path: root/fs/nfs/nfsroot.c
2006-01-08[PATCH] nfsroot: do not silently stop parsing on an unknown optionJorn Dreyer
It would be helpful if the kernel did not silently stop parsing nfs options, but instead warned about any he does not recognize. The attached patch adds one printk to do just that. It took me a couple of hours to find my configuration mistake. Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06NFS: support large reads and writes on the wireChuck Lever
Most NFS server implementations allow up to 64KB reads and writes on the wire. The Solaris NFS server allows up to a megabyte, for instance. Now the Linux NFS client supports transfer sizes up to 1MB, too. This will help reduce protocol and context switch overhead on read/write intensive NFS workloads, and support larger atomic read and write operations on servers that support them. Test-plan: Connectathon and iozone on mount point with wsize=rsize>32768 over TCP. Tests with NFS over UDP to verify the maximum RPC payload size cap. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Add support for NFSv3 ACLsAndreas Gruenbacher
This adds acl support fo nfs clients via the NFSACL protocol extension, by implementing the getxattr, listxattr, setxattr, and removexattr iops for the system.posix_acl_access and system.posix_acl_default attributes. This patch implements a dumb version that uses no caching (and thus adds some overhead). (Another patch in this patchset adds caching as well.) Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Olaf Kirch <okir@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
