path: root/fs/lockd/svcproc.c
2008-10-30NLM: Set address family before calling nlm_host_rebooted()Chuck Lever
The nlm_host_rebooted() function uses nlm_cmp_addr() to find an nsm_handle that matches the rebooted peer. In order for this to work, the passed-in address must have a proper address family. This fixes a post-2.6.28 regression introduced by commit 781b61a6, which added AF_INET6 support to nlm_cmp_addr(). Before that commit, nlm_cmp_addr() didn't care about the address family; it compared only the sin_addr.s_addr field for equality. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-10-03lockd: Add helper to sanity check incoming NOTIFY requestsChuck Lever
lockd accepts SM_NOTIFY calls only from a privileged process on the local system. If lockd uses an AF_INET6 listener, the sender's address (ie the local rpc.statd) will be the IPv6 loopback address, not the IPv4 loopback address. Make sure the privilege test in nlmsvc_proc_sm_notify() and nlm4svc_proc_sm_notify() works for both AF_INET and AF_INET6 family addresses by refactoring the test into a helper and adding support for IPv6 addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-10-03lockd: change nlmclnt_grant() to take a "struct sockaddr *"Chuck Lever
Adjust the signature and callers of nlmclnt_grant() to pass a "struct sockaddr *" instead of a "struct sockaddr_in *" in order to support IPv6 addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-10-03lockd: move grace period checks to common codeJ. Bruce Fields
Do all the grace period checks in svclock.c. This simplifies the code a bit, and will ease some later changes. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-10-03nfsd: common grace period controlJ. Bruce Fields
Rewrite grace period code to unify management of grace period across lockd and nfsd. The current code has lockd and nfsd cooperate to compute a grace period which is satisfactory to them both, and then individually enforce it. This creates a slight race condition, since the enforcement is not coordinated. It's also more complicated than necessary. Here instead we have lockd and nfsd each inform common code when they enter the grace period, and when they're ready to leave the grace period, and allow normal locking only after both of them are ready to leave. We also expect the locks_start_grace()/locks_end_grace() interface here to be simpler to build on for future cluster/high-availability work, which may require (for example) putting individual filesystems into grace, or enforcing grace periods across multiple cluster nodes. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-07-23lockd: trivial sparse endian annotationsHarvey Harrison
fs/lockd/svcproc.c:115:11: warning: incorrect type in initializer (different base types) fs/lockd/svcproc.c:115:11: expected int [signed] rc fs/lockd/svcproc.c:115:11: got restricted __be32 [usertype] <noident> ... and so on... Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-07-20Merge branch 'for-2.6.27' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.27' of git://linux-nfs.org/~bfields/linux: (51 commits) nfsd: nfs4xdr.c do-while is not a compound statement nfsd: Use C99 initializers in fs/nfsd/nfs4xdr.c lockd: Pass "struct sockaddr *" to new failover-by-IP function lockd: get host reference in nlmsvc_create_block() instead of callers lockd: minor svclock.c style fixes lockd: eliminate duplicate nlmsvc_lookup_host call from nlmsvc_lock lockd: eliminate duplicate nlmsvc_lookup_host call from nlmsvc_testlock lockd: nlm_release_host() checks for NULL, caller needn't file lock: reorder struct file_lock to save space on 64 bit builds nfsd: take file and mnt write in nfs4_upgrade_open nfsd: document open share bit tracking nfsd: tabulate nfs4 xdr encoding functions nfsd: dprint operation names svcrdma: Change WR context get/put to use the kmem cache svcrdma: Create a kmem cache for the WR contexts svcrdma: Add flush_scheduled_work to module exit function svcrdma: Limit ORD based on client's advertised IRD svcrdma: Remove unused wait q from svcrdma_xprt structure svcrdma: Remove unneeded spin locks from __svc_rdma_free svcrdma: Add dma map count and WARN_ON ...
2008-07-15SUNRPC: Remove the BKL from the callback functionsTrond Myklebust
Push it into those callback functions that actually need it. Note that all the NFS operations use their own locking, so don't need the BKL. Ditto for the rpcbind client. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-15lockd: eliminate duplicate nlmsvc_lookup_host call from nlmsvc_lockJeff Layton
nlmsvc_lock calls nlmsvc_lookup_host to find a nlm_host struct. The callers of this function, however, call nlmsvc_retrieve_args or nlm4svc_retrieve_args, which also return a nlm_host struct. Change nlmsvc_lock to take a host arg instead of calling nlmsvc_lookup_host itself and change the callers to pass a pointer to the nlm_host they've already found. Since nlmsvc_testlock() now just uses the caller's reference, we no longer need to get or release it. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-07-15lockd: eliminate duplicate nlmsvc_lookup_host call from nlmsvc_testlockJeff Layton
nlmsvc_testlock calls nlmsvc_lookup_host to find a nlm_host struct. The callers of this functions, however, call nlmsvc_retrieve_args or nlm4svc_retrieve_args, which also return a nlm_host struct. Change nlmsvc_testlock to take a host arg instead of calling nlmsvc_lookup_host itself and change the callers to pass a pointer to the nlm_host they've already found. We take a reference to host in the place where nlmsvc_testlock() previous did a new lookup, so the reference counting is unchanged from before. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-07-15lockd: nlm_release_host() checks for NULL, caller needn'tJeff Layton
No need to check for a NULL argument twice. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01lockd: fix reference count leaks in async locking caseOleg Drokin
In a number of places where we wish only to translate nlm_drop_reply to rpc_drop_reply errors we instead return early with rpc_drop_reply, skipping some important end-of-function cleanup. This results in reference count leaks when lockd is doing posix locking on GFS2. Signed-off-by: Oleg Drokin <green@linuxhacker.ru> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-05-06lockd: add code to handle deferred lock requestsMarc Eshel
Rewrite nlmsvc_lock() to use the asynchronous interface. As with testlock, we answer nlm requests in nlmsvc_lock by first looking up the block and then using the results we find in the block if B_QUEUED is set, and calling vfs_lock_file() otherwise. If this a new lock request and we get -EINPROGRESS return on a non-blocking request then we defer the request. Also modify nlmsvc_unlock() to call the filesystem method if appropriate. Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-05-06lockd: handle test_lock deferralsMarc Eshel
Rewrite nlmsvc_testlock() to use the new asynchronous interface: instead of immediately doing a posix_test_lock(), we first look for a matching block. If the subsequent test_lock returns anything other than -EINPROGRESS, we then remove the block we've found and return the results. If it returns -EINPROGRESS, then we defer the lock request. In the case where the block we find in the first step has B_QUEUED set, we bypass the vfs_test_lock entirely, instead using the block to decide how to respond: with nlm_lck_denied if B_TIMED_OUT is set. with nlm_granted if B_GOT_CALLBACK is set. by dropping if neither B_TIMED_OUT nor B_GOT_CALLBACK is set Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-05-06lockd: pass cookie in nlmsvc_testlockMarc Eshel
Change NLM internal interface to pass more information for test lock; we need this to make sure the cookie information is pushed down to the place where we do request deferral, which is handled for testlock by the following patch. Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-02-12[PATCH] knfsd: SUNRPC: Provide room in svc_rqst for larger addressesChuck Lever
Expand the rq_addr field to allow it to contain larger addresses. Specifically, we replace a 'sockaddr_in' with a 'sockaddr_storage', then everywhere the 'sockaddr_in' was referenced, we use instead an accessor function (svc_addr_in) which safely casts the _storage to _in. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] knfsd: SUNRPC: Add a function to format the address in an svc_rqst ↵Chuck Lever
for printing There are loads of places where the RPC server assumes that the rq_addr fields contains an IPv4 address. Top among these are error and debugging messages that display the server's IP address. Let's refactor the address printing into a separate function that's smart enough to figure out the difference between IPv4 and IPv6 addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-06NLM: fix print format for tk_pidChuck Lever
The tk_pid field is an unsigned short. The proper print format specifier for that type is %5u, not %4d. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-10-20[PATCH] lockd endianness annotationsAl Viro
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] fix svc_procfunc declarationAl Viro
svc_procfunc instances return __be32, not int Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] knfsd: Allow lockd to drop replies as appropriateNeilBrown
It is possible for the ->fopen callback from lockd into nfsd to find that an answer cannot be given straight away (an upcall is needed) and so the request has to be 'dropped', to be retried later. That error status is not currently propagated back. So: Change nlm_fopen to return nlm error codes (rather than a private protocol) and define a new nlm_drop_reply code. Cause nlm_drop_reply to cause the rpc request to get rpc_drop_reply when this error comes back. Cause svc_process to drop a request which returns a status of rpc_drop_reply. [akpm@osdl.org: fix warning storm] Cc: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: match GRANTED_RES replies using cookiesOlaf Kirch
When we send a GRANTED_MSG call, we current copy the NLM cookie provided in the original LOCK call - because in 1996, some broken clients seemed to rely on this bug. However, this means the cookies are not unique, so that when the client's GRANTED_RES message comes back, we cannot simply match it based on the cookie, but have to use the client's IP address in addition. Which breaks when you have a multi-homed NFS client. The X/Open spec explicitly mentions that clients should not expect the same cookie; so one may hope that any clients that were broken in 1996 have either been fixed or rendered obsolete. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: Make nlm_host_rebooted use the nsm_handleOlaf Kirch
This patch makes the SM_NOTIFY handling understand and use the nsm_handle. To make it a bit clear what is happening: nlmclent_prepare_reclaim and nlmclnt_finish_reclaim get open-coded into 'reclaimer' The result is tidied up. Then some of that functionality is moved out into nlm_host_rebooted (which calls nlmclnt_recovery which starts a thread which runs reclaimer). Also host_rebooted now finds an nsm_handle rather than a host, then then iterates over all hosts and deals with each host that shares that nsm_handle. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: when looking up a lockd host, pass hostname & lengthOlaf Kirch
This patch adds the peer's hostname (and name length) to all calls to nlm*_lookup_host functions. A subsequent patch will make use of these (is requested by a sysctl). Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: consolidate common code for statd->lockd notificationOlaf Kirch
Common code from nlm4svc_proc_sm_notify and nlmsvc_proc_sm_notify is moved into a new nlm_host_rebooted. This is in preparation of a patch that will change the reboot notification handling entirely. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: hide use of lockd's h_monitored flagOlaf Kirch
This patch moves all checks of the h_monitored flag into the nsm_monitor/unmonitor functions. A subsequent patch will replace the mechanism by which we mark a host as being monitored. There is still one occurence of h_monitored outside of mon.c and that is in clntlock.c where we respond to a reboot. The subsequent patch will modify this too. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20lockd: Add helper for *_RES callbacksTrond Myklebust
2006-03-20NLM: Add nlmclnt_release_callTrond Myklebust
Add a helper function to simplify the freeing of NLM client requests. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20lockd: Make nlmsvc_create_block() use nlmsvc_lookup_host()Trond Myklebust
Currently it uses nlmclnt_lookup_host(), which puts the resulting host structure on a different list. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-02-14[PATCH] NLM: Fix the NLM_GRANTED callback checksTrond Myklebust
If 2 threads attached to the same process are blocking on different locks on different files (maybe even on different servers) but have the same lock arguments (i.e. same offset+length - actually quite common, since most processes try to lock the entire file) then the first GRANTED call that wakes one up will also wake the other. Currently when the NLM_GRANTED callback comes in, lockd walks the list of blocked locks in search of a match to the lock that the NLM server has granted. Although it checks the lock pid, start and end, it fails to check the filehandle and the server address. By checking the filehandle and server IP address, we ensure that this only happens if the locks truly are referencing the same file. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06RPC: Clean up RPC task structureTrond Myklebust
Shrink the RPC task structure. Instead of storing separate pointers for task->tk_exit and task->tk_release, put them in a structure. Also pass the user data pointer as a parameter instead of passing it via task->tk_calldata. This enables us to nest callbacks. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
