path: root/fs/ecryptfs/mmap.c
2009-09-22const: mark remaining address_space_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-22eCryptfs: Fix data corruption when using ecryptfs_passthroughTyler Hicks
ecryptfs_passthrough is a mount option that allows eCryptfs to allow data to be written to non-eCryptfs files in the lower filesystem. The passthrough option was causing data corruption due to it not always being treated as a non-eCryptfs file. The first 8 bytes of an eCryptfs file contains the decrypted file size. This value was being written to the non-eCryptfs files, too. Also, extra 0x00 characters were being written to make the file size a multiple of PAGE_CACHE_SIZE. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2009-01-04fs: symlink write_begin allocation context fixNick Piggin
With the write_begin/write_end aops, page_symlink was broken because it could no longer pass a GFP_NOFS type mask into the point where the allocations happened. They are done in write_begin, which would always assume that the filesystem can be entered from reclaim. This bug could cause filesystem deadlocks. The funny thing with having a gfp_t mask there is that it doesn't really allow the caller to arbitrarily tinker with the context in which it can be called. It couldn't ever be GFP_ATOMIC, for example, because it needs to take the page lock. The only thing any callers care about is __GFP_FS anyway, so turn that into a single flag. Add a new flag for write_begin, AOP_FLAG_NOFS. Filesystems can now act on this flag in their write_begin function. Change __grab_cache_page to accept a nofs argument as well, to honour that flag (while we're there, change the name to grab_cache_page_write_begin which is more instructive and does away with random leading underscores). This is really a more flexible way to go in the end anyway -- if a filesystem happens to want any extra allocations aside from the pagecache ones in ints write_begin function, it may now use GFP_KERNEL (rather than GFP_NOFS) for common case allocations (eg. ocfs2_alloc_write_ctxt, for a random example). [kosaki.motohiro@jp.fujitsu.com: fix ubifs] [kosaki.motohiro@jp.fujitsu.com: fix fuse] Signed-off-by: Nick Piggin <npiggin@suse.de> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: <stable@kernel.org> [2.6.28.x] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Cleaned up the calling convention: just pass in the AOP flags untouched to the grab_cache_page_write_begin() function. That just simplifies everybody, and may even allow future expansion of the logic. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16ecryptfs: convert to use new aopsBadari Pulavarty
Convert ecryptfs to use write_begin/write_end Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24ecryptfs: inode.c mmap.c use unaligned byteorder helpersHarvey Harrison
Fixe sparse warnings: fs/ecryptfs/inode.c:368:15: warning: cast to restricted __be64 fs/ecryptfs/mmap.c:385:12: warning: incorrect type in assignment (different base types) fs/ecryptfs/mmap.c:385:12: expected unsigned long long [unsigned] [assigned] [usertype] file_size fs/ecryptfs/mmap.c:385:12: got restricted __be64 [usertype] <noident> fs/ecryptfs/mmap.c:428:12: warning: incorrect type in assignment (different base types) fs/ecryptfs/mmap.c:428:12: expected unsigned long long [unsigned] [assigned] [usertype] file_size fs/ecryptfs/mmap.c:428:12: got restricted __be64 [usertype] <noident> Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ecryptfs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04eCryptfs: make ecryptfs_prepare_write decrypt the pageMichael Halcrow
When the page is not up to date, ecryptfs_prepare_write() should be acting much like ecryptfs_readpage(). This includes the painfully obvious step of actually decrypting the page contents read from the lower encrypted file. Note that this patch resolves a bug in eCryptfs in 2.6.24 that one can produce with these steps: # mount -t ecryptfs /secret /secret # echo "abc" > /secret/file.txt # umount /secret # mount -t ecryptfs /secret /secret # echo "def" >> /secret/file.txt # cat /secret/file.txt Without this patch, the resulting data returned from cat is likely to be something other than "abc\ndef\n". (Thanks to Benedikt Driessen for reporting this.) Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Benedikt Driessen <bdriessen@escrypt.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06eCryptfs: track header bytes rather than extentsMichael Halcrow
Remove internal references to header extents; just keep track of header bytes instead. Headers can easily span multiple pages with the recent persistent file changes. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06fs/ecryptfs/: possible cleanupsAdrian Bunk
- make the following needlessly global code static: - crypto.c:ecryptfs_lower_offset_for_extent() - crypto.c:key_tfm_list - crypto.c:key_tfm_list_mutex - inode.c:ecryptfs_getxattr() - main.c:ecryptfs_init_persistent_file() - remove the no longer used mmap.c:ecryptfs_lower_page_cache - #if 0 the unused read_write.c:ecryptfs_read() Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Pagecache zeroing: zero_user_segment, zero_user_segments and zero_userChristoph Lameter
Simplify page cache zeroing of segments of pages through 3 functions zero_user_segments(page, start1, end1, start2, end2) Zeros two segments of the page. It takes the position where to start and end the zeroing which avoids length calculations and makes code clearer. zero_user_segment(page, start, end) Same for a single segment. zero_user(page, start, length) Length variant for the case where we know the length. We remove the zero_user_page macro. Issues: 1. Its a macro. Inline functions are preferable. 2. The KM_USER0 macro is only defined for HIGHMEM. Having to treat this special case everywhere makes the code needlessly complex. The parameter for zeroing is always KM_USER0 except in one single case that we open code. Avoiding KM_USER0 makes a lot of code not having to be dealing with the special casing for HIGHMEM anymore. Dealing with kmap is only necessary for HIGHMEM configurations. In those configurations we use KM_USER0 like we do for a series of other functions defined in highmem.h. Since KM_USER0 is depends on HIGHMEM the existing zero_user_page function could not be a macro. zero_user_* functions introduced here can be be inline because that constant is not used when these functions are called. Also extract the flushing of the caches to be outside of the kmap. [akpm@linux-foundation.org: fix nfs and ntfs build] [akpm@linux-foundation.org: fix ntfs build some more] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Steven French <sfrench@us.ibm.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Steven French <sfrench@us.ibm.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-17ecryptfs: fix fsx data corruption problemsEric Sandeen
ecryptfs in 2.6.24-rc3 wasn't surviving fsx for me at all, dying after 4 ops. Generally, encountering problems with stale data and improperly zeroed pages. An extending truncate + write for example would expose stale data. With the changes below I got to a million ops and beyond with all mmap ops disabled - mmap still needs work. (A version of this patch on a RHEL5 kernel ran for over 110 million fsx ops) I added a few comments as well, to the best of my understanding as I read through the code. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Acked-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ecryptfs: clean up page flag handlingMichael Halcrow
The functions that eventually call down to ecryptfs_read_lower(), ecryptfs_decrypt_page(), and ecryptfs_copy_up_encrypted_with_header() should have the responsibility of managing the page Uptodate status. This patch gets rid of some of the ugliness that resulted from trying to push some of the page flag setting too far down the stack. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: remove unused functions and kmem_cacheMichael Halcrow
The switch to read_write.c routines and the persistent file make a number of functions unnecessary. This patch removes them. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: fix data typesMichael Halcrow
Update data types and add casts in order to avoid potential overflow issues. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: convert mmap functions to use persistent fileMichael Halcrow
Convert readpage, prepare_write, and commit_write to use read_write.c routines. Remove sync_page; I cannot think of a good reason for implementing that in eCryptfs. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: update metadata read/write functionsMichael Halcrow
Update the metadata read/write functions and grow_file() to use the read_write.c routines. Do not open another lower file; use the persistent lower file instead. Provide a separate function for crypto.c::ecryptfs_read_xattr_region() to get to the lower xattr without having to go through the eCryptfs getxattr. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: replace encrypt, decrypt, and inode size writeMichael Halcrow
Replace page encryption and decryption routines and inode size write routine with versions that utilize the read_write.c functions. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: read_write.c routinesMichael Halcrow
Add a set of functions through which all I/O to lower files is consolidated. This patch adds a new inode_info reference to a persistent lower file for each eCryptfs inode; another patch later in this series will set that up. This persistent lower file is what the read_write.c functions use to call vfs_read() and vfs_write() on the lower filesystem, so even when reads and writes come in through aops->readpage and aops->writepage, we can satisfy them without resorting to direct access to the lower inode's address space. Several function declarations are going to be changing with this patchset. For now, in order to keep from breaking the build, I am putting dummy parameters in for those functions. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: remove assignments in if-statementsMichael Halcrow
Remove assignments in if-statements. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: remove header_extent_sizeMichael Halcrow
There is no point to keeping a separate header_extent_size and an extent_size. The total size of the header can always be represented as some multiple of the regular data extent size. [randy.dunlap@oracle.com: ecryptfs: fix printk format warning] Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fs: remove some AOP_TRUNCATED_PAGENick Piggin
prepare/commit_write no longer returns AOP_TRUNCATED_PAGE since OCFS2 and GFS2 were converted to the new aops, so we can make some simplifications for that. [michal.k.k.piotrowski@gmail.com: fix warning] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-31eCryptfs: fix possible fault in ecryptfs_sync_pageRyusuke Konishi
This will avoid a possible fault in ecryptfs_sync_page(). In the function, eCryptfs calls sync_page() method of a lower filesystem without checking its existence. However, there are many filesystems that don't have this method including network filesystems such as NFS, AFS, and so forth. They may fail when an eCryptfs page is waiting for lock. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Acked-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20fix some conversion overflowsNick Piggin
Fix page index to offset conversion overflows in buffer layer, ecryptfs, and ocfs2. It would be nice to convert the whole tree to page_offset, but for now just fix the bugs. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-28zero out last page for llseek/writeMichael Halcrow
When one llseek's past the end of the file and then writes, every page past the previous end of the file should be cleared. Trevor found that the code, as is, does not assure that the very last page is always cleared. This patch takes care of that. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-28eCryptfs: fix write zeros behaviorMichael Halcrow
This patch fixes the processes involved in wiping regions of the data during truncate and write events, fixing a kernel hang in 2.6.22-rc4 while assuring that zero values are written out to the appropriate locations during events in which the i_size will change. The range passed to ecryptfs_truncate() from ecryptfs_prepare_write() includes the page that is the object of ecryptfs_prepare_write(). This leads to a kernel hang as read_cache_page() is executed on the same page in the ecryptfs_truncate() execution path. This patch remedies this by limiting the range passed to ecryptfs_truncate() so as to exclude the page that is the object of ecryptfs_prepare_write(); it also adds code to ecryptfs_prepare_write() to zero out the region of its own page when writing past the i_size position. This patch also modifies ecryptfs_truncate() so that when a file is truncated to a smaller size, eCryptfs will zero out the contents of the new last page from the new size through to the end of the last page. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23eCryptfs: delay writing 0's after llseek until writeMichael Halcrow
Delay writing 0's out in eCryptfs after a seek past the end of the file until data is actually written. http://www.opengroup.org/onlinepubs/009695399/functions/lseek.html ``The lseek() function shall not, by itself, extend the size of a file.'' Without this fix, applications that lseek() past the end of the file without writing will experience unexpected behavior. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-17ecryptfs: use zero_user_pageNate Diller
Use zero_user_page() instead of open-coding it. Signed-off-by: Nate Diller <nate.diller@gmail.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: make read_cache_page synchronousNick Piggin
Ensure pages are uptodate after returning from read_cache_page, which allows us to cut out most of the filesystem-internal PageUptodate calls. I didn't have a great look down the call chains, but this appears to fixes 7 possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in block2mtd. All depending on whether the filler is async and/or can return with a !uptodate page. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05[PATCH] ecryptfs: handle AOP_TRUNCATED_PAGE betterDmitriy Monakhov
- In fact we don't have to fail if AOP_TRUNCATED_PAGE was returned from prepare_write or commit_write. It is beter to retry attempt where it is possible. - Rearange ecryptfs_get_lower_page() error handling logic, make it more clean. Signed-off-by: Dmitriy Monakhov <dmonakhov@openvz.org> Acked-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05[PATCH] ecryptfs: check xattr operation support fixDmitriy Monakhov
- ecryptfs_write_inode_size_to_metadata() error code was ignored. - i_op->setxattr() must be supported by lower fs because used below. Signed-off-by: Monakhov Dmitriy <dmonakhov@openvz.org> Acked-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] eCryptfs: remove unnecessary flush_dcache_page()Michael Halcrow
Remove unnecessary flush_dcache_page() call. Thanks to Dmitriy Monakhov for pointing this out. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Dmitriy Monakhov <dmonakhov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] eCryptfs: resolve lower page unlocking problemMichael Halcrow
eCryptfs lower file handling code has several issues: - Retval from prepare_write()/commit_write() wasn't checked to equality to AOP_TRUNCATED_PAGE. - In some places page wasn't unmapped and unlocked after error. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] eCryptfs: add flush_dcache_page() callsMichael Halcrow
Call flush_dcache_page() after modifying a pagecache by hand. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] eCryptfs: open-code flag checking and manipulationMichael Halcrow
Open-code flag checking and manipulation. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Trevor Highland <tshighla@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] eCryptfs: convert kmap() to kmap_atomic()Michael Halcrow
Replace kmap() with kmap_atomic(). Reduce the amount of time that mappings are held. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Trevor Highland <tshighla@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] eCryptfs: Encrypted passthroughMichael Halcrow
Provide an option to provide a view of the encrypted files such that the metadata is always in the header of the files, regardless of whether the metadata is actually in the header or in the extended attribute. This mode of operation is useful for applications like incremental backup utilities that do not preserve the extended attributes when directly accessing the lower files. With this option enabled, the files under the eCryptfs mount point will be read-only. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] eCryptfs: Generalize metadata read/writeMichael Halcrow
Generalize the metadata reading and writing mechanisms, with two targets for now: metadata in file header and metadata in the user.ecryptfs xattr of the lower file. [akpm@osdl.org: printk warning fix] [bunk@stusta.de: make some needlessly global code static] Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] eCryptfs: Public key; packet managementMichael Halcrow
Public key support code. This reads and writes packets in the header that contain public key encrypted file keys. It calls the messaging code in the previous patch to send and receive encryption and decryption request packets from the userspace daemon. [akpm@osdl.org: cleab fix] Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] ecryptfs: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the ecryptfs filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] ecryptfs: fs/Makefile and fs/KconfigMichael Halcrow
eCryptfs is a stacked cryptographic filesystem for Linux. It is derived from Erez Zadok's Cryptfs, implemented through the FiST framework for generating stacked filesystems. eCryptfs extends Cryptfs to provide advanced key management and policy features. eCryptfs stores cryptographic metadata in the header of each file written, so that encrypted files can be copied between hosts; the file will be decryptable with the proper key, and there is no need to keep track of any additional information aside from what is already in the encrypted file itself. [akpm@osdl.org: updates for ongoing API changes] [bunk@stusta.de: cleanups] [akpm@osdl.org: alpha build fix] [akpm@osdl.org: cleanups] [tytso@mit.edu: inode-diet updates] [pbadari@us.ibm.com: generic_file_*_read/write() interface updates] [rdunlap@xenotime.net: printk format fixes] [akpm@osdl.org: make slab creation and teardown table-driven] Signed-off-by: Phillip Hellewell <phillip@hellewell.homeip.net> Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
