This patch applies the following ext4 patch:
ext4 crypto: use per-inode tfm structure
As suggested by Herbert Xu, we shouldn't allocate a new tfm each time
we read or write a page. Instead we can use a single tfm hanging off
the inode's crypt_info structure for all of our encryption needs for
that inode, since the tfm can be used by multiple crypto requests in
parallel.
Also use cmpxchg() to avoid races that could result in crypt_info
structure getting doubly allocated or doubly freed.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
This patch implements encryption support for symlink.
Signed-off-by: Uday Savagaonkar <savagaon@google.com>
This patch activates the following APIs for encryption support.
The rules quoted by ext4 are:
- An unencrypted directory may contain encrypted or unencrypted files
or directories.
- All files or directories in a directory must be protected using the
same key as their containing directory.
- Encrypted inode for regular file should not have inline_data.
- Encrypted symlink and directory may have inline_data and inline_dentry.
This patch activates the following APIs.
1. f2fs_link : validate context
2. f2fs_lookup : ''
3. f2fs_rename : ''
4. f2fs_create/f2fs_mkdir : inherit its dir's context
5. f2fs_direct_IO : do buffered io for regular files
6. f2fs_open : check encryption info
7. f2fs_file_mmap : ''
8. f2fs_setattr : ''
9. f2fs_file_write_iter : '' (Called by sys_io_submit)
10. f2fs_fallocate : do not support fcollapse
11. f2fs_evict_inode : free_encryption_info
Signed-off-by: Michael Halcrow <mhalcrow@google.com>
This patch fixes the below warning.
sparse warnings: (new ones prefixed by >>)
>> fs/f2fs/inode.c:56:23: sparse: restricted __le32 degrades to integer
>> fs/f2fs/inode.c:56:52: sparse: restricted __le32 degrades to integer
Reported-by: kbuild test robot <fengguang.wu@intel.com>
This patch tries to preserve last extent info in extent tree cache into on-disk
inode, so this can help us to reuse the last extent info next time for
performance.
Signed-off-by: Chao Yu <chao2.yu@samsung.com>
With normal extent info cache, we records largest extent mapping between logical
block and physical block into extent info, and we persist extent info in on-disk
inode.
When we enable extent tree cache, if extent info of on-disk inode is exist, and
the extent is not a small fragmented mapping extent. We'd better to load the
extent info into extent tree cache when inode is loaded. By this way we can have
more chance to hit extent tree cache rather than taking more time to read dnode
page for block address.
This patch is to avoid some punch_hole overhead when releasing volatile data.
If volatile data was not written yet, we just can make the first page as zero.
This patch enables rb-tree based extent cache in f2fs.
When we mount with "-o extent_cache", f2fs will try to add recently accessed
page-block mappings into rb-tree based extent cache as much as possible, instead
of original one extent info cache.
By this way, f2fs can support more effective cache between dnode page cache and
disk. It will supply high hit ratio in the cache with fewer memory when dnode
page cache are reclaimed in environment of low memory.
Storage: Sandisk sd card 64g
1.append write file (offset: 0, size: 128M);
2.override write file (offset: 2M, size: 1M);
3.override write file (offset: 4M, size: 1M);
4.override write file (offset: 48M, size: 1M);
5.override write file (offset: 112M, size: 1M);
6.sync
7.echo 3 > /proc/sys/vm/drop_caches
8.read file (size:128M, unit: 4k, count: 32768)
(time dd if=/mnt/f2fs/128m bs=4k count=32768)
Extent Hit Ratio:
before patched
Hit Ratio 121 / 1071 1071 / 1071
Performance:
before patched
real 0m37.051s 0m35.556s
user 0m0.040s 0m0.026s
sys 0m2.990s 0m2.251s
Memory Cost:
before patched
Tree Count: 0 1 (size: 24 bytes)
Node Count: 0 45 (size: 1440 bytes)
v3:
o retest and given more details of test result.
Move ext_lock out of struct extent_info, then in the following patches we can
use variables with struct extent_info type as a parameter to pass pure data.
We use kzalloc to allocate memory in __recover_inline_status, and use this
all-zero memory to check the inline date content of inode page by comparing
them. This is low effective and not needed, let's check inline date content
directly.
[Jaegeuk Kim: make the code more neat]
This patch adds two new ioctls to release inmemory pages grabbed by atomic
writes.
o f2fs_ioc_abort_volatile_write
- If transaction was failed, all the grabbed pages and data should be written.
o f2fs_ioc_release_volatile_write
- This is to enhance the performance of PERSIST mode in sqlite.
In order to avoid huge memory consumption which causes OOM, this patch changes
volatile writes to use normal dirty pages, instead blocked flushing to the disk
as long as system does not suffer from memory pressure.
In do_read_inode, if we failed __recover_inline_status, the inode has inline
flag without increasing its count.
Later, f2fs_evict_inode will decrease the count, which causes -1.
This patch simplifies the inline_data usage with the following rule.
1. inline_data is set during the file creation.
2. If new data is requested to be written ranges out of inline_data,
f2fs converts that inode permanently.
3. There is no cases which converts non-inline_data inode to inline_data.
4. The inline_data flag should be changed under inode page lock.
This patch fixes wrongly counting inline_data inode numbers.
This patch adds status information for inline_dentry inodes.
This patch fixes to use highmem for directory pages.
This patch adds support for volatile writes which keep data pages in memory
until f2fs_evict_inode is called by iput.
For instance, we can use this feature for the sqlite database as follows.
While supporting atomic writes for main database file, we can keep its journal
data temporarily in the page cache by the following sequence.
1. open
-> ioctl(F2FS_IOC_START_VOLATILE_WRITE);
2. writes
: keep all the data in the page cache.
3. flush to the database file with atomic writes
a. ioctl(F2FS_IOC_START_ATOMIC_WRITE);
b. writes
c. ioctl(F2FS_IOC_COMMIT_ATOMIC_WRITE);
4. close
-> drop the cached data
This patch introduces a very limited functionality for atomic write support.
In order to support atomic write, this patch adds two ioctls:
o F2FS_IOC_START_ATOMIC_WRITE
o F2FS_IOC_COMMIT_ATOMIC_WRITE
The database engine should be aware of the following sequence.
1. open
-> ioctl(F2FS_IOC_START_ATOMIC_WRITE);
2. writes
: all the written data will be treated as atomic pages.
3. commit
-> ioctl(F2FS_IOC_COMMIT_ATOMIC_WRITE);
: this flushes all the data blocks to the disk, which will be shown all or
nothing by f2fs recovery procedure.
4. repeat to #2.
The IO pattens should be:
,- START_ATOMIC_WRITE ,- COMMIT_ATOMIC_WRITE
CP | D D D D D D | FSYNC | D D D D | FSYNC ...
`- COMMIT_ATOMIC_WRITE
This patch relocates f2fs_unlock_op in every directory operations to be called
after any error was processed.
Otherwise, the checkpoint can be entered with valid node ids without its
dentry when -ENOSPC is occurred.
Previously f2fs only counts dirty dentry pages, but there is no reason not to
expand the scope.
This patch changes the names on the management of dirty pages and to count
dirty pages in each inode info as well.
If any f2fs_bug_on is triggered, fsck.f2fs is needed.
This patch adds three inline functions to clean up dirty casting codes.
When inode is evicted, all the page cache belong to this inode should be
released including the xattr node page. But previously we didn't do this, this
patch fixed this issue.
v2:
o reposition invalidate_mapping_pages() to the right place suggested by
Jaegeuk Kim.
This patch introduces a inode number list in which represents inodes having
appended data writes or updated data writes after last checkpoint.
This will be used at fsync to determine whether the recovery information
should be written or not.
Reviewed-by: Chao Yu <chao2.yu@samsung.com>
Andrey Tsyvarev reported:
"Using memory error detector reveals the following use-after-free error
in 3.15.0:
AddressSanitizer: heap-use-after-free in f2fs_evict_inode
Read of size 8 by thread T22279:
[<ffffffffa02d8702>] f2fs_evict_inode+0x102/0x2e0 [f2fs]
[<ffffffff812359af>] evict+0x15f/0x290
[< inlined >] iput+0x196/0x280 iput_final
[<ffffffff812369a6>] iput+0x196/0x280
[<ffffffffa02dc416>] f2fs_put_super+0xd6/0x170 [f2fs]
[<ffffffff81210095>] generic_shutdown_super+0xc5/0x1b0
[<ffffffff812105fd>] kill_block_super+0x4d/0xb0
[<ffffffff81210a86>] deactivate_locked_super+0x66/0x80
[<ffffffff81211c98>] deactivate_super+0x68/0x80
[<ffffffff8123cc88>] mntput_no_expire+0x198/0x250
[< inlined >] SyS_umount+0xe9/0x1a0 SYSC_umount
[<ffffffff8123f1c9>] SyS_umount+0xe9/0x1a0
[<ffffffff81cc8df9>] system_call_fastpath+0x16/0x1b
Freed by thread T3:
[<ffffffffa02dc337>] f2fs_i_callback+0x27/0x30 [f2fs]
[< inlined >] rcu_process_callbacks+0x2d6/0x930 __rcu_reclaim
[< inlined >] rcu_process_callbacks+0x2d6/0x930 rcu_do_batch
[< inlined >] rcu_process_callbacks+0x2d6/0x930 invoke_rcu_callbacks
[< inlined >] rcu_process_callbacks+0x2d6/0x930 __rcu_process_callbacks
[<ffffffff810fd266>] rcu_process_callbacks+0x2d6/0x930
[<ffffffff8107cce2>] __do_softirq+0x142/0x380
[<ffffffff8107cf50>] run_ksoftirqd+0x30/0x50
[<ffffffff810b2a87>] smpboot_thread_fn+0x197/0x280
[<ffffffff810a8238>] kthread+0x148/0x160
[<ffffffff81cc8d4c>] ret_from_fork+0x7c/0xb0
Allocated by thread T22276:
[<ffffffffa02dc7dd>] f2fs_alloc_inode+0x2d/0x170 [f2fs]
[<ffffffff81235e2a>] iget_locked+0x10a/0x230
[<ffffffffa02d7495>] f2fs_iget+0x35/0xa80 [f2fs]
[<ffffffffa02e2393>] f2fs_fill_super+0xb53/0xff0 [f2fs]
[<ffffffff81211bce>] mount_bdev+0x1de/0x240
[<ffffffffa02dbce0>] f2fs_mount+0x10/0x20 [f2fs]
[<ffffffff81212a85>] mount_fs+0x55/0x220
[<ffffffff8123c026>] vfs_kern_mount+0x66/0x200
[< inlined >] do_mount+0x2b4/0x1120 do_new_mount
[<ffffffff812400d4>] do_mount+0x2b4/0x1120
[< inlined >] SyS_mount+0xb2/0x110 SYSC_mount
[<ffffffff812414a2>] SyS_mount+0xb2/0x110
The buggy address ffff8800587866c8 is located 48 bytes inside
of 680-byte region [ffff880058786698, ffff880058786940)
Memory state around the buggy address:
ffff880058786100: ffffffff ffffffff ffffffff ffffffff
ffff880058786200: ffffffff ffffffff ffffffrr rrrrrrrr
ffff880058786300: rrrrrrrr rrffffff ffffffff ffffffff
ffff880058786400: ffffffff ffffffff ffffffff ffffffff
ffff880058786500: ffffffff ffffffff ffffffff fffffffr
>ffff880058786600: rrrrrrrr rrrrrrrr rrrfffff ffffffff
ffff880058786700: ffffffff ffffffff ffffffff ffffffff
ffff880058786800: ffffffff ffffffff ffffffff ffffffff
ffff880058786900: ffffffff rrrrrrrr rrrrrrrr rrrr....
ffff880058786a00: ........ ........ ........ ........
ffff880058786b00: ........ ........ ........ ........
Legend:
f - 8 freed bytes
r - 8 redzone bytes
. - 8 allocated bytes
x=1..7 - x allocated bytes + (8-x) redzone bytes
Investigation shows, that f2fs_evict_inode, when called for
'meta_inode', uses invalidate_mapping_pages() for 'node_inode'.
But 'node_inode' is deleted before 'meta_inode' in f2fs_put_super via
iput().
It seems that in common usage scenario this use-after-free is benign,
because 'node_inode' remains partially valid data even after
kmem_cache_free().
But things may change if, while 'meta_inode' is evicted in one f2fs
filesystem, another (mounted) f2fs filesystem requests inode from cache,
and formely
'node_inode' of the first filesystem is returned."
Nids for both meta_inode and node_inode are reservation, so it's not necessary
for us to invalidate pages which will never be allocated.
To fix this issue, let's skipping needlessly invalidating pages for
{meta,node}_inode in f2fs_evict_inode.
Reported-by: Andrey Tsyvarev <tsyvarev@ispras.ru>
Tested-by: Andrey Tsyvarev <tsyvarev@ispras.ru>
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
This patch add lower bound verification for nid in check_nid_range, so nids
reserved like 0, node, meta passed by caller could be checked there.
And then check_nid_range could be used in f2fs_nfs_get_inode for simplifying
code.
If the inode page is clean during its inode eviction, it'd better drop the page
to reduce further memory pressure.
Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
Use set_mask_bits() to atomically set i_flags instead of clearing out the
S_IMMUTABLE, S_APPEND, etc. flags and then setting them from the
FS_IMMUTABLE_FL, FS_APPEND_FL, etc. flags, since this opens up a race
where an immutable file has the immutable flag cleared for a brief
window of time.
Signed-off-by: Zhang Zhen <zhenzhang.zhang@huawei.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs
Pull f2fs updates from Jaegeuk Kim:
"This patch-set includes the following major enhancement patches.
- introduce large directory support
- introduce f2fs_issue_flush to merge redundant flush commands
- merge write IOs as much as possible aligned to the segment
- add sysfs entries to tune the f2fs configuration
- use radix_tree for the free_nid_list to reduce in-memory operations
- remove costly bit operations in f2fs_find_entry
- enhance the readahead flow for CP/NAT/SIT/SSA blocks
The other bug fixes are as follows:
- recover xattr node blocks correctly after sudden-power-cut
- fix to calculate the maximum number of node ids
- enhance to handle many error cases
And, there are a bunch of cleanups"
* tag 'for-f2fs-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (62 commits)
f2fs: fix wrong statistics of inline data
f2fs: check the acl's validity before setting
f2fs: introduce f2fs_issue_flush to avoid redundant flush issue
f2fs: fix to cover io->bio with io_rwsem
f2fs: fix error path when fail to read inline data
f2fs: use list_for_each_entry{_safe} for simplyfying code
f2fs: avoid free slab cache under spinlock
f2fs: avoid unneeded lookup when xattr name length is too long
f2fs: avoid unnecessary bio submit when wait page writeback
f2fs: return -EIO when node id is not matched
f2fs: avoid RECLAIM_FS-ON-W warning
f2fs: skip unnecessary node writes during fsync
f2fs: introduce fi->i_sem to protect fi's info
f2fs: change reclaim rate in percentage
f2fs: add missing documentation for dir_level
f2fs: remove unnecessary threshold
f2fs: throttle the memory footprint with a sysfs entry
f2fs: avoid to drop nat entries due to the negative nr_shrink
f2fs: call f2fs_wait_on_page_writeback instead of native function
f2fs: introduce nr_pages_to_write for segment alignment
Reclaim will be leaving shadow entries in the page cache radix tree upon
evicting the real page. As those pages are found from the LRU, an
iput() can lead to the inode being freed concurrently. At this point,
reclaim must no longer install shadow pages because the inode freeing
code needs to ensure the page tree is really empty.
Add an address_space flag, AS_EXITING, that the inode freeing code sets
under the tree lock before doing the final truncate. Reclaim will check
for this flag before installing shadow pages.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Metin Doslu <metin@citusdata.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Ozgun Erdogan <ozgun@citusdata.com>
Cc: Roman Gushchin <klamm@yandex-team.ru>
Cc: Ryan Mallon <rmallon@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
The get_dirty_dents gives us the number of dirty dentry pages.
This patch introduces an i_dir_level field to support large directory.
Previously, f2fs maintains multi-level hash tables to find a dentry quickly
from a bunch of chiild dentries in a directory, and the hash tables consist of
the following tree structure as below.
In Documentation/filesystems/f2fs.txt,
A : bucket
B : block
N : MAX_DIR_HASH_DEPTH
level #0 | A(2B)
level #1 | A(2B) - A(2B)
level #2 | A(2B) - A(2B) - A(2B) - A(2B)
level #N/2 | A(2B) - A(2B) - A(2B) - A(2B) - A(2B) - ... - A(2B)
level #N | A(4B) - A(4B) - A(4B) - A(4B) - A(4B) - ... - A(4B)
But, if we can guess that a directory will handle a number of child files,
we don't need to traverse the tree from level #0 to #N all the time.
Since the lower level tables contain relatively small number of dentries,
the miss ratio of the target dentry is likely to be high.
In order to avoid that, we can configure the hash tables sparsely from level #0
like this.
level #0 | A(2B) - A(2B) - A(2B) - A(2B)
level #1 | A(2B) - A(2B) - A(2B) - A(2B) - A(2B) - ... - A(2B)
With this structure, we can skip the ineffective tree searches in lower level
hash tables.
This patch adds just a facility for this by introducing i_dir_level in
f2fs_inode.
In order to make fs consistency, update_inode_page should not be failed all
the time. Otherwise, it is possible to lose some metadata in the inode like
a link count.
Fixed a variety of trivial checkpatch warnings. The only delta should
be some minor formatting on log strings that were split / too long.
Signed-off-by: Chris Fries <cfries@motorola.com>
"boo sync" parameter is never referenced in f2fs_wait_on_page_writeback.
We should remove this parameter.
Signed-off-by: Yuan Zhong <yuan.mark.zhong@samsung.com>
This patch adds the number of inline_data files into the status information.
Note that the number is reset whenever the filesystem is newly mounted.
This patch introduces F2FS_INODE that returns struct f2fs_inode * from the inode
page.
By using this macro, we can remove unnecessary casting codes like below.
struct f2fs_inode *ri = &F2FS_NODE(inode_page)->i;
-> struct f2fs_inode *ri = F2FS_INODE(inode_page);
If you want to remove unnecessary BUG_ONs, you can just turn off F2FS_CHECK_FS
in your kernel config.
When storing i_rdev, we should check its file type.
The fs_locks is used to block other ops(ex, recovery) when doing checkpoint.
And each other operate routine(besides checkpoint) needs to acquire a fs_lock,
there is a terrible problem here, if these are too many concurrency threads acquiring
fs_lock, so that they will block each other and may lead to some performance problem,
but this is not the phenomenon we want to see.
Though there are some optimization patches introduced to enhance the usage of fs_lock,
but the thorough solution is using a *rw_sem* to replace the fs_lock.
Checkpoint routine takes write_sem, and other ops take read_sem, so that we can block
other ops(ex, recovery) when doing checkpoint, and other ops will not disturb each other,
this can avoid the problem described above completely.
Because of the weakness of rw_sem, the above change may introduce a potential problem
that the checkpoint thread might get starved if other threads are intensively locking
the read semaphore for I/O.(Pointed out by Xu Jin)
In order to avoid this, a wait_list is introduced, the appending read semaphore ops
will be dropped into the wait_list if checkpoint thread is waiting for write semaphore,
and will be waked up when checkpoint thread gives up write semaphore.
Thanks to Kim's previous review and test, and will be very glad to see other guys'
performance tests about this patch.
V2:
-fix the potential starvation problem.
-use more suitable func name suggested by Xu Jin.
[Jaegeuk Kim: adjust minor coding standard]
This patch adds basic inode flags for inline xattrs, F2FS_INLINE_XATTR,
and add a mount option, inline_xattr, which is enabled when xattr is set.
If the mount option is enabled, all the files are marked with the inline_xattrs
flag.
In f2fs_write_inode, updating inode after f2fs_balance_fs is not
a optimized way in the case that f2fs_gc is performed ahead. The
inode page will be unnecessarily written out twice, one of which
is in f2fs_gc->...->sync_node_pages and the other is in
update_inode_page.
Let's update the inode page in prior to f2fs_balance_fs to avoid
this.
To reproduce it,
$ touch file (before this step, should make the device need f2fs_gc)
$ sync (or wait the bdi to write dirty inode)
Signed-off-by: Jin Xu <jinuxstyle@gmail.com>
This patch fixes a deadlock bug that occurs quite often when there are
concurrent write and fsync on a same file.
Following is the simplified call trace when tasks get hung.
fsync thread:
- f2fs_sync_file
- f2fs_write_data_pages
- update_extent_cache
- update_inode
- wait_on_page_writeback
bdi writeback thread
- __writeback_single_inode
- mutex_lock(sbi->writepages)
The deadlock happens when the fsync thread waits on a inode page that has
been added to the f2fs' cached bio sbi->bio[NODE], and unfortunately,
no one else could be able to submit the cached bio to block layer for
writeback. This is because the fsync thread already hold a sbi->fs_lock and
the sbi->writepages lock, causing the bdi thread being blocked when attempt
to write data pages for the same inode. At the same time, f2fs_gc thread
does not notice the situation and could not help. Even the sync syscall
gets blocked.
To fix it, we could submit the cached bio first before waiting on a inode page
that is being written back.
[Jaegeuk Kim: add more cases to use f2fs_wait_on_page_writeback]
Introduce help function F2FS_NODE() to simplify the conversion of node_page to
f2fs_node.
If update_inode is called, we don't need to do write_inode.
So, let's use a *dirty* flag for each inode.
While an orphan inode has zero link_count, f2fs_gc is able to select the inode
for foreground gc.
- f2fs_gc
- do_garbage_collect
- gc_data_segment
: f2fs_iget is failed
: get_valid_blocks() != 0, so that retry
--> here we got the infinite loop.
This patch resolved this issue.
This patch tries to avoid the following deadlock condition of which the reclaim
path can trigger f2fs_balance_fs again.
[ INFO: inconsistent lock state ]
inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-W} usage.
kswapd0/41 [HC0[0]:SC0[0]:HE1:SE1] takes:
(&sbi->gc_mutex){+.+.?.}, at: f2fs_balance_fs+0xe6/0x100 [f2fs]
{RECLAIM_FS-ON-W} state was registered at:
[<ffffffff810aa5a9>] mark_held_locks+0xb9/0x140
[<ffffffff810aae85>] lockdep_trace_alloc+0x85/0xf0
[<ffffffff8113ab2c>] __alloc_pages_nodemask+0x7c/0x9b0
[<ffffffff81175aa8>] alloc_pages_current+0xb8/0x180
[<ffffffff811319cf>] __page_cache_alloc+0xaf/0xd0
[<ffffffff8113225c>] find_or_create_page+0x4c/0xb0
[<ffffffffa021359e>] find_data_page+0x14e/0x210 [f2fs]
[<ffffffffa021161b>] f2fs_gc+0x9eb/0xd90 [f2fs]
[<ffffffffa0218fae>] f2fs_balance_fs+0xee/0x100 [f2fs]
[<ffffffffa020848c>] f2fs_setattr+0x6c/0x200 [f2fs]
[<ffffffff811ae51b>] notify_change+0x1db/0x3a0
[<ffffffff8118fbd0>] do_truncate+0x60/0xa0
[<ffffffff8118fd95>] vfs_truncate+0x185/0x1b0
[<ffffffff8118fe1c>] do_sys_truncate+0x5c/0xa0
[<ffffffff8118ffee>] SyS_truncate+0xe/0x10
[<ffffffff816e2b42>] system_call_fastpath+0x16/0x1b
Add tracepoints in f2fs for tracing the syncing
operations like filesystem sync, file sync enter/exit.
It will helf to trace the code under debugging scenarios.
Also add tracepoints for tracing the various inode operations
like building inode, eviction of inode, link/unlike of
inodes.
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Pankaj Kumar <pankaj.km@samsung.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
[Jaegeuk: combine and modify the tracepoint structures]
In the previous version, f2fs uses global locks according to the usage types,
such as directory operations, block allocation, block write, and so on.
Reference the following lock types in f2fs.h.
enum lock_type {
RENAME, /* for renaming operations */
DENTRY_OPS, /* for directory operations */
DATA_WRITE, /* for data write */
DATA_NEW, /* for data allocation */
DATA_TRUNC, /* for data truncate */
NODE_NEW, /* for node allocation */
NODE_TRUNC, /* for node truncate */
NODE_WRITE, /* for node write */
NR_LOCK_TYPE,
In that case, we lose the performance under the multi-threading environment,
since every types of operations must be conducted one at a time.
In order to address the problem, let's share the locks globally with a mutex
array regardless of any types.
So, let users grab a mutex and perform their jobs in parallel as much as
possbile.
For this, I propose a new global lock scheme as follows.
0. Data structure
- f2fs_sb_info -> mutex_lock[NR_GLOBAL_LOCKS]
- f2fs_sb_info -> node_write
1. mutex_lock_op(sbi)
- try to get an avaiable lock from the array.
- returns the index of the gottern lock variable.
2. mutex_unlock_op(sbi, index of the lock)
- unlock the given index of the lock.
3. mutex_lock_all(sbi)
- grab all the locks in the array before the checkpoint.
4. mutex_unlock_all(sbi)
- release all the locks in the array after checkpoint.
5. block_operations()
- call mutex_lock_all()
- sync_dirty_dir_inodes()
- grab node_write
- sync_node_pages()
Note that,
the pairs of mutex_lock_op()/mutex_unlock_op() and
mutex_lock_all()/mutex_unlock_all() should be used together.
This patch removes data_version check flow during the fsync call.
The original purpose for the use of data_version was to avoid writng inode
pages redundantly by the fsync calls repeatedly.
However, when user can modify file meta and then call fsync, we should not
skip fsync procedure.
So, let's remove this condition check and hope that user triggers in right
manner.
