commit 2edb6bc3852c681c0d948245bd55108dc6407604 upstream.
From c6d615d2b97fe305cbf123a8751ced859dca1d5e Mon Sep 17 00:00:00 2001
Date: Wed, 16 Nov 2011 09:39:05 +1100
Subject: NFS - fix recent breakage to NFS error handling.
commit 02c24a82187d5a628c68edfe71ae60dc135cd178 made a small and
presumably unintended change to write error handling in NFS.
Previously an error from filemap_write_and_wait_range would only be of
interest if nfs_file_fsync did not return an error. After this commit,
an error from filemap_write_and_wait_range would mean that (the rest of)
nfs_file_fsync would not even be called.
This means that:
1/ you are more likely to see EIO than e.g. EDQUOT or ENOSPC.
2/ NFS_CONTEXT_ERROR_WRITE remains set for longer so more writes are
synchronous.
This patch restores previous behaviour.
Cc: Josef Bacik <josef@redhat.com>
Cc: Jan Kara <jack@suse.cz>
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 6c52961743f38747401b47127b82159ab6d8a7a4 upstream.
After commit 06222e491e663dac939f04b125c9dc52126a75c4 (fs: handle
SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek)
the behaviour of llseek() was changed so that it always revalidates
the file size. The bug appears to be due to a logic error in the
afore-mentioned commit, which always evaluates to 'true'.
Reported-by: Roel Kluin <roel.kluin@gmail.com>
commit 1788ea6e3b2a58cf4fb00206e362d9caff8d86a7 upstream.
commit d953126 changed how nfs_atomic_lookup handles an -EISDIR return
from an OPEN call. Prior to that patch, that caused the client to fall
back to doing a normal lookup. When that patch went in, the code began
returning that error to userspace. The d_revalidate codepath however
never had the corresponding change, so it was still possible to end up
with a NULL ctx->state pointer after that.
That patch caused a regression. When we attempt to open a directory that
does not have a cached dentry, that open now errors out with EISDIR. If
you attempt the same open with a cached dentry, it will succeed.
Fix this by reverting the change in nfs_atomic_lookup and allowing
attempts to open directories to fall back to a normal lookup
Also, add a NFSv4-specific f_ops->open routine that just returns
-ENOTDIR. This should never be called if things are working properly,
but if it ever is, then the dprintk may help in debugging.
To facilitate this, a new file_operations field is also added to the
nfs_rpc_ops struct.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Btrfs needs to be able to control how filemap_write_and_wait_range() is called
in fsync to make it less of a painful operation, so push down taking i_mutex and
the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some
file systems can drop taking the i_mutex altogether it seems, like ext3 and
ocfs2. For correctness sake I just pushed everything down in all cases to make
sure that we keep the current behavior the same for everybody, and then each
individual fs maintainer can make up their mind about what to do from there.
Thanks,
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Josef Bacik <josef@redhat.com>
This converts everybody to handle SEEK_HOLE/SEEK_DATA properly. In some cases
we just return -EINVAL, in others we do the normal generic thing, and in others
we're simply making sure that the properly due-dilligence is done. For example
in NFS/CIFS we need to make sure the file size is update properly for the
SEEK_HOLE and SEEK_DATA case, but since it calls the generic llseek stuff itself
that is all we have to do. Thanks,
Signed-off-by: Andy Adamson <andros@netapp.com>
The filelayout driver sends LAYOUTCOMMIT only when COMMIT goes to
the data server (as opposed to the MDS) and the data server WRITE
is not NFS_FILE_SYNC.
Only whole file layout support means that there is only one IOMODE_RW layout
segment.
Signed-off-by: Alexandros Batsakis <batsakis@netapp.com>
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com>
Signed-off-by: Fred Isaman <iisaman@citi.umich.edu>
Signed-off-by: Mingyang Guo <guomingyang@nrchpc.ac.cn>
Signed-off-by: Tao Guo <guotao@nrchpc.ac.cn>
Signed-off-by: Zhang Jingwang <zhangjingwang@nrchpc.ac.cn>
Tested-by: Boaz Harrosh <bharrosh@panasas.com>
Signed-off-by: Benny Halevy <bhalevy@panasas.com>
Signed-off-by: Fred Isaman <iisaman@netapp.com>
Move the pnfs_update_layout call location to nfs_pageio_do_add_request().
Grab the lseg sent in the doio function to nfs_read_rpcsetup and attach
it to each nfs_read_data so it can be sent to the layout driver.
Signed-off-by: Andy Adamson <andros@citi.umich.edu>
Signed-off-by: Oleg Drokin <green@linuxhacker.ru>
The commit 129a84de2347002f09721cda3155ccfd19fade40 (locks: fix F_GETLK
regression (failure to find conflicts)) fixed the posix_test_lock()
function by itself, however, its usage in NFS changed by the commit
9d6a8c5c213e34c475e72b245a8eb709258e968c (locks: give posix_test_lock
same interface as ->lock) remained broken - subsequent NFS-specific
locking code received F_UNLCK instead of the user-specified lock type.
To fix the problem, fl->fl_type needs to be saved before the
posix_test_lock() call and restored if no local conflicts were reported.
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=23892
Tested-by: Alexander Morozov <amorozov@etersoft.ru>
Signed-off-by: Sergey Vlasov <vsu@altlinux.ru>
Cc: <stable@kernel.org>
The caller allocated it, the caller should free it.
The only issue so far is that we could change the flp pointer even on an
error return if the fl_change callback failed. But we can simply move
the flp assignment after the fl_change invocation, as the callers don't
care about the flp return value if the setlease call failed.
We modified setlease to require the caller to allocate the new lease in
the case of creating a new lease, but forgot to fix up the filesystem
methods.
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Steve French <sfrench@samba.org>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
git://git.linux-nfs.org/projects/trondmy/nfs-2.6
* 'nfs-for-2.6.37' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6:
net/sunrpc: Use static const char arrays
nfs4: fix channel attribute sanity-checks
NFSv4.1: Use more sensible names for 'initialize_mountpoint'
NFSv4.1: pnfs: filelayout: add driver's LAYOUTGET and GETDEVICEINFO infrastructure
NFSv4.1: pnfs: add LAYOUTGET and GETDEVICEINFO infrastructure
NFS: client needs to maintain list of inodes with active layouts
NFS: create and destroy inode's layout cache
NFSv4.1: pnfs: filelayout: introduce minimal file layout driver
NFSv4.1: pnfs: full mount/umount infrastructure
NFS: set layout driver
NFS: ask for layouttypes during v4 fsinfo call
NFS: change stateid to be a union
NFSv4.1: pnfsd, pnfs: protocol level pnfs constants
SUNRPC: define xdr_decode_opaque_fixed
NFSD: remove duplicate NFS4_STATEID_SIZE
* 'nfs-for-2.6.37' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (67 commits)
SUNRPC: Cleanup duplicate assignment in rpcauth_refreshcred
nfs: fix unchecked value
Ask for time_delta during fsinfo probe
Revalidate caches on lock
SUNRPC: After calling xprt_release(), we must restart from call_reserve
NFSv4: Fix up the 'dircount' hint in encode_readdir
NFSv4: Clean up nfs4_decode_dirent
NFSv4: nfs4_decode_dirent must clear entry->fattr->valid
NFSv4: Fix a regression in decode_getfattr
NFSv4: Fix up decode_attr_filehandle() to handle the case of empty fh pointer
NFS: Ensure we check all allocation return values in new readdir code
NFS: Readdir plus in v4
NFS: introduce generic decode_getattr function
NFS: check xdr_decode for errors
NFS: nfs_readdir_filler catch all errors
NFS: readdir with vmapped pages
NFS: remove page size checking code
NFS: decode_dirent should use an xdr_stream
SUNRPC: Add a helper function xdr_inline_peek
NFS: remove readdir plus limit
At the start of the io paths, try to grab the relevant layout
information. This will initiate the inode's layout cache, but
stubs ensure the cache stays empty.
Signed-off-by: Dean Hildebrand <dhildebz@umich.edu>
Signed-off-by: Marc Eshel <eshel@almaden.ibm.com>
Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com>
Instead of blindly zapping the caches, attempt to revalidate them if
the server has indicated that it uses high resolution timestamps.
NFSv4 should be able to always revalidate the cache since the
protocol requires the update of the change attribute on modification of
the data. In reality, there are servers (the Linux NFS server
for example) that do not obey this requirement and use ctime as the
basis for change attribute. Long term, the server needs to be fixed.
At this time, and to be on the safe side, continue zapping caches if
the server indicates that it does not have a high resolution timestamp.
Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com>
In the case where we lock the page, and then find out that the page has
been thrown out of the page cache, we should just return VM_FAULT_NOPAGE.
This is what block_page_mkwrite() does in these situations.
Cc: stable@kernel.org
NFS clients since 2.6.12 support flock locks by emulating fcntl byte-range
locks. Due to this, some windows applications which seem to use both flock
(share mode lock mapped as flock by Samba) and fcntl locks sequentially on
the same file, can't lock as they falsely assume the file is already locked.
The problem was reported on a setup with windows clients accessing excel files
on a Samba exported share which is originally a NFS mount from a NetApp filer.
Older NFS clients (< 2.6.12) did not see this problem as flock locks were
considered local. To support legacy flock behavior, this patch adds a mount
option "-olocal_lock=" which can take the following values:
'none' - Neither flock locks nor POSIX locks are local
'flock' - flock locks are local
'posix' - fcntl/POSIX locks are local
'all' - Both flock locks and POSIX locks are local
Testing:
- This patch was tested by using -olocal_lock option with different values
and the NLM calls were noted from the network packet captured.
'none' - NLM calls were seen during both flock() and fcntl(), flock lock
was granted, fcntl was denied
'flock' - no NLM calls for flock(), NLM call was seen for fcntl(),
granted
'posix' - NLM call was seen for flock() - granted, no NLM call for fcntl()
'all' - no NLM calls were seen during both flock() and fcntl()
- No bugs were seen during NFSv4 locking/unlocking in general and NFSv4
reboot recovery.
Cc: Neil Brown <neilb@suse.de>
Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de>
The do_vfs_lock function on fs/nfs/file.c is only called if NLM is
not being used, via the -onolock mount option. Therefore it cannot
really be "out of sync with lock manager" when the local locking
function called returns an error, as there will be no corresponding
call to the NLM. For details, simply check the if/else on do_setlk
and do_unlk on fs/nfs/file.c.
Signed-Off-By: Fabio Olive Leite <fleite@redhat.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
By the commit af7fa16 2010-08-03 NFS: Fix up the fsync code
close(2) became returning the non-zero value even if it went well.
nfs_file_fsync() should return 0 when "status" is positive.
Signed-off-by: J. R. Okajima <hooanon05@yahoo.co.jp>
* 'nfs-for-2.6.36' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (42 commits)
NFS: NFSv4.1 is no longer a "developer only" feature
NFS: NFS_V4 is no longer an EXPERIMENTAL feature
NFS: Fix /proc/mount for legacy binary interface
NFS: Fix the locking in nfs4_callback_getattr
SUNRPC: Defer deleting the security context until gss_do_free_ctx()
SUNRPC: prevent task_cleanup running on freed xprt
SUNRPC: Reduce asynchronous RPC task stack usage
SUNRPC: Move the bound cred to struct rpc_rqst
SUNRPC: Clean up of rpc_bindcred()
SUNRPC: Move remaining RPC client related task initialisation into clnt.c
SUNRPC: Ensure that rpc_exit() always wakes up a sleeping task
SUNRPC: Make the credential cache hashtable size configurable
SUNRPC: Store the hashtable size in struct rpc_cred_cache
NFS: Ensure the AUTH_UNIX credcache is allocated dynamically
NFS: Fix the NFS users of rpc_restart_call()
SUNRPC: The function rpc_restart_call() should return success/failure
NFSv4: Get rid of the bogus RPC_ASSASSINATED(task) checks
NFSv4: Clean up the process of renewing the NFSv4 lease
NFSv4.1: Handle NFS4ERR_DELAY on SEQUENCE correctly
NFS: nfs_rename() should not have to flush out writebacks
Christoph points out that the VFS will always flush out data before calling
nfs_fsync(), so we can dispense with a full call to nfs_wb_all(), and
replace that with a simpler call to nfs_commit_inode().
See https://bugzilla.kernel.org/show_bug.cgi?id=16056
If other processes are blocked waiting for kswapd to free up some memory so
that they can make progress, then we cannot allow kswapd to block on those
processes.
If the server has given us a delegation on a file, we _know_ that we can
cache the attribute information even when the user has specified 'noac'.
Reviewed-by: Chuck Lever <chuck.lever@oracle.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
We should not attempt to free the page if __GFP_FS is not set. Otherwise we
can deadlock as per
http://bugzilla.kernel.org/show_bug.cgi?id=15578
The bytes counted by the performance counters for NFS writes should
reflect write and sync errors. If the write(2) system call reports
an error, the bytes should not be counted. And, if the write is
short, the actual number of bytes that was written should be counted,
not the number of bytes that was requested.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Bytes read via the splice API should be accounted for in the NFS
performance statistics.
Currently, the NFS I/O counters count the number of bytes requested
by applications, rather than the number of bytes actually read by the
system calls.
The number of bytes requested for reads is actually not that useful,
because the value is usually a buffer size for reads. That is, that
requested number is usually a maximum, and frequently doesn't reflect
the actual number of bytes read.
Nit: The VFSOPEN and VFSFLUSH counters are function call counters.
Count every call to these routines.
If someone calls nfs_release_page(), we presumably already know that the
page is clean, however it may be holding an unstable write.
While Linux provided an O_SYNC flag basically since day 1, it took until
Linux 2.4.0-test12pre2 to actually get it implemented for filesystems,
since that day we had generic_osync_around with only minor changes and the
great "For now, when the user asks for O_SYNC, we'll actually give
O_DSYNC" comment. This patch intends to actually give us real O_SYNC
semantics in addition to the O_DSYNC semantics. After Jan's O_SYNC
patches which are required before this patch it's actually surprisingly
simple, we just need to figure out when to set the datasync flag to
vfs_fsync_range and when not.
This patch renames the existing O_SYNC flag to O_DSYNC while keeping it's
numerical value to keep binary compatibility, and adds a new real O_SYNC
flag. To guarantee backwards compatiblity it is defined as expanding to
both the O_DSYNC and the new additional binary flag (__O_SYNC) to make
sure we are backwards-compatible when compiled against the new headers.
This also means that all places that don't care about the differences can
just check O_DSYNC and get the right behaviour for O_SYNC, too - only
places that actuall care need to check __O_SYNC in addition. Drivers and
network filesystems have been updated in a fail safe way to always do the
full sync magic if O_DSYNC is set. The few places setting O_SYNC for
lower layers are kept that way for now to stay failsafe.
We enforce that O_DSYNC is set when __O_SYNC is set early in the open path
to make sure we always get these sane options.
Note that parisc really screwed up their headers as they already define a
O_DSYNC that has always been a no-op. We try to repair it by using it for
the new O_DSYNC and redefinining O_SYNC to send both the traditional
O_SYNC numerical value _and_ the O_DSYNC one.
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Grant Grundler <grundler@parisc-linux.org>
Cc: Andreas Dilger <adilger@sun.com>
Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Acked-by: Ulrich Drepper <drepper@redhat.com>
* mark struct vm_area_struct::vm_ops as const
* mark vm_ops in AGP code
But leave TTM code alone, something is fishy there with global vm_ops
being used.
Enable hardware memory error handling for NFS
Truncation of data pages at runtime should be safe in NFS,
even when it doesn't support migration so far.
Trond tells me migration is also queued up for 2.6.32.
Acked-by: Trond.Myklebust@netapp.com
Hi.
I have a proposal for possibly resolving this issue.
I believe that this situation occurs due to the way that the
Linux NFS client handles writes which modify partial pages.
The Linux NFS client handles partial page modifications by
allocating a page from the page cache, copying the data from
the user level into the page, and then keeping track of the
offset and length of the modified portions of the page. The
page is not marked as up to date because there are portions
of the page which do not contain valid file contents.
When a read call comes in for a portion of the page, the
contents of the page must be read in the from the server.
However, since the page may already contain some modified
data, that modified data must be written to the server
before the file contents can be read back in the from server.
And, since the writing and reading can not be done atomically,
the data must be written and committed to stable storage on
the server for safety purposes. This means either a
FILE_SYNC WRITE or a UNSTABLE WRITE followed by a COMMIT.
This has been discussed at length previously.
This algorithm could be described as modify-write-read. It
is most efficient when the application only updates pages
and does not read them.
My proposed solution is to add a heuristic to decide whether
to do this modify-write-read algorithm or switch to a read-
modify-write algorithm when initially allocating the page
in the write system call path. The heuristic uses the modes
that the file was opened with, the offset in the page to
read from, and the size of the region to read.
If the file was opened for reading in addition to writing
and the page would not be filled completely with data from
the user level, then read in the old contents of the page
and mark it as Uptodate before copying in the new data. If
the page would be completely filled with data from the user
level, then there would be no reason to read in the old
contents because they would just be copied over.
This would optimize for applications which randomly access
and update portions of files. The linkage editor for the
C compiler is an example of such a thing.
I tested the attached patch by using rpmbuild to build the
current Fedora rawhide kernel. The kernel without the
patch generated about 269,500 WRITE requests. The modified
kernel containing the patch generated about 261,000 WRITE
requests. Thus, about 8,500 fewer WRITE requests were
generated. I suspect that many of these additional
WRITE requests were probably FILE_SYNC requests to WRITE
a single page, but I didn't test this theory.
The difference between this patch and the previous one was
to remove the unneeded PageDirty() test. I then retested to
ensure that the resulting system continued to behave as
desired.
Thanx...
ps
Signed-off-by: Peter Staubach <staubach@redhat.com>
Make NFS a bit more friendly to NUMA and memory hot removal...
* Remove smp_lock.h from files which don't need it (including some headers!)
* Add smp_lock.h to files which do need it
* Make smp_lock.h include conditional in hardirq.h
It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT
This will make hardirq.h inclusion cheaper for every PREEMPT=n config
(which includes allmodconfig/allyesconfig, BTW)
Adds support for splice writes. It effectively calls
generic_file_splice_write() to do the writes.
We need not worry about O_APPEND case as the combination of splice()
writes and O_APPEND is disallowed. This patch propagates NFS write
errors back to the caller. The number of bytes written via splice are
being added to NFSIO_NORMALWRITTENBYTES as these are effectively
cached writes.
Follow up to Nick Piggin's patches to ensure that nfs_vm_page_mkwrite
returns with the page lock held, and sets the VM_FAULT_LOCKED flag.
See http://bugzilla.kernel.org/show_bug.cgi?id=12913
Commit c2ec175c39f62949438354f603f4aa170846aabb ("mm: page_mkwrite
change prototype to match fault") exposed a bug in the NFS
implementation of page_mkwrite. We should be returning 0 on success...
FS-Cache page management for NFS. This includes hooking the releasing and
invalidation of pages marked with PG_fscache (aka PG_private_2) and waiting for
completion of the write-to-cache flag (PG_fscache_write aka PG_owner_priv_2).
Acked-by: Steve Dickson <steved@redhat.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
Add comment banners to some NFS functions so that they can be modified by the
NFS fscache patches for further information.
Change the page_mkwrite prototype to take a struct vm_fault, and return
VM_FAULT_xxx flags. There should be no functional change.
This makes it possible to return much more detailed error information to
the VM (and also can provide more information eg. virtual_address to the
driver, which might be important in some special cases).
This is required for a subsequent fix. And will also make it easier to
merge page_mkwrite() with fault() in future.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Joel Becker <joel.becker@oracle.com>
Cc: Artem Bityutskiy <dedekind@infradead.org>
Cc: Felix Blyakher <felixb@sgi.com>
Close-to-open cache consistency rules really only require us to flush out
writes on calls to close(), and require us to revalidate attributes on the
very last close of the file.
Currently we appear to be doing a lot of extra attribute revalidation
and cache flushes.
Bryan Wu reports that when compiling NFS on nommu machines he gets a
"defined but not used" error on nfs_file_mmap().
The easiest fix is simply to get rid of the special casing in NFS, and
just always call generic_file_mmap() to set up the file.
The following patch is a combination of a patch by myself and Peter
Staubach.
Trond: If we allow other processes to dirty pages while a process is doing
a consistency sync to disk, we can end up never making progress.
Peter: Attached is a patch which addresses a continuing problem with
the NFS client generating out of order WRITE requests. While
this is compliant with all of the current protocol
specifications, there are servers in the market which can not
handle out of order WRITE requests very well. Also, this may
lead to sub-optimal block allocations in the underlying file
system on the server. This may cause the read throughputs to
be reduced when reading the file from the server.
Peter: There has been a lot of work recently done to address out of
order issues on a systemic level. However, the NFS client is
still susceptible to the problem. Out of order WRITE
requests can occur when pdflush is in the middle of writing
out pages while the process dirtying the pages calls
generic_file_buffered_write which calls
generic_perform_write which calls
balance_dirty_pages_rate_limited which ends up calling
writeback_inodes which ends up calling back into the NFS
client to writes out dirty pages for the same file that
pdflush happens to be working with.
[modification by Trond to merge the two similar patches]
With the write_begin/write_end aops, page_symlink was broken because it
could no longer pass a GFP_NOFS type mask into the point where the
allocations happened. They are done in write_begin, which would always
assume that the filesystem can be entered from reclaim. This bug could
cause filesystem deadlocks.
The funny thing with having a gfp_t mask there is that it doesn't really
allow the caller to arbitrarily tinker with the context in which it can be
called. It couldn't ever be GFP_ATOMIC, for example, because it needs to
take the page lock. The only thing any callers care about is __GFP_FS
anyway, so turn that into a single flag.
Add a new flag for write_begin, AOP_FLAG_NOFS. Filesystems can now act on
this flag in their write_begin function. Change __grab_cache_page to
accept a nofs argument as well, to honour that flag (while we're there,
change the name to grab_cache_page_write_begin which is more instructive
and does away with random leading underscores).
This is really a more flexible way to go in the end anyway -- if a
filesystem happens to want any extra allocations aside from the pagecache
ones in ints write_begin function, it may now use GFP_KERNEL (rather than
GFP_NOFS) for common case allocations (eg. ocfs2_alloc_write_ctxt, for a
random example).
[kosaki.motohiro@jp.fujitsu.com: fix ubifs]
[kosaki.motohiro@jp.fujitsu.com: fix fuse]
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: <stable@kernel.org> [2.6.28.x]
[ Cleaned up the calling convention: just pass in the AOP flags
untouched to the grab_cache_page_write_begin() function. That
just simplifies everybody, and may even allow future expansion of the
logic. - Linus ]
