preparation for similar switch in ->setxattr() (see the next commit for
rationale).
Pull vfs cleanups from Al Viro:
"More cleanups from Christoph"
* 'work.preadv2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
nfsd: use RWF_SYNC
fs: add RWF_DSYNC aand RWF_SYNC
ceph: use generic_write_sync
fs: simplify the generic_write_sync prototype
fs: add IOCB_SYNC and IOCB_DSYNC
direct-io: remove the offset argument to dio_complete
direct-io: eliminate the offset argument to ->direct_IO
xfs: eliminate the pos variable in xfs_file_dio_aio_write
filemap: remove the pos argument to generic_file_direct_write
filemap: remove pos variables in generic_file_read_iter
We need to protect the list of hfsplus_readdir_data against parallel
insertions (in readdir) and removals (in release). Add a spinlock
for that. Note that it has nothing to do with protection of
hfsplus_readdir_data->key - we have an exclusion between hfsplus_readdir()
and hfsplus_delete_cat() on directory lock and between several
hfsplus_readdir() for the same struct file on ->f_pos_lock. The spinlock
is strictly for list changes.
The rest of work.xattr stuff isn't needed for this branch
Including blkdev_direct_IO and dax_do_io. It has to be ki_pos to actually
work, so eliminate the superflous argument.
... and do not assume they are already attached to each other
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
When get_acl() is called for an inode whose ACL is not cached yet, the
get_acl inode operation is called to fetch the ACL from the filesystem.
The inode operation is responsible for updating the cached acl with
set_cached_acl(). This is done without locking at the VFS level, so
another task can call set_cached_acl() or forget_cached_acl() before the
get_acl inode operation gets to calling set_cached_acl(), and then
get_acl's call to set_cached_acl() results in caching an outdate ACL.
Prevent this from happening by setting the cached ACL pointer to a
task-specific sentinel value before calling the get_acl inode operation.
Move the responsibility for updating the cached ACL from the get_acl
inode operations to get_acl(). There, only set the cached ACL if the
sentinel value hasn't changed.
The sentinel values are chosen to have odd values. Likewise, the value
of ACL_NOT_CACHED is odd. In contrast, ACL object pointers always have
an even value (ACLs are aligned in memory). This allows to distinguish
uncached ACLs values from ACL objects.
In addition, switch from guarding inode->i_acl and inode->i_default_acl
upates by the inode->i_lock spinlock to using xchg() and cmpxchg().
Filesystems that do not want ACLs returned from their get_acl inode
operations to be cached must call forget_cached_acl() to prevent the VFS
from doing so.
(Patch written by Al Viro and Andreas Gruenbacher.)
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested},
inode_foo(inode) being mutex_foo(&inode->i_mutex).
Please, use those for access to ->i_mutex; over the coming cycle
->i_mutex will become rwsem, with ->lookup() done with it held
only shared.
Mark those kmem allocations that are known to be easily triggered from
userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to
memcg. For the list, see below:
- threadinfo
- task_struct
- task_delay_info
- pid
- cred
- mm_struct
- vm_area_struct and vm_region (nommu)
- anon_vma and anon_vma_chain
- signal_struct
- sighand_struct
- fs_struct
- files_struct
- fdtable and fdtable->full_fds_bits
- dentry and external_name
- inode for all filesystems. This is the most tedious part, because
most filesystems overwrite the alloc_inode method.
The list is far from complete, so feel free to add more objects.
Nevertheless, it should be close to "account everything" approach and
keep most workloads within bounds. Malevolent users will be able to
breach the limit, but this was possible even with the former "account
everything" approach (simply because it did not account everything in
fact).
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Pull vfs xattr updates from Al Viro:
"Andreas' xattr cleanup series.
It's a followup to his xattr work that went in last cycle; -0.5KLoC"
* 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
xattr handlers: Simplify list operation
ocfs2: Replace list xattr handler operations
nfs: Move call to security_inode_listsecurity into nfs_listxattr
xfs: Change how listxattr generates synthetic attributes
tmpfs: listxattr should include POSIX ACL xattrs
tmpfs: Use xattr handler infrastructure
btrfs: Use xattr handler infrastructure
vfs: Distinguish between full xattr names and proper prefixes
posix acls: Remove duplicate xattr name definitions
gfs2: Remove gfs2_xattr_acl_chmod
vfs: Remove vfs_xattr_cmp
kmap() in page_follow_link_light() needed to go - allowing to hold
an arbitrary number of kmaps for long is a great way to deadlocking
the system.
new helper (inode_nohighmem(inode)) needs to be used for pagecache
symlinks inodes; done for all in-tree cases. page_follow_link_light()
instrumented to yell about anything missed.
Add an additional "name" field to struct xattr_handler. When the name
is set, the handler matches attributes with exactly that name. When the
prefix is set instead, the handler matches attributes with the given
prefix and with a non-empty suffix.
This patch should avoid bugs like the one fixed in commit c361016a in
the future.
Reviewed-by: James Morris <james.l.morris@oracle.com>
Remove POSIX_ACL_XATTR_{ACCESS,DEFAULT} and GFS2_POSIX_ACL_{ACCESS,DEFAULT}
and replace them with the definitions in <include/uapi/linux/xattr.h>.
The xattr_handler operations are currently all passed a file system
specific flags value which the operations can use to disambiguate between
different handlers; some file systems use that to distinguish the xattr
namespace, for example. In some oprations, it would be useful to also have
access to the handler prefix. To allow that, pass a pointer to the handler
to operations instead of the flags value alone.
The list operations can never be called; they are even documented to be
unused.
Pages looked up by __hfs_bnode_create() (called by hfs_bnode_create() and
hfs_bnode_find() for finding or creating pages corresponding to an inode)
are immediately kmap()'ed and used (both read and write) and kunmap()'ed,
and should not be page_cache_release()'ed until hfs_bnode_free().
This patch fixes a problem I first saw in July 2012: merely running "du"
on a large hfsplus-mounted directory a few times on a reasonably loaded
system would get the hfsplus driver all confused and complaining about
B-tree inconsistencies, and generates a "BUG: Bad page state". Most
recently, I can generate this problem on up-to-date Fedora 22 with shipped
kernel 4.0.5, by running "du /" (="/" + "/home" + "/mnt" + other smaller
mounts) and "du /mnt" simultaneously on two windows, where /mnt is a
lightly-used QEMU VM image of the full Mac OS X 10.9:
$ df -i / /home /mnt
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/mapper/fedora-root 3276800 551665 2725135 17% /
/dev/mapper/fedora-home 52879360 716221 52163139 2% /home
/dev/nbd0p2 4294967295 1387818 4293579477 1% /mnt
After applying the patch, I was able to run "du /" (60+ times) and "du
/mnt" (150+ times) continuously and simultaneously for 6+ hours.
There are many reports of the hfsplus driver getting confused under load
and generating "BUG: Bad page state" or other similar issues over the
years. [1]
The unpatched code [2] has always been wrong since it entered the kernel
tree. The only reason why it gets away with it is that the
kmap/memcpy/kunmap follow very quickly after the page_cache_release() so
the kernel has not had a chance to reuse the memory for something else,
most of the time.
The current RW driver appears to have followed the design and development
of the earlier read-only hfsplus driver [3], where-by version 0.1 (Dec
2001) had a B-tree node-centric approach to
read_cache_page()/page_cache_release() per bnode_get()/bnode_put(),
migrating towards version 0.2 (June 2002) of caching and releasing pages
per inode extents. When the current RW code first entered the kernel [2]
in 2005, there was an REF_PAGES conditional (and "//" commented out code)
to switch between B-node centric paging to inode-centric paging. There
was a mistake with the direction of one of the REF_PAGES conditionals in
__hfs_bnode_create(). In a subsequent "remove debug code" commit [4], the
read_cache_page()/page_cache_release() per bnode_get()/bnode_put() were
removed, but a page_cache_release() was mistakenly left in (propagating
the "REF_PAGES <-> !REF_PAGE" mistake), and the commented-out
page_cache_release() in bnode_release() (which should be spanned by
!REF_PAGES) was never enabled.
References:
[1]:
Michael Fox, Apr 2013
http://www.spinics.net/lists/linux-fsdevel/msg63807.html
("hfsplus volume suddenly inaccessable after 'hfs: recoff %d too large'")
Sasha Levin, Feb 2015
http://lkml.org/lkml/2015/2/20/85 ("use after free")
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/740814
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1027887
https://bugzilla.kernel.org/show_bug.cgi?id=42342
https://bugzilla.kernel.org/show_bug.cgi?id=63841
https://bugzilla.kernel.org/show_bug.cgi?id=78761
[2]:
http://git.kernel.org/cgit/linux/kernel/git/tglx/history.git/commit/\
fs/hfs/bnode.c?id=d1081202f1d0ee35ab0beb490da4b65d4bc763db
commit d1081202f1d0ee35ab0beb490da4b65d4bc763db
Author: Andrew Morton <akpm@osdl.org>
Date: Wed Feb 25 16:17:36 2004 -0800
[PATCH] HFS rewrite
fs/hfsplus/bnode.c?id=91556682e0bf004d98a529bf829d339abb98bbbd
commit 91556682e0bf004d98a529bf829d339abb98bbbd
Date: Wed Feb 25 16:17:48 2004 -0800
[PATCH] HFS+ support
[3]:
http://sourceforge.net/projects/linux-hfsplus/
http://sourceforge.net/projects/linux-hfsplus/files/Linux%202.4.x%20patch/hfsplus%200.1/
http://sourceforge.net/projects/linux-hfsplus/files/Linux%202.4.x%20patch/hfsplus%200.2/
http://linux-hfsplus.cvs.sourceforge.net/viewvc/linux-hfsplus/linux/\
fs/hfsplus/bnode.c?r1=1.4&r2=1.5
Date: Thu Jun 6 09:45:14 2002 +0000
Use buffer cache instead of page cache in bnode.c. Cache inode extents.
[4]:
http://git.kernel.org/cgit/linux/kernel/git/\
stable/linux-stable.git/commit/?id=a5e3985fa014029eb6795664c704953720cc7f7d
commit a5e3985fa014029eb6795664c704953720cc7f7d
Author: Roman Zippel <zippel@linux-m68k.org>
Date: Tue Sep 6 15:18:47 2005 -0700
[PATCH] hfs: remove debug code
Signed-off-by: Hin-Tak Leung <htl10@users.sourceforge.net>
Signed-off-by: Sergei Antonov <saproj@gmail.com>
Reviewed-by: Anton Altaparmakov <anton@tuxera.com>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Cc: Vyacheslav Dubeyko <slava@dubeyko.com>
Cc: Sougata Santra <sougata@tuxera.com>
Cc: <stable@vger.kernel.org>
Many file systems that implement the show_options hook fail to correctly
escape their output which could lead to unescaped characters (e.g. new
lines) leaking into /proc/mounts and /proc/[pid]/mountinfo files. This
could lead to confusion, spoofed entries (resulting in things like
systemd issuing false d-bus "mount" notifications), and who knows what
else. This looks like it would only be the root user stepping on
themselves, but it's possible weird things could happen in containers or
in other situations with delegated mount privileges.
Here's an example using overlay with setuid fusermount trusting the
contents of /proc/mounts (via the /etc/mtab symlink). Imagine the use
of "sudo" is something more sneaky:
$ BASE="ovl"
$ MNT="$BASE/mnt"
$ LOW="$BASE/lower"
$ UP="$BASE/upper"
$ WORK="$BASE/work/ 0 0
none /proc fuse.pwn user_id=1000"
$ mkdir -p "$LOW" "$UP" "$WORK"
$ sudo mount -t overlay -o "lowerdir=$LOW,upperdir=$UP,workdir=$WORK" none /mnt
$ cat /proc/mounts
none /root/ovl/mnt overlay rw,relatime,lowerdir=ovl/lower,upperdir=ovl/upper,workdir=ovl/work/ 0 0
none /proc fuse.pwn user_id=1000 0 0
$ fusermount -u /proc
$ cat /proc/mounts
cat: /proc/mounts: No such file or directory
This fixes the problem by adding new seq_show_option and
seq_show_option_n helpers, and updating the vulnerable show_option
handlers to use them as needed. Some, like SELinux, need to be open
coded due to unusual existing escape mechanisms.
[akpm@linux-foundation.org: add lost chunk, per Kees]
[keescook@chromium.org: seq_show_option should be using const parameters]
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Acked-by: Jan Kara <jack@suse.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Cc: J. R. Okajima <hooanon05g@gmail.com>
Pull more vfs updates from Al Viro:
"Assorted VFS fixes and related cleanups (IMO the most interesting in
that part are f_path-related things and Eric's descriptor-related
stuff). UFS regression fixes (it got broken last cycle). 9P fixes.
fs-cache series, DAX patches, Jan's file_remove_suid() work"
[ I'd say this is much more than "fixes and related cleanups". The
file_table locking rule change by Eric Dumazet is a rather big and
fundamental update even if the patch isn't huge. - Linus ]
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits)
9p: cope with bogus responses from server in p9_client_{read,write}
p9_client_write(): avoid double p9_free_req()
9p: forgetting to cancel request on interrupted zero-copy RPC
dax: bdev_direct_access() may sleep
block: Add support for DAX reads/writes to block devices
dax: Use copy_from_iter_nocache
dax: Add block size note to documentation
fs/file.c: __fget() and dup2() atomicity rules
fs/file.c: don't acquire files->file_lock in fd_install()
fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation
vfs: avoid creation of inode number 0 in get_next_ino
namei: make set_root_rcu() return void
make simple_positive() public
ufs: use dir_pages instead of ufs_dir_pages()
pagemap.h: move dir_pages() over there
remove the pointless include of lglock.h
fs: cleanup slight list_entry abuse
xfs: Correctly lock inode when removing suid and file capabilities
fs: Call security_ops->inode_killpriv on truncate
fs: Provide function telling whether file_remove_privs() will do anything
list_entry is just a wrapper for container_of, but it is arguably
wrong (and slightly confusing) to use it when the pointed-to struct
member is not a struct list_head. Use container_of directly instead.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
With the planned cgroup writeback support, backing-dev related
declarations will be more widely used across block and cgroup;
unfortunately, including backing-dev.h from include/linux/blkdev.h
makes cyclic include dependency quite likely.
This patch separates out backing-dev-defs.h which only has the
essential definitions and updates blkdev.h to include it. c files
which need access to more backing-dev details now include
backing-dev.h directly. This takes backing-dev.h off the common
include dependency chain making it a lot easier to use it across block
and cgroup.
v2: fs/fat build failure fixed.
Signed-off-by: Jens Axboe <axboe@fb.com>
Pull fourth vfs update from Al Viro:
"d_inode() annotations from David Howells (sat in for-next since before
the beginning of merge window) + four assorted fixes"
RCU pathwalk breakage when running into a symlink overmounting something
fix I_DIO_WAKEUP definition
direct-io: only inc/dec inode->i_dio_count for file systems
fs/9p: fix readdir()
VFS: assorted d_backing_inode() annotations
VFS: fs/inode.c helpers: d_inode() annotations
VFS: fs/cachefiles: d_backing_inode() annotations
VFS: fs library helpers: d_inode() annotations
VFS: assorted weird filesystems: d_inode() annotations
VFS: normal filesystems (and lustre): d_inode() annotations
VFS: security/: d_inode() annotations
VFS: security/: d_backing_inode() annotations
VFS: net/: d_inode() annotations
VFS: net/unix: d_backing_inode() annotations
VFS: kernel/: d_inode() annotations
VFS: audit: d_backing_inode() annotations
VFS: Fix up some ->d_inode accesses in the chelsio driver
VFS: Cachefiles should perform fs modifications on the top layer only
VFS: AF_UNIX sockets should call mknod on the top layer only
Merge third patchbomb from Andrew Morton:
- various misc things
- a couple of lib/ optimisations
- provide DIV_ROUND_CLOSEST_ULL()
- checkpatch updates
- rtc tree
- befs, nilfs2, hfs, hfsplus, fatfs, adfs, affs, bfs
- ptrace fixes
- fork() fixes
- seccomp cleanups
- more mmap_sem hold time reductions from Davidlohr
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (138 commits)
proc: show locks in /proc/pid/fdinfo/X
docs: add missing and new /proc/PID/status file entries, fix typos
drivers/rtc/rtc-at91rm9200.c: make IO endian agnostic
Documentation/spi/spidev_test.c: fix warning
drivers/rtc/rtc-s5m.c: allow usage on device type different than main MFD type
.gitignore: ignore *.tar
MAINTAINERS: add Mediatek SoC mailing list
tomoyo: reduce mmap_sem hold for mm->exe_file
powerpc/oprofile: reduce mmap_sem hold for exe_file
oprofile: reduce mmap_sem hold for mm->exe_file
mips: ip32: add platform data hooks to use DS1685 driver
lib/Kconfig: fix up HAVE_ARCH_BITREVERSE help text
x86: switch to using asm-generic for seccomp.h
sparc: switch to using asm-generic for seccomp.h
powerpc: switch to using asm-generic for seccomp.h
parisc: switch to using asm-generic for seccomp.h
mips: switch to using asm-generic for seccomp.h
microblaze: use asm-generic for seccomp.h
arm: use asm-generic for seccomp.h
seccomp: allow COMPAT sigreturn overrides
On Mac OS X, HFS+ extended attributes are not namespaced. Since we want
to be compatible with OS X filesystems and yet still support the Linux
namespacing system, the hfsplus driver implements a special "osx"
namespace that is reported for any attribute that is not namespaced
on-disk. However, the current code for getting and setting these
unprefixed attributes is broken.
hfsplus_osx_setattr() and hfsplus_osx_getattr() are passed names that have
already had their "osx." prefixes stripped by the generic functions. The
functions first, quite correctly, check those names to make sure that they
aren't prefixed with a known namespace, which would allow namespace access
restrictions to be bypassed. However, the functions then prepend "osx."
to the name they're given before passing it on to hfsplus_getattr() and
hfsplus_setattr(). Not only does this cause the "osx." prefix to be
stored on-disk, defeating its purpose, it also breaks the check for the
special "com.apple.FinderInfo" attribute, which is reported for all files,
and as a consequence makes some userspace applications (e.g. GNU patch)
fail even when extended attributes are not otherwise in use.
There are five commits which have touched this particular code:
127e5f5ae51e ("hfsplus: rework functionality of getting, setting and deleting of extended attributes")
b168fff72109 ("hfsplus: use xattr handlers for removexattr")
bf29e886b242 ("hfsplus: correct usage of HFSPLUS_ATTR_MAX_STRLEN for non-English attributes")
fcacbd95e121 ("fs/hfsplus: move xattr_name allocation in hfsplus_getxattr()")
ec1bbd346f18 ("fs/hfsplus: move xattr_name allocation in hfsplus_setxattr()")
The first commit creates the functions to begin with. The namespace is
prepended by the original code, which I believe was correct at the time,
since hfsplus_?etattr() stripped the prefix if found. The second commit
removes this behavior from hfsplus_?etattr() and appears to have been
intended to also remove the prefixing from hfsplus_osx_?etattr().
However, what it actually does is remove a necessary strncpy() call
completely, breaking the osx namespace entirely. The third commit re-adds
the strncpy() call as it was originally, but doesn't mention it in its
commit message. The final two commits refactor the code and don't affect
its functionality.
This commit does what b168fff attempted to do (prevent the prefix from
being added), but does it properly, instead of passing in an empty buffer
(which is what b168fff actually did).
Fixes: b168fff72109 ("hfsplus: use xattr handlers for removexattr")
Signed-off-by: Thomas Hebb <tommyhebb@gmail.com>
Cc: Hin-Tak Leung <htl10@users.sourceforge.net>
Cc: Sergei Antonov <saproj@gmail.com>
Cc: Anton Altaparmakov <anton@tuxera.com>
Cc: Fabian Frederick <fabf@skynet.be>
Cc: Christian Kujau <lists@nerdbynature.de>
Cc: Viacheslav Dubeyko <slava@dubeyko.com>
Fix a bug which is reproduced as follows. Create a file:
echo abc > test_file
Try to expand the file beyond available space:
truncate --size=<size exceeding available space> test_file
Since HFS+ does not support file size > allocated size, truncate should
fail. However, it ends successfully. The driver returns success despite
having been unable to allocate the requested space for the file. Also
filesystem check finds an error:
Checking catalog file.
Incorrect size for file test_file
(It should be 469094400 instead of 1000000000)
Add a piece of code analogous to code in the fat driver. Now a proper
error is returned and filesystem remains consistent.
In case of memory allocation error, the return should be -ENOMEM, instead
of -ENOSPC.
Signed-off-by: Chengyu Song <csong84@gatech.edu>
Reviewed-by: Sergei Antonov <saproj@gmail.com>
Signed-off-by: Fabian Frederick <fabf@skynet.be>
is_known_namespace() only returns true/false. Also remove inline and let
compiler decide what to do with static functions.
According to commit 5f16f3225b06 ("ext4: atomically set inode->i_flags in
ext4_set_inode_flags()").
Cc: "Theodore Ts'o" <tytso@mit.edu>
security/trusted/user/osx setxattr did the same
xattr_name initialization. Move that operation in hfsplus_setxattr().
Tested with security/trusted/user getfattr/setfattr
security/trusted/user/osx getxattr did the same
xattr_name initialization. Move that operation in hfsplus_getxattr().
This doesn't change how the code works, but clearly the curly braces were
intended.
that's the bulk of filesystem drivers dealing with inodes of their own
Now that no one is using rw, remove it completely.
Signed-off-by: Omar Sandoval <osandov@osandov.com>
The rw parameter to direct_IO is redundant with iov_iter->type, and
treated slightly differently just about everywhere it's used: some users
do rw & WRITE, and others do rw == WRITE where they should be doing a
bitwise check. Simplify this with the new iov_iter_rw() helper, which
always returns either READ or WRITE.
Most filesystems call through to these at some point, so we'll start
here.
All places outside of core VFS that checked ->read and ->write for being NULL or
called the methods directly are gone now, so NULL {read,write} with non-NULL
{read,write}_iter will do the right thing in all cases.
trivial conflict in net/socket.c and non-trivial one in crypto -
that one had evaded aio_complete() removal.
struct kiocb now is a generic I/O container, so move it to fs.h.
Also do a #include diet for aio.h while we're at it.
Fix B-tree corruption when a new record is inserted at position 0 in the
node in hfs_brec_insert(). In this case a hfs_brec_update_parent() is
called to update the parent index node (if exists) and it is passed
hfs_find_data with a search_key containing a newly inserted key instead
of the key to be updated. This results in an inconsistent index node.
The bug reproduces on my machine after an extents overflow record for
the catalog file (CNID=4) is inserted into the extents overflow B-tree.
Because of a low (reserved) value of CNID=4, it has to become the first
record in the first leaf node.
The resulting first leaf node is correct:
| key0.CNID=4 | key1.CNID=123 | key2.CNID=456, ... |
But the parent index key0 still contains the previous key CNID=123:
| key0.CNID=123 | ... |
A change in hfs_brec_insert() makes hfs_brec_update_parent() work
correctly by preventing it from getting fd->record=-1 value from
__hfs_brec_find().
Along the way, I removed duplicate code with unification of the if
condition. The resulting code is equivalent to the original code
because node is never 0.
Also hfs_brec_update_parent() will now return an error after getting a
negative fd->record value. However, the return value of
hfs_brec_update_parent() is not checked anywhere in the file and I'm
leaving it unchanged by this patch. brec.c lacks error checking after
some other calls too, but this issue is of less importance than the one
being fixed by this patch.
Cc: Joe Perches <joe@perches.com>
Reviewed-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Acked-by: Hin-Tak Leung <htl10@users.sourceforge.net>
Cc: Anton Altaparmakov <aia21@cam.ac.uk>
Convert the following where appropriate:
(1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry).
(2) S_ISREG(dentry->d_inode) to d_is_reg(dentry).
(3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more
complicated than it appears as some calls should be converted to
d_can_lookup() instead. The difference is whether the directory in
question is a real dir with a ->lookup op or whether it's a fake dir with
a ->d_automount op.
In some circumstances, we can subsume checks for dentry->d_inode not being
NULL into this, provided we the code isn't in a filesystem that expects
d_inode to be NULL if the dirent really *is* negative (ie. if we're going to
use d_inode() rather than d_backing_inode() to get the inode pointer).
Note that the dentry type field may be set to something other than
DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS
manages the fall-through from a negative dentry to a lower layer. In such a
case, the dentry type of the negative union dentry is set to the same as the
type of the lower dentry.
However, if you know d_inode is not NULL at the call site, then you can use
the d_is_xxx() functions even in a filesystem.
There is one further complication: a 0,0 chardev dentry may be labelled
DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was
intended for special directory entry types that don't have attached inodes.
The following perl+coccinelle script was used:
use strict;
my @callers;
open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') ||
die "Can't grep for S_ISDIR and co. callers";
@callers = <$fd>;
close($fd);
unless (@callers) {
print "No matches\n";
exit(0);
my @cocci = (
'expression E;',
'- S_ISLNK(E->d_inode->i_mode)',
'+ d_is_symlink(E)',
'expression E;',
'- S_ISDIR(E->d_inode->i_mode)',
'+ d_is_dir(E)',
'expression E;',
'- S_ISREG(E->d_inode->i_mode)',
'+ d_is_reg(E)' );
my $coccifile = "tmp.sp.cocci";
open($fd, ">$coccifile") || die $coccifile;
print($fd "$_\n") || die $coccifile foreach (@cocci);
close($fd);
foreach my $file (@callers) {
chomp $file;
print "Processing ", $file, "\n";
system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 ||
die "spatch failed";
[AV: overlayfs parts skipped]
Longname is not correctly handled by hfsplus driver. If an attempt to
create a longname(>255) file/directory is made, it succeeds by creating a
file/directory with HFSPLUS_MAX_STRLEN and incorrect catalog key. Thus
leaving the volume in an inconsistent state. This patch fixes this issue.
Although lookup is always called first to create a negative entry, so just
doing a check in lookup would probably fix this issue. I choose to
propagate error to other iops as well.
Please NOTE: I have factored out hfsplus_cat_build_key_with_cnid from
hfsplus_cat_build_key, to avoid unncessary branching.
Thanks a lot.
TEST:
dir="TEST_DIR"
cdir=`pwd`
name255="_123456789_123456789_123456789_123456789_123456789_123456789\
_123456789_123456789_123456789_123456789_123456789_123456789_123456789\
_123456789_123456789_123456789_123456789_123456789_1234"
name256="${name255}5"
mkdir $dir
cd $dir
touch $name255
rm -f $name255
touch $name256
ls -la
cd $cdir
rm -rf $dir
RESULT:
[sougata@ultrabook tmp]$ cdir=`pwd`
[sougata@ultrabook tmp]$ name256="${name255}5"
[sougata@ultrabook tmp]$ mkdir $dir
[sougata@ultrabook tmp]$ cd $dir
[sougata@ultrabook TEST_DIR]$ touch $name255
[sougata@ultrabook TEST_DIR]$ rm -f $name255
[sougata@ultrabook TEST_DIR]$ touch $name256
[sougata@ultrabook TEST_DIR]$ ls -la
ls: cannot access
_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_1234:
total 0
drwxrwxr-x 1 sougata sougata 3 Feb 20 19:56 .
drwxrwxrwx 1 root root 6 Feb 20 19:56 ..
[sougata@ultrabook TEST_DIR]$ cd $cdir
[sougata@ultrabook tmp]$ rm -rf $dir
rm: cannot remove `TEST_DIR': Directory not empty
-ENAMETOOLONG returned from hfsplus_asc2uni was not propaged to iops.
This allowed hfsplus to create files/directories with HFSPLUS_MAX_STRLEN
and incorrect keys, leaving the FS in an inconsistent state. This patch
fixes this issue.
Signed-off-by: Sougata Santra <sougata@tuxera.com>
Pull vfs updates from Al Viro:
"This the bunch that sat in -next + lock_parent() fix. This is the
minimal set; there's more pending stuff.
In particular, I really hope to get acct.c fixes merged this cycle -
we need that to deal sanely with delayed-mntput stuff. In the next
pile, hopefully - that series is fairly short and localized
(kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more
iov_iter work. Most of prereqs for ->splice_write with sane locking
order are there and Kent's dio rewrite would also fit nicely on top of
this pile"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits)
lock_parent: don't step on stale ->d_parent of all-but-freed one
kill generic_file_splice_write()
ceph: switch to iter_file_splice_write()
shmem: switch to iter_file_splice_write()
nfs: switch to iter_splice_write_file()
fs/splice.c: remove unneeded exports
ocfs2: switch to iter_file_splice_write()
->splice_write() via ->write_iter()
bio_vec-backed iov_iter
optimize copy_page_{to,from}_iter()
bury generic_file_aio_{read,write}
lustre: get rid of messing with iovecs
ceph: switch to ->write_iter()
ceph_sync_direct_write: stop poking into iov_iter guts
ceph_sync_read: stop poking into iov_iter guts
new helper: copy_page_from_iter()
fuse: switch to ->write_iter()
btrfs: switch to ->write_iter()
ocfs2: switch to ->write_iter()
xfs: switch to ->write_iter()
Commit a99b7069aab8 ("hfsplus: Fix undefined __divdi3 in
hfsplus_init_header_node()") introduced do_div() to xattr.c and the
warning below too.
As Geert remarked: "tmp" is "loff_t" which is "__kernel_loff_t", which
is "long long", i.e. signed, while include/asm-generic/div64.h compares
its type with "uint64_t". As inode sizes are positive, it should be
safe to change the type of "tmp" to "u64".
In file included from
arch/powerpc/include/asm/div64.h:1:0,
from include/linux/kernel.h:124,
from include/asm-generic/bug.h:13,
from arch/powerpc/include/asm/bug.h:127,
from include/linux/bug.h:4,
from include/linux/thread_info.h:11,
from include/asm-generic/preempt.h:4,
from arch/powerpc/include/generated/asm/preempt.h:1,
from include/linux/preempt.h:18,
from include/linux/spinlock.h:50,
from include/linux/wait.h:8,
from include/linux/fs.h:6,
from fs/hfsplus/hfsplus_fs.h:19,
from fs/hfsplus/xattr.c:9:
fs/hfsplus/xattr.c: In function 'hfsplus_init_header_node':
include/asm-generic/div64.h:43:28: warning: comparison of distinct pointer types lacks a cast [enabled by default]
(void)(((typeof((n)) *)0) == ((uint64_t *)0)); \
fs/hfsplus/xattr.c:86:2: note: in expansion of macro 'do_div'
do_div(tmp, node_size);
Signed-off-by: Christian Kujau <lists@nerdbynature.de>
Acked-by: Sergei Antonov <saproj@gmail.com>
Suggested-By: Vyacheslav Dubeyko <slava@dubeyko.com>
Some function declarations in hfsplus_fs.h were with argument names,
some without, and some were mixed. This patch adds argument names
everywhere, sorts function in order they go in .c files, and moves
hfs_part_find() to a proper section.
Auto-formatting and sorting was done with:
cfunctions *.c | indent -linux | sed "s| \* | \*|"
Replace while blocksize;shift by ilog2
Zero newly allocated extents in the catalog tree if volume attributes
tell us to. Not doing so we risk getting the "unused node is not
erased" error. See kHFSUnusedNodeFix flag in Apple's source code for
reference.
There was a previous commit clearing the node when it is freed: commit
899bed05e9f6 ("hfsplus: fix issue with unzeroed unused b-tree nodes").
But it did not handle newly allocated extents (this patch fixes it).
And it zeroed nodes in all trees unconditionally which is an overkill.
This patch adds a condition and also switches to 'tree->node_size' as a
simpler method of getting the length to zero.
Cc: Kyle Laracey <kalaracey@gmail.com>
Also add * before function comments (it was not detected by kernel-doc)
