path: root/fs/jfs/jfs_debug.c
2008-05-13JFS: switch to seq_filesAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2008-04-29proc: remove proc_root_fsAlexey Dobriyan
Use creation by full path instead: "fs/foo". Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-06JFS: use print_hex_dump() rather than private dump_mem() functionDave Kleikamp
2006-10-02JFS: White space cleanupDave Kleikamp
Removed trailing spaces & tabs, and spaces preceding tabs. Also a couple very minor comment cleanups. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> (cherry picked from f74156539964d7b3d5164fdf8848e6a682f75b97 commit)
2006-03-24[PATCH] fs: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a duplicate of ARRAY_SIZE. Some trailing whitespaces are also deleted. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Cc: David Howells <dhowells@redhat.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-04JFS: fix sparse warnings by moving extern declarations to headersDave Kleikamp
