path: root/fs/hfs/inode.c
2012-12-20hfs: drop vmtruncateMarco Stornelli
Removed vmtruncate Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-09-21userns: Convert hfs to use kuid and kgid where appropriateEric W. Biederman
Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-08-20workqueue: deprecate flush[_delayed]_work_sync()Tejun Heo
flush[_delayed]_work_sync() are now spurious. Mark them deprecated and convert all users to flush[_delayed]_work(). If you're cc'd and wondering what's going on: Now all workqueues are non-reentrant and the regular flushes guarantee that the work item is not pending or running on any CPU on return, so there's no reason to use the sync flushes at all and they're going away. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Mattia Dongili <malattia@linux.it> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: David Airlie <airlied@linux.ie> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-wireless@vger.kernel.org Cc: Anton Vorontsov <cbou@mail.ru> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Avi Kivity <avi@redhat.com>
2012-07-22hfs: get rid of hfs_sync_superArtem Bityutskiy
This patch makes hfs stop using the VFS '->write_super()' method along with the 's_dirt' superblock flag, because they are on their way out. The whole "superblock write-out" VFS infrastructure is served by the 'sync_supers()' kernel thread, which wakes up every 5 (by default) seconds and writes out all dirty superblocks using the '->write_super()' call-back. But the problem with this thread is that it wastes power by waking up the system every 5 seconds, even if there are no diry superblocks, or there are no client file-systems which would need this (e.g., btrfs does not use '->write_super()'). So we want to kill it completely and thus, we need to make file-systems to stop using the '->write_super()' VFS service, and then remove it together with the kernel thread. Tested using fsstress from the LTP project. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22hfs: simplify a bit checking for R/OArtem Bityutskiy
We have the following pattern in 2 places in HFS if (!RDONLY) hfs_mdb_commit(); This patch pushes the RDONLY check down to 'hfs_mdb_commit()'. This will make the following patches a bit simpler. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22hfs: push lock_super downArtem Bityutskiy
HFS uses 'lock_super()'/'unlock_super()' around 'hfs_mdb_commit()' in order to serialize MDB (Master Directory Block) changes. Push it down to 'hfs_mdb_commit()' in order to simplify the code a bit. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-06vfs: Rename end_writeback() to clear_inode()Jan Kara
After we moved inode_sync_wait() from end_writeback() it doesn't make sense to call the function end_writeback() anymore. Rename it to clear_inode() which well says what the function really does - set I_CLEAR flag. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
2012-01-03hfs: propagate umode_tAl Viro
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: simplify the blockdev_direct_IO prototypeChristoph Hellwig
Simple filesystems always pass inode->i_sb_bdev as the block device argument, and never need a end_io handler. Let's simply things for them and for my grepping activity by dropping these arguments. The only thing not falling into that scheme is ext4, which passes and end_io handler without needing special flags (yet), but given how messy the direct I/O code there is use of __blockdev_direct_IO in one instead of two out of three cases isn't going to make a large difference anyway. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: move inode_dio_wait calls into ->setattrChristoph Hellwig
Let filesystems handle waiting for direct I/O requests themselves instead of doing it beforehand. This means filesystem-specific locks to prevent new dio referenes from appearing can be held. This is important to allow generalizing i_dio_count to non-DIO_LOCKING filesystems. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-25switch hfs to hlist_add_fake()Al Viro
2010-08-09convert remaining ->clear_inode() to ->evict_inode()Al Viro
2010-08-09get rid of file_fsync()Al Viro
Copy and simplify in the only two users remaining. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09remove inode_setattrChristoph Hellwig
Replace inode_setattr with opencoded variants of it in all callers. This moves the remaining call to vmtruncate into the filesystem methods where it can be replaced with the proper truncate sequence. In a few cases it was obvious that we would never end up calling vmtruncate so it was left out in the opencoded variant: spufs: explicitly checks for ATTR_SIZE earlier btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above In addition to that ncpfs called inode_setattr with handcrafted iattrs, which allowed to trim down the opencoded variant. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09get rid of cont_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in preparation of the new truncate sequence and rename the non-truncating version to cont_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09sort out blockdev_direct_IO variantsChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in prepearation of the new truncate calling sequence. This was only done for DIO_LOCKING filesystems, so the __blockdev_direct_IO_newtrunc variant was not needed anyway. Get rid of blockdev_direct_IO_no_locking and its _newtrunc variant while at it as just opencoding the two additional paramters is shorted than the name suffix. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-03-05pass writeback_control to ->write_inodeChristoph Hellwig
This gives the filesystem more information about the writeback that is happening. Trond requested this for the NFS unstable write handling, and other filesystems might benefit from this too by beeing able to distinguish between the different callers in more detail. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-13hfs: fix memory leak when unmountingDave Anderson
When an HFS filesystem is unmounted, it leaks a 2-page bitmap. Also, under extreme memory pressure, it's possible that hfs_releasepage() may use a tree pointer that has not been initialized, and if so, the release request should just be rejected. [akpm@linux-foundation.org: free_pages(0) is legal, remove obvious comment] Signed-off-by: Dave Anderson <anderson@redhat.com> Tested-by: Eugene Teo <eugeneteo@kernel.sg> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-14CRED: Wrap task credential accesses in the HFS filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-23[PATCH] move executable checking into ->permission()Miklos Szeredi
For execute permission on a regular files we need to check if file has any execute bits at all, regardless of capabilites. This check is normally performed by generic_permission() but was also added to the case when the filesystem defines its own ->permission() method. In the latter case the filesystem should be responsible for performing this check. Move the check from inode_permission() inside filesystems which are not calling generic_permission(). Create a helper function execute_ok() that returns true if the inode is a directory or if any execute bits are present in i_mode. Also fix up the following code: - coda control file is never executable - sysctl files are never executable - hfs_permission seems broken on MAY_EXEC, remove - hfsplus_permission is eqivalent to generic_permission(), remove Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2008-07-26[PATCH] f_count may wrap aroundAl Viro
make it atomic_long_t; while we are at it, get rid of useless checks in affs, hfs and hpfs - ->open() always has it equal to 1, ->release() - to 0. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] sanitize ->permission() prototypeAl Viro
* kill nameidata * argument; map the 3 bits in ->flags anybody cares about to new MAY_... ones and pass with the mask. * kill redundant gfs2_iop_permission() * sanitize ecryptfs_permission() * fix remaining places where ->permission() instances might barf on new MAY_... found in mask. The obvious next target in that direction is permission(9) folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-25hfs: convert extents_lock in a mutexMatthias Kaehlcke
Apple Macintosh file system: The semaphore extens_lock is used as a mutex. Convert it to the mutex API Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16hfs: convert to new aopsNick Piggin
Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 2Arjan van de Ven
2006-12-08[PATCH] struct path: convert hfsJosef Sipek
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] remove ->get_blocks() supportBadari Pulavarty
Now that get_block() can handle mapping multiple disk blocks, no need to have ->get_blocks(). This patch removes fs specific ->get_blocks() added for DIO and makes it users use get_block() instead. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] hfs: cleanup HFS printsRoman Zippel
Add the log level and a "hfs: " prefix to all kernel prints. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: fs/*Al Viro
- ->releasepage() annotated (s/int/gfp_t), instances updated - missing gfp_t in fs/* added - fixed misannotation from the original sweep caught by bitwise checks: XFS used __nocast both for gfp_t and for flags used by XFS allocator. The latter left with unsigned int __nocast; we might want to add a different type for those but for now let's leave them alone. That, BTW, is a case when __nocast use had been actively confusing - it had been used in the same code for two different and similar types, with no way to catch misuses. Switch of gfp_t to bitwise had caught that immediately... One tricky bit is left alone to be dealt with later - mapping->flags is a mix of gfp_t and error indications. Left alone for now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] hfs: NLS supportRoman Zippel
This adds NLS support to HFS. Using the kernel options iocharset and codepage it's possible to map the disk encoding to a local mapping. If these options are not used, it falls back to the old direct mapping. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
