path: root/fs/ext3/fsync.c
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21Merge branch 'master' into for-2.6.35Jens Axboe
Conflicts: fs/ext3/fsync.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-21ext3: Fix waiting on transaction during fsyncJan Kara
log_start_commit() returns 1 only when it started a transaction commit. Thus in case transaction commit is already running, we fail to wait for the commit to finish. Fix the issue by always waiting for the commit regardless of the log_start_commit return value. Signed-off-by: Jan Kara <jack@suse.cz>
2010-04-28blkdev: generalize flags for blkdev_issue_fn functionsDmitry Monakhov
The patch just convert all blkdev_issue_xxx function to common set of flags. Wait/allocation semantics preserved. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-11-11ext3: Wait for proper transaction commit on fsyncJan Kara
We cannot rely on buffer dirty bits during fsync because pdflush can come before fsync is called and clear dirty bits without forcing a transaction commit. What we do is that we track which transaction has last changed the inode and which transaction last changed allocation and force it to disk on fsync. Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2009-09-16ext3: Flush disk caches on fsync when neededJan Kara
In case we fsync() a file and inode is not dirty, we don't force a transaction to disk and hence don't flush disk caches. Thus file data could be just in disk caches and not on persistent storage. Fix the problem by flushing disk caches if we didn't force a transaction commit. Signed-off-by: Jan Kara <jack@suse.cz>
2008-04-28ext3: fdatasync should skip metadata writeout when overwritingHisashi Hifumi
Currently fdatasync is identical to fsync in ext3. I think fdatasync should skip journal flush in data=ordered and data=writeback mode when it overwrites to already-instantiated blocks on HDD. When I_DIRTY_DATASYNC flag is not set, fdatasync should skip journal writeout because this indicates only atime or/and mtime updates. Following patch is the same approach of ext2's fsync code(ext2_sync_file). I did a performance test using the sysbench. #sysbench --num-threads=128 --max-requests=50000 --test=fileio --file-total-size=128G --file-test-mode=rndwr --file-fsync-mode=fdatasync run The result on ext3 was: -2.6.24 Operations performed: 0 Read, 50080 Write, 59600 Other = 109680 Total Read 0b Written 782.5Mb Total transferred 782.5Mb (12.116Mb/sec) 775.45 Requests/sec executed Test execution summary: total time: 64.5814s total number of events: 50080 total time taken by event execution: 3713.9836 per-request statistics: min: 0.0000s avg: 0.0742s max: 0.9375s approx. 95 percentile: 0.2901s Threads fairness: events (avg/stddev): 391.2500/23.26 execution time (avg/stddev): 29.0155/1.99 -2.6.24-patched Operations performed: 0 Read, 50009 Write, 61596 Other = 111605 Total Read 0b Written 781.39Mb Total transferred 781.39Mb (16.419Mb/sec) 1050.83 Requests/sec executed Test execution summary: total time: 47.5900s total number of events: 50009 total time taken by event execution: 2934.5768 per-request statistics: min: 0.0000s avg: 0.0587s max: 0.8938s approx. 95 percentile: 0.1993s Threads fairness: events (avg/stddev): 390.6953/22.64 execution time (avg/stddev): 22.9264/1.17 Filesystem I/O throughput was improved. Signed-off-by :Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Acked-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18sparse pointer use of zero as nullStephen Hemminger
Get rid of sparse related warnings from places that use integer as NULL pointer. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Andi Kleen <ak@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Ian Kent <raven@themaw.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-27[PATCH] ext3 and jbd cleanup: remove whitespaceMingming Cao
Remove whitespace from ext3 and jbd, before we clone ext4. Signed-off-by: Mingming Cao<cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
