path: root/fs/ext2
2010-03-05dquot: cleanup inode allocation / freeing routinesChristoph Hellwig
Get rid of the alloc_inode and free_inode dquot operations - they are always called from the filesystem and if a filesystem really needs their own (which none currently does) it can just call into it's own routine directly. Also get rid of the vfs_dq_alloc/vfs_dq_free wrappers and always call the lowlevel dquot_alloc_inode / dqout_free_inode routines directly, which now lose the number argument which is always 1. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: cleanup space allocation / freeing routinesChristoph Hellwig
Get rid of the alloc_space, free_space, reserve_space, claim_space and release_rsv dquot operations - they are always called from the filesystem and if a filesystem really needs their own (which none currently does) it can just call into it's own routine directly. Move shared logic into the common __dquot_alloc_space, dquot_claim_space_nodirty and __dquot_free_space low-level methods, and rationalize the wrappers around it to move as much as possible code into the common block for CONFIG_QUOTA vs not. Also rename all these helpers to be named dquot_* instead of vfs_dq_*. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-16Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (38 commits) direct I/O fallback sync simplification ocfs: stop using do_sync_mapping_range cleanup blockdev_direct_IO locking make generic_acl slightly more generic sanitize xattr handler prototypes libfs: move EXPORT_SYMBOL for d_alloc_name vfs: force reval of target when following LAST_BIND symlinks (try #7) ima: limit imbalance msg Untangling ima mess, part 3: kill dead code in ima Untangling ima mess, part 2: deal with counters Untangling ima mess, part 1: alloc_file() O_TRUNC open shouldn't fail after file truncation ima: call ima_inode_free ima_inode_free IMA: clean up the IMA counts updating code ima: only insert at inode creation time ima: valid return code from ima_inode_alloc fs: move get_empty_filp() deffinition to internal.h Sanitize exec_permission_lite() Kill cached_lookup() and real_lookup() Kill path_lookup_open() ... Trivial conflicts in fs/direct-io.c
2009-12-16sanitize xattr handler prototypesChristoph Hellwig
Add a flags argument to struct xattr_handler and pass it to all xattr handler methods. This allows using the same methods for multiple handlers, e.g. for the ACL methods which perform exactly the same action for the access and default ACLs, just using a different underlying attribute. With a little more groundwork it'll also allow sharing the methods for the regular user/trusted/secure handlers in extN, ocfs2 and jffs2 like it's already done for xfs in this patch. Also change the inode argument to the handlers to a dentry to allow using the handlers mechnism for filesystems that require it later, e.g. cifs. [with GFS2 bits updated by Steven Whitehouse <swhiteho@redhat.com>] Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16ext2: report metadata errors during fsyncJan Kara
When an IO error happens while writing metadata buffers, we should better report it and call ext2_error since the filesystem is probably no longer consistent. Sometimes such IO errors happen while flushing thread does background writeback, the buffer gets later evicted from memory, and thus the only trace of the error remains as AS_EIO bit set in blockdevice's mapping. So we check this bit in ext2_fsync and report the error although we cannot be really sure which buffer we failed to write. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16ext2: avoid WARN() messages when failing to write to the superblockTheodore Ts'o
This fixes a common warning reported by kerneloops.org [Kernel summit hacking hour] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-10ext2: fix comment in ext2_find_entry about return valuesJérémy Cochoy
Signed-off-by: Jérémy Cochoy <jeremy.cochoy@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-10ext2: clear uptodate flag on super block I/O errorStephen Hemminger
This fixes a WARN backtrace in mark_buffer_dirty() that occurs during unmount when a USB or floppy device is removed. I reported this a kernel regression, but looks like it might have been there for longer than that. The super block update from a previous operation has marked the buffer as in error, and the flag has to be cleared before doing the update. (Similar code already exists in ext4). Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-10ext2: Unify log messages in ext2Alexey Fisher
make messages produced by ext2 more unified. It should be easy to parse. dmesg before patch: [ 4893.684892] reservations ON [ 4893.684896] xip option not supported [ 4893.684961] EXT2-fs warning: mounting ext3 filesystem as ext2 [ 4893.684964] EXT2-fs warning: maximal mount count reached, running e2fsck is recommended [ 4893.684990] EXT II FS: 0.5b, 95/08/09, bs=1024, fs=1024, gc=2, bpg=8192, ipg=1280, mo=80010] dmesg after patch: [ 4893.684892] EXT2-fs (loop0): reservations ON [ 4893.684896] EXT2-fs (loop0): xip option not supported [ 4893.684961] EXT2-fs (loop0): warning: mounting ext3 filesystem as ext2 [ 4893.684964] EXT2-fs (loop0): warning: maximal mount count reached, running e2fsck is recommended [ 4893.684990] EXT2-fs (loop0): 0.5b, 95/08/09, bs=1024, fs=1024, gc=2, bpg=8192, ipg=1280, mo=80010] Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net> Reviewed-by: Andreas Dilger <adilger@sun.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-24Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (21 commits) HWPOISON: Enable error_remove_page on btrfs HWPOISON: Add simple debugfs interface to inject hwpoison on arbitary PFNs HWPOISON: Add madvise() based injector for hardware poisoned pages v4 HWPOISON: Enable error_remove_page for NFS HWPOISON: Enable .remove_error_page for migration aware file systems HWPOISON: The high level memory error handler in the VM v7 HWPOISON: Add PR_MCE_KILL prctl to control early kill behaviour per process HWPOISON: shmem: call set_page_dirty() with locked page HWPOISON: Define a new error_remove_page address space op for async truncation HWPOISON: Add invalidate_inode_page HWPOISON: Refactor truncate to allow direct truncating of page v2 HWPOISON: check and isolate corrupted free pages v2 HWPOISON: Handle hardware poisoned pages in try_to_unmap HWPOISON: Use bitmask/action code for try_to_unmap behaviour HWPOISON: x86: Add VM_FAULT_HWPOISON handling to x86 page fault handler v2 HWPOISON: Add poison check to page fault handling HWPOISON: Add basic support for poisoned pages in fault handler v3 HWPOISON: Add new SIGBUS error codes for hardware poison signals HWPOISON: Add support for poison swap entries v2 HWPOISON: Export some rmap vma locking to outside world ...
2009-09-23ext2: fix format string compile warning (ino_t)Heiko Carstens
Unlike on most other architectures ino_t is an unsigned int on s390. So add an explicit cast to avoid this compile warning: fs/ext2/namei.c: In function 'ext2_lookup': fs/ext2/namei.c:73: warning: format '%lu' expects type 'long unsigned int', but argument 4 has type 'ino_t' Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: make block_device_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-16HWPOISON: Enable .remove_error_page for migration aware file systemsAndi Kleen
Enable removing of corrupted pages through truncation for a bunch of file systems: ext*, xfs, gfs2, ocfs2, ntfs These should cover most server needs. I chose the set of migration aware file systems for this for now, assuming they have been especially audited. But in general it should be safe for all file systems on the data area that support read/write and truncate. Caveat: the hardware error handler does not take i_mutex for now before calling the truncate function. Is that ok? Cc: tytso@mit.edu Cc: hch@infradead.org Cc: mfasheh@suse.com Cc: aia21@cantab.net Cc: hugh.dickins@tiscali.co.uk Cc: swhiteho@redhat.com Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-09-14ext2: Update comment about generic_osync_inodeJan Kara
We rely on generic_write_sync() now. CC: linux-ext4@vger.kernel.org Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-08ext[234]: move over to 'check_acl' permission modelLinus Torvalds
Don't implement per-filesystem 'extX_permission()' functions that have to be called for every path component operation, and instead just expose the actual ACL checking so that the VFS layer can now do it for us. Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-05ext2: fix unbalanced kmap()/kunmap()Nicolas Pitre
In ext2_rename(), dir_page is acquired through ext2_dotdot(). It is then released through ext2_set_link() but only if old_dir != new_dir. Failing that, the pkmap reference count is never decremented and the page remains pinned forever. Repeat that a couple times with highmem pages and all pkmap slots get exhausted, and every further kmap() calls end up stalling on the pkmap_map_wait queue at which point the whole system comes to a halt. Signed-off-by: Nicolas Pitre <nico@marvell.com> Acked-by: Theodore Ts'o <tytso@mit.edu> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30ext2: return -EIO not -ESTALE on directory traversal through deleted inodeBryan Donlan
ext2_iget() returns -ESTALE if invoked on a deleted inode, in order to report errors to NFS properly. However, in ext[234]_lookup(), this -ESTALE can be propagated to userspace if the filesystem is corrupted such that a directory entry references a deleted inode. This leads to a misleading error message - "Stale NFS file handle" - and confusion on the part of the admin. The bug can be easily reproduced by creating a new filesystem, making a link to an unused inode using debugfs, then mounting and attempting to ls -l said link. This patch thus changes ext2_lookup to return -EIO if it receives -ESTALE from ext2_iget(), as ext2 does for other filesystem metadata corruption; and also invokes the appropriate ext*_error functions when this case is detected. Signed-off-by: Bryan Donlan <bdonlan@gmail.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24helpers for acl caching + switch to thoseAl Viro
helpers: get_cached_acl(inode, type), set_cached_acl(inode, type, acl), forget_cached_acl(inode, type). ubifs/xattr.c needed includes reordered, the rest is a plain switchover. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-24switch ext2 to inode->i_aclAl Viro
2009-06-18ext2: Do not update mtime of a moved directoryJan Kara
One of our users is complaining that his backup tool is upset on ext2 (while it's happy on ext3, xfs, ...) because of the mtime change. The problem is: mkdir foo mkdir bar mkdir foo/a Now under ext2: mv foo/a foo/b changes mtime of 'foo/a' (foo/b after the move). That does not really make sense and it does not happen under any other filesystem I've seen. More complicated is: mv foo/a bar/a This changes mtime of foo/a (bar/a after the move) and it makes some sense since we had to update parent directory pointer of foo/a. But again, no other filesystem does this. So after some thoughts I'd vote for consistency and change ext2 to behave the same as other filesystems. Do not update mtime of a moved directory. Specs don't say anything about it (neither that it should, nor that it should not be updated) and other common filesystems (ext3, ext4, xfs, reiserfs, fat, ...) don't do it. So let's become more consistent. Spotted by ronny.pretzsch@dfs.de, initial fix by Jörn Engel. Reported-by: <ronny.pretzsch@dfs.de> Cc: <hare@suse.de> Cc: Jörn Engel <joern@logfs.org> Signed-off-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-12trivial: ext2: fix a typo in comment in ext2.hAli Gholami Rudi
Signed-off-by: Ali Gholami Rudi <ali@rudi.ir> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-11ext2: add ->sync_fsChristoph Hellwig
Add a ->sync_fs method for data integrity syncs, and reimplement ->write_super ontop of it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11switch ext2 to simple_fsync()Al Viro
kill ext2_sync_file() (along with ext2/fsync.c), get rid of ext2_update_inode() - it's an alias of ext2_write_inode(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11Push BKL down into ->remount_fs()Alessio Igor Bogani
[xfs, btrfs, capifs, shmem don't need BKL, exempt] Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11push BKL down into ->put_superChristoph Hellwig
Move BKL into ->put_super from the only caller. A couple of filesystems had trivial enough ->put_super (only kfree and NULLing of s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs, hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most of them probably don't need it, but I'd rather sort that out individually. Preferably after all the other BKL pushdowns in that area. [AV: original used to move lock_super() down as well; these changes are removed since we don't do lock_super() at all in generic_shutdown_super() now] [AV: fuse, btrfs and xfs are known to need no damn BKL, exempt] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11remove ->write_super call in generic_shutdown_superChristoph Hellwig
We just did a full fs writeout using sync_filesystem before, and if that's not enough for the filesystem it can perform it's own writeout in ->put_super, which many filesystems already do. Move a call to foofs_write_super into every foofs_put_super for now to guarantee identical behaviour until it's cleaned up by the individual filesystem maintainers. Exceptions: - affs already has identical copy & pasted code at the beginning of affs_put_super so no need to do it twice. - xfs does the right thing without it and I have changes pending for the xfs tree touching this are so I don't really need conflicts here.. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-17ext2: Fix memory leak in ext2_fill_super() in case of a failed mountManish Katiyar
Signed-off-by: Manish Katiyar <mkatiyar@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-04-27ext2: missing unlock in ext2_quota_write()Dan Carpenter
The inode->i_mutex should be unlocked. Found by smatch (http://repo.or.cz/w/smatch.git). Compile tested. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-04-13ext2: fix data corruption for racing writesJan Kara
If two writers allocating blocks to file race with each other (e.g. because writepages races with ordinary write or two writepages race with each other), ext2_getblock() can be called on the same inode in parallel. Before we are going to allocate new blocks, we have to recheck the block chain we have obtained so far without holding truncate_mutex. Otherwise we could overwrite the indirect block pointer set by the other writer leading to data loss. The below test program by Ying is able to reproduce the data loss with ext2 on in BRD in a few minutes if the machine is under memory pressure: long kMemSize = 50 << 20; int kPageSize = 4096; int main(int argc, char **argv) { int status; int count = 0; int i; char *fname = "/mnt/test.mmap"; char *mem; unlink(fname); int fd = open(fname, O_CREAT | O_EXCL | O_RDWR, 0600); status = ftruncate(fd, kMemSize); mem = mmap(0, kMemSize, PROT_READ | PROT_WRITE, MAP_SHARED, fd, 0); // Fill the memory with 1s. memset(mem, 1, kMemSize); sleep(2); for (i = 0; i < kMemSize; i++) { int byte_good = mem[i] != 0; if (!byte_good && ((i % kPageSize) == 0)) { //printf("%d ", i / kPageSize); count++; } } munmap(mem, kMemSize); close(fd); unlink(fname); if (count > 0) { printf("Running %d bad page\n", count); return 1; } return 0; } Cc: Ying Han <yinghan@google.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Jan Kara <jack@suse.cz> Cc: Mingming Cao <cmm@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31New helper - current_umask()Al Viro
current->fs->umask is what most of fs_struct users are doing. Put that into a helper function. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-26ext2: Zero our b_size in ext2_quota_read()Manish Katiyar
ext2_quota_read() doesn't initialize tmp_bh.b_size before calling ext2_get_block() where we access it. Since it is a local variable it might contain some garbage. Make sure it is filled with reasonable value before passing. Signed-off-by: Manish Katiyar <mkatiyar@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-03-26ext2: Use lowercase names of quota functionsJan Kara
Use lowercase names of quota functions instead of old uppercase ones. Signed-off-by: Jan Kara <jack@suse.cz> CC: linux-ext4@vger.kernel.org
2009-02-11ext2/xip: refuse to change xip flag during remount with busy inodesCarsten Otte
For a reason that I was unable to understand in three months of debugging, mount ext2 -o remount stopped working properly when remounting from regular operation to xip, or the other way around. According to a git bisect search, the problem was introduced with the VM_MIXEDMAP/PTE_SPECIAL rework in the vm: commit 70688e4dd1647f0ceb502bbd5964fa344c5eb411 Author: Nick Piggin <npiggin@suse.de> Date: Mon Apr 28 02:13:02 2008 -0700 xip: support non-struct page backed memory In the failing scenario, the filesystem is mounted read only via root= kernel parameter on s390x. During remount (in rc.sysinit), the inodes of the bash binary and its libraries are busy and cannot be invalidated (the bash which is running rc.sysinit resides on subject filesystem). Afterwards, another bash process (running ifup-eth) recurses into a subshell, runs dup_mm (via fork). Some of the mappings in this bash process were created from inodes that could not be invalidated during remount. Both parent and child process crash some time later due to inconsistencies in their address spaces. The issue seems to be timing sensitive, various attempts to recreate it have failed. This patch refuses to change the xip flag during remount in case some inodes cannot be invalidated. This patch keeps users from running into that issue. [akpm@linux-foundation.org: cleanup] Signed-off-by: Carsten Otte <cotte@de.ibm.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Jared Hulbert <jaredeh@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15ext2: also update the inode on disk when dir is IS_DIRSYNCJan Kara
We used to just write changed page for IS_DIRSYNC inodes. But we also have to update the directory inode itself just for the case that we've allocated a new block and changed i_size. [akpm@linux-foundation.org: still sync the data page] Signed-off-by: Jan Kara <jack@suse.cz> Tested-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08ext2: tighten restrictions on inode flagsDuane Griffin
At the moment there are few restrictions on which flags may be set on which inodes. Specifically DIRSYNC may only be set on directories and IMMUTABLE and APPEND may not be set on links. Tighten that to disallow TOPDIR being set on non-directories and only NODUMP and NOATIME to be set on non-regular file, non-directories. Introduces a flags masking function which masks flags based on mode and use it during inode creation and when flags are set via the ioctl to facilitate future consistency. Signed-off-by: Duane Griffin <duaneg@dghda.com> Acked-by: Andreas Dilger <adilger@sun.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08ext2: don't inherit inappropriate inode flags from parentDuane Griffin
At present BTREE/INDEX is the only flag that new ext2 inodes do NOT inherit from their parent. In addition prevent the flags DIRTY, ECOMPR, INDEX, IMAGIC and TOPDIR from being inherited. List inheritable flags explicitly to prevent future flags from accidentally being inherited. This fixes the TOPDIR flag inheritance bug reported at http://bugzilla.kernel.org/show_bug.cgi?id=9866. Signed-off-by: Duane Griffin <duaneg@dghda.com> Acked-by: Andreas Dilger <adilger@sun.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08ext2: allocate ->s_blockgroup_lock separatelyPekka J Enberg
As spotted by kmemtrace, struct ext2_sb_info is 17024 bytes on 64-bit which makes it a very bad fit for SLAB allocators. The culprit of the wasted memory is ->s_blockgroup_lock which can be as big as 16 KB when NR_CPUS >= 32. To fix that, allocate ->s_blockgroup_lock, which fits nicely in a order 2 page in the worst case, separately. This shinks down struct ext2_sb_info enough to fit a 1 KB slab cache so now we allocate 16 KB + 1 KB instead of 32 KB saving 15 KB of memory. Acked-by: Andreas Dilger <adilger@sun.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08ext2: fix ext2_splice_branch() commentsQinghuang Feng
There is no argument named @chain in ext2_splice_branch, remove references to it. Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-31nfsd race fixes: ext2Al Viro
* make ext2_new_inode() put the inode into icache in locked state * do not unlock until the inode is fully set up; otherwise nfsd might pick it in half-baked state. * make sure that ext2_new_inode() does *not* lead to two inodes with the same inumber hashed at the same time; otherwise a bogus fhandle coming from nfsd might race with inode creation: nfsd: iget_locked() creates inode nfsd: try to read from disk, block on that. ext2_new_inode(): allocate inode with that inumber ext2_new_inode(): insert it into icache, set it up and dirty ext2_write_inode(): get the relevant part of inode table in cache, set the entry for our inode (and start writing to disk) nfsd: get CPU again, look into inode table, see nice and sane on-disk inode, set the in-core inode from it oops - we have two in-core inodes with the same inumber live in icache, both used for IO. Welcome to fs corruption... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-31ext2: ensure fast symlinks are NUL-terminatedDuane Griffin
Ensure fast symlink targets are NUL-terminated, even if corrupted on-disk. Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Duane Griffin <duaneg@dghda.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-11-14CRED: Wrap task credential accesses in the Ext2 filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: linux-ext4@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdevLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdev: (66 commits) [PATCH] kill the rest of struct file propagation in block ioctls [PATCH] get rid of struct file use in blkdev_ioctl() BLKBSZSET [PATCH] get rid of blkdev_locked_ioctl() [PATCH] get rid of blkdev_driver_ioctl() [PATCH] sanitize blkdev_get() and friends [PATCH] remember mode of reiserfs journal [PATCH] propagate mode through swsusp_close() [PATCH] propagate mode through open_bdev_excl/close_bdev_excl [PATCH] pass fmode_t to blkdev_put() [PATCH] kill the unused bsize on the send side of /dev/loop [PATCH] trim file propagation in block/compat_ioctl.c [PATCH] end of methods switch: remove the old ones [PATCH] switch sr [PATCH] switch sd [PATCH] switch ide-scsi [PATCH] switch tape_block [PATCH] switch dcssblk [PATCH] switch dasd [PATCH] switch mtd_blkdevs [PATCH] switch mmc ...
2008-10-23[PATCH] get rid of on-stack dentry in ext2_get_parent()Al Viro
2008-10-23[PATCH] switch all filesystems over to d_obtain_aliasChristoph Hellwig
Switch all users of d_alloc_anon to d_obtain_alias. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] move block_device_operations to blkdev.hAl Viro
2008-10-20fs/Kconfig: move ext2, ext3, ext4, JBD, JBD2 outAlexey Dobriyan
Use fs/*/Kconfig more, which is good because everything related to one filesystem is in one place and fs/Kconfig is quite fat. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16ext2: avoid printk floods in the face of directory corruptionEric Sandeen
A very large directory with many read failures (either due to storage problems, or due to invalid size & blocks from corruption) will generate a printk storm as the filesystem continues to try to read all the blocks. This flood of messages can tie up the box until it is complete - which may be a very long time, especially for very large corrupted values. This is fixed by only reporting the corruption once each time we try to read the directory. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Eugene Teo <eugeneteo@kernel.sg> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16ext2: fix ext2 block reservation early ENOSPC issueMingming Cao
We could run into ENOSPC error on ext2, even when there is free blocks on the filesystem. The problem is triggered in the case the goal block group has 0 free blocks , and the rest block groups are skipped due to the check of "free_blocks < windowsz/2". Current code could fall back to non reservation allocation to prevent early ENOSPC after examing all the block groups with reservation on , but this code was bypassed if the reservation window is turned off already, which is true in this case. This patch fixed two issues: 1) We don't need to turn off block reservation if the goal block group has 0 free blocks left and continue search for the rest of block groups. Current code the intention is to turn off the block reservation if the goal allocation group has a few (some) free blocks left (not enough for make the desired reservation window),to try to allocation in the goal block group, to get better locality. But if the goal blocks have 0 free blocks, it should leave the block reservation on, and continues search for the next block groups,rather than turn off block reservation completely. 2) we don't need to check the window size if the block reservation is off. The problem was originally found and fixed in ext4. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13vfs: Use const for kernel parser tableSteven Whitehouse
This is a much better version of a previous patch to make the parser tables constant. Rather than changing the typedef, we put the "const" in all the various places where its required, allowing the __initconst exception for nfsroot which was the cause of the previous trouble. This was posted for review some time ago and I believe its been in -mm since then. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Alexander Viro <aviro@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
