path: root/fs/jbd2/commit.c
2008-01-30spinlock: lockbreak cleanupNick Piggin
The break_lock data structure and code for spinlocks is quite nasty. Not only does it double the size of a spinlock but it changes locking to a potentially less optimal trylock. Put all of that under CONFIG_GENERIC_LOCKBREAK, and introduce a __raw_spin_is_contended that uses the lock data itself to determine whether there are waiters on the lock, to be used if CONFIG_GENERIC_LOCKBREAK is not set. Rename need_lockbreak to spin_needbreak, make it use spin_is_contended to decouple it from the spinlock implementation, and make it typesafe (rwlocks do not have any need_lockbreak sites -- why do they even get bloated up with that break_lock then?). Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-28ext4: Add the journal checksum featureGirish Shilamkar
The journal checksum feature adds two new flags i.e JBD2_FEATURE_INCOMPAT_ASYNC_COMMIT and JBD2_FEATURE_COMPAT_CHECKSUM. JBD2_FEATURE_CHECKSUM flag indicates that the commit block contains the checksum for the blocks described by the descriptor blocks. Due to checksums, writing of the commit record no longer needs to be synchronous. Now commit record can be sent to disk without waiting for descriptor blocks to be written to disk. This behavior is controlled using JBD2_FEATURE_ASYNC_COMMIT flag. Older kernels/e2fsck should not be able to recover the journal with _ASYNC_COMMIT hence it is made incompat. The commit header has been extended to hold the checksum along with the type of the checksum. For recovery in pass scan checksums are verified to ensure the sanity and completeness(in case of _ASYNC_COMMIT) of every transaction. Signed-off-by: Andreas Dilger <adilger@clusterfs.com> Signed-off-by: Girish Shilamkar <girish@clusterfs.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com>
2008-01-28jbd2: jbd2 stats through procfsJohann Lombardi
The patch below updates the jbd stats patch to 2.6.20/jbd2. The initial patch was posted by Alex Tomas in December 2005 (http://marc.info/?l=linux-ext4&m=113538565128617&w=2). It provides statistics via procfs such as transaction lifetime and size. Sometimes, investigating performance problems, i find useful to have stats from jbd about transaction's lifetime, size, etc. here is a patch for review and inclusion probably. for example, stats after creation of 3M files in htree directory: [root@bob ~]# cat /proc/fs/jbd/sda/history R/C tid wait run lock flush log hndls block inlog ctime write drop close R 261 8260 2720 0 0 750 9892 8170 8187 C 259 750 0 4885 1 R 262 20 2200 10 0 770 9836 8170 8187 R 263 30 2200 10 0 3070 9812 8170 8187 R 264 0 5000 10 0 1340 0 0 0 C 261 8240 3212 4957 0 R 265 8260 1470 0 0 4640 9854 8170 8187 R 266 0 5000 10 0 1460 0 0 0 C 262 8210 2989 4868 0 R 267 8230 1490 10 0 4440 9875 8171 8188 R 268 0 5000 10 0 1260 0 0 0 C 263 7710 2937 4908 0 R 269 7730 1470 10 0 3330 9841 8170 8187 R 270 0 5000 10 0 830 0 0 0 C 265 8140 3234 4898 0 C 267 720 0 4849 1 R 271 8630 2740 20 0 740 9819 8170 8187 C 269 800 0 4214 1 R 272 40 2170 10 0 830 9716 8170 8187 R 273 40 2280 0 0 3530 9799 8170 8187 R 274 0 5000 10 0 990 0 0 0 where, R - line for transaction's life from T_RUNNING to T_FINISHED C - line for transaction's checkpointing tid - transaction's id wait - for how long we were waiting for new transaction to start (the longest period journal_start() took in this transaction) run - real transaction's lifetime (from T_RUNNING to T_LOCKED lock - how long we were waiting for all handles to close (time the transaction was in T_LOCKED) flush - how long it took to flush all data (data=ordered) log - how long it took to write the transaction to the log hndls - how many handles got to the transaction block - how many blocks got to the transaction inlog - how many blocks are written to the log (block + descriptors) ctime - how long it took to checkpoint the transaction write - how many blocks have been written during checkpointing drop - how many blocks have been dropped during checkpointing close - how many running transactions have been closed to checkpoint this one all times are in msec. [root@bob ~]# cat /proc/fs/jbd/sda/info 280 transaction, each upto 8192 blocks average: 1633ms waiting for transaction 3616ms running transaction 5ms transaction was being locked 1ms flushing data (in ordered mode) 1799ms logging transaction 11781 handles per transaction 5629 blocks per transaction 5641 logged blocks per transaction Signed-off-by: Johann Lombardi <johann.lombardi@bull.net> Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Eric Sandeen <sandeen@redhat.com>
2008-01-28jbd2: Fix assertion failure in fs/jbd2/checkpoint.cJan Kara
Before we start committing a transaction, we call __journal_clean_checkpoint_list() to cleanup transaction's written-back buffers. If this call happens to remove all of them (and there were already some buffers), __journal_remove_checkpoint() will decide to free the transaction because it isn't (yet) a committing transaction and soon we fail some assertion - the transaction really isn't ready to be freed :). We change the check in __journal_remove_checkpoint() to free only a transaction in T_FINISHED state. The locking there is subtle though (as everywhere in JBD ;(). We use j_list_lock to protect the check and a subsequent call to __journal_drop_transaction() and do the same in the end of journal_commit_transaction() which is the only place where a transaction can get to T_FINISHED state. Probably I'm too paranoid here and such locking is not really necessary - checkpoint lists are processed only from log_do_checkpoint() where a transaction must be already committed to be processed or from __journal_clean_checkpoint_list() where kjournald itself calls it and thus transaction cannot change state either. Better be safe if something changes in future... Signed-off-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-10-17jbd2: fix commit code to properly abort journalJan Kara
We should really call journal_abort() and not __journal_abort_hard() in case of errors. The latter call does not record the error in the journal superblock and thus filesystem won't be marked as with errors later (and user could happily mount it without any warning). Signed-off-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-10-17jbd2: JBD_XXX to JBD2_XXX naming cleanupMingming Cao
change JBD_XXX macros to JBD2_XXX in JBD2/Ext4 Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2007-10-17JBD2: jbd2 slab allocation cleanupsMingming Cao
JBD2: Replace slab allocations with page allocations JBD2 allocate memory for committed_data and frozen_data from slab. However JBD2 should not pass slab pages down to the block layer. Use page allocator pages instead. This will also prepare JBD for the large blocksize patchset. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com>
2007-07-16jbd2 commit: fix transaction droppingJan Kara
We have to check that also the second checkpoint list is non-empty before dropping the transaction. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Chuck Ebbert <cebbert@redhat.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: <linux-ext4@vger.kernel.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] jbd2: wait for already submitted t_sync_datalist buffer to completeHisashi Hifumi
In the current jbd code, if a buffer on BJ_SyncData list is dirty and not locked, the buffer is refiled to BJ_Locked list, submitted to the IO and waited for IO completion. But the fsstress test showed the case that when a buffer was already submitted to the IO just before the buffer_dirty(bh) check, the buffer was not waited for IO completion. Following patch solves this problem. If it is assumed that a buffer is submitted to the IO before the buffer_dirty(bh) check and still being written to disk, this buffer is refiled to BJ_Locked list. Signed-off-by: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Cc: Jan Kara <jack@ucw.cz> Cc: "Stephen C. Tweedie" <sct@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: switch blks_type from sector_t to ullMingming Cao
Similar to ext4, change blocks in JBD2 from sector_t to unsigned long long. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: sector_t conversionMingming Cao
JBD layer in-kernel block varibles type fixes to support >32 bit block number and convert to sector_t type. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] 64-bit jbd2 coreZach Brown
Here is the patch to JBD to handle 64 bit block numbers, originally from Zach Brown. This patch is useful only after adding support for 64-bit block numbers in the filesystem. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: rename jbd2 symbols to avoid duplication of jbd symbolsMingming Cao
Mingming Cao originally did this work, and Shaggy reproduced it using some scripts from her. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: initial copy of files from jbdDave Kleikamp
This is a simple copy of the files in fs/jbd to fs/jbd2 and /usr/incude/linux/[ext4_]jbd.h to /usr/include/[ext4_]jbd2.h Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
