If the client is using NFS v4.1, then we can use SECINFO_NO_NAME to find
the secflavor for the initial mount. If the server doesn't support
SECINFO_NO_NAME then I fall back on the "guess and check" method used
for v4.0 mounts.
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Commit 28331a46d88459788c8fca72dbb0415cd7f514c9 "Ensure we request the
ordinary fileid when doing readdirplus"
changed the meaning of NFS_ATTR_FATTR_FILEID which used to be set when
FATTR4_WORD1_MOUNTED_ON_FILED was requested.
Allow nfs_fhget to succeed with only a mounted on fileid when crossing
a mountpoint or a referral.
Ask for the fileid of the absent file system if mounted_on_fileid is not
supported.
Signed-off-by: Andy Adamson <andros@netapp.com>
cc:stable@kernel.org [2.6.39]
* 'pnfs-submit' of git://git.open-osd.org/linux-open-osd: (32 commits)
pnfs-obj: pg_test check for max_io_size
NFSv4.1: define nfs_generic_pg_test
NFSv4.1: use pnfs_generic_pg_test directly by layout driver
NFSv4.1: change pg_test return type to bool
NFSv4.1: unify pnfs_pageio_init functions
pnfs-obj: objlayout_encode_layoutcommit implementation
pnfs: encode_layoutcommit
pnfs-obj: report errors and .encode_layoutreturn Implementation.
pnfs: encode_layoutreturn
pnfs: layoutret_on_setattr
pnfs: layoutreturn
pnfs-obj: osd raid engine read/write implementation
pnfs: support for non-rpc layout drivers
pnfs-obj: define per-inode private structure
pnfs: alloc and free layout_hdr layoutdriver methods
pnfs-obj: objio_osd device information retrieval and caching
pnfs-obj: decode layout, alloc/free lseg
pnfs-obj: pnfs_osd XDR client implementation
pnfs-obj: pnfs_osd XDR definitions
pnfs-obj: objlayoutdriver module skeleton
Non-rpc layout driver such as for objects and blocks
implement their own I/O path and error handling logic.
Therefore bypass NFS-based error handling for these layout drivers.
[fix lseg ref-count bugs, and null de-refs]
[Fall out from: non-rpc layout drivers]
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
[get rid of PNFS_USE_RPC_CODE]
[get rid of __nfs4_write_done_cb]
[revert useless change in nfs4_write_done_cb]
Signed-off-by: Benny Halevy <bhalevy@panasas.com>
Change each shrinker's API by consolidating the existing parameters into
shrink_control struct. This will simplify any further features added w/o
touching each file of shrinker.
[akpm@linux-foundation.org: fix build]
[akpm@linux-foundation.org: fix warning]
[kosaki.motohiro@jp.fujitsu.com: fix up new shrinker API]
[akpm@linux-foundation.org: fix xfs warning]
[akpm@linux-foundation.org: update gfs2]
Signed-off-by: Ying Han <yinghan@google.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Acked-by: Pavel Emelyanov <xemul@openvz.org>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
A submount may use different security than the parent
mount does. We should figure out what sec flavor the
submount uses at mount time.
A later patch will need to perform a lookup using an
alternate client with a different security flavor.
This patch adds support for doing that on NFS v4.
Implement all the hooks created in the previous patches.
This requires exporting quite a few functions and adding a few
structure fields.
Signed-off-by: Fred Isaman <iisaman@netapp.com>
git://git.linux-nfs.org/projects/trondmy/nfs-2.6
* 'nfs-for-2.6.39' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (54 commits)
RPC: killing RPC tasks races fixed
xprt: remove redundant check
SUNRPC: Convert struct rpc_xprt to use atomic_t counters
SUNRPC: Ensure we always run the tk_callback before tk_action
sunrpc: fix printk format warning
xprt: remove redundant null check
nfs: BKL is no longer needed, so remove the include
NFS: Fix a warning in fs/nfs/idmap.c
Cleanup: Factor out some cut-and-paste code.
cleanup: save 60 lines/100 bytes by combining two mostly duplicate functions.
NFS: account direct-io into task io accounting
gss:krb5 only include enctype numbers in gm_upcall_enctypes
RPCRDMA: Fix FRMR registration/invalidate handling.
RPCRDMA: Fix to XDR page base interpretation in marshalling logic.
NFSv4: Send unmapped uid/gids to the server when using auth_sys
NFSv4: Propagate the error NFS4ERR_BADOWNER to nfs4_do_setattr
NFSv4: cleanup idmapper functions to take an nfs_server argument
NFSv4: Send unmapped uid/gids to the server if the idmapper fails
NFSv4: If the server sends us a numeric uid/gid then accept it
NFSv4.1: reject zero layout with zeroed stripe unit
It's always equal to dentry->d_sb
part 3: now we have everything to get nfs_path() just by dentry -
just follow to (disconnected) root and pick the rest of the thing
there.
Start killing propagation of struct vfsmount * on the paths that
used to bring it to nfs_path().
step 1 of ->mnt_devname fixes: make sure we have the value of devname
available in ..._get_root().
Allows the pnfs filelayout driver to write to the data servers.
Note that COMMIT to data servers will be implemented in a future
patch. To avoid improper behavior, for the moment any WRITE to a data
server that would also require a COMMIT to the data server is sent
NFS_FILE_SYNC.
Signed-off-by: Andy Adamson <andros@citi.umich.edu>
Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com>
Signed-off-by: Fred Isaman <iisaman@citi.umich.edu>
Signed-off-by: Mingyang Guo <guomingyang@nrchpc.ac.cn>
Signed-off-by: Oleg Drokin <green@linuxhacker.ru>
Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com>
Use our own async error handler.
Mark the layout as failed and retry i/o through the MDS on specified errors.
Update the mds_offset in nfs_readpage_retry so that a failed short-read retry
to a DS gets correctly resent through the MDS.
Attempt a pNFS file layout read by setting up the nfs_read_data struct and
calling nfs_initiate_read with the data server rpc client and the
filelayout rpc call ops.
Error handling is implemented in a subsequent patch.
Tested-by: Guo Mingyang <guomingyang@nrchpc.ac.cn>
Introduce a data server set_client and init session following the
nfs4_set_client and nfs4_init_session convention.
Once a new nfs_client is on the nfs_client_list, the nfs_client cl_cons_state
serializes access to creating an nfs_client struct with matching properties.
Use the new nfs_get_client() that initializes new clients.
Now nfs_get_client returns an nfs_client ready to be used no matter if it was
found or created.
The information required to find the nfs_client cooresponding to the incoming
back channel request is contained in the NFS layer. Perform minimal checking
in the RPC layer pg_authenticate method, and push more detailed checking into
the NFS layer where the nfs_client can be found.
Make NFS use the new d_automount() dentry operation rather than abusing
follow_link() on directories.
Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Acked-by: Ian Kent <raven@themaw.net>
Fixes a bug where the nfs_client could be freed during callback processing.
Refactor nfs_find_client to use minorversion specific means to locate the
correct nfs_client structure.
In the NFS layer, V4.0 clients are found using the callback_ident field in the
CB_COMPOUND header. V4.1 clients are found using the sessionID in the
CB_SEQUENCE operation which is also compared against the sessionID associated
with the back channel thread after a successful CREATE_SESSION.
Each of these methods finds the one an only nfs_client associated
with the incoming callback request - so nfs_find_client_next is not needed.
In the RPC layer, the pg_authenticate call needs to find the nfs_client. For
the v4.0 callback service, the callback identifier has not been decoded so a
search by address, version, and minorversion is used. The sessionid for the
sessions based callback service has (usually) not been set for the
pg_authenticate on a CB_NULL call which can be sent prior to the return
of a CREATE_SESSION call, so the sessionid associated with the back channel
thread is not used to find the client in pg_authenticate for CB_NULL calls.
Pass the referenced nfs_client to each CB_COMPOUND operation being proceesed
via the new cb_process_state structure. The reference is held across
cb_compound processing.
Use the new cb_process_state struct to move the NFS4ERR_RETRY_UNCACHED_REP
processing from process_op into nfs4_callback_sequence where it belongs.
Use the small id to pointer translator service to provide a unique callback
identifier per SETCLIENTID call used to identify the v4.0 callback service
associated with the clientid.
Clean up.
The pointer returned by ->decode_dirent() is no longer used as a
pointer. The only call site (xdr_decode() in fs/nfs/dir.c) simply
extracts the errno value encoded in the pointer. Replace the
returned pointer with a standard integer errno return value.
Also, pass the "server" argument as part of the nfs_entry instead of
as a separate parameter. It's faster to derive "server" in
nfs_readdir_xdr_to_array() since we already have the directory's inode
handy. "server" ought to be invariant for a set of entries in the
same directory, right?
The legacy versions of decode_dirent() don't use "server" anyway, so
it's wasted work for them to derive and pass "server" for each entry.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Tested-by: J. Bruce Fields <bfields@redhat.com>
We'd like to prevent local buffer overflows caused by malicious or
broken servers. New xdr_stream style decoders can do that.
For efficiency, we also eventually want to be able to pass xdr_streams
from call_decode() to all XDR decoding functions, rather than building
an xdr_stream in every XDR decoding function in the kernel.
nfs_decode_dirent() is renamed to follow the naming convention of the
other two dirent decoders.
Static helper functions are left without the "inline" directive. This
allows the compiler to choose automatically how to optimize these for
size or speed.
Clean up.
To distinguish more clearly between the on-the-wire NFSERR_ value and
our local errno values, use the proper type for the argument of
nfs_stat_to_errno().
Add a documenting comment appropriate for a global function shared
outside this source file.
Store the dirent->d_type in the struct nfs_cache_array_entry so that we
can use it in getdents() calls.
This fixes a regression with the new readdir code.
By requsting more attributes during a readdir, we can mimic the readdir plus
operation that was in NFSv3.
To test, I ran the command `ls -lU --color=none` on directories with various
numbers of files. Without readdir plus, I see this:
n files | 100 | 1,000 | 10,000 | 100,000 | 1,000,000
real | 0m00.153s | 0m00.589s | 0m05.601s | 0m56.691s | 9m59.128s
user | 0m00.007s | 0m00.007s | 0m00.077s | 0m00.703s | 0m06.800s
sys | 0m00.010s | 0m00.070s | 0m00.633s | 0m06.423s | 1m10.005s
access | 3 | 1 | 1 | 4 | 31
getattr | 2 | 1 | 1 | 1 | 1
lookup | 104 | 1,003 | 10,003 | 100,003 | 1,000,003
readdir | 2 | 16 | 158 | 1,575 | 15,749
total | 111 | 1,021 | 10,163 | 101,583 | 1,015,784
With readdir plus enabled, I see this:
real | 0m00.115s | 0m00.206s | 0m01.079s | 0m12.521s | 2m07.528s
user | 0m00.003s | 0m00.003s | 0m00.040s | 0m00.290s | 0m03.296s
sys | 0m00.007s | 0m00.020s | 0m00.120s | 0m01.357s | 0m17.556s
access | 3 | 1 | 1 | 1 | 7
lookup | 4 | 3 | 3 | 3 | 3
readdir | 6 | 62 | 630 | 6,300 | 62,993
total | 15 | 67 | 635 | 6,305 | 63,004
Readdir plus disabled has about a 16x increase in the number of rpc calls and
is 4 - 5 times slower on large directories.
We can use vmapped pages to read more information from the network at once.
This will reduce the number of calls needed to complete a readdir.
[trondmy: Added #include for linux/vmalloc.h> in fs/nfs/dir.c]
Convert nfs*xdr.c to use an xdr stream in decode_dirent. This will prevent a
kernel oops that has been occuring when reading a vmapped page.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits)
no need for list_for_each_entry_safe()/resetting with superblock list
Fix sget() race with failing mount
vfs: don't hold s_umount over close_bdev_exclusive() call
sysv: do not mark superblock dirty on remount
sysv: do not mark superblock dirty on mount
btrfs: remove junk sb_dirt change
BFS: clean up the superblock usage
AFFS: wait for sb synchronization when needed
AFFS: clean up dirty flag usage
cifs: truncate fallout
mbcache: fix shrinker function return value
mbcache: Remove unused features
add f_flags to struct statfs(64)
pass a struct path to vfs_statfs
update VFS documentation for method changes.
All filesystems that need invalidate_inode_buffers() are doing that explicitly
convert remaining ->clear_inode() to ->evict_inode()
Make ->drop_inode() just return whether inode needs to be dropped
fs/inode.c:clear_inode() is gone
fs/inode.c:evict() doesn't care about delete vs. non-delete paths now
Fix up trivial conflicts in fs/nilfs2/super.c
* 'nfs-for-2.6.36' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (42 commits)
NFS: NFSv4.1 is no longer a "developer only" feature
NFS: NFS_V4 is no longer an EXPERIMENTAL feature
NFS: Fix /proc/mount for legacy binary interface
NFS: Fix the locking in nfs4_callback_getattr
SUNRPC: Defer deleting the security context until gss_do_free_ctx()
SUNRPC: prevent task_cleanup running on freed xprt
SUNRPC: Reduce asynchronous RPC task stack usage
SUNRPC: Move the bound cred to struct rpc_rqst
SUNRPC: Clean up of rpc_bindcred()
SUNRPC: Move remaining RPC client related task initialisation into clnt.c
SUNRPC: Ensure that rpc_exit() always wakes up a sleeping task
SUNRPC: Make the credential cache hashtable size configurable
SUNRPC: Store the hashtable size in struct rpc_cred_cache
NFS: Ensure the AUTH_UNIX credcache is allocated dynamically
NFS: Fix the NFS users of rpc_restart_call()
SUNRPC: The function rpc_restart_call() should return success/failure
NFSv4: Get rid of the bogus RPC_ASSASSINATED(task) checks
NFSv4: Clean up the process of renewing the NFSv4 lease
NFSv4.1: Handle NFS4ERR_DELAY on SEQUENCE correctly
NFS: nfs_rename() should not have to flush out writebacks
Fix up those functions that depend on knowing whether or not
rpc_restart_call is successful or not.
The current shrinker implementation requires the registered callback
to have global state to work from. This makes it difficult to shrink
caches that are not global (e.g. per-filesystem caches). Pass the shrinker
structure to the callback so that users can embed the shrinker structure
in the context the shrinker needs to operate on and get back to it in the
callback via container_of().
Signed-off-by: Dave Chinner <dchinner@redhat.com>
All we really want is the ability to retrieve the root file handle. We no
longer need the ability to walk down the path, since that is now done in
nfs_follow_remote_path().
This gives the filesystem more information about the writeback that
is happening. Trond requested this for the NFS unstable write handling,
and other filesystems might benefit from this too by beeing able to
distinguish between the different callers in more detail.
Also rename it: it is used in generic code, and so should not have a 'nfs4'
prefix.
We no longer need to maintain a distinction between nfs41_sequence_done and
nfs41_sequence_free_slot.
This fixes a number of slot table leakages in the NFSv4.1 code.
The v4.1 client should take into account the desired rsize, wsize when
negotiating the max size in CREATE_SESSION. Accordingly, it should use
rsize, wsize that are smaller than the session negotiated values.
Signed-off-by: Alexandros Batsakis <batsakis@netapp.com>
The NFSv4.1 spec-29 (18.36.3) says that the server MUST use an ONC RPC
(program) version number equal to 4 in callbacks sent to the client.
For now we allow both versions 1 and 4.
nfs41_sequence_free_slot can be called multiple times on SEQUENCE operation
errors.
No reason to inline nfs4_restart_rpc
Reported-by: Trond Myklebust <trond.myklebust@netapp.com>
nfs_writeback_done and nfs_readpage_retry call nfs4_restart_rpc outside the
error handler, and the slot is not freed prior to restarting in the rpc_prepare
state during session reset.
Fix this by moving the call to nfs41_sequence_free_slot from the error
path of nfs41_sequence_done into nfs4_restart_rpc, and by removing the test
for NFS4CLNT_SESSION_SETUP.
Always free slot and goto the rpc prepare state on async errors.
The bit is no longer used for session setup, only for session reset.
When mounting an "nfs" type file system, recognize "v4," "vers=4," or
"nfsvers=4" mount options, and convert the file system to "nfs4" under
the covers.
[trondmy: fixed up binary mount code so it sets the 'version' field too]
The meaning of not specifying the "port=" mount option is different
for "-t nfs" and "-t nfs4" mounts. The default port value for
NFSv2/v3 mounts is 0, but the default for NFSv4 mounts is 2049.
To support "-t nfs -o vers=4", the mount option parser must detect
when "port=" is missing so that the correct default port value can be
set depending on which NFS version is requested.
Make NFS a bit more friendly to NUMA and memory hot removal...
Clean up.
Clean up: Use the common routine now provided in sunrpc.ko for parsing mount
addresses.
Introduce a set of functions in the kernel's RPC implementation for
converting between a socket address and either a standard
presentation address string or an RPC universal address.
The universal address functions will be used to encode and decode
RPCB_FOO and NFSv4 SETCLIENTID arguments. The other functions are
part of a previous promise to deliver shared functions that can be
used by upper-layer protocols to display and manipulate IP
addresses.
The kernel's current address printf formatters were designed
specifically for kernel to user-space APIs that require a particular
string format for socket addresses, thus are somewhat limited for the
purposes of sunrpc.ko. The formatter for IPv6 addresses, %pI6, does
not support short-handing or scope IDs. Also, these printf formatters
are unique per address family, so a separate formatter string is
required for printing AF_INET and AF_INET6 addresses.
