path: root/fs/nfs/nfs4filelayoutdev.c
2011-03-11NFSv4.1: turn off pNFS on ds connection failureAndy Adamson
If a data server is unavailable, go through MDS. Mark the deviceid containing the data server as a negative cache entry. Do not try to connect to any data server on a deviceid marked as a negative cache entry. Mark any layout that tries to use the marked deviceid as failed. Inodes with a layout marked as fails will not use the layout for I/O, and will not perform any more layoutgets. Inodes without a layout will still do layoutget, but the layout will get marked immediately. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1 move deviceid cache to filelayout driverChristoph Hellwig
No need for generic cache with only one user. Keep a simple hash of deviceids in the filelayout driver. Signed-off-by: Christoph Hellwig <hch@infradead.org> Acked-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: filelayout i/o helpersFred Isaman
Prepare for filelayout_read_pagelist with helper functions that find the correct data server, filehandle, and offset. Signed-off-by: Andy Adamson <andros@citi.umich.edu> Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: Mike Sager <sager@netapp.com> Signed-off-by: Oleg Drokin <green@linuxhacker.ru> Signed-off-by: Tao Guo <guotao@nrchpc.ac.cn> Signed-off-by: Tigran Mkrtchyan <tigran@anahit.desy.de> Signed-off-by: Tigran Mkrtchyan <tigran.mkrtchyan@desy.de> Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: data server connectionAndy Adamson
Introduce a data server set_client and init session following the nfs4_set_client and nfs4_init_session convention. Once a new nfs_client is on the nfs_client_list, the nfs_client cl_cons_state serializes access to creating an nfs_client struct with matching properties. Use the new nfs_get_client() that initializes new clients. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-10nfs: add kmalloc return value check in decode_and_add_dsStanislav Fomichev
add kmalloc return value check in decode_and_add_ds Signed-off-by: Stanislav Fomichev <kernel@fomichev.me> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-25NFS4: Avoid potential NULL pointer dereference in decode_and_add_ds().Jesper Juhl
On Mon, 17 Jan 2011, Mi Jinlong wrote: > > > Jesper Juhl: > > strrchr() can return NULL if nothing is found. If this happens we'll > > dereference a NULL pointer in > > fs/nfs/nfs4filelayoutdev.c::decode_and_add_ds(). > > > > I tried to find some other code that guarantees that this can never > > happen but I was unsuccessful. So, unless someone else can point to some > > code that ensures this can never be a problem, I believe this patch is > > needed. > > > > While I was changing this code I also noticed that all the dprintk() > > statements, except one, start with "%s:". The one missing the ":" I added > > it to. > > Maybe another one also should be changed at decode_and_add_ds() at line 243: > > 243 printk("%s Decoded address and port %s\n", __func__, buf); > Missed that one. Thanks. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-24NFSv4.1: pnfs: filelayout: add driver's LAYOUTGET and GETDEVICEINFO ↵Andy Adamson
infrastructure Implement the driver's io_ops->alloc_lseg and free_lseg functions, which integrate into the deviceid cache and calls out to nfs4_proc_getdeviceinfo when necessary. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Dean Hildebrand <dhildebz@umich.edu> Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: Mike Sager <sager@netapp.com> Signed-off-by: Oleg Drokin <green@linuxhacker.ru> Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com> Signed-off-by: Tao Guo <guotao@nrchpc.ac.cn> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
