Commit 4f6563677ae8 ("Move locks API users to locks_lock_inode_wait()")
moved flock/posix lock identify code to locks_lock_inode_wait(), but
missed to set fl_flags to FL_FLOCK which will cause kernel panic in
locks_lock_inode_wait().
Fixes: 4f6563677ae8 ("Move locks API users to locks_lock_inode_wait()")
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
This patch makes no functional changes. Its goal is to reduce the
size of the gfs2 inode in memory by rearranging structures and
changing the size of some variables within the structure.
Before this patch, multi-block reservation structures were allocated
from a special slab. This patch folds the structure into the gfs2_inode
structure. The disadvantage is that the gfs2_inode needs more memory,
even when a file is opened read-only. The advantages are: (a) we don't
need the special slab and the extra time it takes to allocate and
deallocate from it. (b) we no longer need to worry that the structure
exists for things like quota management. (c) This also allows us to
remove the calls to get_write_access and put_write_access since we
know the structure will exist.
This patch basically reverts the majority of patch 5407e24.
That patch eliminated the gfs2_qadata structure in favor of just
using the reservations structure. The problem with doing that is that
it increases the size of the reservations structure. That is not an
issue until it comes time to fold the reservations structure into the
inode in memory so we know it's always there. By separating out the
quota structure again, we aren't punishing the non-quota users by
making all the inodes bigger, requiring more slab space. This patch
creates a new slab area to allocate the quota stuff so it's managed
a little more sanely.
When new files and directories are created inside a parent directory
we automatically inherit the GFS2_DIF_SYSTEM flag (if set) and assign
it to the new file/dirs.
All new system files/dirs created in the metafs by, say gfs2_jadd,
will have this flag set because they will have parent directories in
the metafs whose GFS2_DIF_SYSTEM flag has already been set (most likely
by a previous mkfs.gfs2)
Signed-off-by: Abhi Das <adas@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2
Pull gfs2 updates from Bob Peterson:
"Here is a list of patches we've accumulated for GFS2 for the current
upstream merge window. There are only six patches this time:
1. A cleanup patch from Andreas to remove the gl_spin #define in favor
of its value for the sake of clarity.
2. A fix from Andy Price to mark the inode dirty during fallocate.
3. A fix from Andy Price to set s_mode on mount failures to prevent a
stack trace.
4 A patch from me to prevent a kernel BUG() in trans_add_meta/trans_add_data
due to uninitialized storage.
5. A patch from me to protecting our freeing of the in-core directory
hash table to prevent double-free.
6. A fix for a page/block rounding problem that resulted in a metadata
coherency problem when the block size != page size"
I've got a lot more patches in various stages of review and testing,
but I'm afraid they'll have to wait until the next merge window. So
next time we're likely to have a lot more"
* tag 'gfs2-merge-window' of git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2:
GFS2: Fix rgrp end rounding problem for bsize < page size
GFS2: Protect freeing directory hash table with i_lock spin_lock
gfs2: Remove gl_spin define
gfs2: Add missing else in trans_add_meta/data
GFS2: Set s_mode before parsing mount options
GFS2: fallocate: do not rely on file_update_time to mark the inode dirty
Instead of having users check for FL_POSIX or FL_FLOCK to call the correct
locks API function, use the check within locks_lock_inode_wait(). This
allows for some later cleanup.
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
Previously __gfs2_fallocate() relied on file_update_time() marking the
inode dirty, but that's not a safe assumption as that function doesn't
dirty the inode in some cases. Mark the inode dirty explicitly.
Signed-off-by: Andrew Price <anprice@redhat.com>
git://git.kernel.org:/pub/scm/linux/kernel/git/gfs2/linux-gfs2
Pull GFS2 updates from Bob Peterson:
"Here are the patches we've accumulated for GFS2 for the current
upstream merge window. We have a good mixture this time. Here are
some of the features:
- Fix a problem with RO mounts writing to the journal.
- Further improvements to quotas on GFS2.
- Added support for rename2 and RENAME_EXCHANGE on GFS2.
- Increase performance by making glock lru_list less of a bottleneck.
- Increase performance by avoiding unnecessary buffer_head releases.
- Increase performance by using average glock round trip time from all CPUs.
- Fixes for some compiler warnings and minor white space issues.
- Other misc bug fixes"
* tag 'gfs2-merge-window' of git://git.kernel.org:/pub/scm/linux/kernel/git/gfs2/linux-gfs2:
GFS2: Don't brelse rgrp buffer_heads every allocation
GFS2: Don't add all glocks to the lru
gfs2: Don't support fallocate on jdata files
gfs2: s64 cast for negative quota value
gfs2: limit quota log messages
gfs2: fix quota updates on block boundaries
gfs2: fix shadow warning in gfs2_rbm_find()
gfs2: kerneldoc warning fixes
gfs2: convert simple_str to kstr
GFS2: make sure S_NOSEC flag isn't overwritten
GFS2: add support for rename2 and RENAME_EXCHANGE
gfs2: handle NULL rgd in set_rgrp_preferences
GFS2: inode.c: indent with TABs, not spaces
GFS2: mark the journal idle to fix ro mounts
GFS2: Average in only non-zero round-trip times for congestion stats
GFS2: Use average srttb value in congestion calculations
We cannot provide an efficient implementation due to the headers
on the data blocks, so there doesn't seem much point in having it.
At the end of gfs2_set_inode_flags inode->i_flags is set to flags, so
we should be modifying flags instead of inode->i_flags, so it isn't
overwritten.
Signed-off-by: Benjamin Marzinski <bmarzins redhat com>
Pull third hunk of vfs changes from Al Viro:
"This contains the ->direct_IO() changes from Omar + saner
generic_write_checks() + dealing with fcntl()/{read,write}() races
(mirroring O_APPEND/O_DIRECT into iocb->ki_flags and instead of
repeatedly looking at ->f_flags, which can be changed by fcntl(2),
check ->ki_flags - which cannot) + infrastructure bits for dhowells'
d_inode annotations + Christophs switch of /dev/loop to
vfs_iter_write()"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (30 commits)
block: loop: switch to VFS ITER_BVEC
configfs: Fix inconsistent use of file_inode() vs file->f_path.dentry->d_inode
VFS: Make pathwalk use d_is_reg() rather than S_ISREG()
VFS: Fix up debugfs to use d_is_dir() in place of S_ISDIR()
VFS: Combine inode checks with d_is_negative() and d_is_positive() in pathwalk
NFS: Don't use d_inode as a variable name
VFS: Impose ordering on accesses of d_inode and d_flags
VFS: Add owner-filesystem positive/negative dentry checks
nfs: generic_write_checks() shouldn't be done on swapout...
ocfs2: use __generic_file_write_iter()
mirror O_APPEND and O_DIRECT into iocb->ki_flags
switch generic_write_checks() to iocb and iter
ocfs2: move generic_write_checks() before the alignment checks
ocfs2_file_write_iter: stop messing with ppos
udf_file_write_iter: reorder and simplify
fuse: ->direct_IO() doesn't need generic_write_checks()
ext4_file_write_iter: move generic_write_checks() up
xfs_file_aio_write_checks: switch to iocb/iov_iter
generic_write_checks(): drop isblk argument
blkdev_write_iter: expand generic_file_checks() call in there
Pull second vfs update from Al Viro:
"Now that net-next went in... Here's the next big chunk - killing
->aio_read() and ->aio_write().
There'll be one more pile today (direct_IO changes and
generic_write_checks() cleanups/fixes), but I'd prefer to keep that
one separate"
* 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (37 commits)
->aio_read and ->aio_write removed
pcm: another weird API abuse
infinibad: weird APIs switched to ->write_iter()
kill do_sync_read/do_sync_write
fuse: use iov_iter_get_pages() for non-splice path
fuse: switch to ->read_iter/->write_iter
switch drivers/char/mem.c to ->read_iter/->write_iter
make new_sync_{read,write}() static
coredump: accept any write method
switch /dev/loop to vfs_iter_write()
serial2002: switch to __vfs_read/__vfs_write
ashmem: use __vfs_read()
export __vfs_read()
autofs: switch to __vfs_write()
new helper: __vfs_write()
switch hugetlbfs to ->read_iter()
coda: switch to ->read_iter/->write_iter
ncpfs: switch to ->read_iter/->write_iter
net/9p: remove (now-)unused helpers
p9_client_attach(): set fid->uid correctly
Most of the patches fix GFS2 quotas, which were not properly enforced.
There's another that adds me as a GFS2 co-maintainer, and a couple
patches that fix a kernel panic doing splice_write on GFS2 as well as
a few correctness patches"
gfs2: fix quota refresh race in do_glock()
gfs2: incorrect check for debugfs returns
gfs2: allow fallocate to max out quotas/fs efficiently
gfs2: allow quota_check and inplace_reserve to return available blocks
gfs2: perform quota checks against allocation parameters
GFS2: Move gfs2_file_splice_write outside of #ifdef
GFS2: Allocate reservation during splice_write
GFS2: gfs2_set_acl(): Cache "no acl" as well
Add myself (Bob Peterson) as a maintainer of GFS2
... avoiding write_iter/fcntl races.
All places outside of core VFS that checked ->read and ->write for being NULL or
called the methods directly are gone now, so NULL {read,write} with non-NULL
{read,write}_iter will do the right thing in all cases.
struct kiocb now is a generic I/O container, so move it to fs.h.
Also do a #include diet for aio.h while we're at it.
We can quickly get an estimate of how many blocks are available
for allocation restricted by quota and fs size respectively, using
the ap->allowed field in the gfs2_alloc_parms structure.
gfs2_quota_check() and gfs2_inplace_reserve() provide these values.
Once we have the total number of blocks available to us, we can
compute how many bytes of data can be written using those blocks
instead of guessing inefficiently.
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Use struct gfs2_alloc_parms as an argument to gfs2_quota_check()
and gfs2_quota_lock_check() to check for quota violations while
accounting for the new blocks requested by the current operation
in ap->target.
Previously, the number of new blocks requested during an operation
were not accounted for during quota_check and would allow these
operations to exceed quota. This was not very apparent since most
operations allocated only 1 block at a time and quotas would get
violated in the next operation. i.e. quota excess would only be by
1 block or so. With fallocate, (where we allocate a bunch of blocks
at once) the quota excess is non-trivial and is addressed by this
patch.
This patch moves function gfs2_file_splice_write so it's not
conditionally compiled.
This patch adds a GFS2-specific function for splice_write which
first calls function gfs2_rs_alloc to make sure a reservation
structure has been allocated before attempting to reserve blocks.
Pull lazytime mount option support from Al Viro:
"Lazytime stuff from tytso"
* 'lazytime' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
ext4: add optimization for the lazytime mount option
vfs: add find_inode_nowait() function
vfs: add support for a lazytime mount option
Nobody uses it anymore.
[akpm@linux-foundation.org: fix filemap_xip.c]
Cc: Wu Fengguang <fengguang.wu@intel.com>
Add a new mount option which enables a new "lazytime" mode. This mode
causes atime, mtime, and ctime updates to only be made to the
in-memory version of the inode. The on-disk times will only get
updated when (a) if the inode needs to be updated for some non-time
related change, (b) if userspace calls fsync(), syncfs() or sync(), or
(c) just before an undeleted inode is evicted from memory.
This is OK according to POSIX because there are no guarantees after a
crash unless userspace explicitly requests via a fsync(2) call.
For workloads which feature a large number of random write to a
preallocated file, the lazytime mount option significantly reduces
writes to the inode table. The repeated 4k writes to a single block
will result in undesirable stress on flash devices and SMR disk
drives. Even on conventional HDD's, the repeated writes to the inode
table block will trigger Adjacent Track Interference (ATI) remediation
latencies, which very negatively impact long tail latencies --- which
is a very big deal for web serving tiers (for example).
Google-Bug-Id: 18297052
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
gfs2_fallocate() wasn't updating ctime and mtime when modifying the
inode. Add a call to file_update_time() to do that.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
This addresses an issue caught by fsx where the inode size was not being
updated to the expected value after fallocate(2) with mode 0.
The problem was caused by the offset and len parameters being converted
to multiples of the file system's block size, so i_size would be rounded
up to the nearest block size multiple instead of the requested size.
This replaces the per-chunk i_size updates with a single i_size_write on
successful completion of the operation. With this patch gfs2 gets
through a complete run of fsx.
For clarity, the check for (error == 0) following the loop is removed as
all failures before that point jump to out_* labels or return.
gfs2_fallocate wasn't checking inode_newsize_ok nor get_write_access.
Split out the context setup and inode locking pieces into a separate
function to make it more clear and add these missing calls.
inode_newsize_ok is called conditional on FALLOC_FL_KEEP_SIZE as there
is no need to enforce a file size limit if it isn't going to change.
If an application does a sequence of (1) big write, (2) little write
we don't necessarily want to reset the size hint based on the smaller
size. The fact that they did any big writes implies they may do more,
and therefore we should try to allocate bigger block reservations, even
if the last few were small writes. Therefore this patch changes function
gfs2_size_hint so that the size hint can only grow; it cannot shrink.
This is especially important where there are multiple writers.
Pull file locking related changes from Jeff Layton:
"This release is a little more busy for file locking changes than the
last:
- a set of patches from Kinglong Mee to fix the lockowner handling in
knfsd
- a pile of cleanups to the internal file lease API. This should get
us a bit closer to allowing for setlease methods that can block.
There are some dependencies between mine and Bruce's trees this cycle,
and I based my tree on top of the requisite patches in Bruce's tree"
* tag 'locks-v3.18-1' of git://git.samba.org/jlayton/linux: (26 commits)
locks: fix fcntl_setlease/getlease return when !CONFIG_FILE_LOCKING
locks: flock_make_lock should return a struct file_lock (or PTR_ERR)
locks: set fl_owner for leases to filp instead of current->files
locks: give lm_break a return value
locks: __break_lease cleanup in preparation of allowing direct removal of leases
locks: remove i_have_this_lease check from __break_lease
locks: move freeing of leases outside of i_lock
locks: move i_lock acquisition into generic_*_lease handlers
locks: define a lm_setup handler for leases
locks: plumb a "priv" pointer into the setlease routines
nfsd: don't keep a pointer to the lease in nfs4_file
locks: clean up vfs_setlease kerneldoc comments
locks: generic_delete_lease doesn't need a file_lock at all
nfsd: fix potential lease memory leak in nfs4_setlease
locks: close potential race in lease_get_mtime
security: make security_file_set_fowner, f_setown and __f_setown void return
locks: consolidate "nolease" routines
locks: remove lock_may_read and lock_may_write
lockd: rip out deferred lock handling from testlock codepath
NFSD: Get reference of lockowner when coping file_lock
GFS2 and NFS have setlease routines that always just return -EINVAL.
Turn that into a generic routine that can live in fs/libfs.c.
Cc: <linux-nfs@vger.kernel.org>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: <cluster-devel@redhat.com>
Signed-off-by: Jeff Layton <jlayton@primarydata.com>
Acked-by: Trond Myklebust <trond.myklebust@primarydata.com>
This patch changes the flock code so that it uses the TRY_1CB flag
instead of the TRY flag on the first attempt. That forces any holding
nodes to issue a dlm callback, which requests a demote of the glock.
Then, if the "try" failed, it sleeps a small amount of time for the
demote to occur. Then it tries again, for an increasing amount of time.
Subsequent attempts to gain the "try" lock don't use "_1CB" so that
only one callback is issued.
This patch removes the GLF_NOCACHE flag from the glocks associated with
flocks. There should be no good reason not to cache glocks for flocks:
they only force the glock to be demoted before they can be reacquired,
which can slow down performance and even cause glock hangs, especially
in cases where the flocks are held in Shared (SH) mode.
This patch allows flock glocks to use a non-blocking dequeue rather
than dq_wait. It also reverts the previous patch I had posted regarding
dq_wait. The reverted patch isn't necessarily a bad idea, but I decided
this might avoid unforeseen side effects, and was therefore safer.
Pull vfs updates from Al Viro:
"This the bunch that sat in -next + lock_parent() fix. This is the
minimal set; there's more pending stuff.
In particular, I really hope to get acct.c fixes merged this cycle -
we need that to deal sanely with delayed-mntput stuff. In the next
pile, hopefully - that series is fairly short and localized
(kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more
iov_iter work. Most of prereqs for ->splice_write with sane locking
order are there and Kent's dio rewrite would also fit nicely on top of
this pile"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits)
lock_parent: don't step on stale ->d_parent of all-but-freed one
kill generic_file_splice_write()
ceph: switch to iter_file_splice_write()
shmem: switch to iter_file_splice_write()
nfs: switch to iter_splice_write_file()
fs/splice.c: remove unneeded exports
ocfs2: switch to iter_file_splice_write()
->splice_write() via ->write_iter()
bio_vec-backed iov_iter
optimize copy_page_{to,from}_iter()
bury generic_file_aio_{read,write}
lustre: get rid of messing with iovecs
ceph: switch to ->write_iter()
ceph_sync_direct_write: stop poking into iov_iter guts
ceph_sync_read: stop poking into iov_iter guts
new helper: copy_page_from_iter()
fuse: switch to ->write_iter()
btrfs: switch to ->write_iter()
ocfs2: switch to ->write_iter()
xfs: switch to ->write_iter()
iter_file_splice_write() - a ->splice_write() instance that gathers the
pipe buffers, builds a bio_vec-based iov_iter covering those and feeds
it to ->write_iter(). A bunch of simple cases coverted to that...
[AV: fixed the braino spotted by Cyrill]
Related function is not gfs2_set_flags but do_gfs2_set_flags
Signed-off-by: Fabian Frederick <fabf@skynet.be>
GFS2 has a transaction glock, which must be grabbed for every
transaction, whose purpose is to deal with freezing the filesystem.
Aside from this involving a large amount of locking, it is very easy to
make the current fsfreeze code hang on unfreezing.
This patch rewrites how gfs2 handles freezing the filesystem. The
transaction glock is removed. In it's place is a freeze glock, which is
cached (but not held) in a shared state by every node in the cluster
when the filesystem is mounted. This lock only needs to be grabbed on
freezing, and actions which need to be safe from freezing, like
recovery.
When a node wants to freeze the filesystem, it grabs this glock
exclusively. When the freeze glock state changes on the nodes (either
from shared to unlocked, or shared to exclusive), the filesystem does a
special log flush. gfs2_log_flush() does all the work for flushing out
the and shutting down the incore log, and then it tries to grab the
freeze glock in a shared state again. Since the filesystem is stuck in
gfs2_log_flush, no new transaction can start, and nothing can be written
to disk. Unfreezing the filesytem simply involes dropping the freeze
glock, allowing gfs2_log_flush() to grab and then release the shared
lock, so it is cached for next time.
However, in order for the unfreezing ioctl to occur, gfs2 needs to get a
shared lock on the filesystem root directory inode to check permissions.
If that glock has already been grabbed exclusively, fsfreeze will be
unable to get the shared lock and unfreeze the filesystem.
In order to allow the unfreeze, this patch makes gfs2 grab a shared lock
on the filesystem root directory during the freeze, and hold it until it
unfreezes the filesystem. The functions which need to grab a shared
lock in order to allow the unfreeze ioctl to be issued now use the lock
grabbed by the freeze code instead.
The freeze and unfreeze code take care to make sure that this shared
lock will not be dropped while another process is using it.
Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com>
filemap_map_pages() is generic implementation of ->map_pages() for
filesystems who uses page cache.
It should be safe to use filemap_map_pages() for ->map_pages() if
filesystem use filemap_fault() for ->fault().
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Ning Qu <quning@gmail.com>
This patch causes GFS2 to lock the i_mutex during fallocate. It
also switches from using a dinode's inode glock to using a local
holder like the other GFS2 i_operations.
This patch adds a structure to contain allocation parameters with
the intention of future expansion of this structure. The idea is
that we should be able to add more information about the allocation
in the future in order to allow the allocator to make a better job
of placing the requests on-disk.
There is no functional difference from applying this patch.
The reservation for an inode should be cleared when it is truncated so
that we can start again at a different offset for future allocations.
We could try and do better than that, by resetting the search based on
where the truncation started from, but this is only a first step.
In addition, there are three callers of gfs2_rs_delete() but only one
of those should really be testing the value of i_writecount. While
we get away with that in the other cases currently, I think it would
be better if we made that test specific to the one case which
requires it.
GFS2 was only setting I_DIRTY_DATASYNC on files that it wrote to, when
it actually increased the file size. If gfs2_fsync was called without
I_DIRTY_DATASYNC set, it didn't flush the incore data to the log before
returning, so any metadata or journaled data changes were not getting
fsynced. This meant that writes to the middle of files were not always
getting fsynced properly.
This patch makes gfs2 set I_DIRTY_DATASYNC whenever metadata has been
updated during a write. It also make gfs2_sync flush the incore log
if I_DIRTY_PAGES is set, and the file is using data journalling. This
will make sure that all incore logged data gets written to disk before
returning from a fsync.
Pull second set of VFS changes from Al Viro:
"Assorted f_pos race fixes, making do_splice_direct() safe to call with
i_mutex on parent, O_TMPFILE support, Jeff's locks.c series,
->d_hash/->d_compare calling conventions changes from Linus, misc
stuff all over the place."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
Document ->tmpfile()
ext4: ->tmpfile() support
vfs: export lseek_execute() to modules
lseek_execute() doesn't need an inode passed to it
block_dev: switch to fixed_size_llseek()
cpqphp_sysfs: switch to fixed_size_llseek()
tile-srom: switch to fixed_size_llseek()
proc_powerpc: switch to fixed_size_llseek()
ubi/cdev: switch to fixed_size_llseek()
pci/proc: switch to fixed_size_llseek()
isapnp: switch to fixed_size_llseek()
lpfc: switch to fixed_size_llseek()
locks: give the blocked_hash its own spinlock
locks: add a new "lm_owner_key" lock operation
locks: turn the blocked_list into a hashtable
locks: convert fl_link to a hlist_node
locks: avoid taking global lock if possible when waking up blocked waiters
locks: protect most of the file_lock handling with i_lock
locks: encapsulate the fl_link list handling
locks: make "added" in __posix_lock_file a bool
Pull GFS2 updates from Steven Whitehouse:
"There are a few bug fixes for various, mostly very minor corner cases,
plus some interesting new features.
The new features include atomic_open whose main benefit will be the
reduction in locking overhead in case of combined lookup/create and
open operations, sorting the log buffer lists by block number to
improve the efficiency of AIL writeback, and aggressively issuing
revokes in gfs2_log_flush to reduce overhead when dropping glocks."
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-nmw:
GFS2: Reserve journal space for quota change in do_grow
GFS2: Fix fstrim boundary conditions
GFS2: fix warning message
GFS2: aggressively issue revokes in gfs2_log_flush
GFS2: fix regression in dir_double_exhash
GFS2: Add atomic_open support
GFS2: Only do one directory search on create
GFS2: fix error propagation in init_threads()
GFS2: Remove no-op wrapper function
GFS2: Cocci spatch "ptr_ret.spatch"
GFS2: Eliminate gfs2_rg_lops
GFS2: Sort buffer lists by inplace block number
Having a global lock that protects all of this code is a clear
scalability problem. Instead of doing that, move most of the code to be
protected by the i_lock instead. The exceptions are the global lists
that the ->fl_link sits on, and the ->fl_block list.
->fl_link is what connects these structures to the
global lists, so we must ensure that we hold those locks when iterating
over or updating these lists.
Furthermore, sound deadlock detection requires that we hold the
blocked_list state steady while checking for loops. We also must ensure
that the search and update to the list are atomic.
For the checking and insertion side of the blocked_list, push the
acquisition of the global lock into __posix_lock_file and ensure that
checking and update of the blocked_list is done without dropping the
lock in between.
On the removal side, when waking up blocked lock waiters, take the
global lock before walking the blocked list and dequeue the waiters from
the global list prior to removal from the fl_block list.
With this, deadlock detection should be race free while we minimize
excessive file_lock_lock thrashing.
Finally, in order to avoid a lock inversion problem when handling
/proc/locks output we must ensure that manipulations of the fl_block
list are also protected by the file_lock_lock.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
I've restricted atomic_open to only operate on regular files, although
I still don't understand why atomic_open should not be possible also for
directories on GFS2. That can always be added in later though, if it
makes sense.
The ->atomic_open function can be passed negative dentries, which
in most cases means either ENOENT (->lookup) or a call to d_instantiate
(->create). In the GFS2 case though, we need to actually perform the
look up, since we do not know whether there has been a new inode created
on another node. The look up calls d_splice_alias which then tries to
rehash the dentry - so the solution here is to simply check for that
in d_splice_alias. The same issue is likely to affect any other cluster
filesystem implementing ->atomic_open
Cc: "J. Bruce Fields" <bfields fieldses org>
Cc: Jeff Layton <jlayton@redhat.com>
This patch calls get_write_access in a few functions. This
merely increases inode->i_writecount for the duration of the function.
That will ensure that any file closes won't delete the inode's
multi-block reservation while the function is running.
