path: root/fs/nfs/internal.h
2009-04-03NFS: Add mount options to enable local caching on NFSDavid Howells
Add NFS mount options to allow the local caching support to be enabled. The attached patch makes it possible for the NFS filesystem to be told to make use of the network filesystem local caching service (FS-Cache). To be able to use this, a recent nfsutils package is required. There are three variant NFS mount options that can be added to a mount command to control caching for a mount. Only the last one specified takes effect: (*) Adding "fsc" will request caching. (*) Adding "fsc=<string>" will request caching and also specify a uniquifier. (*) Adding "nofsc" will disable caching. For example: mount warthog:/ /a -o fsc The cache of a particular superblock (NFS FSID) will be shared between all mounts of that volume, provided they have the same connection parameters and are not marked 'nosharecache'. Where it is otherwise impossible to distinguish superblocks because all the parameters are identical, but the 'nosharecache' option is supplied, a uniquifying string must be supplied, else only the first mount will be permitted to use the cache. If there's a key collision, then the second mount will disable caching and give a warning into the kernel log. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03NFS: Define and create superblock-level objectsDavid Howells
Define and create superblock-level cache index objects (as managed by nfs_server structs). Each superblock object is created in a server level index object and is itself an index into which inode-level objects are inserted. Ideally there would be one superblock-level object per server, and the former would be folded into the latter; however, since the "nosharecache" option exists this isn't possible. The superblock object key is a sequence consisting of: (1) Certain superblock s_flags. (2) Various connection parameters that serve to distinguish superblocks for sget(). (3) The volume FSID. (4) The security flavour. (5) The uniquifier length. (6) The uniquifier text. This is normally an empty string, unless the fsc=xyz mount option was used to explicitly specify a uniquifier. The key blob is of variable length, depending on the length of (6). The superblock object is given no coherency data to carry in the auxiliary data permitted by the cache. It is assumed that the superblock is always coherent. This patch also adds uniquification handling such that two otherwise identical superblocks, at least one of which is marked "nosharecache", won't end up trying to share the on-disk cache. It will be possible to manually provide a uniquifier through a mount option with a later patch to avoid the error otherwise produced. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-03-19NFS: Optimise NFS close()Trond Myklebust
Close-to-open cache consistency rules really only require us to flush out writes on calls to close(), and require us to revalidate attributes on the very last close of the file. Currently we appear to be doing a lot of extra attribute revalidation and cache flushes. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-11NFS: Throttle page dirtying while we're flushing to diskTrond Myklebust
The following patch is a combination of a patch by myself and Peter Staubach. Trond: If we allow other processes to dirty pages while a process is doing a consistency sync to disk, we can end up never making progress. Peter: Attached is a patch which addresses a continuing problem with the NFS client generating out of order WRITE requests. While this is compliant with all of the current protocol specifications, there are servers in the market which can not handle out of order WRITE requests very well. Also, this may lead to sub-optimal block allocations in the underlying file system on the server. This may cause the read throughputs to be reduced when reading the file from the server. Peter: There has been a lot of work recently done to address out of order issues on a systemic level. However, the NFS client is still susceptible to the problem. Out of order WRITE requests can occur when pdflush is in the middle of writing out pages while the process dirtying the pages calls generic_file_buffered_write which calls generic_perform_write which calls balance_dirty_pages_rate_limited which ends up calling writeback_inodes which ends up calling back into the NFS client to writes out dirty pages for the same file that pdflush happens to be working with. Signed-off-by: Peter Staubach <staubach@redhat.com> [modification by Trond to merge the two similar patches] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFS: "[no]resvport" mount option changes mountd client tooChuck Lever
If the admin has specified the "noresvport" option for an NFS mount point, the kernel's NFS client uses an unprivileged source port for the main NFS transport. The kernel's mountd client should use an unprivileged port in this case as well. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFS: introduce nfs_mount_info struct for calling nfs_mount()Chuck Lever
Clean up: convert nfs_mount() to take a single data structure argument to make it simpler to add more arguments. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFS: Move declaration of nfs_mount() to fs/nfs/internal.hChuck Lever
Clean up: The nfs_mount() function is not to be used outside of the NFS client. Move its public declaration to fs/nfs/internal.h. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-10NFS: Cleanup nfs_set_portJ. Bruce Fields
Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-07nfs: Fix misparsing of nfsv4 fs_locations attributeJ. Bruce Fields
The code incorrectly assumes here that the server name (or ip address) is null-terminated. This can cause referrals to fail in some cases. Also support ipv6 addresses. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-07nfs: prepare to share nfs_set_portJ. Bruce Fields
We plan to use this function elsewhere. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-06NFS: Clean up nfs_sb_active/nfs_sb_deactiveTrond Myklebust
Instead of causing umount requests to block on server->active_wq while the asynchronous sillyrename deletes are executing, we can use the sb->s_active counter to obtain a reference to the super_block, and then release that reference in nfs_async_unlink_release(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09NFS: Ensure we zap only the access and acl caches when setting new aclsTrond Myklebust
...and ensure that we obey the NFS_INO_INVALID_ACL flag when retrieving the acls. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-19NFS: Always enable NFS direct I/OChuck Lever
Since O_DIRECT is a standard feature that is enabled in most distros, eliminate the CONFIG_NFS_DIRECTIO build option, and change the fs/nfs/Makefile to always build in the NFS direct I/O engine. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-19NFS: Save the value of the "port=" mount optionChuck Lever
During a remount based on the mount options displayed in /proc/mounts, we want to preserve the original behavior of the mount request. Let's save the original setting of the "port=" mount option in the mount's nfs_server structure. This allows us to simplify the default behavior of port setting for NFSv4 mounts: by default, NFSv2/3 mounts first try an RPC bind to determine the NFS server's port, unless the user specified the "port=" mount option; Users can force the client to skip the RPC bind by explicitly specifying "port=<value>". NFSv4, by contrast, assumes the NFS server port is 2049 and skips the RPC bind, unless the user specifies "port=". Users can force an RPC bind for NFSv4 by explicitly specifying "port=0". I added a couple of extra comments to clarify this behavior. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-19NFS: Fix up data types of fields in nfs_parsed_mount_optionsChuck Lever
Clean up: make data types of fields in nfs_parsed_mount_options more consistent with other uses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-08Merge commit 'origin' into develTrond Myklebust
2008-03-06NFS: use new LSM interfaces to explicitly set mount optionsEric Paris
NFS and SELinux worked together previously because SELinux had NFS specific knowledge built in. This design was approved by both groups back in 2004 but the recent NFS changes to use nfs_parsed_mount_data and the usage of nfs_clone_mount_data showed this to be a poor fragile solution. This patch fixes the NFS functionality regression by making use of the new LSM interfaces to allow an FS to explicitly set its own mount options. The explicit setting of mount options is done in the nfs get_sb functions which are called before the generic vfs hooks try to set mount options for filesystems which use text mount data. This does not currently support NFSv4 as that functionality did not exist in previous kernels and thus there is no regression. I will be adding the needed code, which I believe to be the exact same as the v3 code, in nfs4_get_sb for 2.6.26. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-02-25NFS: Add an nfsiod workqueueTrond Myklebust
NFS post-rpciod cleanups often involve tasks that cannot be safely performed within the rpciod context (due to deadlock concerns). We therefore add a dedicated NFS workqueue that can perform tasks like cleaning up state after an interrupted NFSv4 open() call, or calling put_nfs_open_context() after an asynchronous read or write call. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFSv4: Iterate through all nfs_clients when the server recalls a delegationTrond Myklebust
The same delegation may have been handed out to more than one nfs_client. Ensure that if a recall occurs, we return all instances. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Support non-IPv4 addresses in nfs_parsed_mount_dataChuck Lever
Replace the nfs_server and mount_server address fields in the nfs_parsed_mount_data structure with a "struct sockaddr_storage" instead of a "struct sockaddr_in". Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Adjust nfs_clone_mount structure to store "struct sockaddr *"Chuck Lever
Change the addr field in the nfs_clone_mount structure to store a "struct sockaddr *" to support non-IPv4 addresses in the NFS client. Note this is mostly a cosmetic change, and does not actually allow referrals using IPv6 addresses. The existing referral code assumes that the server returns a string that represents an IPv4 address. This code needs to support hostnames and IPv6 addresses as well as IPv4 addresses, thus it will need to be reorganized completely (to handle DNS resolution in user space). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Change nfs_find_client() to take "struct sockaddr *"Chuck Lever
Adjust arguments and callers of nfs_find_client() to pass a "struct sockaddr *" instead of "struct sockaddr_in *" to support non-IPv4 addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Trond: Also fix up protocol version number argument in nfs_find_client() to use the correct u32 type. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Remove support for the 'mountprog' optionChuck Lever
Remove the mount option that allows users to specify an alternate mountd program number. The client hasn't support setting an alternate mountd program number for a very long time. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Remove support for the 'nfsprog' optionChuck Lever
Remove the mount option that allows users to specify an alternate NFS program number. The client hasn't support setting an alternate NFS program number for a very long time. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Stop sillyname renames and unmounts from racingSteve Dickson
Added an active/deactive mechanism to the nfs_server structure allowing async operations to hold off umount until the operations are done. Signed-off-by: Steve Dickson <steved@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: use in-kernel mount argument structure for nfsv4 mounts\"Talpey, Thomas\
The user-visible nfs4_mount_data does not contain sufficient data to describe new mount options, and also is now a legacy structure. Replace it with the internal nfs_parsed_mount_data for nfsv4 in-kernel use. Signed-off-by: Tom Talpey <tmt@netapp.com> Acked-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: use in-kernel mount argument structure for nfsv[23] mounts\"Talpey, Thomas\
The user-visible nfs_mount_data does not contain sufficient data to describe new mount options, and also is now a legacy structure. Replace it with the internal nfs_parsed_mount_data for nfsv[23] in-kernel use. Signed-off-by: Tom Talpey <tmt@netapp.com> Acked-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: move nfs_parsed_mount_data structure definition\"Talpey, Thomas\
In preparation for rearranging the nfs mount argument passing, make the nfs_parsed_mount_data struct visible across nfs kernel files. Signed-off-by: Tom Talpey <tmt@netapp.com> Acked-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10NFS: Clean-up: use correct type when converting NFS blocks to local blocksChuck Lever
inode->i_blocks is a blkcnt_t these days, which can be a u64 or unsigned long, depending on the setting of CONFIG_LSF. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30NFS: Fix a buffer overflow in the allocation of struct nfs_read/writedataTrond Myklebust
2007-02-03NFSv4: Cleanups for fs_locations code.Trond Myklebust
Start long arduous project... What the hell is struct dentry = {}; all about? Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-12-06NFS: Cleanup: add common helper nfs_page_length()Trond Myklebust
Clean up a lot of ad-hoc page length calculations in fs/nfs/write.c Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-10-20[PATCH] xdr annotations: NFS readdir entriesAl Viro
on-the-wire data is big-endian [in large part pulled from Alexey's patch] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22NFS: Add server and volume lists to /procDavid Howells
Make two new proc files available: /proc/fs/nfsfs/servers /proc/fs/nfsfs/volumes The first lists the servers with which we are currently dealing (struct nfs_client), and the second lists the volumes we have on those servers (struct nfs_server). Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Share NFS superblocks per-protocol per-server per-FSIDDavid Howells
The attached patch makes NFS share superblocks between mounts from the same server and FSID over the same protocol. It does this by creating each superblock with a false root and returning the real root dentry in the vfsmount presented by get_sb(). The root dentry set starts off as an anonymous dentry if we don't already have the dentry for its inode, otherwise it simply returns the dentry we already have. We may thus end up with several trees of dentries in the superblock, and if at some later point one of anonymous tree roots is discovered by normal filesystem activity to be located in another tree within the superblock, the anonymous root is named and materialises attached to the second tree at the appropriate point. Why do it this way? Why not pass an extra argument to the mount() syscall to indicate the subpath and then pathwalk from the server root to the desired directory? You can't guarantee this will work for two reasons: (1) The root and intervening nodes may not be accessible to the client. With NFS2 and NFS3, for instance, mountd is called on the server to get the filehandle for the tip of a path. mountd won't give us handles for anything we don't have permission to access, and so we can't set up NFS inodes for such nodes, and so can't easily set up dentries (we'd have to have ghost inodes or something). With this patch we don't actually create dentries until we get handles from the server that we can use to set up their inodes, and we don't actually bind them into the tree until we know for sure where they go. (2) Inaccessible symbolic links. If we're asked to mount two exports from the server, eg: mount warthog:/warthog/aaa/xxx /mmm mount warthog:/warthog/bbb/yyy /nnn We may not be able to access anything nearer the root than xxx and yyy, but we may find out later that /mmm/www/yyy, say, is actually the same directory as the one mounted on /nnn. What we might then find out, for example, is that /warthog/bbb was actually a symbolic link to /warthog/aaa/xxx/www, but we can't actually determine that by talking to the server until /warthog is made available by NFS. This would lead to having constructed an errneous dentry tree which we can't easily fix. We can end up with a dentry marked as a directory when it should actually be a symlink, or we could end up with an apparently hardlinked directory. With this patch we need not make assumptions about the type of a dentry for which we can't retrieve information, nor need we assume we know its place in the grand scheme of things until we actually see that place. This patch reduces the possibility of aliasing in the inode and page caches for inodes that may be accessed by more than one NFS export. It also reduces the number of superblocks required for NFS where there are many NFS exports being used from a server (home directory server + autofs for example). This in turn makes it simpler to do local caching of network filesystems, as it can then be guaranteed that there won't be links from multiple inodes in separate superblocks to the same cache file. Obviously, cache aliasing between different levels of NFS protocol could still be a problem, but at least that gives us another key to use when indexing the cache. This patch makes the following changes: (1) The server record construction/destruction has been abstracted out into its own set of functions to make things easier to get right. These have been moved into fs/nfs/client.c. All the code in fs/nfs/client.c has to do with the management of connections to servers, and doesn't touch superblocks in any way; the remaining code in fs/nfs/super.c has to do with VFS superblock management. (2) The sequence of events undertaken by NFS mount is now reordered: (a) A volume representation (struct nfs_server) is allocated. (b) A server representation (struct nfs_client) is acquired. This may be allocated or shared, and is keyed on server address, port and NFS version. (c) If allocated, the client representation is initialised. The state member variable of nfs_client is used to prevent a race during initialisation from two mounts. (d) For NFS4 a simple pathwalk is performed, walking from FH to FH to find the root filehandle for the mount (fs/nfs/getroot.c). For NFS2/3 we are given the root FH in advance. (e) The volume FSID is probed for on the root FH. (f) The volume representation is initialised from the FSINFO record retrieved on the root FH. (g) sget() is called to acquire a superblock. This may be allocated or shared, keyed on client pointer and FSID. (h) If allocated, the superblock is initialised. (i) If the superblock is shared, then the new nfs_server record is discarded. (j) The root dentry for this mount is looked up from the root FH. (k) The root dentry for this mount is assigned to the vfsmount. (3) nfs_readdir_lookup() creates dentries for each of the entries readdir() returns; this function now attaches disconnected trees from alternate roots that happen to be discovered attached to a directory being read (in the same way nfs_lookup() is made to do for lookup ops). The new d_materialise_unique() function is now used to do this, thus permitting the whole thing to be done under one set of locks, and thus avoiding any race between mount and lookup operations on the same directory. (4) The client management code uses a new debug facility: NFSDBG_CLIENT which is set by echoing 1024 to /proc/net/sunrpc/nfs_debug. (5) Clone mounts are now called xdev mounts. (6) Use the dentry passed to the statfs() op as the handle for retrieving fs statistics rather than the root dentry of the superblock (which is now a dummy). Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Eliminate client_sys in favour of cl_rpcclientDavid Howells
Eliminate nfs_server::client_sys in favour of nfs_client::cl_rpcclient as we only really need one per server that we're talking to since it doesn't have any security on it. The retransmission management variables are also moved to the common struct as they're required to set up the cl_rpcclient connection. The NFS2/3 client and client_acl connections are thenceforth derived by cloning the cl_rpcclient connection and post-applying the authorisation flavour. The code for setting up the initial common connection has been moved to client.c as nfs_create_rpc_client(). All the NFS program definition tables are also moved there as that's where they're now required rather than super.c. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Generalise the nfs_client structureDavid Howells
Generalise the nfs_client structure by: (1) Moving nfs_client to a more general place (nfs_fs_sb.h). (2) Renaming its maintenance routines to be non-NFS4 specific. (3) Move those maintenance routines to a new non-NFS4 specific file (client.c) and move the declarations to internal.h. (4) Make nfs_find/get_client() take a full sockaddr_in to include the port number (will be required for NFS2/3). (5) Make nfs_find/get_client() take the NFS protocol version (again will be required to differentiate NFS2, 3 & 4 client records). Also: (6) Make nfs_client construction proceed akin to inodes, marking them as under construction and providing a function to indicate completion. (7) Make nfs_get_client() wait interruptibly if it finds a client that it can share, but that client is currently being constructed. (8) Make nfs4_create_client() use (6) and (7) instead of locking cl_sem. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Fix up split of fs/nfs/inode.cDavid Howells
Fix ups for the splitting of the superblock stuff out of fs/nfs/inode.c, including: (*) Move the callback tcpport module param into callback.c. (*) Move the idmap cache timeout module param into idmap.c. (*) Changes to internal.h: (*) namespace-nfs4.c was renamed to nfs4namespace.c. (*) nfs_stat_to_errno() is in nfs2xdr.c, not nfs4xdr.c. (*) nfs4xdr.c is contingent on CONFIG_NFS_V4. (*) nfs4_path() is only uses if CONFIG_NFS_V4 is set. Plus also: (*) The sec_flavours[] table should really be const. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Add an ACCESS cache memory shrinkerTrond Myklebust
A pinned inode may in theory end up filling memory with cached ACCESS calls. This patch ensures that the VM may shrink away the cache in these particular cases. The shrinker works by iterating through the list of inodes on the global nfs_access_lru_list, and removing the least recently used access cache entry until it is done (or until the entire cache is empty). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-07-02[PATCH] nfs: non-procfs build fixDominik Hackl
This fixes a bug in fs/nfs which makes it impossible to build nfs without having procfs enabled. Signed-off-by: Dominik Hackl <dominik@hackl.dhs.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] fix static linking of NFSDavid Brownell
Builds on ARM report link problems with common configurations like statically linked NFS (for nfsroot). The symptom is that __init section code references __exit section code; that won't work since the exit sections are discarded (since they can never be called). The best fix for these particular cases would be an "__init_or_exit" section annotation. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25git-nfs-build-fixesAndrew Morton
Fix various problems with nfs4 disabled. And various other things. In file included from fs/nfs/inode.c:50: fs/nfs/internal.h:24: error: static declaration of 'nfs_do_refmount' follows non-static declaration include/linux/nfs_fs.h:320: error: previous declaration of 'nfs_do_refmount' was here fs/nfs/internal.h:65: warning: 'struct nfs4_fs_locations' declared inside parameter list fs/nfs/internal.h:65: warning: its scope is only this definition or declaration, which is probably not what you want fs/nfs/internal.h: In function 'nfs4_path': fs/nfs/internal.h:97: error: 'struct nfs_server' has no member named 'mnt_path' fs/nfs/inode.c: In function 'init_once': fs/nfs/inode.c:1116: error: 'struct nfs_inode' has no member named 'open_states' fs/nfs/inode.c:1116: error: 'struct nfs_inode' has no member named 'delegation' fs/nfs/inode.c:1116: error: 'struct nfs_inode' has no member named 'delegation_state' fs/nfs/inode.c:1116: error: 'struct nfs_inode' has no member named 'rwsem' distcc[26452] ERROR: compile fs/nfs/inode.c on g5/64 failed make[1]: *** [fs/nfs/inode.o] Error 1 make: *** [fs/nfs/inode.o] Error 2 make: *** Waiting for unfinished jobs.... In file included from fs/nfs/nfs3xdr.c:26: fs/nfs/internal.h:24: error: static declaration of 'nfs_do_refmount' follows non-static declaration include/linux/nfs_fs.h:320: error: previous declaration of 'nfs_do_refmount' was here fs/nfs/internal.h:65: warning: 'struct nfs4_fs_locations' declared inside parameter list fs/nfs/internal.h:65: warning: its scope is only this definition or declaration, which is probably not what you want fs/nfs/internal.h: In function 'nfs4_path': fs/nfs/internal.h:97: error: 'struct nfs_server' has no member named 'mnt_path' distcc[26486] ERROR: compile fs/nfs/nfs3xdr.c on g5/64 failed make[1]: *** [fs/nfs/nfs3xdr.o] Error 1 make: *** [fs/nfs/nfs3xdr.o] Error 2 In file included from fs/nfs/nfs3proc.c:24: fs/nfs/internal.h:24: error: static declaration of 'nfs_do_refmount' follows non-static declaration include/linux/nfs_fs.h:320: error: previous declaration of 'nfs_do_refmount' was here fs/nfs/internal.h:65: warning: 'struct nfs4_fs_locations' declared inside parameter list fs/nfs/internal.h:65: warning: its scope is only this definition or declaration, which is probably not what you want fs/nfs/internal.h: In function 'nfs4_path': fs/nfs/internal.h:97: error: 'struct nfs_server' has no member named 'mnt_path' distcc[26469] ERROR: compile fs/nfs/nfs3proc.c on bix/32 failed make[1]: *** [fs/nfs/nfs3proc.o] Error 1 make: *** [fs/nfs/nfs3proc.o] Error 2 **FAILED** Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Andreas Gruenbacher <agruen@suse.de> Cc: Andy Adamson <andros@citi.umich.edu> Cc: Chuck Lever <cel@netapp.com> Cc: David Howells <dhowells@redhat.com> Cc: J. Bruce Fields <bfields@fieldses.org> Cc: Manoj Naik <manoj@almaden.ibm.com> Cc: Marc Eshel <eshel@almaden.ibm.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-09NFS: Split fs/nfs/inode.cDavid Howells
As fs/nfs/inode.c is rather large, heterogenous and unwieldy, the attached patch splits it up into a number of files: (*) fs/nfs/inode.c Strictly inode specific functions. (*) fs/nfs/super.c Superblock management functions for NFS and NFS4, normal access, clones and referrals. The NFS4 superblock functions _could_ move out into a separate conditionally compiled file, but it's probably not worth it as there're so many common bits. (*) fs/nfs/namespace.c Some namespace-specific functions have been moved here. (*) fs/nfs/nfs4namespace.c NFS4-specific namespace functions (this could be merged into the previous file). This file is conditionally compiled. (*) fs/nfs/internal.h Inter-file declarations, plus a few simple utility functions moved from fs/nfs/inode.c. Additionally, all the in-.c-file externs have been moved here, and those files they were moved from now includes this file. For the most part, the functions have not been changed, only some multiplexor functions have changed significantly. I've also: (*) Added some extra banner comments above some functions. (*) Rearranged the function order within the files to be more logical and better grouped (IMO), though someone may prefer a different order. (*) Reduced the number of #ifdefs in .c files. (*) Added missing __init and __exit directives. Signed-Off-By: David Howells <dhowells@redhat.com>
