path: root/fs/gfs2/eaops.c
2007-10-10[GFS2] mark struct *_operations constDenis Cheng
these struct *_operations are all method tables, thus should be const. Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-16Remove capability.h from mm.hAlexey Dobriyan
I forgot to remove capability.h from mm.h while removing sched.h! This patch remedies that, because the only inline function which was using CAP_something was made out of line. Cross-compile tested without regressions on: all powerpc defconfigs all mips defconfigs all m68k defconfigs all arm defconfigs all ia64 defconfigs alpha alpha-allnoconfig alpha-defconfig alpha-up arm i386 i386-allnoconfig i386-defconfig i386-up ia64 ia64-allnoconfig ia64-defconfig ia64-up m68k mips parisc parisc-allnoconfig parisc-defconfig parisc-up powerpc powerpc-up s390 s390-allnoconfig s390-defconfig s390-up sparc sparc-allnoconfig sparc-defconfig sparc-up sparc64 sparc64-allnoconfig sparc64-defconfig sparc64-up um-x86_64 x86_64 x86_64-allnoconfig x86_64-defconfig x86_64-up as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-30[GFS2] Shrink gfs2_inode (3) - di_modeSteven Whitehouse
This removes the duplicate di_mode field in favour of using the inode->i_mode field. This saves 4 bytes. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-25[GFS2/DLM] Fix trailing whitespaceSteven Whitehouse
As per Andrew Morton's request, removed trailing whitespace. Cc: Andrew Morton <akpm@osdl.org> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-19[GFS2] Export lm_interface to kernel headersFabio Massimo Di Nitto
lm_interface.h has a few out of the tree clients such as GFS1 and userland tools. Right now, these clients keeps a copy of the file in their build tree that can go out of sync. Move lm_interface.h to include/linux, export it to userland and clean up fs/gfs2 to use the new location. Signed-off-by: Fabio M. Di Nitto <fabbione@ubuntu.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-05[GFS2] Extended attribute code style changesSteven Whitehouse
As per Jan Engelhardt's request and also a few of my own. It has been possible to add a few most const to the code as a result of the change in gfs2_ea_name2type. Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-01[GFS2] Update copyright, tidy up incore.hSteven Whitehouse
As per comments from Jan Engelhardt <jengelh@linux01.gwdg.de> this updates the copyright message to say "version" in full rather than "v.2". Also incore.h has been updated to remove forward structure declarations which are not required. The gfs2_quota_lvb structure has now had endianess annotations added to it. Also quota.c has been updated so that we now store the lvb data locally in endian independant format to avoid needing a structure in host endianess too. As a result the endianess conversions are done as required at various points and thus the conversion routines in lvb.[ch] are no longer required. I've moved the one remaining constant in lvb.h thats used into lm.h and removed the unused lvb.[ch]. I have not changed the HIF_ constants. That is left to a later patch which I hope will unify the gh_flags and gh_iflags fields of the struct gfs2_holder. Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-06-22[GFS2] [-mm patch] fs/gfs2/: make code staticAdrian Bunk
This patch makes the following needlessly global code static: - eaops.c: struct gfs2_security_eaops - rgrp.c: gfs2_free_uninit_di() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-06-14[GFS2] Fix unlinked file handlingSteven Whitehouse
This patch fixes the way we have been dealing with unlinked, but still open files. It removes all limits (other than memory for inodes, as per every other filesystem) on numbers of these which we can support on GFS2. It also means that (like other fs) its the responsibility of the last process to close the file to deallocate the storage, rather than the person who did the unlinking. Note that with GFS2, those two events might take place on different nodes. Also there are a number of other changes: o We use the Linux inode subsystem as it was intended to be used, wrt allocating GFS2 inodes o The Linux inode cache is now the point which we use for local enforcement of only holding one copy of the inode in core at once (previous to this we used the glock layer). o We no longer use the unlinked "special" file. We just ignore it completely. This makes unlinking more efficient. o We now use the 4th block allocation state. The previously unused state is used to track unlinked but still open inodes. o gfs2_inoded is no longer needed o Several fields are now no longer needed (and removed) from the in core struct gfs2_inode o Several fields are no longer needed (and removed) from the in core superblock There are a number of future possible optimisations and clean ups which have been made possible by this patch. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-05-25[GFS2] Fix for selinux supportRyan O'Hara
This should fix the mount problems with gfs2 and selinux. Signed-off-by: Ryan O'Hara <rohara@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-05-22[GFS2] selinux supportRyan O'Hara
This adds support to GFS2 for selinux extended attributes. There is a known bug in gfs2_ea_get() which is believed to be independant of this patch. Further patches will follow once that bug is fixed in order to make GFS2 use as much of the generic eattr infrastructure as possible. Signed-off-by: Ryan O'Hara <rohara@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-05-18[GFS2] Update copyright date to 2006Steven Whitehouse
2006-05-18[GFS2] Remove semaphore.h from C filesSteven Whitehouse
We no longer use semaphores, everything has been converted to mutex or rwsem, so we don't need to include this header any more. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-04-28[GFS2] [-mm patch] fs/gfs2/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make needlessly global code static - #if 0 unused functions - remove the following global function that was both unused and unimplemented: - super.c: gfs2_do_upgrade() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-02-27[GFS2] Macros removal in gfs2.hSteven Whitehouse
As suggested by Pekka Enberg <penberg@cs.helsinki.fi>. The DIV_RU macro is renamed DIV_ROUND_UP and and moved to kernel.h The other macros are gone from gfs2.h as (although not requested by Pekka Enberg) are a number of included header file which are now included individually. The inode number comparison function is now an inline function. The DT2IF and IF2DT may be addressed in a future patch. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-01-16[GFS2] The core of GFS2David Teigland
This patch contains all the core files for GFS2. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
