path: root/fs/jbd2/commit.c
2013-08-28jbd2: Fix endian mixing problems in the checksumming codeDarrick J. Wong
In the jbd2 checksumming code, explicitly declare separate variables with endianness information so that we don't get confused and screw things up again. Also fixes sparse warnings. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-06-12jbd2: fix duplicate debug label for phase 2Paul Gortmaker
Currently we see this output: $git grep phase fs/jbd2 fs/jbd2/commit.c: jbd_debug(3, "JBD2: commit phase 1\n"); fs/jbd2/commit.c: jbd_debug(3, "JBD2: commit phase 2\n"); fs/jbd2/commit.c: jbd_debug(3, "JBD2: commit phase 2\n"); fs/jbd2/commit.c: jbd_debug(3, "JBD2: commit phase 3\n"); fs/jbd2/commit.c: jbd_debug(3, "JBD2: commit phase 4\n"); [...] There is clearly a duplicate label for phase 2, and they are both active (i.e. not in #if ... #else block). Rename them to be "2a" and "2b" so the debug output is unambiguous. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-06-12jbd2: relocate assert after state lock in journal_commit_transaction()Paul Gortmaker
The state lock is taken after we are doing an assert on the state value, not before. So we might in fact be doing an assert on a transient value. Ensure the state check is within the scope of the state lock being taken. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-06-04jbd2: transaction reservation supportJan Kara
In some cases we cannot start a transaction because of locking constraints and passing started transaction into those places is not handy either because we could block transaction commit for too long. Transaction reservation is designed to solve these issues. It reserves a handle with given number of credits in the journal and the handle can be later attached to the running transaction without blocking on commit or checkpointing. Reserved handles do not block transaction commit in any way, they only reduce maximum size of the running transaction (because we have to always be prepared to accomodate request for attaching reserved handle). Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-06-04jbd2: refine waiting for shadow buffersJan Kara
Currently when we add a buffer to a transaction, we wait until the buffer is removed from BJ_Shadow list (so that we prevent any changes to the buffer that is just written to the journal). This can take unnecessarily long as a lot happens between the time the buffer is submitted to the journal and the time when we remove the buffer from BJ_Shadow list. (e.g. We wait for all data buffers in the transaction, we issue a cache flush, etc.) Also this creates a dependency of do_get_write_access() on transaction commit (namely waiting for data IO to complete) which we want to avoid when implementing transaction reservation. So we modify commit code to set new BH_Shadow flag when temporary shadowing buffer is created and we clear that flag once IO on that buffer is complete. This allows do_get_write_access() to wait only for BH_Shadow bit and thus removes the dependency on data IO completion. Reviewed-by: Zheng Liu <wenqing.lz@taobao.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-06-04jbd2: remove journal_head from descriptor buffersJan Kara
Similarly as for metadata buffers, also log descriptor buffers don't really need the journal head. So strip it and remove BJ_LogCtl list. Reviewed-by: Zheng Liu <wenqing.lz@taobao.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-06-04jbd2: don't create journal_head for temporary journal buffersJan Kara
When writing metadata to the journal, we create temporary buffer heads for that task. We also attach journal heads to these buffer heads but the only purpose of the journal heads is to keep buffers linked in transaction's BJ_IO list. We remove the need for journal heads by reusing buffer_head's b_assoc_buffers list for that purpose. Also since BJ_IO list is just a temporary list for transaction commit, we use a private list in jbd2_journal_commit_transaction() for that thus removing BJ_IO list from transaction completely. Reviewed-by: Zheng Liu <wenqing.lz@taobao.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-05-28jbd2: fix block tag checksum verification brokennessDarrick J. Wong
Al Viro complained of a ton of bogosity with regards to the jbd2 block tag header checksum. This one checksum is 16 bits, so cut off the upper 16 bits and treat it as a 16-bit value and don't mess around with be32* conversions. Fortunately metadata checksumming is still "experimental" and not in a shipping e2fsprogs, so there should be few users affected by this. Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
2013-04-03jbd2: fix race between jbd2_journal_remove_checkpoint and ->j_commit_callbackDmitry Monakhov
The following race is possible: [kjournald2] other_task jbd2_journal_commit_transaction() j_state = T_FINISHED; spin_unlock(&journal->j_list_lock); ->jbd2_journal_remove_checkpoint() ->jbd2_journal_free_transaction(); ->kmem_cache_free(transaction) ->j_commit_callback(journal, transaction); -> USE_AFTER_FREE WARNING: at lib/list_debug.c:62 __list_del_entry+0x1c0/0x250() Hardware name: list_del corruption. prev->next should be ffff88019a4ec198, but was 6b6b6b6b6b6b6b6b Modules linked in: cpufreq_ondemand acpi_cpufreq freq_table mperf coretemp kvm_intel kvm crc32c_intel ghash_clmulni_intel microcode sg xhci_hcd button sd_mod crc_t10dif aesni_intel ablk_helper cryptd lrw aes_x86_64 xts gf128mul ahci libahci pata_acpi ata_generic dm_mirror dm_region_hash dm_log dm_mod Pid: 16400, comm: jbd2/dm-1-8 Tainted: G W 3.8.0-rc3+ #107 Call Trace: [<ffffffff8106fb0d>] warn_slowpath_common+0xad/0xf0 [<ffffffff8106fc06>] warn_slowpath_fmt+0x46/0x50 [<ffffffff813637e9>] ? ext4_journal_commit_callback+0x99/0xc0 [<ffffffff8148cae0>] __list_del_entry+0x1c0/0x250 [<ffffffff813637bf>] ext4_journal_commit_callback+0x6f/0xc0 [<ffffffff813ca336>] jbd2_journal_commit_transaction+0x23a6/0x2570 [<ffffffff8108aa42>] ? try_to_del_timer_sync+0x82/0xa0 [<ffffffff8108b491>] ? del_timer_sync+0x91/0x1e0 [<ffffffff813d3ecf>] kjournald2+0x19f/0x6a0 [<ffffffff810ad630>] ? wake_up_bit+0x40/0x40 [<ffffffff813d3d30>] ? bit_spin_lock+0x80/0x80 [<ffffffff810ac6be>] kthread+0x10e/0x120 [<ffffffff810ac5b0>] ? __init_kthread_worker+0x70/0x70 [<ffffffff818ff6ac>] ret_from_fork+0x7c/0xb0 [<ffffffff810ac5b0>] ? __init_kthread_worker+0x70/0x70 In order to demonstrace this issue one should mount ext4 with mount -o discard option on SSD disk. This makes callback longer and race window becomes wider. In order to fix this we should mark transaction as finished only after callbacks have completed Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@vger.kernel.org
2013-02-06jbd2: track request delay statisticsTheodore Ts'o
Track the delay between when we first request that the commit begin and when it actually begins, so we can see how much of a gap exists. In theory, this should just be the remaining scheduling quantuum of the thread which requested the commit (assuming it was not a synchronous operation which triggered the commit request) plus scheduling overhead; however, it's possible that real time processes might get in the way of letting the kjournald thread from executing. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2012-09-26jbd2: fix assertion failure in commit code due to lacking transaction creditsJan Kara
ext4 users of data=journal mode with blocksize < pagesize were occasionally hitting assertion failure in jbd2_journal_commit_transaction() checking whether the transaction has at least as many credits reserved as buffers attached. The core of the problem is that when a file gets truncated, buffers that still need checkpointing or that are attached to the committing transaction are left with buffer_mapped set. When this happens to buffers beyond i_size attached to a page stradding i_size, subsequent write extending the file will see these buffers and as they are mapped (but underlying blocks were freed) things go awry from here. The assertion failure just coincidentally (and in this case luckily as we would start corrupting filesystem) triggers due to journal_head not being properly cleaned up as well. We fix the problem by unmapping buffers if possible (in lots of cases we just need a buffer attached to a transaction as a place holder but it must not be written out anyway). And in one case, we just have to bite the bullet and wait for transaction commit to finish. CC: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Jan Kara <jack@suse.cz>
2012-07-23jbd2: remove the second argument of kmap_atomicCong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
2012-05-27jbd2: checksum data blocks that are stored in the journalDarrick J. Wong
Calculate and verify checksums of each data block being stored in the journal. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2012-05-27jbd2: checksum commit blocksDarrick J. Wong
Calculate and verify the checksum of commit blocks. In checksum v2, deprecate most of the checksum v1 commit block checksum fields, since each block has its own checksum. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2012-05-27jbd2: checksum descriptor blocksDarrick J. Wong
Calculate and verify a checksum of each descriptor block. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2012-05-22jbd2: change disk layout for metadata checksummingDarrick J. Wong
Define flags and allocate space in on-disk journal structures to support checksumming of journal metadata. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2012-04-23jbd2: use GFP_NOFS for blkdev_issue_flushShaohua Li
flush request is issued in transaction commit code path, so looks using GFP_KERNEL to allocate memory for flush request bio falls into the classic deadlock issue. I saw btrfs and dm get it right, but ext4, xfs and md are using GFP. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Reviewed-by: Jan Kara <jack@suse.cz> Cc: stable@vger.kernel.org
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-28Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 updates for 3.4 from Ted Ts'o: "Ext4 commits for 3.3 merge window; mostly cleanups and bug fixes The changes to export dirty_writeback_interval are from Artem's s_dirt cleanup patch series. The same is true of the change to remove the s_dirt helper functions which never got used by anyone in-tree. I've run these changes by Al Viro, and am carrying them so that Artem can more easily fix up the rest of the file systems during the next merge window. (Originally we had hopped to remove the use of s_dirt from ext4 during this merge window, but his patches had some bugs, so I ultimately ended dropping them from the ext4 tree.)" * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (66 commits) vfs: remove unused superblock helpers mm: export dirty_writeback_interval ext4: remove useless s_dirt assignment ext4: write superblock only once on unmount ext4: do not mark superblock as dirty unnecessarily ext4: correct ext4_punch_hole return codes ext4: remove restrictive checks for EOFBLOCKS_FL ext4: always set then trimmed blocks count into len ext4: fix trimmed block count accunting ext4: fix start and len arguments handling in ext4_trim_fs() ext4: update s_free_{inodes,blocks}_count during online resize ext4: change some printk() calls to use ext4_msg() instead ext4: avoid output message interleaving in ext4_error_<foo>() ext4: remove trailing newlines from ext4_msg() and ext4_error() messages ext4: add no_printk argument validation, fix fallout ext4: remove redundant "EXT4-fs: " from uses of ext4_msg ext4: give more helpful error message in ext4_ext_rm_leaf() ext4: remove unused code from ext4_ext_map_blocks() ext4: rewrite punch hole to use ext4_ext_remove_space() jbd2: cleanup journal tail after transaction commit ...
2012-03-20jbd2: remove the second argument of k[un]map_atomic()Cong Wang
2012-03-13jbd2: cleanup journal tail after transaction commitJan Kara
Normally, we have to issue a cache flush before we can update journal tail in journal superblock, effectively wiping out old transactions from the journal. So use the fact that during transaction commit we issue cache flush anyway and opportunistically push journal tail as far as we can. Since update of journal superblock is still costly (we have to use WRITE_FUA), we update log tail only if we can free significant amount of space. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2012-03-13jbd2: issue cache flush after checkpointing even with internal journalJan Kara
When we reach jbd2_cleanup_journal_tail(), there is no guarantee that checkpointed buffers are on a stable storage - especially if buffers were written out by jbd2_log_do_checkpoint(), they are likely to be only in disk's caches. Thus when we update journal superblock effectively removing old transaction from journal, this write of superblock can get to stable storage before those checkpointed buffers which can result in filesystem corruption after a crash. Thus we must unconditionally issue a cache flush before we update journal superblock in these cases. A similar problem can also occur if journal superblock is written only in disk's caches, other transaction starts reusing space of the transaction cleaned from the log and power failure happens. Subsequent journal replay would still try to replay the old transaction but some of it's blocks may be already overwritten by the new transaction. For this reason we must use WRITE_FUA when updating log tail and we must first write new log tail to disk and update in-memory information only after that. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2012-03-13jbd2: protect all log tail updates with j_checkpoint_mutexJan Kara
There are some log tail updates that are not protected by j_checkpoint_mutex. Some of these are harmless because they happen during startup or shutdown but updates in jbd2_journal_commit_transaction() and jbd2_journal_flush() can really race with other log tail updates (e.g. someone doing jbd2_journal_flush() with someone running jbd2_cleanup_journal_tail()). So protect all log tail updates with j_checkpoint_mutex. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2012-03-13jbd2: split updating of journal superblock and marking journal emptyJan Kara
There are three case of updating journal superblock. In the first case, we want to mark journal as empty (setting s_sequence to 0), in the second case we want to update log tail, in the third case we want to update s_errno. Split these cases into separate functions. It makes the code slightly more straightforward and later patches will make the distinction even more important. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2012-02-20jbd2: allocate transaction from separate slab cacheYongqiang Yang
There is normally only a handful of these active at any one time, but putting them in a separate slab cache makes debugging memory corruption problems easier. Manish Katiyar also wanted this make it easier to test memory failure scenarios in the jbd2 layer. Cc: Manish Katiyar <mkatiyar@gmail.com> Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-12-28jbd2: clear revoked flag on buffers before a new transaction startedYongqiang Yang
Currently, we clear revoked flag only when a block is reused. However, this can tigger a false journal error. Consider a situation when a block is used as a meta block and is deleted(revoked) in ordered mode, then the block is allocated as a data block to a file. At this moment, user changes the file's journal mode from ordered to journaled and truncates the file. The block will be considered re-revoked by journal because it has revoked flag still pending from the last transaction and an assertion triggers. We fix the problem by keeping the revoked status more uptodate - we clear revoked flag when switching revoke tables to reflect there is no revoked buffers in current transaction any more. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-11-01jbd2: Unify log messages in jbd2 codeEryu Guan
Some jbd2 code prints out kernel messages with "JBD2: " prefix, at the same time other jbd2 code prints with "JBD: " prefix. Unify the prefix to "JBD2: ". Signed-off-by: Eryu Guan <guaneryu@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-06-13jbd2: Fix oops in jbd2_journal_remove_journal_head()Jan Kara
jbd2_journal_remove_journal_head() can oops when trying to access journal_head returned by bh2jh(). This is caused for example by the following race: TASK1 TASK2 jbd2_journal_commit_transaction() ... processing t_forget list __jbd2_journal_refile_buffer(jh); if (!jh->b_transaction) { jbd_unlock_bh_state(bh); jbd2_journal_try_to_free_buffers() jbd2_journal_grab_journal_head(bh) jbd_lock_bh_state(bh) __journal_try_to_free_buffer() jbd2_journal_put_journal_head(jh) jbd2_journal_remove_journal_head(bh); jbd2_journal_put_journal_head() in TASK2 sees that b_jcount == 0 and buffer is not part of any transaction and thus frees journal_head before TASK1 gets to doing so. Note that even buffer_head can be released by try_to_free_buffers() after jbd2_journal_put_journal_head() which adds even larger opportunity for oops (but I didn't see this happen in reality). Fix the problem by making transactions hold their own journal_head reference (in b_jcount). That way we don't have to remove journal_head explicitely via jbd2_journal_remove_journal_head() and instead just remove journal_head when b_jcount drops to zero. The result of this is that [__]jbd2_journal_refile_buffer(), [__]jbd2_journal_unfile_buffer(), and __jdb2_journal_remove_checkpoint() can free journal_head which needs modification of a few callers. Also we have to be careful because once journal_head is removed, buffer_head might be freed as well. So we have to get our own buffer_head reference where it matters. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-26Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (61 commits) jbd2: Add MAINTAINERS entry jbd2: fix a potential leak of a journal_head on an error path ext4: teach ext4_ext_split to calculate extents efficiently ext4: Convert ext4 to new truncate calling convention ext4: do not normalize block requests from fallocate() ext4: enable "punch hole" functionality ext4: add "punch hole" flag to ext4_map_blocks() ext4: punch out extents ext4: add new function ext4_block_zero_page_range() ext4: add flag to ext4_has_free_blocks ext4: reserve inodes and feature code for 'quota' feature ext4: add support for multiple mount protection ext4: ensure f_bfree returned by ext4_statfs() is non-negative ext4: protect bb_first_free in ext4_trim_all_free() with group lock ext4: only load buddy bitmap in ext4_trim_fs() when it is needed jbd2: Fix comment to match the code in jbd2__journal_start() ext4: fix waiting and sending of a barrier in ext4_sync_file() jbd2: Add function jbd2_trans_will_send_data_barrier() jbd2: fix sending of data flush on journal commit ext4: fix ext4_ext_fiemap_cb() to handle blocks before request range correctly ...
2011-05-24jbd2: Add function jbd2_trans_will_send_data_barrier()Jan Kara
Provide a function which returns whether a transaction with given tid will send a flush to the filesystem device. The function will be used by ext4 to detect whether fsync needs to send a separate flush or not. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-24jbd2: fix sending of data flush on journal commitJan Kara
In data=ordered mode, it's theoretically possible (however rare) that an inode is filed to transaction's t_inode_list and a flusher thread writes all the data and inode is reclaimed before the transaction starts to commit. In such a case, we could erroneously omit sending a flush to file system device when it is different from the journal device (because data can still be in disk cache only). Fix the problem by setting a flag in a transaction when some inode is added to it and then send disk flush in the commit code when the flag is set. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-17jbd/jbd2: remove obsolete summarise_journal_usage.Tao Ma
summarise_journal_usage seems to be obsolete for a long time, so remove it. Cc: Jan Kara <jack@suse.cz> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-05-08jbd2: Fix forever sleeping process in do_get_write_access()Jan Kara
In do_get_write_access() we wait on BH_Unshadow bit for buffer to get from shadow state. The waking code in journal_commit_transaction() has a bug because it does not issue a memory barrier after the buffer is moved from the shadow state and before wake_up_bit() is called. Thus a waitqueue check can happen before the buffer is actually moved from the shadow state and waiting process may never be woken. Fix the problem by issuing proper barrier. Reported-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-04-11Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: fix data corruption regression by reverting commit 6de9843dab3f ext4: Allow indirect-block file to grow the file size to max file size ext4: allow an active handle to be started when freezing ext4: sync the directory inode in ext4_sync_parent() ext4: init timer earlier to avoid a kernel panic in __save_error_info jbd2: fix potential memory leak on transaction commit ext4: fix a double free in ext4_register_li_request ext4: fix credits computing for indirect mapped files ext4: remove unnecessary [cm]time update of quota file jbd2: move bdget out of critical section
2011-04-05jbd2: fix potential memory leak on transaction commitZhang Huan
There is potential memory leak of journal head in function jbd2_journal_commit_transaction. The problem is that JBD2 will not reclaim the journal head of commit record if error occurs or journal is abotred. I use the following script to reproduce this issue, on a RHEL6 system. I found it very easy to reproduce with async commit enabled. mount /dev/sdb /mnt -o journal_checksum,journal_async_commit touch /mnt/xxx echo offline > /sys/block/sdb/device/state sync umount /mnt rmmod ext4 rmmod jbd2 Removal of the jbd2 module will make slab complaining that "cache `jbd2_journal_head': can't free all objects". Signed-off-by: Zhang Huan <zhhuan@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-03-17jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit pluggingJens Axboe
'write_op' was still used, even though it was always WRITE_SYNC now. Add plugging around the cases where it submits IO, and flush them before we end up waiting for that IO. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: kill off REQ_UNPLUGJens Axboe
With the plugging now being explicitly controlled by the submitter, callers need not pass down unplugging hints to the block layer. If they want to unplug, it's because they manually plugged on their own - in which case, they should just unplug at will. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-27Merge branch 'next' into upstream-mergeTheodore Ts'o
Conflicts: fs/ext4/inode.c fs/ext4/mballoc.c include/trace/events/ext4.h
2010-10-27jbd2: Fix I/O hang in jbd2_journal_release_jbd_inodeBrian King
This fixes a hang seen in jbd2_journal_release_jbd_inode on a lot of Power 6 systems running with ext4. When we get in the hung state, all I/O to the disk in question gets blocked where we stay indefinitely. Looking at the task list, I can see we are stuck in jbd2_journal_release_jbd_inode waiting on a wake up. I added some debug code to detect this scenario and dump additional data if we were stuck in jbd2_journal_release_jbd_inode for longer than 30 minutes. When it hit, I was able to see that i_flags was 0, suggesting we missed the wake up. This patch changes i_flags to be an unsigned long, uses bit operators to access it, and adds barriers around the accesses. Prior to applying this patch, we were regularly hitting this hang on numerous systems in our test environment. After applying the patch, the hangs no longer occur. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-22Merge branch 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits) xen-blkfront: disable barrier/flush write support Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c block: remove BLKDEV_IFL_WAIT aic7xxx_old: removed unused 'req' variable block: remove the BH_Eopnotsupp flag block: remove the BLKDEV_IFL_BARRIER flag block: remove the WRITE_BARRIER flag swap: do not send discards as barriers fat: do not send discards as barriers ext4: do not send discards as barriers jbd2: replace barriers with explicit flush / FUA usage jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier jbd: replace barriers with explicit flush / FUA usage nilfs2: replace barriers with explicit flush / FUA usage reiserfs: replace barriers with explicit flush / FUA usage gfs2: replace barriers with explicit flush / FUA usage btrfs: replace barriers with explicit flush / FUA usage xfs: replace barriers with explicit flush / FUA usage block: pass gfp_mask and flags to sb_issue_discard dm: convey that all flushes are processed as empty ...
2010-09-20cfq: improve fsync performance for small filesCorrado Zoccolo
Fsync performance for small files achieved by cfq on high-end disks is lower than what deadline can achieve, due to idling introduced between the sync write happening in process context and the journal commit. Moreover, when competing with a sequential reader, a process writing small files and fsync-ing them is starved. This patch fixes the two problems by: - marking journal commits as WRITE_SYNC, so that they get the REQ_NOIDLE flag set, - force all queues that have REQ_NOIDLE requests to be put in the noidle tree. Having the queue associated to the fsync-ing process and the one associated to journal commits in the noidle tree allows: - switching between them without idling, - fairness vs. competing idling queues, since they will be serviced only after the noidle tree expires its slice. Acked-by: Vivek Goyal <vgoyal@redhat.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Tested-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Corrado Zoccolo <czoccolo@gmail.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-16block: remove BLKDEV_IFL_WAITChristoph Hellwig
All the blkdev_issue_* helpers can only sanely be used for synchronous caller. To issue cache flushes or barriers asynchronously the caller needs to set up a bio by itself with a completion callback to move the asynchronous state machine ahead. So drop the BLKDEV_IFL_WAIT flag that is always specified when calling blkdev_issue_* and also remove the now unused flags argument to blkdev_issue_flush and blkdev_issue_zeroout. For blkdev_issue_discard we need to keep it for the secure discard flag, which gains a more descriptive name and loses the bitops vs flag confusion. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10jbd2: replace barriers with explicit flush / FUA usageChristoph Hellwig
Switch to the WRITE_FLUSH_FUA flag for journal commits and remove the EOPNOTSUPP detection for barriers. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrierJan Kara
Currently JBD2 relies blkdev_issue_flush() draining the queue when ASYNC_COMMIT feature is set. This property is going away so make JBD2 wait for buffers it needs on its own before submitting the cache flush. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-18kill BH_Ordered flagChristoph Hellwig
Instead of abusing a buffer_head flag just add a variant of sync_dirty_buffer which allows passing the exact type of write flag required. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-03jbd2: Remove t_handle_lock from start_this_handle()Theodore Ts'o
This should remove the last exclusive lock from start_this_handle(), so that we should now be able to start multiple transactions at the same time on large SMP systems. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-08-03jbd2: Change j_state_lock to be a rwlock_tTheodore Ts'o
Lockstat reports have shown that j_state_lock is a major source of lock contention, especially on systems with more than 4 CPU cores. So change it to be a read/write spinlock. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-08-02jbd2: Use atomic variables to avoid taking t_handle_lock in jbd2_journal_stopTheodore Ts'o
By using an atomic_t for t_updates and t_outstanding credits, this should allow us to not need to take transaction t_handle_lock in jbd2_journal_stop(). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
