path: root/fs/ext4
2010-10-27Merge branch 'next' into upstream-mergeTheodore Ts'o
Conflicts: fs/ext4/inode.c fs/ext4/mballoc.c include/trace/events/ext4.h
2010-10-27ext4: optimize orphan_list handling for ext4_setattrDmitry Monakhov
Surprisingly chown() on ext4 is not SMP scalable operation. Due to unconditional orphan_del(NULL, inode) in ext4_setattr() result in significant performance overhead because of global orphan mutex, especially in no-journal mode (where orphan_add() is noop). It is possible to skip explicit orphan_del if possible. Results of fchown() micro-benchmark in no-journal mode while (1) { iteration++; fchown(fd, uid, gid); fchown(fd, uid + 1, gid + 1) } measured: iterations per millisecond | nr_tasks | w/o patch | with patch | | 1 | 142 | 185 | | 4 | 109 | 642 | Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: fix unbalanced mutex unlock in error path of ext4_li_request_newNicolas Kaiser
Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: fix compile error in ext4_fallocate()Kazuya Mio
When I compiled 2.6.36-rc3 kernel with EXT4FS_DEBUG definition, I got the following compile error. CC [M] fs/ext4/extents.o fs/ext4/extents.c: In function 'ext4_fallocate': fs/ext4/extents.c:3772: error: 'block' undeclared (first use in this function) fs/ext4/extents.c:3772: error: (Each undeclared identifier is reported only once fs/ext4/extents.c:3772: error: for each function it appears in.) make[2]: *** [fs/ext4/extents.o] Error 1 The patch fixes this problem. Signed-off-by: Kazuya Mio <k-mio@sx.jp.nec.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: move ext4_mb_{get,put}_buddy_cache_lock and make them staticEric Sandeen
These functions are only used within fs/ext4/mballoc.c, so move them so they are used after they are defined, and then make them be static. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: rename mark_bitmap_end() to ext4_mark_bitmap_end()Theodore Ts'o
Fix a namespace leak from fs/ext4 Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: move flush_completed_IO to fs/ext4/fsync.c and make it staticTheodore Ts'o
Fix a namespace leak by moving the function to the file where it is used and making it static. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: rename {ext,idx}_pblock and inline small extent functionsTheodore Ts'o
Cleanup namespace leaks from fs/ext4 and the inline trivial functions ext4_{ext,idx}_pblock() and ext4_{ext,idx}_store_pblock() since the code size actually shrinks when we make these functions inline, they're so trivial. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: make various ext4 functions be staticTheodore Ts'o
These functions have no need to be exported beyond file context. No functions needed to be moved for this commit; just some function declarations changed to be static and removed from header files. (A similar patch was submitted by Eric Sandeen, but I wanted to handle code movement in separate patches to make sure code changes didn't accidentally get dropped.) Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: rename {exit,init}_ext4_*() to ext4_{exit,init}_*()Theodore Ts'o
This is a cleanup to avoid namespace leaks out of fs/ext4 Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: fix kernel oops if the journal superblock has a non-zero j_errnoTheodore Ts'o
Commit 84061e0 fixed an accounting bug only to introduce the possibility of a kernel OOPS if the journal has a non-zero j_errno field indicating that the file system had detected a fs inconsistency. After the journal replay, if the journal superblock indicates that the file system has an error, this indication is transfered to the file system and then ext4_commit_super() is called to write this to the disk. But since the percpu counters are now initialized after the journal replay, the call to ext4_commit_super() will cause a kernel oops since it needs to use the percpu counters the ext4 superblock structure. The fix is to skip setting the ext4 free block and free inode fields if the percpu counter has not been set. Thanks to Ken Sumrall for reporting and analyzing the root causes of this bug. Addresses-Google-Bug: #3054080 Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: update writeback_index based on last page scannedEric Sandeen
As pointed out in a prior patch, updating the mapping's writeback_index based on pages written isn't quite right; what the writeback index is really supposed to reflect is the next page which should be scanned for writeback during periodic flush. As in write_cache_pages(), write_cache_pages_da() does this scanning for us as we assemble the mpd for later writeout. If we keep track of the next page after the current scan, we can easily update writeback_index without worrying about pages written vs. pages skipped, etc. Without this, an fsync will reset writeback_index to 0 (its starting index) + however many pages it wrote, which can mess up the progress of periodic flush. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: implement writeback livelock avoidance using page taggingEric Sandeen
This is analogous to Jan Kara's commit, f446daaea9d4a420d16c606f755f3689dcb2d0ce mm: implement writeback livelock avoidance using page tagging but since we forked write_cache_pages, we need to reimplement it there (and in ext4_da_writepages, since range_cyclic handling was moved to there) If you start a large buffered IO to a file, and then set fsync after it, you'll find that fsync does not complete until the other IO stops. If you continue re-dirtying the file (say, putting dd with conv=notrunc in a loop), when fsync finally completes (after all IO is done), it reports via tracing that it has written many more pages than the file contains; in other words it has synced and re-synced pages in the file multiple times. This then leads to problems with our writeback_index update, since it advances it by pages written, and essentially sets writeback_index off the end of the file... With the following patch, we only sync as much as was dirty at the time of the sync. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: tidy up a void argument in inode.cEric Sandeen
This doesn't fix anything at all, it just removes a vestige of prior use from __mpage_da_writepage() __mpage_da_writepage() had a *void argument leftover from its previous life as a callback; make it reflect the actual type. Fixing this up makes it slightly more obvious to read, and enables proper typechecking. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: add batched_discard into ext4 feature listLukas Czerner
Should be applied on the top of "lazy inode table initialization" and "batched discard support" patch-sets. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: Add batched discard support for ext4Lukas Czerner
Walk through allocation groups and trim all free extents. It can be invoked through FITRIM ioctl on the file system. The main idea is to provide a way to trim the whole file system if needed, since some SSD's may suffer from performance loss after the whole device was filled (it does not mean that fs is full!). It search for free extents in allocation groups specified by Byte range start -> start+len. When the free extent is within this range, blocks are marked as used and then trimmed. Afterwards these blocks are marked as free in per-group bitmap. Since fstrim is a long operation it is good to have an ability to interrupt it by a signal. This was added by Dmitry Monakhov. Thanks Dimitry. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Reviewed-by: Jan Kara <jack@suse.cz> Reviewed-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: Use return value from sb_issue_discard()Lukas Czerner
Use return value from sb_issue_discard() as return value in ext4_issue_discard(). Since sb_issue_discard() may result in more serious errors than just -EOPNOTSUPP it is worth to inform user of this function about them to handle error cases properly. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: Check return value of sb_getblk() and friendsNamhyung Kim
Fail block allocation if sb_getblk() returns NULL. In that case, sb_find_get_block() also likely to fail so that it should skip calling ext4_forget(). Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: use bio layer instead of buffer layer in mpage_da_submit_ioTheodore Ts'o
Call the block I/O layer directly instad of going through the buffer layer. This should give us much better performance and scalability, as well as lowering our CPU utilization when doing buffered writeback. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: move mpage_put_bnr_to_bhs()'s functionality to mpage_da_submit_io()Theodore Ts'o
This massively simplifies the ext4_da_writepages() code path by completely removing mpage_put_bnr_bhs(), which is almost 100 lines of code iterating over a set of pages using pagevec_lookup(), and folds that functionality into mpage_da_submit_io()'s existing pagevec_lookup() loop. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: inline walk_page_buffers() into mpage_da_submit_ioTheodore Ts'o
Expand the call: if (walk_page_buffers(NULL, page_bufs, 0, len, NULL, ext4_bh_delay_or_unwritten)) goto redirty_page into mpage_da_submit_io(). This will allow us to merge in mpage_put_bnr_to_bhs() in the next patch. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: inline ext4_writepage() into mpage_da_submit_io()Theodore Ts'o
As a prepratory step to switching to bio_submit, inline ext4_writepage() into mpage_da_submit() and then simplify things a bit. This makes it clearer what mpage_da_submit needs to do. Also, move the ClearPageChecked(page) call into __ext4_journalled_writepage(), as a minor bit of cleanup refactoring. This also allows us to pull i_size_read() and ext4_should_journal_data() out of the loop, which should be a very minor CPU savings. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: simplify ext4_writepage()Theodore Ts'o
The actual code in ext4_writepage() is unnecessarily convoluted. Simplify it so it is easier to understand, but otherwise logically equivalent. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: call mpage_da_submit_io() from mpage_da_map_blocks()Theodore Ts'o
Eventually we need to completely reorganize the ext4 writepage callpath, but for now, we simplify things a little by calling mpage_da_submit_io() from mpage_da_map_blocks(), since all of the places where we call mpage_da_map_blocks() it is followed up by a call to mpage_da_submit_io(). We're also a wee bit better with respect to error handling, but there are still a number of issues where it's not clear what the right thing is to do with ext4 functions deep in the writeback codepath fails. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: use KMEM_CACHE instead of kmem_cache_createTheodore Ts'o
Also remove the SLAB_RECLAIM_ACCOUNT flag from the system zone kmem cache. This slab tends to be fairly static, so it shouldn't be marked as likely to have free pages that can be reclaimed. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: use search_dirblock() in ext4_dx_find_entry()Theodore Ts'o
Use the search_dirblock() in ext4_dx_find_entry(). It makes the code easier to read, and it takes advantage of common code. It also saves 100 bytes or so of text space. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Brad Spengler <spender@grsecurity.net>
2010-10-27ext4: avoid uninitialized memory references in ext3_htree_next_block()Theodore Ts'o
If the first block of htree directory is missing '.' or '..' but is otherwise a valid directory, and we do a lookup for '.' or '..', it's possible to dereference an uninitialized memory pointer in ext4_htree_next_block(). We avoid this by moving the special case from ext4_dx_find_entry() to ext4_find_entry(); this also means we can optimize ext4_find_entry() slightly when NFS looks up "..". Thanks to Brad Spengler for pointing a Clang warning that led me to look more closely at this code. The warning was harmless, but it was useful in pointing out code that was too ugly to live. This warning was also reported by Roman Borisov. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Brad Spengler <spender@grsecurity.net>
2010-10-27ext4: remove unused ext4_sb_info membersEric Sandeen
Not that these take up a lot of room, but the structure is long enough as it is, and there's no need to confuse people with these various undocumented & unused structure members... Signed-off-by: Eric Sandeen <sandeen@redaht.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: queue conversion after adding to inode's completed IO listEric Sandeen
By queuing the io end on the unwritten workqueue before adding it to our inode's list of completed IOs, I think we run the risk of the work getting completed, and the IO freed, before we try to add it to the inode's i_completed_io_list. It should be safe to add it to the inode's list of completed IOs, and -then- queue it for completion, I think. Thanks to Dave Chinner for pointing out the race. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Jiaying Zhang <jiayingz@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: don't use ext4_allocation_contexts for tracingEric Sandeen
Many tracepoints were populating an ext4_allocation_context to pass in, but this requires a slab allocation even when tracepoints are off. In fact, 4 of 5 of these allocations were only for tracing. In addition, we were only using a small fraction of the 144 bytes of this structure for this purpose. We can do away with all these alloc/frees of the ac and simply pass in the bits we care about, instead. I tested this by turning on tracing and running through xfstests on x86_64. I did not actually do anything with the trace output, however. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: fix potential infinite loop in ext4_da_writepages()Toshiyuki Okajima
On linux-2.6.36-rc2, if we execute the following script, we can hang the system when the /bin/sync command is executed: ======================================================================== #!/bin/sh echo -n "HANG UP TEST: " /bin/dd if=/dev/zero of=/tmp/img bs=1k count=1 seek=1M 2> /dev/null /sbin/mkfs.ext4 -Fq /tmp/img /bin/mount -o loop -t ext4 /tmp/img /mnt /bin/dd if=/dev/zero of=/mnt/file bs=1 count=1 \ seek=$((16*1024*1024*1024*1024-4096)) 2> /dev/null /bin/sync /bin/umount /mnt echo "DONE" exit 0 ======================================================================== We can see the following backtrace if we get the kdump when this hangup occurs: ====================================================================== kthread() => bdi_writeback_thread() => wb_do_writeback() => wb_writeback() => writeback_inodes_wb() => writeback_sb_inodes() => writeback_single_inode() => ext4_da_writepages() ---+ ^ infinite | | loop | +-------------+ ====================================================================== The reason why this hangup happens is described as follows: 1) We write the last extent block of the file whose size is the filesystem maximum size. 2) "BH_Delay" flag is set on the buffer_head of its block. 3) - the member, "m_lblk" of struct mpage_da_data is 4294967295 (UINT_MAX) - the member, "m_len" of struct mpage_da_data is 1 mpage_put_bnr_to_bhs() which is called via ext4_da_writepages() cannot clear "BH_Delay" flag of the buffer_head because the type of m_lblk is ext4_lblk_t and then m_lblk + m_len is overflow. Therefore an infinite loop occurs because ext4_da_writepages() cannot write the page (which corresponds to the block) since "BH_Delay" flag isn't cleared. ---------------------------------------------------------------------- static void mpage_put_bnr_to_bhs(struct mpage_da_data *mpd, struct ext4_map_blocks *map) { ... int blocks = map->m_len; ... do { // cur_logical = 4294967295 // map->m_lblk = 4294967295 // blocks = 1 // *** map->m_lblk + blocks == 0 (OVERFLOW!) *** // (cur_logical >= map->m_lblk + blocks) => true if (cur_logical >= map->m_lblk + blocks) break; ---------------------------------------------------------------------- NOTE: Mounting with the nodelalloc option will avoid this codepath, and thus, avoid this hang Signed-off-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: improve llseek error handling for overly large seek offsetsToshiyuki Okajima
The llseek system call should return EINVAL if passed a seek offset which results in a write error. What this maximum offset should be depends on whether or not the huge_file file system feature is set, and whether or not the file is extent based or not. If the file has no "EXT4_EXTENTS_FL" flag, the maximum size which can be written (write systemcall) is different from the maximum size which can be sought (lseek systemcall). For example, the following 2 cases demonstrates the differences between the maximum size which can be written, versus the seek offset allowed by the llseek system call: #1: mkfs.ext3 <dev>; mount -t ext4 <dev> #2: mkfs.ext3 <dev>; tune2fs -Oextent,huge_file <dev>; mount -t ext4 <dev> Table. the max file size which we can write or seek at each filesystem feature tuning and file flag setting +============+===============================+===============================+ | \ File flag| | | | \ | !EXT4_EXTENTS_FL | EXT4_EXTETNS_FL | |case \| | | +------------+-------------------------------+-------------------------------+ | #1 | write: 2194719883264 | write: -------------- | | | seek: 2199023251456 | seek: -------------- | +------------+-------------------------------+-------------------------------+ | #2 | write: 4402345721856 | write: 17592186044415 | | | seek: 17592186044415 | seek: 17592186044415 | +------------+-------------------------------+-------------------------------+ The differences exist because ext4 has 2 maxbytes which are sb->s_maxbytes (= extent-mapped maxbytes) and EXT4_SB(sb)->s_bitmap_maxbytes (= block-mapped maxbytes). Although generic_file_llseek uses only extent-mapped maxbytes. (llseek of ext4_file_operations is generic_file_llseek which uses sb->s_maxbytes.) Therefore we create ext4 llseek function which uses 2 maxbytes. The new own function originates from generic_file_llseek(). If the file flag, "EXT4_EXTENTS_FL" is not set, the function alters inode->i_sb->s_maxbytes into EXT4_SB(inode->i_sb)->s_bitmap_maxbytes. Signed-off-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger.kernel@dilger.ca>
2010-10-27ext4: don't update sb journal_devnum when RO devMaciej Żenczykowski
An ext4 filesystem on a read-only device, with an external journal which is at a different device number then recorded in the superblock will fail to honor the read-only setting of the device and trigger a superblock update (write). For example: - ext4 on a software raid which is in read-only mode - external journal on a read-write device which has changed device num - attempt to mount with -o journal_dev=<new_number> - hits BUG_ON(mddev->ro = 1) in md.c Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Maciej Żenczykowski <zenczykowski@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: use sb_issue_zeroout in ext4_ext_zerooutLukas Czerner
Change ext4_ext_zeroout to use sb_issue_zeroout instead of its own approach to zero out extents. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: use sb_issue_zeroout in setup_new_group_blocksLukas Czerner
Use sb_issue_zeroout to zero out inode table and descriptor table blocks instead of old approach which involves journaling. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: add interface to advertise ext4 features in sysfsLukas Czerner
User-space should have the opportunity to check what features doest ext4 support in each particular copy. This adds easy interface by creating new "features" directory in sys/fs/ext4/. In that directory files advertising feature names can be created. Add lazy_itable_init to the feature list. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: add support for lazy inode table initializationLukas Czerner
When the lazy_itable_init extended option is passed to mke2fs, it considerably speeds up filesystem creation because inode tables are not zeroed out. The fact that parts of the inode table are uninitialized is not a problem so long as the block group descriptors, which contain information regarding how much of the inode table has been initialized, has not been corrupted However, if the block group checksums are not valid, e2fsck must scan the entire inode table, and the the old, uninitialized data could potentially cause e2fsck to report false problems. Hence, it is important for the inode tables to be initialized as soon as possble. This commit adds this feature so that mke2fs can safely use the lazy inode table initialization feature to speed up formatting file systems. This is done via a new new kernel thread called ext4lazyinit, which is created on demand and destroyed, when it is no longer needed. There is only one thread for all ext4 filesystems in the system. When the first filesystem with inititable mount option is mounted, ext4lazyinit thread is created, then the filesystem can register its request in the request list. This thread then walks through the list of requests picking up scheduled requests and invoking ext4_init_inode_table(). Next schedule time for the request is computed by multiplying the time it took to zero out last inode table with wait multiplier, which can be set with the (init_itable=n) mount option (default is 10). We are doing this so we do not take the whole I/O bandwidth. When the thread is no longer necessary (request list is empty) it frees the appropriate structures and exits (and can be created later later by another filesystem). We do not disturb regular inode allocations in any way, it just do not care whether the inode table is, or is not zeroed. But when zeroing, we have to skip used inodes, obviously. Also we should prevent new inode allocations from the group, while zeroing is on the way. For that we take write alloc_sem lock in ext4_init_inode_table() and read alloc_sem in the ext4_claim_inode, so when we are unlucky and allocator hits the group which is currently being zeroed, it just has to wait. This can be suppresed using the mount option no_init_itable. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: fix NULL pointer dereference in print_daily_error_info()Sergey Senozhatsky
Fix NULL pointer dereference in print_daily_error_info, when called on unmounted fs (EXT4_SB(sb) returns NULL), by removing error reporting timer in ext4_put_super. Google-Bug-Id: 3017663 Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: don't hold spinlock while calling ext4_issue_discard()Lukas Czerner
We can't hold the block group spinlock because we ext4_issue_discard() calls wait and hence can get rescheduled. Google-Bug-Id: 3017678 Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: check for negative error code from sb_issue_discardLukas Czerner
sb_issue_discard() is returning negative error code, so check for -EOPNOTSUPP. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: don't bump up LONG_MAX nr_to_write by a factor of 8Eric Sandeen
I'm uneasy with lots of stuff going on in ext4_da_writepages(), but bumping nr_to_write from LLONG_MAX to -8 clearly isn't making anything better, so avoid the multiplier in that case. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: stop looping in ext4_num_dirty_pages when max_pages reachedEric Sandeen
Today we simply break out of the inner loop when we have accumulated max_pages; this keeps scanning forwad and doing pagevec_lookup_tag() in the while (!done) loop, this does potentially a lot of work with no net effect. When we have accumulated max_pages, just clean up and return. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: use dedicated slab caches for group_info structuresCurt Wohlgemuth
ext4_group_info structures are currently allocated with kmalloc(). With a typical 4K block size, these are 136 bytes each -- meaning they'll each consume a 256-byte slab object. On a system with many ext4 large partitions, that's a lot of wasted kernel slab space. (E.g., a single 1TB partition will have about 8000 block groups, using about 2MB of slab, of which nearly 1MB is wasted.) This patch creates an array of slab pointers created as needed -- depending on the superblock block size -- and uses these slabs to allocate the group info objects. Google-Bug-Id: 2980809 Signed-off-by: Curt Wohlgemuth <curtw@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: fix EOFBLOCKS_FL handlingTheodore Ts'o
It turns out we have several problems with how EOFBLOCKS_FL is handled. First of all, there was a fencepost error where we were not clearing the EOFBLOCKS_FL when fill in the last uninitialized block, but rather when we allocate the next block _after_ the uninitalized block. Secondly we were not testing to see if we needed to clear the EOFBLOCKS_FL when writing to the file O_DIRECT or when were converting an uninitialized block (which is the most common case). Google-Bug-Id: 2928259 Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-25fs: do not assign default i_ino in new_inodeChristoph Hellwig
Instead of always assigning an increasing inode number in new_inode move the call to assign it into those callers that actually need it. For now callers that need it is estimated conservatively, that is the call is added to all filesystems that do not assign an i_ino by themselves. For a few more filesystems we can avoid assigning any inode number given that they aren't user visible, and for others it could be done lazily when an inode number is actually needed, but that's left for later patches. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: kill block_prepare_writeChristoph Hellwig
__block_write_begin and block_prepare_write are identical except for slightly different calling conventions. Convert all callers to the __block_write_begin calling conventions and drop block_prepare_write. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-22Merge branch 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits) xen-blkfront: disable barrier/flush write support Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c block: remove BLKDEV_IFL_WAIT aic7xxx_old: removed unused 'req' variable block: remove the BH_Eopnotsupp flag block: remove the BLKDEV_IFL_BARRIER flag block: remove the WRITE_BARRIER flag swap: do not send discards as barriers fat: do not send discards as barriers ext4: do not send discards as barriers jbd2: replace barriers with explicit flush / FUA usage jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier jbd: replace barriers with explicit flush / FUA usage nilfs2: replace barriers with explicit flush / FUA usage reiserfs: replace barriers with explicit flush / FUA usage gfs2: replace barriers with explicit flush / FUA usage btrfs: replace barriers with explicit flush / FUA usage xfs: replace barriers with explicit flush / FUA usage block: pass gfp_mask and flags to sb_issue_discard dm: convey that all flushes are processed as empty ...
2010-10-22Merge branch 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: (30 commits) BKL: remove BKL from freevxfs BKL: remove BKL from qnx4 autofs4: Only declare function when CONFIG_COMPAT is defined autofs: Only declare function when CONFIG_COMPAT is defined ncpfs: Lock socket in ncpfs while setting its callbacks fs/locks.c: prepare for BKL removal BKL: Remove BKL from ncpfs BKL: Remove BKL from OCFS2 BKL: Remove BKL from squashfs BKL: Remove BKL from jffs2 BKL: Remove BKL from ecryptfs BKL: Remove BKL from afs BKL: Remove BKL from USB gadgetfs BKL: Remove BKL from autofs4 BKL: Remove BKL from isofs BKL: Remove BKL from fat BKL: Remove BKL from ext2 filesystem BKL: Remove BKL from do_new_mount() BKL: Remove BKL from cgroup BKL: Remove BKL from NTFS ...
2010-10-04BKL: Remove BKL from ext4 filesystemJan Blunck
The BKL is still used in ext4_put_super(), ext4_fill_super() and ext4_remount(). All three calles are protected against concurrent calls by the s_umount rw semaphore of struct super_block. Therefore the BKL is protecting nothing in this case. Signed-off-by: Jan Blunck <jblunck@infradead.org> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
