path: root/fs/hugetlbfs/inode.c
2015-01-20fs: remove mapping->backing_dev_infoChristoph Hellwig
Now that we never use the backing_dev_info pointer in struct address_space we can simply remove it and save 4 to 8 bytes in every inode. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Reviewed-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-01-20fs: deduplicate noop_backing_dev_infoChristoph Hellwig
hugetlbfs, kernfs and dlmfs can simply use noop_backing_dev_info instead of creating a local duplicate. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jan Kara <jack@suse.cz> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-12-13mm: convert i_mmap_mutex to rwsemDavidlohr Bueso
The i_mmap_mutex is a close cousin of the anon vma lock, both protecting similar data, one for file backed pages and the other for anon memory. To this end, this lock can also be a rwsem. In addition, there are some important opportunities to share the lock when there are no tree modifications. This conversion is straightforward. For now, all users take the write lock. [sfr@canb.auug.org.au: update fremap.c] Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: "Kirill A. Shutemov" <kirill@shutemov.name> Acked-by: Hugh Dickins <hughd@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-13mm: use new helper functions around the i_mmap_mutexDavidlohr Bueso
Convert all open coded mutex_lock/unlock calls to the i_mmap_[lock/unlock]_write() helpers. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: "Kirill A. Shutemov" <kirill@shutemov.name> Acked-by: Hugh Dickins <hughd@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04fs/hugetlbfs/inode.c: remove null test before kfreeFabian Frederick
Fix checkpatch warning: WARNING: kfree(NULL) is safe this check is probably not required Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04fs/hugetlbfs/inode.c: use static const for dentry_operationsFabian Frederick
...like other filesystems. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04fs/hugetlbfs/inode.c: add static to hugetlbfs_i_mmap_mutex_keyFabian Frederick
hugetlbfs_i_mmap_mutex_key is only used in inode.c Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04fs/hugetlbfs/inode.c: complete conversion to pr_foo()Andrew Morton
2014-05-06hugetlb: ensure hugepage access is denied if hugepages are not supportedNishanth Aravamudan
Currently, I am seeing the following when I `mount -t hugetlbfs /none /dev/hugetlbfs`, and then simply do a `ls /dev/hugetlbfs`. I think it's related to the fact that hugetlbfs is properly not correctly setting itself up in this state?: Unable to handle kernel paging request for data at address 0x00000031 Faulting instruction address: 0xc000000000245710 Oops: Kernel access of bad area, sig: 11 [#1] SMP NR_CPUS=2048 NUMA pSeries .... In KVM guests on Power, in a guest not backed by hugepages, we see the following: AnonHugePages: 0 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 64 kB HPAGE_SHIFT == 0 in this configuration, which indicates that hugepages are not supported at boot-time, but this is only checked in hugetlb_init(). Extract the check to a helper function, and use it in a few relevant places. This does make hugetlbfs not supported (not registered at all) in this environment. I believe this is fine, as there are no valid hugepages and that won't change at runtime. [akpm@linux-foundation.org: use pr_info(), per Mel] [akpm@linux-foundation.org: fix build when HPAGE_SHIFT is undefined] Signed-off-by: Nishanth Aravamudan <nacc@linux.vnet.ibm.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm, hugetlb: unify region structure handlingJoonsoo Kim
Currently, to track reserved and allocated regions, we use two different ways, depending on the mapping. For MAP_SHARED, we use address_mapping's private_list and, while for MAP_PRIVATE, we use a resv_map. Now, we are preparing to change a coarse grained lock which protect a region structure to fine grained lock, and this difference hinder it. So, before changing it, unify region structure handling, consistently using a resv_map regardless of the kind of mapping. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-24cope with potentially long ->d_dname() output for shmem/hugetlbAl Viro
dynamic_dname() is both too much and too little for those - the output may be well in excess of 64 bytes dynamic_dname() assumes to be enough (thanks to ashmem feeding really long names to shmem_file_setup()) and vsnprintf() is an overkill for those guys. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-08-13hugetlb: fix lockdep splat caused by pmd sharingMichal Hocko
Dave has reported the following lockdep splat: ================================= [ INFO: inconsistent lock state ] 3.11.0-rc1+ #9 Not tainted --------------------------------- inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-W} usage. kswapd0/49 [HC0[0]:SC0[0]:HE1:SE1] takes: (&mapping->i_mmap_mutex){+.+.?.}, at: [<c114971b>] page_referenced+0x87/0x5e3 {RECLAIM_FS-ON-W} state was registered at: mark_held_locks+0x81/0xe7 lockdep_trace_alloc+0x5e/0xbc __alloc_pages_nodemask+0x8b/0x9b6 __get_free_pages+0x20/0x31 get_zeroed_page+0x12/0x14 __pmd_alloc+0x1c/0x6b huge_pmd_share+0x265/0x283 huge_pte_alloc+0x5d/0x71 hugetlb_fault+0x7c/0x64a handle_mm_fault+0x255/0x299 __do_page_fault+0x142/0x55c do_page_fault+0xd/0x16 error_code+0x6c/0x74 irq event stamp: 3136917 hardirqs last enabled at (3136917): _raw_spin_unlock_irq+0x27/0x50 hardirqs last disabled at (3136916): _raw_spin_lock_irq+0x15/0x78 softirqs last enabled at (3136180): __do_softirq+0x137/0x30f softirqs last disabled at (3136175): irq_exit+0xa8/0xaa other info that might help us debug this: Possible unsafe locking scenario: CPU0 ---- lock(&mapping->i_mmap_mutex); <Interrupt> lock(&mapping->i_mmap_mutex); *** DEADLOCK *** no locks held by kswapd0/49. stack backtrace: CPU: 1 PID: 49 Comm: kswapd0 Not tainted 3.11.0-rc1+ #9 Hardware name: Dell Inc. Precision WorkStation 490 /0DT031, BIOS A08 04/25/2008 Call Trace: dump_stack+0x4b/0x79 print_usage_bug+0x1d9/0x1e3 mark_lock+0x1e0/0x261 __lock_acquire+0x623/0x17f2 lock_acquire+0x7d/0x195 mutex_lock_nested+0x6c/0x3a7 page_referenced+0x87/0x5e3 shrink_page_list+0x3d9/0x947 shrink_inactive_list+0x155/0x4cb shrink_lruvec+0x300/0x5ce shrink_zone+0x53/0x14e kswapd+0x517/0xa75 kthread+0xa8/0xaa ret_from_kernel_thread+0x1b/0x28 which is a false positive caused by hugetlb pmd sharing code which allocates a new pmd from withing mapping->i_mmap_mutex. If this allocation causes reclaim then the lockdep detector complains that we might self-deadlock. This is not correct though, because hugetlb pages are not reclaimable so their mapping will be never touched from the reclaim path. The patch tells lockup detector that hugetlb i_mmap_mutex is special by assigning it a separate lockdep class so it won't report possible deadlocks on unrelated mappings. [peterz@infradead.org: comment for annotation] Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07hugetlbfs: fix mmap failure in unaligned size requestNaoya Horiguchi
The current kernel returns -EINVAL unless a given mmap length is "almost" hugepage aligned. This is because in sys_mmap_pgoff() the given length is passed to vm_mmap_pgoff() as it is without being aligned with hugepage boundary. This is a regression introduced in commit 40716e29243d ("hugetlbfs: fix alignment of huge page requests"), where alignment code is pushed into hugetlb_file_setup() and the variable len in caller side is not changed. To fix this, this patch partially reverts that commit, and adds alignment code in caller side. And it also introduces hstate_sizelog() in order to get proper hstate to specified hugepage size. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=56881 [akpm@linux-foundation.org: fix warning when CONFIG_HUGETLB_PAGE=n] Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: <iceman_dvd@yahoo.com> Cc: Steven Truelove <steven.truelove@utoronto.ca> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-17hugetlbfs: stop setting VM_DONTDUMP in initializing vma(VM_HUGETLB)Naoya Horiguchi
Currently we fail to include any data on hugepages into coredump, because VM_DONTDUMP is set on hugetlbfs's vma. This behavior was recently introduced by commit 314e51b9851b ("mm: kill vma flag VM_RESERVED and mm->reserved_vm counter"). This looks to me a serious regression, so let's fix it. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Acked-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Cc: <stable@vger.kernel.org> [3.7+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-26hugetlb_file_setup(): use d_alloc_pseudo()Al Viro
2013-02-22fs: Preserve error code in get_empty_filp(), part 2Anatol Pomozov
Allocating a file structure in function get_empty_filp() might fail because of several reasons: - not enough memory for file structures - operation is not allowed - user is over its limit Currently the function returns NULL in all cases and we loose the exact reason of the error. All callers of get_empty_filp() assume that the function can fail with ENFILE only. Return error through pointer. Change all callers to preserve this error code. [AV: cleaned up a bit, carved the get_empty_filp() part out into a separate commit (things remaining here deal with alloc_file()), removed pipe(2) behaviour change] Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-22new helper: file_inode(file)Al Viro
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-12-11mm: adjust address_space_operations.migratepage() return codeRafael Aquini
Memory fragmentation introduced by ballooning might reduce significantly the number of 2MB contiguous memory blocks that can be used within a guest, thus imposing performance penalties associated with the reduced number of transparent huge pages that could be used by the guest workload. This patch-set follows the main idea discussed at 2012 LSFMMS session: "Ballooning for transparent huge pages" -- http://lwn.net/Articles/490114/ to introduce the required changes to the virtio_balloon driver, as well as the changes to the core compaction & migration bits, in order to make those subsystems aware of ballooned pages and allow memory balloon pages become movable within a guest, thus avoiding the aforementioned fragmentation issue Following are numbers that prove this patch benefits on allowing compaction to be more effective at memory ballooned guests. Results for STRESS-HIGHALLOC benchmark, from Mel Gorman's mmtests suite, running on a 4gB RAM KVM guest which was ballooning 512mB RAM in 64mB chunks, at every minute (inflating/deflating), while test was running: ===BEGIN stress-highalloc STRESS-HIGHALLOC highalloc-3.7 highalloc-3.7 rc4-clean rc4-patch Pass 1 55.00 ( 0.00%) 62.00 ( 7.00%) Pass 2 54.00 ( 0.00%) 62.00 ( 8.00%) while Rested 75.00 ( 0.00%) 80.00 ( 5.00%) MMTests Statistics: duration 3.7 3.7 rc4-clean rc4-patch User 1207.59 1207.46 System 1300.55 1299.61 Elapsed 2273.72 2157.06 MMTests Statistics: vmstat 3.7 3.7 rc4-clean rc4-patch Page Ins 3581516 2374368 Page Outs 11148692 10410332 Swap Ins 80 47 Swap Outs 3641 476 Direct pages scanned 37978 33826 Kswapd pages scanned 1828245 1342869 Kswapd pages reclaimed 1710236 1304099 Direct pages reclaimed 32207 31005 Kswapd efficiency 93% 97% Kswapd velocity 804.077 622.546 Direct efficiency 84% 91% Direct velocity 16.703 15.682 Percentage direct scans 2% 2% Page writes by reclaim 79252 9704 Page writes file 75611 9228 Page writes anon 3641 476 Page reclaim immediate 16764 11014 Page rescued immediate 0 0 Slabs scanned 2171904 2152448 Direct inode steals 385 2261 Kswapd inode steals 659137 609670 Kswapd skipped wait 1 69 THP fault alloc 546 631 THP collapse alloc 361 339 THP splits 259 263 THP fault fallback 98 50 THP collapse fail 20 17 Compaction stalls 747 499 Compaction success 244 145 Compaction failures 503 354 Compaction pages moved 370888 474837 Compaction move failure 77378 65259 ===END stress-highalloc This patch: Introduce MIGRATEPAGE_SUCCESS as the default return code for address_space_operations.migratepage() method and documents the expected return code for the same method in failure cases. Signed-off-by: Rafael Aquini <aquini@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <andi@firstfloor.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11mm: use vm_unmapped_area() in hugetlbfsMichel Lespinasse
Update the hugetlb_get_unmapped_area function to make use of vm_unmapped_area() instead of implementing a brute force search. Signed-off-by: Michel Lespinasse <walken@google.com> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11mm: support more pagesizes for MAP_HUGETLB/SHM_HUGETLBAndi Kleen
There was some desire in large applications using MAP_HUGETLB or SHM_HUGETLB to use 1GB huge pages on some mappings, and stay with 2MB on others. This is useful together with NUMA policy: use 2MB interleaving on some mappings, but 1GB on local mappings. This patch extends the IPC/SHM syscall interfaces slightly to allow specifying the page size. It borrows some upper bits in the existing flag arguments and allows encoding the log of the desired page size in addition to the *_HUGETLB flag. When 0 is specified the default size is used, this makes the change fully compatible. Extending the internal hugetlb code to handle this is straight forward. Instead of a single mount it just keeps an array of them and selects the right mount based on the specified page size. When no page size is specified it uses the mount of the default page size. The change is not visible in /proc/mounts because internal mounts don't appear there. It also has very little overhead: the additional mounts just consume a super block, but not more memory when not used. I also exported the new flags to the user headers (they were previously under __KERNEL__). Right now only symbols for x86 and some other architecture for 1GB and 2MB are defined. The interface should already work for all other architectures though. Only architectures that define multiple hugetlb sizes actually need it (that is currently x86, tile, powerpc). However tile and powerpc have user configurable hugetlb sizes, so it's not easy to add defines. A program on those architectures would need to query sysfs and use the appropiate log2. [akpm@linux-foundation.org: cleanups] [rientjes@google.com: fix build] [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hillf Danton <dhillf@gmail.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-06propagate name change to comments in kernel sourceNadia Yvette Chambers
I've legally changed my name with New York State, the US Social Security Administration, et al. This patch propagates the name change and change in initials and login to comments in the kernel source as well. Signed-off-by: Nadia Yvette Chambers <nyc@holomorphy.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-10-09mm: replace vma prio_tree with an interval treeMichel Lespinasse
Implement an interval tree as a replacement for the VMA prio_tree. The algorithms are similar to lib/interval_tree.c; however that code can't be directly reused as the interval endpoints are not explicitly stored in the VMA. So instead, the common algorithm is moved into a template and the details (node type, how to get interval endpoints from the node, etc) are filled in using the C preprocessor. Once the interval tree functions are available, using them as a replacement to the VMA prio tree is a relatively simple, mechanical job. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: kill vma flag VM_RESERVED and mm->reserved_vm counterKonstantin Khlebnikov
A long time ago, in v2.4, VM_RESERVED kept swapout process off VMA, currently it lost original meaning but still has some effects: | effect | alternative flags -+------------------------+--------------------------------------------- 1| account as reserved_vm | VM_IO 2| skip in core dump | VM_IO, VM_DONTDUMP 3| do not merge or expand | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP 4| do not mlock | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP This patch removes reserved_vm counter from mm_struct. Seems like nobody cares about it, it does not exported into userspace directly, it only reduces total_vm showed in proc. Thus VM_RESERVED can be replaced with VM_IO or pair VM_DONTEXPAND | VM_DONTDUMP. remap_pfn_range() and io_remap_pfn_range() set VM_IO|VM_DONTEXPAND|VM_DONTDUMP. remap_vmalloc_range() set VM_DONTEXPAND | VM_DONTDUMP. [akpm@linux-foundation.org: drivers/vfio/pci/vfio_pci.c fixup] Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-10-02fs: push rcu_barrier() from deactivate_locked_super() to filesystemsKirill A. Shutemov
There's no reason to call rcu_barrier() on every deactivate_locked_super(). We only need to make sure that all delayed rcu free inodes are flushed before we destroy related cache. Removing rcu_barrier() from deactivate_locked_super() affects some fast paths. E.g. on my machine exit_group() of a last process in IPC namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-21userns: Convert hugetlbfs to use kuid/kgid where appropriateEric W. Biederman
Note sysctl_hugetlb_shm_group can only be written in the root user in the initial user namespace, so we can assume sysctl_hugetlb_shm_group is in the initial user namespace. Cc: William Irwin <wli@holomorphy.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-07-31hugetlb: use mmu_gather instead of a temporary linked list for accumulating ↵Aneesh Kumar K.V
pages Use a mmu_gather instead of a temporary linked list for accumulating pages when we unmap a hugepage range Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-14don't pass nameidata to ->create()Al Viro
boolean "does it have to be exclusive?" flag is passed instead; Local filesystem should just ignore it - the object is guaranteed not to be there yet. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-28Merge tag 'writeback' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linuxLinus Torvalds
Pull writeback tree from Wu Fengguang: "Mainly from Jan Kara to avoid iput() in the flusher threads." * tag 'writeback' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux: writeback: Avoid iput() from flusher thread vfs: Rename end_writeback() to clear_inode() vfs: Move waiting for inode writeback from end_writeback() to evict_inode() writeback: Refactor writeback_single_inode() writeback: Remove wb->list_lock from writeback_single_inode() writeback: Separate inode requeueing after writeback writeback: Move I_DIRTY_PAGES handling writeback: Move requeueing when I_SYNC set to writeback_sb_inodes() writeback: Move clearing of I_SYNC into inode_sync_complete() writeback: initialize global_dirty_limit fs: remove 8 bytes of padding from struct writeback_control on 64 bit builds mm: page-writeback.c: local functions should not be exposed globally
2012-05-06vfs: Rename end_writeback() to clear_inode()Jan Kara
After we moved inode_sync_wait() from end_writeback() it doesn't make sense to call the function end_writeback() anymore. Rename it to clear_inode() which well says what the function really does - set I_CLEAR flag. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
2012-04-25hugetlbfs: lockdep annotate root inode properlyAneesh Kumar K.V
This fixes the below reported false lockdep warning. e096d0c7e2e4 ("lockdep: Add helper function for dir vs file i_mutex annotation") added a similar annotation for every other inode in hugetlbfs but missed the root inode because it was allocated by a separate function. For HugeTLB fs we allow taking i_mutex in mmap. HugeTLB fs doesn't support file write and its file read callback is modified in a05b0855fd ("hugetlbfs: avoid taking i_mutex from hugetlbfs_read()") to not take i_mutex. Hence for HugeTLB fs with regular files we really don't take i_mutex with mmap_sem held. ====================================================== [ INFO: possible circular locking dependency detected ] 3.4.0-rc1+ #322 Not tainted ------------------------------------------------------- bash/1572 is trying to acquire lock: (&mm->mmap_sem){++++++}, at: [<ffffffff810f1618>] might_fault+0x40/0x90 but task is already holding lock: (&sb->s_type->i_mutex_key#12){+.+.+.}, at: [<ffffffff81125f88>] vfs_readdir+0x56/0xa8 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&sb->s_type->i_mutex_key#12){+.+.+.}: [<ffffffff810a09e5>] lock_acquire+0xd5/0xfa [<ffffffff816a2f5e>] __mutex_lock_common+0x48/0x350 [<ffffffff816a3325>] mutex_lock_nested+0x2a/0x31 [<ffffffff811fb8e1>] hugetlbfs_file_mmap+0x7d/0x104 [<ffffffff810f859a>] mmap_region+0x272/0x47d [<ffffffff810f8a39>] do_mmap_pgoff+0x294/0x2ee [<ffffffff810f8b65>] sys_mmap_pgoff+0xd2/0x10e [<ffffffff8103d19e>] sys_mmap+0x1d/0x1f [<ffffffff816a5922>] system_call_fastpath+0x16/0x1b -> #0 (&mm->mmap_sem){++++++}: [<ffffffff810a0256>] __lock_acquire+0xa81/0xd75 [<ffffffff810a09e5>] lock_acquire+0xd5/0xfa [<ffffffff810f1645>] might_fault+0x6d/0x90 [<ffffffff81125d62>] filldir+0x6a/0xc2 [<ffffffff81133a83>] dcache_readdir+0x5c/0x222 [<ffffffff81125fa8>] vfs_readdir+0x76/0xa8 [<ffffffff811260b6>] sys_getdents+0x79/0xc9 [<ffffffff816a5922>] system_call_fastpath+0x16/0x1b other info that might help us debug this: Possible unsafe locking scenario: CPU0 CPU1 ---- ---- lock(&sb->s_type->i_mutex_key#12); lock(&mm->mmap_sem); lock(&sb->s_type->i_mutex_key#12); lock(&mm->mmap_sem); *** DEADLOCK *** 1 lock held by bash/1572: #0: (&sb->s_type->i_mutex_key#12){+.+.+.}, at: [<ffffffff81125f88>] vfs_readdir+0x56/0xa8 stack backtrace: Pid: 1572, comm: bash Not tainted 3.4.0-rc1+ #322 Call Trace: [<ffffffff81699a3c>] print_circular_bug+0x1f8/0x209 [<ffffffff810a0256>] __lock_acquire+0xa81/0xd75 [<ffffffff810f38aa>] ? handle_pte_fault+0x5ff/0x614 [<ffffffff8109e622>] ? mark_lock+0x2d/0x258 [<ffffffff810f1618>] ? might_fault+0x40/0x90 [<ffffffff810a09e5>] lock_acquire+0xd5/0xfa [<ffffffff810f1618>] ? might_fault+0x40/0x90 [<ffffffff816a3249>] ? __mutex_lock_common+0x333/0x350 [<ffffffff810f1645>] might_fault+0x6d/0x90 [<ffffffff810f1618>] ? might_fault+0x40/0x90 [<ffffffff81125d62>] filldir+0x6a/0xc2 [<ffffffff81133a83>] dcache_readdir+0x5c/0x222 [<ffffffff81125cf8>] ? sys_ioctl+0x74/0x74 [<ffffffff81125cf8>] ? sys_ioctl+0x74/0x74 [<ffffffff81125cf8>] ? sys_ioctl+0x74/0x74 [<ffffffff81125fa8>] vfs_readdir+0x76/0xa8 [<ffffffff811260b6>] sys_getdents+0x79/0xc9 [<ffffffff816a5922>] system_call_fastpath+0x16/0x1b Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Dave Jones <davej@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Josh Boyer <jwboyer@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-05hugetlbfs: remove unregister_filesystem() when initializing moduleHillf Danton
It was introduced by d1d5e05ffdc1 ("hugetlbfs: return error code when initializing module") but as Al pointed out, is a bad idea. Quoted comments from Al: "Note that unregister_filesystem() in module init is *always* wrong; it's not an issue here (it's done too early to care about and realistically the box is not going anywhere - it'll panic when attempt to exec /sbin/init fails, if not earlier), but it's a damn bad example. Consider a normal fs module. Somebody loads it and in parallel with that we get a mount attempt on that fs type. It comes between register and failure exits that causes unregister; at that point we are screwed since grabbing a reference to module as done by mount is enough to prevent exit, but not to prevent the failure of init. As the result, module will get freed when init fails, mounted fs of that type be damned." So remove it. Signed-off-by: Hillf Danton <dhillf@gmail.com> Cc: David Rientjes <rientjes@google.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-22Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge first batch of patches from Andrew Morton: "A few misc things and all the MM queue" * emailed from Andrew Morton <akpm@linux-foundation.org>: (92 commits) memcg: avoid THP split in task migration thp: add HPAGE_PMD_* definitions for !CONFIG_TRANSPARENT_HUGEPAGE memcg: clean up existing move charge code mm/memcontrol.c: remove unnecessary 'break' in mem_cgroup_read() mm/memcontrol.c: remove redundant BUG_ON() in mem_cgroup_usage_unregister_event() mm/memcontrol.c: s/stealed/stolen/ memcg: fix performance of mem_cgroup_begin_update_page_stat() memcg: remove PCG_FILE_MAPPED memcg: use new logic for page stat accounting memcg: remove PCG_MOVE_LOCK flag from page_cgroup memcg: simplify move_account() check memcg: remove EXPORT_SYMBOL(mem_cgroup_update_page_stat) memcg: kill dead prev_priority stubs memcg: remove PCG_CACHE page_cgroup flag memcg: let css_get_next() rely upon rcu_read_lock() cgroup: revert ss_id_lock to spinlock idr: make idr_get_next() good for rcu_read_lock() memcg: remove unnecessary thp check in page stat accounting memcg: remove redundant returns memcg: enum lru_list lru ...
2012-03-21hugetlbfs: return error code when initializing moduleHillf Danton
Return an errno upon failure to create inode kmem cache, and unregister the FS upon failure to mount. [akpm@linux-foundation.org: remove unneeded test of `error'] Signed-off-by: Hillf Danton <dhillf@gmail.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21hugetlbfs: fix alignment of huge page requestsSteven Truelove
When calling shmget() with SHM_HUGETLB, shmget aligns the request size to PAGE_SIZE, but this is not sufficient. Modify hugetlb_file_setup() to align requests to the huge page size, and to accept an address argument so that all alignment checks can be performed in hugetlb_file_setup(), rather than in its callers. Change newseg() and mmap_pgoff() to match the new prototype and eliminate a now redundant alignment check. [akpm@linux-foundation.org: fix build] Signed-off-by: Steven Truelove <steven.truelove@utoronto.ca> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21mm, hugetlb: add thread name and pid to SHM_HUGETLB mlock rlimit warningDavid Rientjes
Add the thread name and pid of the application that is allocating shm segments with MAP_HUGETLB without being a part of /proc/sys/vm/hugetlb_shm_group or having CAP_IPC_LOCK. This identifies the application so it may be fixed by avoiding using the deprecated exception (see Documentation/feature-removal-schedule.txt). Signed-off-by: David Rientjes <rientjes@google.com> Cc: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21hugepages: fix use after free bug in "quota" handlingDavid Gibson
hugetlbfs_{get,put}_quota() are badly named. They don't interact with the general quota handling code, and they don't much resemble its behaviour. Rather than being about maintaining limits on on-disk block usage by particular users, they are instead about maintaining limits on in-memory page usage (including anonymous MAP_PRIVATE copied-on-write pages) associated with a particular hugetlbfs filesystem instance. Worse, they work by having callbacks to the hugetlbfs filesystem code from the low-level page handling code, in particular from free_huge_page(). This is a layering violation of itself, but more importantly, if the kernel does a get_user_pages() on hugepages (which can happen from KVM amongst others), then the free_huge_page() can be delayed until after the associated inode has already been freed. If an unmount occurs at the wrong time, even the hugetlbfs superblock where the "quota" limits are stored may have been freed. Andrew Barry proposed a patch to fix this by having hugepages, instead of storing a pointer to their address_space and reaching the superblock from there, had the hugepages store pointers directly to the superblock, bumping the reference count as appropriate to avoid it being freed. Andrew Morton rejected that version, however, on the grounds that it made the existing layering violation worse. This is a reworked version of Andrew's patch, which removes the extra, and some of the existing, layering violation. It works by introducing the concept of a hugepage "subpool" at the lower hugepage mm layer - that is a finite logical pool of hugepages to allocate from. hugetlbfs now creates a subpool for each filesystem instance with a page limit set, and a pointer to the subpool gets added to each allocated hugepage, instead of the address_space pointer used now. The subpool has its own lifetime and is only freed once all pages in it _and_ all other references to it (i.e. superblocks) are gone. subpools are optional - a NULL subpool pointer is taken by the code to mean that no subpool limits are in effect. Previous discussion of this bug found in: "Fix refcounting in hugetlbfs quota handling.". See: https://lkml.org/lkml/2011/8/11/28 or http://marc.info/?l=linux-mm&m=126928970510627&w=1 v2: Fixed a bug spotted by Hillf Danton, and removed the extra parameter to alloc_huge_page() - since it already takes the vma, it is not necessary. Signed-off-by: Andrew Barry <abarry@cray.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21hugetlb: cleanup hugetlb.hDavid Gibson
Make a couple of small cleanups to linux/include/hugetlb.h. The set_file_hugepages() function, which was not used anywhere is removed, and the hugetlbfs_config and hugetlbfs_inode_info structures with its HUGETLBFS_I helper function are moved into inode.c, the only place they were used. These structures are really linked to the hugetlbfs filesystem specifically not to hugepage mm handling in general, so they belong in the filesystem code not in a generally available header. It would be nice to move the hugetlbfs_sb_info (superblock) structure in there as well, but it's currently needed in a number of places via the hstate_vma() and hstate_inode(). Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Cc: Hugh Dickins <hughd@google.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Andrew Barry <abarry@cray.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Hillf Danton <dhillf@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21hugetlbfs: avoid taking i_mutex from hugetlbfs_read()Aneesh Kumar K.V
Taking i_mutex in hugetlbfs_read() can result in deadlock with mmap as explained below Thread A: read() on hugetlbfs hugetlbfs_read() called i_mutex grabbed hugetlbfs_read_actor() called __copy_to_user() called page fault is triggered Thread B, sharing address space with A: mmap() the same file ->mmap_sem is grabbed on task_B->mm->mmap_sem hugetlbfs_file_mmap() is called attempt to grab ->i_mutex and block waiting for A to give it up Thread A: pagefault handled blocked on attempt to grab task_A->mm->mmap_sem, which happens to be the same thing as task_B->mm->mmap_sem. Block waiting for B to give it up. AFAIU the i_mutex locking was added to hugetlbfs_read() as per http://lkml.indiana.edu/hypermail/linux/kernel/0707.2/3066.html to take care of the race between truncate and read. This patch fixes this by looking at page->mapping under lock_page() (find_lock_page()) to ensure that the inode didn't get truncated in the range during a parallel read. Ideally we can extend the patch to make sure we don't increase i_size in mmap. But that will break userspace, because applications will now have to use truncate(2) to increase i_size in hugetlbfs. Based on the original patch from Hillf Danton. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@kernel.org> [everything after 2007 :)] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21hugetlbfs: fix hugetlb_get_unmapped_area()Xiao Guangrong
Use/update cached_hole_size and free_area_cache properly to speedup finding of a free region. Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hillf Danton <dhillf@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-01-12mm: compaction: introduce sync-light migration for use by compactionMel Gorman
This patch adds a lightweight sync migrate operation MIGRATE_SYNC_LIGHT mode that avoids writing back pages to backing storage. Async compaction maps to MIGRATE_ASYNC while sync compaction maps to MIGRATE_SYNC_LIGHT. For other migrate_pages users such as memory hotplug, MIGRATE_SYNC is used. This avoids sync compaction stalling for an excessive length of time, particularly when copying files to a USB stick where there might be a large number of dirty pages backed by a filesystem that does not support ->writepages. [aarcange@redhat.com: This patch is heavily based on Andrea's work] [akpm@linux-foundation.org: fix fs/nfs/write.c build] [akpm@linux-foundation.org: fix fs/btrfs/disk-io.c build] Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Dave Jones <davej@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Andy Isaacson <adi@hexapodia.org> Cc: Nai Xia <nai.xia@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: compaction: determine if dirty pages can be migrated without blocking ↵Mel Gorman
within ->migratepage Asynchronous compaction is used when allocating transparent hugepages to avoid blocking for long periods of time. Due to reports of stalling, there was a debate on disabling synchronous compaction but this severely impacted allocation success rates. Part of the reason was that many dirty pages are skipped in asynchronous compaction by the following check; if (PageDirty(page) && !sync && mapping->a_ops->migratepage != migrate_page) rc = -EBUSY; This skips over all mapping aops using buffer_migrate_page() even though it is possible to migrate some of these pages without blocking. This patch updates the ->migratepage callback with a "sync" parameter. It is the responsibility of the callback to fail gracefully if migration would block. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Dave Jones <davej@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Andy Isaacson <adi@hexapodia.org> Cc: Nai Xia <nai.xia@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-03hugetlbfs: propagate umode_tAl Viro
2012-01-03hugetlbfs: switch to inode_init_owner()Al Viro
... rather than open-coding it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch ->mknod() to umode_tAl Viro
2012-01-03switch ->create() to umode_tAl Viro
vfs_create() ignores everything outside of 16bit subset of its mode argument; switching it to umode_t is obviously equivalent and it's the only caller of the method Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch vfs_mkdir() and ->mkdir() to umode_tAl Viro
vfs_mkdir() gets int, but immediately drops everything that might not fit into umode_t and that's the only caller of ->mkdir()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
