path: root/fs/gfs2/locking/dlm/mount.c
2009-03-24GFS2: Merge lock_dlm module into GFS2Steven Whitehouse
This is the big patch that I've been working on for some time now. There are many reasons for wanting to make this change such as: o Reducing overhead by eliminating duplicated fields between structures o Simplifcation of the code (reduces the code size by a fair bit) o The locking interface is now the DLM interface itself as proposed some time ago. o Fewer lookups of glocks when processing replies from the DLM o Fewer memory allocations/deallocations for each glock o Scope to do further optimisations in the future (but this patch is more than big enough for now!) Please note that (a) this patch relates to the lock_dlm module and not the DLM itself, that is still a separate module; and (b) that we retain the ability to build GFS2 as a standalone single node filesystem with out requiring the DLM. This patch needs a lot of testing, hence my keeping it I restarted my -git tree after the last merge window. That way, this has the maximum exposure before its merged. This is (modulo a few minor bug fixes) the same patch that I've been posting on and off the the last three months and its passed a number of different tests so far. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-01-05GFS2: Send useful information with uevent messagesSteven Whitehouse
In order to distinguish between two differing uevent messages and to avoid using the (racy) method of reading status from sysfs in future, this adds some status information to our uevent messages. Btw, before anybody says "sysfs isn't racy", I'm aware of that, but the way that GFS2 was using it (send an ambiugous uevent and then expect the receiver to read sysfs to find out the status of the reported operation) was. The additional benefit of using the new interface is that it should be possible for a node to recover multiple journals at the same time, since there is no longer any confusion as to which journal the status belongs to. At some future stage, when all the userland programs have been converted, I intend to remove the old interface. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-08-28dlm: allow multiple lockspace createsDavid Teigland
Add a count for lockspace create and release so that create can be called multiple times to use the lockspace from different places. Also add the new flag DLM_LSFL_NEWEXCL to create a lockspace with the previous behavior of returning -EEXIST if the lockspace already exists. Signed-off-by: David Teigland <teigland@redhat.com>
2008-06-27[GFS2] Fix module buildingSteven Whitehouse
Two lines missed from the previous patch. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-06-27[GFS2] Remove all_list from lock_dlmSteven Whitehouse
I discovered that we had a list onto which every lock_dlm lock was being put. Its only function was to discover whether we'd got any locks left after umount. Since there was already a counter for that purpose as well, I removed the list. The saving is sizeof(struct list_head) per glock - well worth having. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-06-27[GFS2] Remove remote lock dropping codeSteven Whitehouse
There are several reasons why this is undesirable: 1. It never happens during normal operation anyway 2. If it does happen it causes performance to be very, very poor 3. It isn't likely to solve the original problem (memory shortage on remote DLM node) it was supposed to solve 4. It uses a bunch of arbitrary constants which are unlikely to be correct for any particular situation and for which the tuning seems to be a black art. 5. In an N node cluster, only 1/N of the dropped locked will actually contribute to solving the problem on average. So all in all we are better off without it. This also makes merging the lock_dlm module into GFS2 a bit easier. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-06-27[GFS2] Fix ordering bug in lock_dlmSteven Whitehouse
This looks like a lot of change, but in fact its not. Mostly its things moving from one file to another. The change is just that instead of queuing lock completions and callbacks from the DLM we now pass them directly to GFS2. This gives us a net loss of two list heads per glock (a fair saving in memory) plus a reduction in the latency of delivering the messages to GFS2, plus we now have one thread fewer as well. There was a bug where callbacks and completions could be delivered in the wrong order due to this unnecessary queuing which is fixed by this patch. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Bob Peterson <rpeterso@redhat.com>
2008-04-21dlm: move plock code from gfs2David Teigland
Move the code that handles cluster posix locks from gfs2 into the dlm so that it can be used by both gfs2 and ocfs2. Signed-off-by: David Teigland <teigland@redhat.com>
2008-01-25[GFS2] tidy up error messageDavid Teigland
Print error with log_error() to be consistent with others. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Fabio M. Di Nitto <fabbione@ubuntu.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-01-25[GFS2] Check for installation of mount helpers for DLM mountsFabio Massimo Di Nitto
The patch is a fix to abort mount if the mount.gfs* and possible umount.* are missing from /sbin. While we do what we can to guarantee that they are installed properly in userland (CVS HEAD), we want to make sure that mount still aborts properly. The only sign of missing helpers is that lock_dlm will receive no mount options at all. According to David the problem does not exist for lock_nolock as the helpers are not required. The patch has been tested for both gfs and gfs2 and it works as expected. The lack of mount.gfs* will generate an error that is propagated to mount: oot@node1:~# mount -t gfs2 /dev/nbd2 /mnt/ mount: wrong fs type, bad option, bad superblock on /dev/nbd2, missing codepage or helper program, or other error In some cases useful info is found in syslog - try dmesg | tail or so [ 3513.303346] GFS2: fsid=: Trying to join cluster "lock_dlm", "gutsy:gfs2" [ 3513.304546] DLM/GFS2/GFS ERROR: (u)mount helpers are not installed properly! [ 3513.306290] GFS2: fsid=: can't mount proto=lock_dlm, table=gutsy:gfs2, hostdata= You might want to notice that it will also avoid mount to hang or fail silently or with strange errors that will require the cluster to reboot/restart before you can actually mount the filesystem again. Signed-off-by: Fabio M. Di Nitto <fabbione@ubuntu.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[DLM] variable allocationPatrick Caulfield
Add a new flag, DLM_LSFL_FS, to be used when a file system creates a lockspace. This flag causes the dlm to use GFP_NOFS for allocations instead of GFP_KERNEL. (This updated version of the patch uses gfp_t for ls_allocation.) Signed-Off-By: Patrick Caulfield <pcaulfie@redhat.com> Signed-Off-By: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-02-05[GFS2] make lock_dlm drop_count tunable in sysfsDavid Teigland
We want to be able to change or disable the default drop_count (number at which the dlm asks gfs to limit the the number of locks it's holding). Add it to the collection of sysfs tunables for an fs. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-10-11[PATCH] misuse of strstrAl Viro
2006-09-08[GFS2] Use void * instead of typedef for locking module interfaceSteven Whitehouse
As requested by Jan Engelhardt, this removes the typedefs in the locking module interface and replaces them with void *. Also since we are changing the interface, I've added a few consts as well. Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Cc: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-07[GFS2] Remove unused sync_lvb code from lock modulesSteven Whitehouse
This code is no longer used for anything and can be removed from the locking modules. The sync_lvb function is not required as this happens automatically with the current locking system. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-07[GFS2] Remove one typedefSteven Whitehouse
This removes one of the typedefs from the locking interface. It is replaced by a forward declaration of the gfs2 superblock. The other two are not so easy to solve since in their case, they can refer to one of two possible structures. Cc: David Teigland <teigland@redhat.com> Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-04[GFS2] Align all labels against LH sideSteven Whitehouse
This makes everything consistent. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-01[GFS2] Update copyright, tidy up incore.hSteven Whitehouse
As per comments from Jan Engelhardt <jengelh@linux01.gwdg.de> this updates the copyright message to say "version" in full rather than "v.2". Also incore.h has been updated to remove forward structure declarations which are not required. The gfs2_quota_lvb structure has now had endianess annotations added to it. Also quota.c has been updated so that we now store the lvb data locally in endian independant format to avoid needing a structure in host endianess too. As a result the endianess conversions are done as required at various points and thus the conversion routines in lvb.[ch] are no longer required. I've moved the one remaining constant in lvb.h thats used into lm.h and removed the unused lvb.[ch]. I have not changed the HIF_ constants. That is left to a later patch which I hope will unify the gh_flags and gh_iflags fields of the struct gfs2_holder. Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-05-19[GFS2] setup lock_dlm kobject earlierDavid Teigland
Setup the lock_dlm kobject before setting up the dlm lockspace instead of after. We want to use the sysfs files to detect the mount without having to wait for the dlm setup which can take a while. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-04-26[DLM] lock_dlm recover_status patchDavid Teigland
This saves the journal recovery result and makes it visible through sysfs. User space needs to know if the node actually recovered the journal or tried and gave up. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-03-28[DLM] Look for "nodir" in the lockspace mount optionsDavid Teigland
Look for "nodir" in the hostdata mount option which is used to set the NODIR flag in dlm_new_lockspace(). Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-01-18[GFS2] Only two args for kobject_uevent() in locking/dlm/mount.cDavid Teigland
Update the dlm interface module to take account of the recently removed third argument to kobject_uevent() Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steve Whitehouse <swhiteho@redhat.com>
2006-01-17[GFS2] An update of the GFS2 lock modulesDavid Teigland
This brings the lock modules uptodate and removes the stray .mod.c file which accidently got included in the last check in. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-01-16[GFS2] The lock modules for GFS2David Teigland
This patch contains the pluggable locking modules for GFS2. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
