path: root/fs/hfsplus/hfsplus_fs.h
2008-04-29fs/hfsplus/: proper externsAdrian Bunk
Add proper extern declarations for two structs in fs/hfsplus/hfsplus_fs.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop HFSPLUS from using iget() and read_inode()David Howells
Stop the HFSPLUS filesystem from using iget() and read_inode(). Replace hfsplus_read_inode() with hfsplus_iget(), and call that instead of iget(). hfsplus_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. hfsplus_fill_super() returns any error incurred when getting the root inode. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16HFS+: add custom dentry hash and comparison operationsDuane Griffin
Add custom dentry hash and comparison operations for HFS+ filesystems that are case-insensitive and/or do automatic unicode decomposition. The new operations reuse the existing HFS+ ASCII to unicode conversion, unicode decomposition and case folding functionality. Signed-off-by: Duane Griffin <duaneg@dghda.com> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-30[PATCH] BLOCK: Move common FS-specific ioctls to linux/fs.h [try #6]David Howells
Move common FS-specific ioctls from linux/ext2_fs.h to linux/fs.h as FS_IOC_* and FS_IOC32_* and have the users of them use those as a base. Also move the GETFLAGS/SETFLAGS flags to linux/fs.h as FS_*_FL macros, and then have the other users use them as a base. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] hfs: set correct ctimeRoman Zippel
Read the correct ctime from disk (it was written but never read for some reason). Read also creation date, which is used in the next patch. (Problem found by Olivier Castan <olivier.castan@certa.ssi.gouv.fr>) Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] hfs: add HFSX supportDavid Elliott
Add support for HFSX, which allows for case-sensitive filenames. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] fs/hfsplus/: remove the hfsplus_inode_check() debug functionAdrian Bunk
This patch removes the hfsplus_inode_check() debug function. It also removes the now obsolete last_inode_cnt and inode_cnt from struct hfsplus_sb_info. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-29[PATCH] hfsplus: don't modify journaled volumeRoman Zippel
Access to a journaled HFS+ volume is not officially supported under Linux, so mount such a volume read-only, but users can override this behaviour using the "force" mount option. The minimum requirement to relax this check is to at least check that the journal is empty and so nothing needs to be replayed to make sure the volume is consistent. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] hfs: show_options supportRoman Zippel
This adds support for show_options. It also fixes some namespace polution in the hfsplus driver. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
