Set i_nlink to zero for temporary inode from very beginning.
otherwise we may fail to start new journal handle and this
inode will be unreferenced but with i_nlink == 1
Since we hold inode reference it can not be pruned.
Also add missed journal_start retval check.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
At several places we modify EXT4_I(inode)->i_state without holding
i_mutex (ext4_release_file, ext4_bmap, ext4_journalled_writepage,
ext4_do_update_inode, ...). These modifications are racy and we can
lose updates to i_state. So convert handling of i_state to use bitops
which are atomic.
Cc: Jan Kara <jack@suse.cz>
Currently all quota block reservation macros contains hard-coded "2"
aka MAXQUOTAS value. This is no good because in some places it is not
obvious to understand what does this digit represent. Let's introduce
new macro with self descriptive name.
Acked-by: Mingming Cao <cmm@us.ibm.com>
Add the facility for ext4_forget() to be called from
ext4_free_blocks(). This simplifies the code in a large number of
places, and centralizes most of the work of calling ext4_forget() into
a single place.
Also fix a bug in the extents migration code; it wasn't calling
ext4_forget() when releasing the indirect blocks during the
conversion. As a result, if the system cashed during or shortly after
the extents migration, and the released indirect blocks get reused as
data blocks, the journal replay would corrupt the data blocks. With
this new patch, fixing this bug was as simple as adding the
EXT4_FREE_BLOCKS_FORGET flags to the call to ext4_free_blocks().
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
When writing into an unitialized extent via direct I/O, and the direct
I/O doesn't exactly cover the unitialized extent, split the extent
into uninitialized and initialized extents before submitting the I/O.
This avoids needing to deal with an ENOSPC error in the end_io
callback that gets used for direct I/O.
When the IO is complete, the written extent will be marked as initialized.
Singed-Off-By: Mingming Cao <cmm@us.ibm.com>
EXT4_EXT_MIGRATE is only intended to be used for an in-memory flag,
and the hex value assigned to it collides with FS_DIRECTIO_FL (which
is also stored in i_flags). There's no reason for the
EXT4_EXT_MIGRATE bit to be stored in i_flags, so we switch it to use
i_state instead.
We need to unlock the new inode before iput. This patch fixes the
following warning when calling chattr +e to migrate a file to use
extents. It also fixes problems in when e4defrag attempts to
defragment an inode.
[ 470.400044] ------------[ cut here ]------------
[ 470.400065] WARNING: at fs/inode.c:1210 generic_delete_inode+0x65/0x16a()
[ 470.400072] Hardware name: N/A
[ 470.400353] Pid: 4451, comm: chattr Not tainted 2.6.31-rc7-red-debug #4
[ 470.400359] Call Trace:
[ 470.400372] [<ffffffff81037771>] warn_slowpath_common+0x77/0x8f
[ 470.400385] [<ffffffff81037798>] warn_slowpath_null+0xf/0x11
[ 470.400395] [<ffffffff810b7f28>] generic_delete_inode+0x65/0x16a
[ 470.400405] [<ffffffff810b8044>] generic_drop_inode+0x17/0x1bd
[ 470.400413] [<ffffffff810b7083>] iput+0x61/0x65
[ 470.400455] [<ffffffffa003b229>] ext4_ext_migrate+0x5eb/0x66a [ext4]
[ 470.400492] [<ffffffffa002b1f8>] ext4_ioctl+0x340/0x756 [ext4]
[ 470.400507] [<ffffffff810b1a91>] vfs_ioctl+0x1d/0x82
[ 470.400517] [<ffffffff810b1ff0>] do_vfs_ioctl+0x483/0x4c9
[ 470.400527] [<ffffffff81059c30>] ? trace_hardirqs_on+0xd/0xf
[ 470.400537] [<ffffffff810b2087>] sys_ioctl+0x51/0x74
[ 470.400549] [<ffffffff8100ba6b>] system_call_fastpath+0x16/0x1b
[ 470.400557] ---[ end trace ab85723542352dac ]---
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Enhance the inode allocator to take a goal inode number as a
paremeter; if it is specified, it takes precedence over Orlov or
parent directory inode allocation algorithms.
The extents migration function uses the goal inode number so that the
extent trees allocated the migration function use the correct flex_bg.
In the future, the goal inode functionality will also be used to
allocate an adjacent inode for the extended attributes.
Also, for testing purposes the goal inode number can be specified via
/sys/fs/{dev}/inode_goal. This can be useful for testing inode
allocation beyond 2^32 blocks on very large filesystems.
Signed-off-by: Andreas Dilger <adilger@sun.com>
Instead of using a random number to determine the goal parent grop for
the Orlov top directories, use a hash of the directory name. This
allows for repeatable results when trying to benchmark filesystem
layout algorithms.
This was found through a code checker (http://repo.or.cz/w/smatch.git/).
It looks like you might be able to trigger the error by trying to migrate
a readonly file system.
This mount option is largely superfluous, and in fact the way it was
implemented was buggy; if a filesystem which did not have the extents
feature flag was mounted -o extents, the filesystem would attempt to
create and use extents-based file even though the extents feature flag
was not eabled. The simplest thing to do is to nuke the mount option
entirely. It's not all that useful to force the non-creation of new
extent-based files if the filesystem can support it.
A few weeks ago I posted a patch for discussion that allowed ext4 to run
without a journal. Since that time I've integrated the excellent
comments from Andreas and fixed several serious bugs. We're currently
running with this patch and generating some performance numbers against
both ext2 (with backported reservations code) and ext4 with and without
a journal. It just so happens that running without a journal is
slightly faster for most everything.
We did
iozone -T -t 4 s 2g -r 256k -T -I -i0 -i1 -i2
which creates 4 threads, each of which create and do reads and writes on
a 2G file, with a buffer size of 256K, using O_DIRECT for all file opens
to bypass the page cache. Results:
ext2 ext4, default ext4, no journal
initial writes 13.0 MB/s 15.4 MB/s 15.7 MB/s
rewrites 13.1 MB/s 15.6 MB/s 15.9 MB/s
reads 15.2 MB/s 16.9 MB/s 17.2 MB/s
re-reads 15.3 MB/s 16.9 MB/s 17.2 MB/s
random readers 5.6 MB/s 5.6 MB/s 5.7 MB/s
random writers 5.1 MB/s 5.3 MB/s 5.4 MB/s
So it seems that, so far, this was a useful exercise.
Signed-off-by: Frank Mayhar <fmayhar@google.com>
The migrate ioctl writes to the filsystem, so we need to elevate the
write count.
This patch modified the writepage/write_begin credit calculation for
extent files, to use the credits caculation helper function.
The current calculation of how many index/leaf blocks should be
accounted is too conservetive, it always considered the worse case,
where the tree level is 5, and in the case of multiple chunk
allocations, it always assumed no blocks were dirtied in common across
the allocations. This path uses the accurate depth of the inode with
some extras to calculate the index blocks, and also less conservative in
the case of multiple allocation accounting.
Signed-off-by: Mingming Cao <cmm@us.ibm.com>
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Move ext4 headers out of include/linux. This is just the trivial move,
there's some more thing that could be done later.
Fail migrate if we allocated new blocks via mmap write.
If we write to holes in the file via mmap, we end up allocating
new blocks. This block allocation happens without taking inode->i_mutex.
Since migrate is protected by i_mutex and migrate expects that no
new blocks get allocated during migrate, fail migrate if new blocks
get allocated.
We can't take inode->i_mutex in the mmap write path because that
would result in a locking order violation between i_mutex and mmap_sem.
Also adding a separate rw_sempahore for protection is really high overhead
for a rare operation such as migrate.
Acked-by: Jan Kara <jack@suse.cz>
The path variable returned via ext4_ext_find_extent is a kmalloc
variable and needs to be freeded. It also contains a reference to
buffer_head which needs to be dropped.
In order to prevent a circular locking dependency when an unlink
operation is racing with an ext4 migration, we delay taking i_data_sem
until just before switch the inode format, and use i_mutex to prevent
writes and truncates during the first part of the migration operation.
For fast symbolic links, the file content is stored in the i_block[]
array, which is not compatible with the new file extents format.
e2fsck reports error on such files because EXTENTS_FL is set.
Don't set the EXTENTS_FL flag when creating fast symlinks.
In the case of file migration, skip fast symbolic links.
Signed-off-by: Valerie Clement <valerie.clement@bull.net>
Signed-off-by: Alex Tomas <alex@clusterfs.com>
Signed-off-by: Andreas Dilger <adilger@clusterfs.com>
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
The below patch add ioctl for migrating ext3 indirect block mapped inode
to ext4 extent mapped inode.
