path: root/fs/lockd/clntlock.c
2012-04-11Lockd: pass network namespace to creation and destruction routinesStanislav Kinsbursky
v2: dereference of most probably already released nlm_host removed in nlmclnt_done() and reclaimer(). These routines are called from locks reclaimer() kernel thread. This thread works in "init_net" network context and currently relays on persence on lockd thread and it's per-net resources. Thus lockd_up() and lockd_down() can't relay on current network context. So let's pass corrent one into them. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-02-15LockD: make nlm hosts network namespace awareStanislav Kinsbursky
This object depends on RPC client, and thus on network namespace. So let's make it's allocation and lookup in network namespace context. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Create client-side nlm_host cacheChuck Lever
NFS clients don't need the garbage collection processing that is performed on nlm_host structures. The client picks up an nlm_host at mount time and holds a reference to it until the file system is unmounted. Servers, on the other hand, don't have a precise way to tell when an nlm_host is no longer being used, so zero refcount nlm_host entries are left to expire in the cache after a time. Basically there's nothing holding a reference to an nlm_host between individual server-side NLM requests, but we can't afford the expense of recreating them for every new NLM request from a client. The nlm_host cache adds some lifetime hysteresis to entries in the cache so the next time a particular nlm_host is needed, it's likely to be discovered by a lookup rather than created from whole cloth. With the new implementation, client nlm_host cache items are no longer garbage collected, and are destroyed directly by a new release function specialized for client entries, nlmclnt_release_host(). They are cached in their own data structure, and have their own lookup logic, simplified and specialized for client nlm_host entries. However, the client nlm_host cache still shares reboot recovery logic with the server nlm_host cache. The NSM "peer rebooted" downcall for clients and servers still come through the same RPC call. This is a legacy formal API that would be difficult to alter, and besides, the user space NSM implementation can't tell the difference between peers that are clients or servers. For this reason, the client cache continues to share the nlm_host_mutex (and reboot recovery logic) with the server cache. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-22lockd: Remove BKL from the clientBryan Schumaker
This patch removes all calls to lock_kernel() from the client. This patch should be applied after the "fs/lock.c prepare for BKL removal" patch submitted by Arnd Bergmann on September 18. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-08-21sunrpc: add routine for comparing addressesJeff Layton
lockd needs these sort of routines, as does the NFSv4 callback code. Move lockd's routines into common code and rename them so that they can be used by others. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-03-28lockd: Start PF_INET6 listener only if IPv6 support is availableChuck Lever
Apparently a lot of people need to disable IPv6 completely on their distributor-built systems, which have CONFIG_IPV6_MODULE enabled at build time. They do this by blacklisting the ipv6.ko module. This causes the creation of the lockd service listener to fail if CONFIG_IPV6_MODULE is set, but the module cannot be loaded. Now that the kernel's PF_INET6 RPC listeners are completely separate from PF_INET listeners, we can always start PF_INET. Then lockd can try to start PF_INET6, but it isn't required to be available. Note this has the added benefit that NLM callbacks from AF_INET6 servers will never come from AF_INET remotes. We no longer have to worry about matching mapped IPv4 addresses to AF_INET when comparing addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-10NLM: Fix GRANT callback address comparison when IPv6 is enabledChuck Lever
The NFS mount command may pass an AF_INET server address to lockd. If lockd happens to be using a PF_INET6 listener, the nlm_cmp_addr() in nlmclnt_grant() will fail to match requests from that host because they will all have a mapped IPv4 AF_INET6 address. Adopt the same solution used in nfs_sockaddr_match_ipaddr() for NFSv4 callbacks: if either address is AF_INET, map it to an AF_INET6 address before doing the comparison. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NLM: allow lockd requests from an unprivileged portChuck Lever
If the admin has specified the "noresvport" option for an NFS mount point, the kernel's NFS client uses an unprivileged source port for the main NFS transport. The kernel's lockd client should use an unprivileged port in this case as well. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23lockd: convert reclaimer thread to kthread interfaceJeff Layton
My understanding is that there is a push to turn the kernel_thread interface into a non-exported symbol and move all kernel threads to use the kthread API. This patch changes lockd to use kthread_run to spawn the reclaimer thread. I've made the assumption here that the extra module references taken when we spawn this thread are unnecessary and removed them. I've also added a KERN_ERR printk that pops if the thread can't be spawned to warn the admin that the locks won't be reclaimed. In the future, it would be nice to be able to notify userspace that locks have been lost (probably by implementing SIGLOST), and adding some good policies about how long we should reattempt to reclaim the locks. Finally, I removed a comment about memory leaks that I believe is obsolete and added a new one to clarify the result of sending a SIGKILL to the reclaimer thread. As best I can tell, doing so doesn't actually cause a memory leak. I consider this patch 2.6.29 material. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-04NLM: Remove "proto" argument from lockd_up()Chuck Lever
Clean up: Now that lockd_up() starts listeners for both transports, the "proto" argument is no longer needed. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-10-03lockd: change nlmclnt_grant() to take a "struct sockaddr *"Chuck Lever
Adjust the signature and callers of nlmclnt_grant() to pass a "struct sockaddr *" instead of a "struct sockaddr_in *" in order to support IPv6 addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-10-03lockd: Adjust nlmclnt_lookup_host() signature to accomodate non-AF_INETChuck Lever
Pass a struct sockaddr * and a length to nlmclnt_lookup_host() to accomodate non-AF_INET family addresses. As a side benefit, eliminate the hostname_len argument, as the hostname is always NUL-terminated. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-09-29lockd: Teach nlm_cmp_addr() to support AF_INET6 addressesChuck Lever
Update the nlm_cmp_addr() helper to support AF_INET6 as well as AF_INET addresses. New version takes two "struct sockaddr *" arguments instead of "struct sockaddr_in *" arguments. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-09-29lockd: Use sockaddr_storage + length for h_addr fieldChuck Lever
To store larger addresses in the nlm_host structure, make h_addr a sockaddr_storage, and add an address length field. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-01-30NLM: Introduce an arguments structure for nlmclnt_init()Chuck Lever
Clean up: pass 5 arguments to nlmclnt_init() in a structure similar to the new nfs_client_initdata structure. Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
2008-01-30NLM: Introduce external nlm_host set-up and tear-down functionsChuck Lever
We would like to remove the per-lock-operation nlm_lookup_host() call from nlmclnt_proc(). The new architecture pins an nlm_host structure to each NFS client superblock that has the "lock" mount option set. The NFS client passes in the pinned nlm_host structure during each call to nlmclnt_proc(). NFS client unmount processing "puts" the nlm_host so it can be garbage- collected later. This patch introduces externally callable NLM functions that handle mount-time nlm_host set up and tear-down. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-14NLM: don't use CLONE_SIGHAND in nlmclnt_recoveryOleg Nesterov
reclaimer() calls allow_signal() which plays with parent process's ->sighand. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-01-30[PATCH] fs/lockd/clntlock.c: add missing newlines to dprintk'sAdrian Bunk
This patch adds missing newlines to dprintk's. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] lockd endianness annotationsAl Viro
Annotated, all places switched to keeping status net-endian. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert lockdJosef Sipek
2006-10-20[PATCH] lockd endianness annotationsAl Viro
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: fix use of h_nextrebindOlaf Kirch
nlmclnt_recovery would try to force a portmap rebind by setting host->h_nextrebind to 0. The right thing to do here is to set it to the current time. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: Make nlm_host_rebooted use the nsm_handleOlaf Kirch
This patch makes the SM_NOTIFY handling understand and use the nsm_handle. To make it a bit clear what is happening: nlmclent_prepare_reclaim and nlmclnt_finish_reclaim get open-coded into 'reclaimer' The result is tidied up. Then some of that functionality is moved out into nlm_host_rebooted (which calls nlmclnt_recovery which starts a thread which runs reclaimer). Also host_rebooted now finds an nsm_handle rather than a host, then then iterates over all hosts and deals with each host that shares that nsm_handle. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: introduce nsm_handleOlaf Kirch
This patch introduces the nsm_handle, which is shared by all nlm_host objects referring to the same client. With this patch applied, all nlm_hosts from the same address will share the same nsm_handle. A future patch will add sharing by name. Note: this patch changes h_name so that it is no longer guaranteed to be an IP address of the host. When the host represents an NFS server, h_name will be the name passed in the mount call. When the host represents a client, h_name will be the name presented in the lock request received from the client. A h_name is only used for printing informational messages, this change should not be significant. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: Correctly handle error condition from lockd_upNeilBrown
If lockd_up fails - what should we expect? Do we have to later call lockd_down? Well the nfs client thinks "no", the nfs server thinks "yes". lockd thinks "yes". The only answer that really makes sense is "no" !! So: Make lockd_up only increment nlmsvc_users on success. Make nfsd handle errors from lockd_up properly. Make sure lockd_up(0) never fails when lockd is running so that the 'reclaimer' call to lockd_up doesn't need to be error checked. Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: be more selective in which sockets lockd listens onNeilBrown
Currently lockd listens on UDP always, and TCP if CONFIG_NFSD_TCP is set. However as lockd performs services of the client as well, this is a problem. If CONFIG_NfSD_TCP is not set, and a tcp mount is used, the server will not be able to call back to lockd. So: - add an option to lockd_up saying which protocol is needed - Always open sockets for which an explicit port was given, otherwise only open a socket of the type required - Change nfsd to do one lockd_up per socket rather than one per thread. This - removes the dependancy on CONFIG_NFSD_TCP - means that lockd may open sockets other than at startup - means that lockd will *not* listen on UDP if the only mounts are TCP mount (and nfsd hasn't started). The latter is the only one that concerns me at all - I don't know if this might be a problem with some servers. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] add newline to nfs dprintkMartin Bligh
Add missing \n to dprintk Signed-off-by: Martin Bligh <mbligh@google.com> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-09NLM: Fix reclaim racesTrond Myklebust
Currently it is possible for a task to remove its locks at the same time as the NLM recovery thread is trying to recover them. This quickly leads to an Oops. Protect the locks using an rw semaphore while they are being recovered. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NLM: Simplify client locksTrond Myklebust
2006-03-20lockd: Fix Oopses due to list manipulation errors.Trond Myklebust
The patch "stop abusing file_lock_list introduces a couple of bugs since the locks may be copied and need to be removed from the lists when they are destroyed. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20lockd: stop abusing file_lock_listChristoph Hellwig
Currently lockd directly access the file_lock_list from fs/locks.c. It does so to mark locks granted or reclaimable. This is very suboptimal, because a) lockd needs to poke into locks.c internals, and b) it needs to iterate over all locks in the system for marking locks granted or reclaimable. This patch adds lists for granted and reclaimable locks to the nlm_host structure instead, and adds locks to those. nlmclnt_lock: now adds the lock to h_granted instead of setting the NFS_LCK_GRANTED, still O(1) nlmclnt_mark_reclaim: goes away completely, replaced by a list_splice_init. Complexity reduced from O(locks in the system) to O(1) reclaimer: iterates over h_reclaim now, complexity reduced from O(locks in the system) to O(locks per nlm_host) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20lockd: Don't expose the process pid to the NLM serverTrond Myklebust
Instead we use the nlm_lockowner->pid. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-02-14[PATCH] NLM: Fix the NLM_GRANTED callback checksTrond Myklebust
If 2 threads attached to the same process are blocking on different locks on different files (maybe even on different servers) but have the same lock arguments (i.e. same offset+length - actually quite common, since most processes try to lock the entire file) then the first GRANTED call that wakes one up will also wake the other. Currently when the NLM_GRANTED callback comes in, lockd walks the list of blocked locks in search of a match to the lock that the NLM server has granted. Although it checks the lock pid, start and end, it fails to check the filehandle and the server address. By checking the filehandle and server IP address, we ensure that this only happens if the locks truly are referencing the same file. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-19NLM: Fix Oops in nlmclnt_mark_reclaim()Trond Myklebust
When mixing -olock and -onolock mounts on the same client, we have to check that fl->fl_u.nfs_fl.owner is set before dereferencing it. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NLM: fix a client-side race on blocking locks.Trond Myklebust
If the lock blocks, the server may send us a GRANTED message that races with the reply to our LOCK request. Make sure that we catch the GRANTED by queueing up our request on the nlm_blocked list before we send off the first LOCK rpc call. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NLM: cleanup for blocked locks.Trond Myklebust
