_test method is implemented. [Fix BUG] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2011-05-29pnfs: Use byte-range for layoutgetBenny Halevy
Add offset and count parameters to pnfs_update_layout and use them to get the layout in the pageio path. Order cache layout segments in the following order: * offset (ascending) * length (descending) * iomode (RW before READ) Test byte range against the layout segment in use in pnfs_{read,write}_pg_test so not to coalesce pages not using the same layout segment. [fix lseg ordering] [clean up pnfs_find_lseg lseg arg] [remove unnecessary FIXME] [fix ordering in pnfs_insert_layout] [clean up pnfs_insert_layout] Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2011-05-11NFSv4.1: Ensure that layoutget uses the correct gfp modesTrond Myklebust
Currently, writebacks may end up recursing back into the filesystem due to GFP_KERNEL direct reclaims in the pnfs subsystem. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-15nfs: BKL is no longer needed, so remove the includeStephen Rothwell
2011-03-11NFSv4.1: Clear lseg pointer in ->doio functionFred Isaman
Now that we have access to the pointer, clear it immediately after the put, instead of in caller. Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: rearrange ->doio argsFred Isaman
This will make it possible to clear the lseg pointer in the same function as it is put, instead of in the caller nfs_pageio_doio(). Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: filelayout async error handlerAndy Adamson
Use our own async error handler. Mark the layout as failed and retry i/o through the MDS on specified errors. Update the mds_offset in nfs_readpage_retry so that a failed short-read retry to a DS gets correctly resent through the MDS. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: filelayout readAndy Adamson
Attempt a pNFS file layout read by setting up the nfs_read_data struct and calling nfs_initiate_read with the data server rpc client and the filelayout rpc call ops. Error handling is implemented in a subsequent patch. Signed-off-by: Andy Adamson <andros@citi.umich.edu> Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com> Signed-off-by: Fred Isaman <iisaman@citi.umich.edu> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Mingyang Guo <guomingyang@nrchpc.ac.cn> Signed-off-by: Oleg Drokin <green@linuxhacker.ru> Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Tested-by: Guo Mingyang <guomingyang@nrchpc.ac.cn> Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: generic readAndy Adamson
Separate the rpc run portion of nfs_read_rpcsetup into a new function nfs_initiate_read that is called for normal NFS I/O. Add a pNFS read_pagelist function that is called instead of nfs_intitate_read for pNFS reads. Signed-off-by: Andy Adamson <andros@citi.umich.edu> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com> Signed-off-by: Fred Isaman <iisaman@citi.umich.edu> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Mike Sager <sager@netapp.com> Signed-off-by: Mingyang Guo <guomingyang@nrchpc.ac.cn> Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Tao Guo <guotao@nrchpc.ac.cn> Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: shift pnfs_update_layout locationsFred Isaman
Move the pnfs_update_layout call location to nfs_pageio_do_add_request(). Grab the lseg sent in the doio function to nfs_read_rpcsetup and attach it to each nfs_read_data so it can be sent to the layout driver. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Andy Adamson <andros@citi.umich.edu> Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com> Signed-off-by: Fred Isaman <iisaman@citi.umich.edu> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Oleg Drokin <green@linuxhacker.ru> Signed-off-by: Tao Guo <guotao@nrchpc.ac.cn> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: coelesce across layout stripesFred Isaman
Add a pg_test layout driver hook which is used to avoid coelescing I/O across layout stripes. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Andy Adamson <andros@citi.umich.edu> Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com> Signed-off-by: Fred Isaman <iisaman@citi.umich.edu> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Oleg Drokin <green@linuxhacker.ru> Signed-off-by: Tao Guo <guotao@nrchpc.ac.cn> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-07nfs: remove extraneous and problematic calls to nfs_clear_requestTrond Myklebust
When a nfs_page is freed, nfs_free_request is called which also calls nfs_clear_request to clean out the lock and open contexts and free the pagecache page. However, a couple of places in the nfs code call nfs_clear_request themselves. What happens here if the refcount on the request is still high? We'll be releasing contexts and freeing pointers while the request is possibly still in use. Remove those bare calls to nfs_clear_context. That should only be done when the request is being freed. Note that when doing this, we need to watch out for tests of req->wb_page. Previously, nfs_set_page_tag_locked() and nfs_clear_page_tag_locked() would check the value of req->wb_page to figure out if the page is mapped into the nfsi->nfs_page_tree. We now indicate the page is mapped using the new bit PG_MAPPED in req->wb_flags . Reported-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-24NFS: create and destroy inode's layout cacheBenny Halevy
At the start of the io paths, try to grab the relevant layout information. This will initiate the inode's layout cache, but stubs ensure the cache stays empty. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Dean Hildebrand <dhildebz@umich.edu> Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: Tao Guo <guotao@nrchpc.ac.cn> Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-09-24NFSv4.1: keep seq_res.sr_slot as pointer rather than an indexBenny Halevy
Having to explicitly initialize sr_slotid to NFS4_MAX_SLOT_TABLE resulted in numerous bugs. Keeping the current slot as a pointer to the slot table is more straight forward and robust as it's implicitly set up to NULL wherever the seq_res member is initialized to zeroes. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-07-30NFSv4: Ensure that we track the NFSv4 lock state in read/write requests.Trond Myklebust
This patch fixes bugzilla entry 14501: https://bugzilla.kernel.org/show_bug.cgi?id=14501 Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-06-22NFSv4.1: Make nfs4_setup_sequence take a nfs_server argumentTrond Myklebust
In anticipation of the day when we have per-filesystem sessions, and also in order to allow the session to change in the event of a filesystem migration event. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-05-14NFS: Read requests can use GFP_KERNEL.Trond Myklebust
There is no danger of deadlock should the allocation trigger page writeback. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-07NFS: Fix up the declaration of nfs4_restart_rpc when NFSv4 not configuredTrond Myklebust
Also rename it: it is used in generic code, and so should not have a 'nfs4' prefix. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-05NFSv41: Clean up slot table managementTrond Myklebust
We no longer need to maintain a distinction between nfs41_sequence_done and nfs41_sequence_free_slot. This fixes a number of slot table leakages in the NFSv4.1 code. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-04nfs41: call free slot from nfs4_restart_rpcAndy Adamson
nfs41_sequence_free_slot can be called multiple times on SEQUENCE operation errors. No reason to inline nfs4_restart_rpc Reported-by: Trond Myklebust <trond.myklebust@netapp.com> nfs_writeback_done and nfs_readpage_retry call nfs4_restart_rpc outside the error handler, and the slot is not freed prior to restarting in the rpc_prepare state during session reset. Fix this by moving the call to nfs41_sequence_free_slot from the error path of nfs41_sequence_done into nfs4_restart_rpc, and by removing the test for NFS4CLNT_SESSION_SETUP. Always free slot and goto the rpc prepare state on async errors. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-12NFS: Fix an O_DIRECT Oops...Trond Myklebust
We can't call nfs_readdata_release()/nfs_writedata_release() without first initialising and referencing args.context. Doing so inside nfs_direct_read_schedule_segment()/nfs_direct_write_schedule_segment() causes an Oops. We should rather be calling nfs_readdata_free()/nfs_writedata_free() in those cases. Looking at the O_DIRECT code, the "struct nfs_direct_req" is already referencing the nfs_open_context for us. Since the readdata and writedata structures carry a reference to that, we can simplify things by getting rid of the extra nfs_open_context references, so that we can replace all instances of nfs_readdata_release()/nfs_writedata_release(). Reported-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Tested-by: Catalin Marinas <catalin.marinas@arm.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-17nfs41: use rpc prepare call state for session resetAndy Adamson
[nfs41: change nfs4_restart_rpc argument] [nfs41: check for session not minorversion] [nfs41: trigger the state manager for session reset] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [always define nfs4_restart_rpc] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: read sequence setup/done supportAndy Adamson
Implement the read rpc_call_prepare method for asynchronuos nfs rpcs, call nfs41_setup_sequence from respective rpc_call_validate_args methods. Call nfs4_sequence_done from respective rpc_call_done methods. Note that we need to pass a pointer to the nfs_server in calls data for passing on to nfs4_sequence_done. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [pnfs: client data server write validate and release] Signed-off-by: Andy Adamson <andros@umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [move the nfs4_sequence_free_slot call in nfs_readpage_retry from] [nfs41: separate free slot from sequence done] [remove nfs_readargs.nfs_server, use calldata->inode instead] Signed-off-by: Andy Adamson <andros@umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: Support sessions with O_DIRECT] Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: nfs4_sequence_free_slot use nfs_client for data server] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: set up seq_res.sr_slotidAndy Adamson
Initialize nfs4_sequence_res sr_slotid to NFS4_MAX_SLOT_TABLE. [was nfs41: sequence res use slotid] Signed-off-by: Andy Adamson <andros@netapp.com> [pulled definition of struct nfs4_sequence_res.sr_slotid to here] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-04-03NFS: Store pages from an NFS inode into a local cacheDavid Howells
Store pages from an NFS inode into the cache data storage object associated with that inode. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03NFS: Read pages from FS-Cache into an NFS inodeDavid Howells
Read pages from an FS-Cache data storage object representing an inode into an NFS inode. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03NFS: nfs_readpage_async() needs to be accessible as a fallback for local cachingDavid Howells
nfs_readpage_async() needs to be non-static so that it can be used as a fallback for the local on-disk caching should an EIO crop up when reading the cache. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2008-12-23nfs: remove redundant tests on reading new pagesWu Fengguang
aops->readpages() and its NFS helper readpage_async_filler() will only be called to do readahead I/O for newly allocated pages. So it's not necessary to test for the always 0 dirty/uptodate page flags. The removal of nfs_wb_page() call also fixes a readahead bug: the NFS readahead has been synchronous since 2.6.23, because that call will clear PG_readahead, which is the reminder for asynchronous readahead. More background: the PG_readahead page flag is shared with PG_reclaim, one for read path and the other for write path. clear_page_dirty_for_io() unconditionally clears PG_readahead to prevent possible readahead residuals, assuming itself to be always called in the write path. However, NFS is one and the only exception in that it _always_ calls clear_page_dirty_for_io() in the read path, i.e. for readpages()/readpage(). Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Wu Fengguang <wfg@linux.intel.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-05-16nfs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-04-19NFS: Ensure that rpc_run_task() errors are propagated back to the callerTrond Myklebust
