path: root/fs/jffs2/readinode.c
2006-06-20Merge git://git.infradead.org/~dwmw2/rbtree-2.6Linus Torvalds
* git://git.infradead.org/~dwmw2/rbtree-2.6: [RBTREE] Switch rb_colour() et al to en_US spelling of 'color' for consistency Update UML kernel/physmem.c to use rb_parent() accessor macro [RBTREE] Update hrtimers to use rb_parent() accessor macro. [RBTREE] Add explicit alignment to sizeof(long) for struct rb_node. [RBTREE] Merge colour and parent fields of struct rb_node. [RBTREE] Remove dead code in rb_erase() [RBTREE] Update JFFS2 to use rb_parent() accessor macro. [RBTREE] Update eventpoll.c to use rb_parent() accessor macro. [RBTREE] Update key.c to use rb_parent() accessor macro. [RBTREE] Update ext3 to use rb_parent() accessor macro. [RBTREE] Change rbtree off-tree marking in I/O schedulers. [RBTREE] Add accessor macros for colour and parent fields of rb_node
2006-06-18[JFFS2] Check CRC32 on dirent and data nodes each time they're readDavid Woodhouse
Also, make sure dirents are marked REF_UNCHECKED when we 'discover' them through eraseblock summary. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-06-18[JFFS2] Don't trust node headers before the CRC is checked.David Woodhouse
Especially when summary code is used, we can have in-memory data structures referencing certain nodes without them actually being readable on the flash. Discard the nodes gracefully in that case, rather than triggering a BUG(). Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-04-21[RBTREE] Update JFFS2 to use rb_parent() accessor macro.David Woodhouse
2006-04-11[PATCH] jffs2: fix printk warningsRandy Dunlap
Fix printk format warnings in jffs2. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-03-09[PATCH] mtd: 64 bit fixesAtsushi Nemoto
Fix some bugs in mtd/jffs2 on 64bit platform. The MEMGETBADBLOCK/MEMSETBADBLOCK ioctl are not listed in compat_ioctl.h. And some variables in jffs2 are declared as uint32_t but used to hold size_t values. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[JFFS2] Clean up trailing white spacesThomas Gleixner
2005-11-06[JFFS2] Debug code simplification, update TODOArtem B. Bityutskiy
Simplify the debugging code further. Update the TODO list Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Calculate CRC check starting point correctlyArtem B. Bityutskiy
When data starts from the beginning of NAND page, 'len' must be zero, not c->wbuf_page. Thanks to Zoltan Sogor for reporting this problem. Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Fix JFFS2 [mc]time handlingArtem B. Bityutskiy
From: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Debug code clean up - step 7Artem B. Bityutskiy
Remove more noisy debugs. Add current->pid to debug messages. Remove bogus includes. Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Correct buggy length checksArtem B. Bityutskiy
The previous changes introduced wrong length calculations. Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Debug code clean up - step 6Artem B. Bityutskiy
Remove extra noisy debugs Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Build fragtree in reverse orderArtem B. Bityutskiy
Instead of building fragtree starting from node with the smallest version number, start from the highest. This helps to avoid reading and checking obsolete nodes. Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Move another fragtree-related function to nodelist.cArtem B. Bityutskiy
2005-11-06[JFFS2] Fix up new debug code for eCos buildAndrew Lunn
The debug code cleanup broke the eCos build. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Debug code clean up - step 5Artem B. Bityutskiy
Replace the D1(printk()) style debugging with the new debug macros Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Move scattered function into related filesArtem B. Bityutskiy
Move functions to read inodes into readinode.c Move functions to handle fragtree and dentry lists into nodelist.[ch] Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Namespace clean upArtem B. Bityutskiy
Rename functions to a name matching the functionality. Remove stall debug code Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Debug code clean up - step 3Artem B. Bityutskiy
Various simplifiactions. printk format corrections. Convert more code to use the new debug functions. Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Debug code clean up - step 2Artem B. Bityutskiy
If debugging is disabled, define debugging functions as empty macros, instead of using Dx() explicitly. Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Use f->target instead of f->dents for symlink targetArtem B. Bityutskiy
JFFS2 uses f->dents to store the pointer to the symlink target string (in case the inode is symlink). This is somewhat ugly to use the same field for different reasons. Introduce distinct field f->target for this purpose. Note, f->fragtree, f->dents, f->target may probably be put in a union. Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Debug code clean up - step 1Artem B. Bityutskiy
Move debug functions into a seperate source file Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-07-12[JFFS2] Remove needless variable initializationArtem B. Bityuckiy
Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-07-12[JFFS2] Avoid alloc/dealloc for zero sized nodesArtem B. Bityuckiy
2005-07-06[JFFS2] Optimise jffs2_add_tn_to_list David Woodhouse
Use an rbtree instead of a simple linked list. We were wasting an amazing amount of time in jffs2_add_tn_to_list(). Thanks to Artem Bityuckiy and Jarkko Jlavinen for noticing. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Add symlink caching support.Artem B. Bityuckiy
2005-05-23[JFFS2] Prevent ino cache removal for inodes in useDavid Woodhouse
Don't remove inocache for inodes which are in read_inode() or clear_inode() until they're done. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
