path: root/fs/nfs/pnfs.c
2015-07-28nfs: plug memory leak when ->prepare_layoutcommit failsJeff Layton
"data" is currently leaked when the prepare_layoutcommit operation returns an error. Put the cred before taking the spinlock in that case, take the lock and then goto out_unlock which will drop the lock and then free "data". Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-07-11pNFS: Don't throw out valid layout segmentsTrond Myklebust
It is OK for layout segments to remain hashed even if no-one holds any references to them, provided that the segments are still valid. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-07-11pNFS: pnfs_roc_drain() fix a race with openTrond Myklebust
If a process reopens the file before we can send off the CLOSE/DELEGRETURN, then pnfs_roc_drain() may end up waiting for a new set of layout segments that are marked as return-on-close, but haven't yet been returned. Fix this by only waiting for those layout segments that were invalidated in pnfs_roc(). Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-07-11pNFS: Fix races between return-on-close and layoutreturn.Trond Myklebust
If one or more of the layout segments reports an error during I/O, then we may have to send a layoutreturn to report the error back to the NFS metadata server. This patch ensures that the return-on-close code can detect the outstanding layoutreturn, and not preempt it. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-07-11pNFS: pnfs_roc_drain should return 'true' when sleepingTrond Myklebust
Also clean up the case where we don't find a return-on-close layout segment. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-27NFSv4.2: LAYOUTSTATS is optional to implementTrond Myklebust
Make it so, by checking the return value for NFS4ERR_MOTSUPP and caching the information as a server capability. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-26nfs: provide pnfs_report_layoutstat when NFS42 is disabledPeng Tao
kbuild test robot reported: fs/built-in.o: In function `pnfs_report_layoutstat': >> (.text+0x151a1c): undefined reference to `nfs42_proc_layoutstats_generic' Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-24nfs42: serialize LAYOUTSTATS calls of the same filePeng Tao
There is no need to report concurrently. Reviewed-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-24pnfs: add pnfs_report_layoutstat helper functionPeng Tao
2015-06-17NFS: Ensure we set NFS_CONTEXT_RESEND_WRITES when requeuing writesTrond Myklebust
If a write attempt fails, and the write is queued up for resending to the server, as opposed to being dropped, then we need to set the appropriate flag so that nfs_file_fsync() does the right thing. Cc: stable@vger.kernel.org Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-17pNFS: Fix a memory leak when attempted pnfs failsTrond Myklebust
pnfs_do_write() expects the call to pnfs_write_through_mds() to free the pgio header and to release the layout segment before exiting. The problem is that nfs_pgio_data_destroy() doesn't actually do this; it only frees the memory allocated by nfs_generic_pgio(). Ditto for pnfs_do_read()... Fix in both cases is to add a call to hdr->release(hdr). Cc: stable@vger.kernel.org Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-04-23Merge branch 'bugfixes'Trond Myklebust
* bugfixes: NFSv4: Return delegations synchronously in evict_inode SUNRPC: Fix a regression when reconnecting NFS: remount with security change should return EINVAL nfs: do not export discarded symbols NFSv4.1: don't export static symbol
2015-03-27NFSv4.1/pnfs: Separate out metadata and data consistency for pNFSTrond Myklebust
The LAYOUTCOMMIT operation means different things to different layout types. For blocks and objects, it is both a data and metadata consistency operation. For files and flexfiles, it is only a metadata consistency operation. This patch separates out the 2 cases, allowing the files/flexfiles layout drivers to optimise away the data consistency calls to layoutcommit. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-03-27NFSv4.1/pnfs: Ensure we send layoutcommit before return-on-closeTrond Myklebust
We must not send a close or delegreturn that would result in a return-on-close of the layout without ensuring that we've also sent the necessary layoutcommit. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-03-27NFSv4.1/pnfs: Refactor pnfs_set_layoutcommit()Trond Myklebust
pnfs_set_layoutcommit() and pnfs_commit_set_layoutcommit() are 100% identical except for the function arguments. Refactor to eliminate the difference. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-03-27NFSv4.1/pnfs: Fix setting of layoutcommit last write byteTrond Myklebust
If the NFS_INO_LAYOUTCOMMIT flag was unset, then we _must_ ensure that we also reset the last write byte (lwb) for that layout. The current code depends on us clearing the lwb when we clear NFS_INO_LAYOUTCOMMIT, which is not the case when we call pnfs_clear_layoutcommit(). Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-03-12NFSv4.1: don't export static symbolJulia Lawall
The semantic patch that fixes this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ type T; identifier f; @@ static T f (...) { ... } @@ identifier r.f; declarer name EXPORT_SYMBOL_GPL; @@ -EXPORT_SYMBOL_GPL(f); // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-02-10pnfs: delete an unintended gotoDan Carpenter
There was an extra goto here where it shouldn't be, because of a merge error. Fixes: e2c63e091e29 ('Merge branch 'flexfiles'') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-02-05NFSv4.1: Fix pnfs_put_lseg racesTrond Myklebust
pnfs_layoutreturn_free_lseg_async() can also race with inode put in the general case. We can now fix this, and also simplify the code. Cc: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-02-05NFSv4.1: pnfs_send_layoutreturn should use GFP_NOFSTrond Myklebust
In we want to be able to call pnfs_send_layoutreturn() from within the writeback path, we really want it to use GFP_NOFS in order to prevent recursion. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-02-03Merge branch 'flexfiles'Trond Myklebust
* flexfiles: (53 commits) pnfs: lookup new lseg at lseg boundary nfs41: .init_read and .init_write can be called with valid pg_lseg pnfs: Update documentation on the Layout Drivers pnfs/flexfiles: Add the FlexFile Layout Driver nfs: count DIO good bytes correctly with mirroring nfs41: wait for LAYOUTRETURN before retrying LAYOUTGET nfs: add a helper to set NFS_ODIRECT_RESCHED_WRITES to direct writes nfs41: add NFS_LAYOUT_RETRY_LAYOUTGET to layout header flags nfs/flexfiles: send layoutreturn before freeing lseg nfs41: introduce NFS_LAYOUT_RETURN_BEFORE_CLOSE nfs41: allow async version layoutreturn nfs41: add range to layoutreturn args pnfs: allow LD to ask to resend read through pnfs nfs: add nfs_pgio_current_mirror helper nfs: only reset desc->pg_mirror_idx when mirroring is supported nfs41: add a debug warning if we destroy an unempty layout pnfs: fail comparison when bucket verifier not set nfs: mirroring support for direct io nfs: add mirroring support to pgio layer pnfs: pass ds_commit_idx through the commit path ... Conflicts: fs/nfs/pnfs.c fs/nfs/pnfs.h
2015-02-03pnfs: lookup new lseg at lseg boundaryWeston Andros Adamson
Before mirroring support was added, the pageio descriptor's pg_lseg was set to null when an RPC was sent. Because of this, pg_init was called at lseg boundaries with pg_lseg = NULL, and it could be set to the new lseg. Signed-off-by: Weston Andros Adamson <dros@primarydata.com>
2015-02-03nfs41: .init_read and .init_write can be called with valid pg_lsegPeng Tao
With pgio refactoring in v3.15, .init_read and .init_write can be called with valid pgio->pg_lseg. file layout was fixed at that time by commit c6194271f (pnfs: filelayout: support non page aligned layouts). But the generic helper still needs to be fixed. Cc: stable@vger.kernel.org # 3.15+ Signed-off-by: Peng Tao <tao.peng@primarydata.com>
2015-02-03pnfs/flexfiles: Add the FlexFile Layout DriverTom Haynes
The flexfile layout is a new layout that extends the file layout. It is currently being drafted as a specification at https://datatracker.ietf.org/doc/draft-ietf-nfsv4-layout-types/ Signed-off-by: Weston Andros Adamson <dros@primarydata.com> Signed-off-by: Tom Haynes <loghyr@primarydata.com> Signed-off-by: Tao Peng <bergwolf@primarydata.com>
2015-02-03nfs41: wait for LAYOUTRETURN before retrying LAYOUTGETPeng Tao
Also take care to stop waiting if someone clears retry bit. Signed-off-by: Peng Tao <tao.peng@primarydata.com>
2015-02-03nfs41: add NFS_LAYOUT_RETRY_LAYOUTGET to layout header flagsPeng Tao
Use it to indicate that LD wants to retry layoutget. LD can set it whenever it wants the common pnfs code to return and retry pnfs path through a new layout. The bit gets cleared when client does a new layoutget, when client closes the file (ROC case), or when kernel needs to evict the inode (non-ROC case). Signed-off-by: Peng Tao <tao.peng@primarydata.com>
2015-02-03nfs/flexfiles: send layoutreturn before freeing lsegPeng Tao
Otherwise we'll lose error tracking information when encoding layoutreturn. pnfs_put_lseg may be called from rpc callbacks. So we should not call pnfs_send_layoutreturn directly because it can deadlock in the rpc layer. Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Tom Haynes <loghyr@primarydata.com>
2015-02-03nfs41: introduce NFS_LAYOUT_RETURN_BEFORE_CLOSEPeng Tao
When it is set, generic pnfs would try to send layoutreturn right before last close/delegation_return regard less NFS_LAYOUT_ROC is set or not. LD can then make sure layoutreturn is always sent rather than being omitted. The difference against NFS_LAYOUT_RETURN is that NFS_LAYOUT_RETURN_BEFORE_CLOSE does not block usage of the layout so LD can set it and expect generic layer to try pnfs path at the same time. Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Tom Haynes <loghyr@primarydata.com>
2015-02-03nfs41: allow async version layoutreturnPeng Tao
2015-02-03nfs41: add range to layoutreturn argsPeng Tao
So that callers can specify which range to return. Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Tom Haynes <loghyr@primarydata.com>
2015-02-03pnfs: allow LD to ask to resend read through pnfsPeng Tao
If current IO cannot be completed due to some transient errors, LD may want to ask generic layer to resend the request through pnfs again. Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Tom Haynes <loghyr@primarydata.com>
2015-02-03nfs: add nfs_pgio_current_mirror helperPeng Tao
Let it return current nfs_pgio_mirror in use depending on pg_mirror_count. For read, we always use pg_mirrors[0], so this effectively gives us freedom to use pg_mirror_idx to track the actual mirror to read from through out the IO stack. Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Tom Haynes <loghyr@primarydata.com>
2015-02-03nfs41: add a debug warning if we destroy an unempty layoutPeng Tao
So that we can detect the case if some layout segments are still pinned which is surely a bug that we need to fix. Signed-off-by: Peng Tao <tao.peng@primarydata.com>
2015-02-03nfs: add mirroring support to pgio layerWeston Andros Adamson
This patch adds mirrored write support to the pgio layer. The default is to use one mirror, but pgio callers may define callbacks to change this to any value up to the (arbitrarily selected) limit of 16. The basic idea is to break out members of nfs_pageio_descriptor that cannot be shared between mirrored DSes and put them in a new structure. Signed-off-by: Weston Andros Adamson <dros@primarydata.com>
2015-02-03pnfs: release lseg in pnfs_generic_pg_cleanupWeston Andros Adamson
This is needed to support mirrored writes - the first write can't just trash the lseg, we need to keep it around until all mirrors have written. Signed-off-by: Weston Andros Adamson <dros@primarydata.com>
2015-02-03nfs41: clear NFS_LAYOUT_RETURN if layoutreturn is sent or failed to sendPeng Tao
So that pnfs path is not disabled for ever. Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Tom Haynes <Thomas.Haynes@primarydata.com>
2015-02-03nfs41: send layoutreturn in last put_lsegPeng Tao
If current lseg is the last lseg marked with NFS_LSEG_LAYOUTRETURN, send layoutreturn. Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Tom Haynes <Thomas.Haynes@primarydata.com>
2015-02-03nfs41: don't use a layout if it is marked for returningPeng Tao
And if we are to return the same type of layouts, don't bother sending more layoutgets. Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Tom Haynes <Thomas.Haynes@primarydata.com>
2015-02-03nfs41: add a helper to mark layout for returnPeng Tao
It marks all matching layout segments as NFS_LSEG_LAYOUTRETURN, which is an indicator for pnfs_put_lseg() to send layoutreturn, and also prevents pnfs_update_layout() from using the returning segments. Once it is set, it never gets cleared. It also sets proper io failure bit so that pnfs path can be retried after PNFS_LAYOUTGET_RETRY_TIMEOUT second. Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Tom Haynes <Thomas.Haynes@primarydata.com>
2015-02-03nfs41: make a helper function to send layoutreturnPeng Tao
It allows to specify different iomode to return. Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Tom Haynes <Thomas.Haynes@primarydata.com>
2015-02-03nfs41: pass iomode through layoutreturn argsPeng Tao
So that it is possible to return a specific iomode layouts. Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Tom Haynes <Thomas.Haynes@primarydata.com>
2015-02-03nfs41: serialize first layoutget of a filePeng Tao
Per RFC 5661 Errata 3208: | A client MAY always forget its layout state and associated | layout stateid at any time (See also section 12.5.5.1). | In such case, the client MUST use a non-layout stateid for the next | LAYOUTGET operation. This will signal the server that the client has | no more layouts on the file and its respective layout state can be | released before issuing a new layout in response to LAYOUTGET. In order to make such a signal unique to server, client needs to serialize all layoutgets using non-layout stateid. We implement this by serializing layoutgets when client has no layout segments at hand. Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Tom Haynes <Thomas.Haynes@primarydata.com>
2015-02-03nfs41: close a small race window when adding new layout to global listPeng Tao
2015-02-03nfs/flexclient: export pnfs_layoutcommit_inodePeng Tao
flexfiles needs to start layoutcommit when necessary Signed-off-by: Peng Tao <tao.peng@primarydata.com>
2015-01-24NFSv4.1: Optimise layout return-on-closeTrond Myklebust
Optimise the layout return on close code by ensuring that 1) Add a check for whether we hold a layout before taking any spinlocks 2) Only take the spin lock once 3) Use nfs_state->state to speed up open file checks Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-10-08NFSv4.1/pnfs: replace broken pnfs_put_lseg_asyncTrond Myklebust
You cannot call pnfs_put_lseg_async() more than once per lseg, so it is really an inappropriate way to deal with a refcount issue. Instead, replace it with a function that decrements the refcount, and puts the final 'free' operation (which is incompatible with locks) on the workqueue. Cc: Weston Andros Adamson <dros@primarydata.com> Fixes: e6cf82d1830f: pnfs: add pnfs_put_lseg_async Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-09-10pnfs: add return_range methodChristoph Hellwig
If a layout driver keeps per-inode state outside of the layout segments it needs to be notified of any layout returns or recalls on an inode, and not just about the freeing of layout segments. Add a method to acomplish this, which will allow the block layout driver to handle the case of truncated and re-expanded files properly. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-09-10pnfs: force a layout commit when encountering busy segments during recallChristoph Hellwig
Expedite layout recall processing by forcing a layout commit when we see busy segments. Without it the layout recall might have to wait until the VM decided to start writeback for the file, which can introduce long delays. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-09-10pnfs: allow splicing pre-encoded pages into the layoutcommit argsChristoph Hellwig
Currently there is no XDR buffer space allocated for the per-layout driver layoutcommit payload, which leads to server buffer overflows in the blocklayout driver even under simple workloads. As we can't do per-layout sizes for XDR operations we'll have to splice a previously encoded list of pages into the XDR stream, similar to how we handle ACL buffers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-09-10pnfs: avoid using stale stateids after layoutreturnChristoph Hellwig
After we issued a layoutreturn operations the may free the layout stateid and will thus cause bad stateid error when the client uses it again. We currently try to avoid this case by chosing the open stateid if not lsegs are present for this inode. But various places can hold refererence on lsegs and thus cause the list not to be empty shortly after a layout return. Add an explicit flag to mark the current layout stateid invalid and force usage of the openstateid after we did a full file layoutreturn. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
