path: root/fs/jbd2/commit.c
2007-07-16jbd2 commit: fix transaction droppingJan Kara
We have to check that also the second checkpoint list is non-empty before dropping the transaction. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Chuck Ebbert <cebbert@redhat.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: <linux-ext4@vger.kernel.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] jbd2: wait for already submitted t_sync_datalist buffer to completeHisashi Hifumi
In the current jbd code, if a buffer on BJ_SyncData list is dirty and not locked, the buffer is refiled to BJ_Locked list, submitted to the IO and waited for IO completion. But the fsstress test showed the case that when a buffer was already submitted to the IO just before the buffer_dirty(bh) check, the buffer was not waited for IO completion. Following patch solves this problem. If it is assumed that a buffer is submitted to the IO before the buffer_dirty(bh) check and still being written to disk, this buffer is refiled to BJ_Locked list. Signed-off-by: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Cc: Jan Kara <jack@ucw.cz> Cc: "Stephen C. Tweedie" <sct@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: switch blks_type from sector_t to ullMingming Cao
Similar to ext4, change blocks in JBD2 from sector_t to unsigned long long. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: sector_t conversionMingming Cao
JBD layer in-kernel block varibles type fixes to support >32 bit block number and convert to sector_t type. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] 64-bit jbd2 coreZach Brown
Here is the patch to JBD to handle 64 bit block numbers, originally from Zach Brown. This patch is useful only after adding support for 64-bit block numbers in the filesystem. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: rename jbd2 symbols to avoid duplication of jbd symbolsMingming Cao
Mingming Cao originally did this work, and Shaggy reproduced it using some scripts from her. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: initial copy of files from jbdDave Kleikamp
This is a simple copy of the files in fs/jbd to fs/jbd2 and /usr/incude/linux/[ext4_]jbd.h to /usr/include/[ext4_]jbd2.h Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
