path: root/fs/efivarfs/file.c
2014-11-19kill f_dentry usesAl Viro
2014-03-04efivarfs: 'efivarfs_file_write' function reorganizationGeyslan G. Bem
This reorganization removes useless 'bytes' prior assignment and uses 'memdup_user' instead 'kmalloc' + 'copy_from_user'. Signed-off-by: Geyslan G. Bem <geyslan@gmail.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2013-05-13efivarfs: Never return ENOENT from firmware againLingzhu Xiang
Previously in 1fa7e69 efi_status_to_err() translated firmware status EFI_NOT_FOUND to -EIO instead of -ENOENT for efivarfs operations to avoid confusion. After refactoring in e14ab23, it is also used in other places where the translation may be unnecessary. So move the translation to efivarfs specific code. Also return EOF for reading zero-length files, which is what users would expect. Cc: Josh Boyer <jwboyer@redhat.com> Cc: Jeremy Kerr <jk@ozlabs.org> Cc: Lee, Chun-Yi <jlee@suse.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Lingzhu Xiang <lxiang@redhat.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-04-20Merge remote-tracking branch 'efi/chainsaw' into x86/efiH. Peter Anvin
Resolved Conflicts: drivers/firmware/efivars.c fs/efivarsfs/file.c Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-04-17efivarfs: Move to fs/efivarfsMatt Fleming
Now that efivarfs uses the efivar API, move it out of efivars.c and into fs/efivarfs where it belongs. This move will eventually allow us to enable the efivarfs code without having to also enable CONFIG_EFI_VARS built, and vice versa. Furthermore, things like, mount -t efivarfs none /sys/firmware/efi/efivars will now work if efivarfs is built as a module without requiring the use of MODULE_ALIAS(), which would have been necessary when the efivarfs code was part of efivars.c. Cc: Matthew Garrett <matthew.garrett@nebula.com> Cc: Jeremy Kerr <jk@ozlabs.org> Reviewed-by: Tom Gundersen <teg@jklm.no> Tested-by: Tom Gundersen <teg@jklm.no> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
