path: root/fs/minix/itree_v1.c
2007-02-12[PATCH] Minix V3 supportAndries Brouwer
This morning I needed to read a Minix V3 filesystem, but unfortunately my 2.6.19 did not support that, and neither did the downloaded 2.6.20rc4. Fortunately, google told me that Daniel Aragones had already done the work, patch found at http://www.terra.es/personal2/danarag/ Unfortunaly, looking at the patch was painful to my eyes, so I polished it a bit before applying. The resulting kernel boots, and reads the filesystem it needed to read. Signed-off-by: Daniel Aragones <danarag@gmail.com> Signed-off-by: Andries Brouwer <aeb@cwi.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-03-25[PATCH] fix messages in fs/minixDenis Vlasenko
Believe it or not, but in fs/minix/*, the oldest filesystem in the kernel, something still can be fixed: printk("new_inode: bit already set"); "\n" is missing! While at it, I also removed periods from the end of error messages and made capitalization uniform. Also s/i-node/inode/, s/printk (/printk(/ Signed-ff-by: Denis Vlasenko <vda@ilport.com.ua> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
