path: root/fs/ncpfs/ncplib_kernel.c
2006-03-23[PATCH] sem2mutex: NCPFSIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] fs/ncpfs/: remove unused #ifdef USE_OLD_SLOW_DIRECTORY_LISTING codeAdrian Bunk
This patch removes some unused #ifdef USE_OLD_SLOW_DIRECTORY_LISTING code. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
