path: root/fs/inode.c
2006-03-25[PATCH] fs/inode.c: make iprune_mutex staticAdrian Bunk
There's no reason for iprune_mutex being global. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread slab cache hooksPaul Jackson
Change the kmem_cache_create calls for certain slab caches to support cpuset memory spreading. See the previous patches, cpuset_mem_spread, for an explanation of cpuset memory spreading, and cpuset_mem_spread_slab_cache for the slab cache support for memory spreading. The slab caches marked for now are: dentry_cache, inode_cache, some xfs slab caches, and buffer_head. This list may change over time. In particular, other file system types that are used extensively on large NUMA systems may want to allow for spreading their directory and inode slab cache entries. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: ipruneIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: inotifyIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: John McCutchan <ttb@tentacle.dhs.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Acked-by: Robert Love <rml@novell.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] DocBook: fix some kernel-doc comments in fs and blockMartin Waitz
Update some parameter descriptions to actually match the code. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] per-mountpoint noatime/nodiratimeChristoph Hellwig
Turn noatime and nodiratime into per-mount instead of per-sb flags. After all the preparations this is a rather trivial patch. The mount code needs to treat the two options as per-mount instead of per-superblock, and touch_atime needs to be changed to check the new MNT_ flags in addition to the MS_ flags that are kept for filesystems that are always noatime/nodiratime but not user settable anymore. Besides that core code only nfs needed an update because it's leaving atime updates to the server and thus sets the S_NOATIME flag on every inode, but needs to know whether it's a real noatime mount for an getattr optimization. While we're at it I've killed the IS_NOATIME/IS_NODIRATIME macros that were only used by touch_atime. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] remove update_atimeChristoph Hellwig
All callers use touch_atime now which takes a vfsmount and allows us to implement per-mount noatime. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] replace inode_update_time with file_update_timeChristoph Hellwig
To allow various options to work per-mount instead of per-sb we need a struct vfsmount when updating ctime and mtime. This preparation patch replaces the inode_update_time routine with a file_update_atime routine so we can easily get at the vfsmount. (and the file makes more sense in this context anyway). Also get rid of the unused second argument - we always want to update the ctime when calling this routine. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-08[PATCH] tiny: Uninline some inode.c functionsMatt Mackall
uninline a couple inode.c functions add/remove: 2/0 grow/shrink: 0/5 up/down: 256/-428 (-172) function old new delta ifind - 136 +136 ifind_fast - 120 +120 ilookup5_nowait 131 80 -51 ilookup 158 71 -87 ilookup5 171 80 -91 iget_locked 190 95 -95 iget5_locked 240 136 -104 Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] fix nr_unused accounting, and avoid recursing in iput with ↵Andrea Arcangeli
I_WILL_FREE set list_move(&inode->i_list, &inode_in_use); } else { list_move(&inode->i_list, &inode_unused); + inodes_stat.nr_unused++; } } wake_up_inode(inode); Are you sure the above diff is correct? It was added somewhere between 2.6.5 and 2.6.8. I think it's wrong. The only way I can imagine the i_count to be zero in the above path, is that I_WILL_FREE is set. And if I_WILL_FREE is set, then we must not increase nr_unused. So I believe the above change is buggy and it will definitely overstate the number of unused inodes and it should be backed out. Note that __writeback_single_inode before calling __sync_single_inode, can drop the spinlock and we can have both the dirty and locked bitflags clear here: spin_unlock(&inode_lock); __wait_on_inode(inode); iput(inode); XXXXXXX spin_lock(&inode_lock); } use inode again here a construct like the above makes zero sense from a reference counting standpoint. Either we don't ever use the inode again after the iput, or the inode_lock should be taken _before_ executing the iput (i.e. a __iput would be required). Taking the inode_lock after iput means the iget was useless if we keep using the inode after the iput. So the only chance the 2.6 was safe to call __writeback_single_inode with the i_count == 0, is that I_WILL_FREE is set (I_WILL_FREE will prevent the VM to free the inode in XXXXX). Potentially calling the above iput with I_WILL_FREE was also wrong because it would recurse in iput_final (the second mainline bug). The below (untested) patch fixes the nr_unused accounting, avoids recursing in iput when I_WILL_FREE is set and makes sure (with the BUG_ON) that we don't corrupt memory and that all holders that don't set I_WILL_FREE, keeps a reference on the inode! Signed-off-by: Andrea Arcangeli <andrea@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: fs/*Al Viro
- ->releasepage() annotated (s/int/gfp_t), instances updated - missing gfp_t in fs/* added - fixed misannotation from the original sweep caught by bitwise checks: XFS used __nocast both for gfp_t and for flags used by XFS allocator. The latter left with unsigned int __nocast; we might want to add a different type for those but for now let's leave them alone. That, BTW, is a case when __nocast use had been actively confusing - it had been used in the same code for two different and similar types, with no way to catch misuses. Switch of gfp_t to bitwise had caught that immediately... One tricky bit is left alone to be dealt with later - mapping->flags is a mix of gfp_t and error indications. Left alone for now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] move truncate_inode_pages() into ->delete_inode()Mark Fasheh
Allow file systems supporting ->delete_inode() to call truncate_inode_pages() on their own. OCFS2 wants this so it can query the cluster before making a final decision on whether to wipe an inode from disk or not. In some corner cases an inode marked on the local node via voting may not actually get orphaned. A good example is node death before the transaction moving the inode to the orphan dir commits to the journal. Without this patch, the truncate_inode_pages() call in generic_delete_inode() would discard valid data for such inodes. During earlier discussion in the 2.6.13 merge plan thread, Christoph Hellwig indicated that other file systems might also find this useful. IMHO, the best solution would be to just allow ->drop_inode() to do the cluster query but it seems that would require a substantial reworking of that section of the code. Assuming it is safe to call write_inode_now() in ocfs2_delete_inode() for those inodes which won't actually get wiped, this solution should get us by for now. Trivial testing of this patch (and a related OCFS2 update) has shown this to avoid the corruption I'm seeing. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] fs: remove redundant timespec_equal test in update_atime()Tejun Heo
In update_atime(), timespec_equal() test is done twice in succession and the second is always false. This patch removes the second test. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-13[PATCH] Fix soft lockup due to NTFS: VFS part and explanationAnton Altaparmakov
Something has changed in the core kernel such that we now get concurrent inode write outs, one e.g via pdflush and one via sys_sync or whatever. This causes a nasty deadlock in ntfs. The only clean solution unfortunately requires a minor vfs api extension. First the deadlock analysis: Prerequisive knowledge: NTFS has a file $MFT (inode 0) loaded at mount time. The NTFS driver uses the page cache for storing the file contents as usual. More interestingly this file contains the table of on-disk inodes as a sequence of MFT_RECORDs. Thus NTFS driver accesses the on-disk inodes by accessing the MFT_RECORDs in the page cache pages of the loaded inode $MFT. The situation: VFS inode X on a mounted ntfs volume is dirty. For same inode X, the ntfs_inode is dirty and thus corresponding on-disk inode, which is as explained above in a dirty PAGE_CACHE_PAGE belonging to the table of inodes ($MFT, inode 0). What happens: Process 1: sys_sync()/umount()/whatever... calls __sync_single_inode() for $MFT -> do_writepages() -> write_page for the dirty page containing the on-disk inode X, the page is now locked -> ntfs_write_mst_block() which clears PageUptodate() on the page to prevent anyone else getting hold of it whilst it does the write out (this is necessary as the on-disk inode needs "fixups" applied before the write to disk which are removed again after the write and PageUptodate is then set again). It then analyses the page looking for dirty on-disk inodes and when it finds one it calls ntfs_may_write_mft_record() to see if it is safe to write this on-disk inode. This then calls ilookup5() to check if the corresponding VFS inode is in icache(). This in turn calls ifind() which waits on the inode lock via wait_on_inode whilst holding the global inode_lock. Process 2: pdflush results in a call to __sync_single_inode for the same VFS inode X on the ntfs volume. This locks the inode (I_LOCK) then calls write-inode -> ntfs_write_inode -> map_mft_record() -> read_cache_page() of the page (in page cache of table of inodes $MFT, inode 0) containing the on-disk inode. This page has PageUptodate() clear because of Process 1 (see above) so read_cache_page() blocks when tries to take the page lock for the page so it can call ntfs_read_page(). Thus Process 1 is holding the page lock on the page containing the on-disk inode X and it is waiting on the inode X to be unlocked in ifind() so it can write the page out and then unlock the page. And Process 2 is holding the inode lock on inode X and is waiting for the page to be unlocked so it can call ntfs_readpage() or discover that Process 1 set PageUptodate() again and use the page. Thus we have a deadlock due to ifind() waiting on the inode lock. The only sensible solution: NTFS does not care whether the VFS inode is locked or not when it calls ilookup5() (it doesn't use the VFS inode at all, it just uses it to find the corresponding ntfs_inode which is of course attached to the VFS inode (both are one single struct); and it uses the ntfs_inode which is subject to its own locking so I_LOCK is irrelevant) hence we want a modified ilookup5_nowait() which is the same as ilookup5() but it does not wait on the inode lock. Without such functionality I would have to keep my own ntfs_inode cache in the NTFS driver just so I can find ntfs_inodes independent of their VFS inodes which would be slow, memory and cpu cycle wasting, and incredibly stupid given the icache already exists in the VFS. Below is a patch that does the ilookup5_nowait() implementation in fs/inode.c and exports it. ilookup5_nowait.diff: Introduce ilookup5_nowait() which is basically the same as ilookup5() but it does not wait on the inode's lock (i.e. it omits the wait_on_inode() done in ifind()). This is needed to avoid a nasty deadlock in NTFS. Signed-off-by: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] inotifyRobert Love
inotify is intended to correct the deficiencies of dnotify, particularly its inability to scale and its terrible user interface: * dnotify requires the opening of one fd per each directory that you intend to watch. This quickly results in too many open files and pins removable media, preventing unmount. * dnotify is directory-based. You only learn about changes to directories. Sure, a change to a file in a directory affects the directory, but you are then forced to keep a cache of stat structures. * dnotify's interface to user-space is awful. Signals? inotify provides a more usable, simple, powerful solution to file change notification: * inotify's interface is a system call that returns a fd, not SIGIO. You get a single fd, which is select()-able. * inotify has an event that says "the filesystem that the item you were watching is on was unmounted." * inotify can watch directories or files. Inotify is currently used by Beagle (a desktop search infrastructure), Gamin (a FAM replacement), and other projects. See Documentation/filesystems/inotify.txt. Signed-off-by: Robert Love <rml@novell.com> Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] bugfix: two read_inode() calls without clear_inode() call betweenArtem B. Bityuckiy
Bug symptoms ~~~~~~~~~~~~ For the same inode VFS calls read_inode() twice and doesn't call clear_inode() between the two read_inode() invocations. Bug description ~~~~~~~~~~~~~~~ Suppose we have an inode which has zero reference count but is still in the inode cache. Suppose kswapd invokes shrink_icache_memory() to free some RAM. In prune_icache() inodes are removed from i_hash. prune_icache () is then going to call clear_inode(), but drops the inode_lock spinlock before this. If in this moment another task calls iget() for an inode which was just removed from i_hash by prune_icache(), then iget() invokes read_inode() for this inode, because it is *already removed* from i_hash. The end result is: we call iget(#N) then iput(#N); inode #N has zero i_count now and is in the inode cache; kswapd starts. kswapd removes the inode #N from i_hash ans is preempted; we call iget(#N) again; read_inode() is invoked as the result; but we expect clear_inode() before. Fix ~~~~~~~ To fix the bug I remove inodes from i_hash later, when clear_inode() is actually called. I remove them from i_hash under spinlock protection. Since the i_state is set to I_FREEING, it is safe to do this. The others will sleep waiting for the inode state change. I also postpone removing inodes from i_sb_list. It is not compulsory to do so but I do it for readability reasons. Inodes are added/removed to the lists together everywhere in the code and there is no point to change this rule. This is harmless because the only user of i_sb_list which somehow may interfere with me (invalidate_list()) is excluded by the iprune_sem mutex. The same race is possible in invalidate_list() so I do the same for it. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] __wait_on_freeing_inode fixMiklos Szeredi
This patch fixes queer behavior in __wait_on_freeing_inode(). If I_LOCK was not set it called yield(), effectively busy waiting for the removal of the inode from the hash. This change was introduced within "[PATCH] eliminate inode waitqueue hashtable" Changeset 1.1938.166.16 last october by wli. The solution is to restore the old behavior, of unconditionally waiting on the waitqueue. It doesn't matter if I_LOCK is not set initally, the task will go to sleep, and wake up when wake_up_inode() is called from generic_delete_inode() after removing the inode from the hash chain. Comment is also updated to better reflect current behavior. This condition is very hard to trigger normally (simultaneous clear_inode() with iget()) so probably only heavy stress testing can reveal any change of behavior. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] export generic_drop_inode() to modulesMark Fasheh
OCFS2 wants to mark an inode which has been orphaned by another node so that during final iput it takes the correct path through the VFS and can pass through the OCFS2 delete_inode callback. Since i_nlink can get out of date with other nodes, the best way I see to accomplish this is by clearing i_nlink on those inodes at drop_inode time. Other than this small amount of work, nothing different needs to happen, so I think it would be cleanest to be able to just call generic_drop_inode at the end of the OCFS2 drop_inode callback. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] fix for prune_icache()/forced final iput() racesAlexander Viro
Based on analysis and a patch from Russ Weight <rweight@us.ibm.com> There is a race condition that can occur if an inode is allocated and then released (using iput) during the ->fill_super functions. The race condition is between kswapd and mount. For most filesystems this can only happen in an error path when kswapd is running concurrently. For isofs, however, the error can occur in a more common code path (which is how the bug was found). The logic here is "we want final iput() to free inode *now* instead of letting it sit in cache if fs is going down or had not quite come up". The problem is with kswapd seeing such inodes in the middle of being killed and happily taking over. The clean solution would be to tell kswapd to leave those inodes alone and let our final iput deal with them. I.e. add a new flag (I_FORCED_FREEING), set it before write_inode_now() there and make prune_icache() leave those alone. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] remove do_sync parameter from __invalidate_deviceChristoph Hellwig
The only caller that ever sets it can call fsync_bdev itself easily. Also update some comments. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] avoid -ENOMEM due reclaimable slab cachesAndrea Arcangeli
This makes sure that reclaimable buffer headers and reclaimable inodes are accounted properly during the overcommit checks. Signed-off-by: Andrea Arcangeli <andrea@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
