path: root/fs/ext4/symlink.c
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-10ext4: Remove CONFIG_EXT4_FS_XATTRTao Ma
Ted has sent out a RFC about removing this feature. Eric and Jan confirmed that both RedHat and SUSE enable this feature in all their product. David also said that "As far as I know, it's enabled in all Android kernels that use ext4." So it seems OK for us. And what's more, as inline data depends its implementation on xattr, and to be frank, I don't run any test again inline data enabled while xattr disabled. So I think we should add inline data and remove this config option in the same release. [ The savings if you disable CONFIG_EXT4_FS_XATTR is only 27k, which isn't much in the grand scheme of things. Since no one seems to be testing this configuration except for some automated compile farms, on balance we are better removing this config option, and so that it is effectively always enabled. -- tytso ] Cc: David Brown <davidb@codeaurora.org> Cc: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-05-16ext4: symlink must be handled via filesystem specific operationDmitry Monakhov
generic setattr implementation is no longer responsible for quota transfer so synlinks must be handled via ext4_setattr. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-10-10ext4: Rename ext4dev to ext4Theodore Ts'o
The ext4 filesystem is getting stable enough that it's time to drop the "dev" prefix. Also remove the requirement for the TEST_FILESYS flag. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-09-08ext4: Fix whitespace checkpatch warnings/errorsTheodore Ts'o
2008-04-29ext4: move headers out of include/linuxChristoph Hellwig
Move ext4 headers out of include/linux. This is just the trivial move, there's some more thing that could be done later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2006-10-11[PATCH] jbd2: enable building of jbd2 and have ext4 use it rather than jbdMingming Cao
Reworked from a patch by Mingming Cao and Randy Dunlap Signed-off-By: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: rename ext4 symbols to avoid duplication of ext3 symbolsMingming Cao
Mingming Cao originally did this work, and Shaggy reproduced it using some scripts from her. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: initial copy of files from ext3Dave Kleikamp
Start of the ext4 patch series. See Documentation/filesystems/ext4.txt for details. This is a simple copy of the files in fs/ext3 to fs/ext4 and /usr/incude/linux/ext3* to /usr/include/ex4* Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
