successful
unlock in case where server does not support POSIX locks and nobrl is
not specified.
Signed-off-by: Steve French <sfrench@us.ibm.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Fixes Samba bugzilla bug # 4182
Rename by handle failures (retry after rename by path) were not
being returned back.
[chrisw: trivial backport in CHANGES]
CIFS had one path in which dentry was instantiated before the corresponding
inode metadata was filled in.
Fixes Redhat bugzilla bug #163493
Acked-by: Eric Paris <eparis@redhat.com>
Acked-by: Dave Kleikamp <shaggy@austin.ibm.com>
specified
Pointed out by Bjoern Jacke
le16 compared to host-endian constant
u8 fed to le32_to_cpu()
new POSIX locking code
Pointed out by Guenter Kukkukk
Signed-of-by: Steve French <sfrench@us.ibm.com>
(cherry picked from bbf33d512da608c7221fec42b56b9ef89c25a5ee commit)
Allow Windows blocking locks to be cancelled via a
CANCEL_LOCK call. TODO - restrict this to servers
that support NT_STATUS codes (Win9x will probably
not support this call).
Signed-off-by: Jeremy Allison <jra@samba.org>
(cherry picked from 570d4d2d895569825d0d017d4e76b51138f68864 commit)
Make cifsd allow us to suspend if it has lost the connection with a server
Ref: http://bugzilla.kernel.org/show_bug.cgi?id=6811
Acked-by: Pavel Machek <pavel@ucw.cz>
(cherry picked from 27bd6cd87b0ada66515ad49bc346d77d1e9d3e05 commit)
Although harmless, we were sometimes treating midState like it contained
flags but they are exclusive states, and this makes that more clear.
(cherry picked from 586c057c3a68dd6ae0f3ba94fbf76798b1558074 commit)
(cherry picked from b33a3f55e54fd210fc043eafcf83728b03bc9e02 commit)
request and do not time out slow requests to a server that is still responding
well to other threads
Suggested by jra of Samba team
(cherry picked from 89b57148115479eef074b8d3f86c4c86c96ac969 commit)
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Same as with already do with the file operations: keep them in .rodata and
prevents people from doing runtime patching.
Cc: Steven French <sfrench@us.ibm.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: (25 commits)
[CIFS] Fix authentication choice so we do not force NTLMv2 unless the
[CIFS] Fix alignment of unicode strings in previous patch
[CIFS] Fix allocation of buffers for new session setup routine to allow
[CIFS] Remove calls to to take f_owner.lock
[CIFS] remove some redundant null pointer checks
[CIFS] Fix compile warning when CONFIG_CIFS_EXPERIMENTAL is off
[CIFS] Enable sec flags on mount for cifs (part one)
[CIFS] Fix suspend/resume problem which causes EIO on subsequent access to
[CIFS] fix minor compile warning when config_cifs_weak_security is off
[CIFS] NTLMv2 support part 5
[CIFS] Add support for readdir to legacy servers
[CIFS] NTLMv2 support part 4
[CIFS] NTLMv2 support part 3
[CIFS] NTLMv2 support part 2
[CIFS] Fix mask so can set new cifs security flags properly
CIFS] Support for older servers which require plaintext passwords - part 2
[CIFS] Support for older servers which require plaintext passwords
[CIFS] Fix mapping of old SMB return code Invalid Net Name so it is
[CIFS] Missing brace
[CIFS] Do not overwrite aops
user specifies it is required or turns of ntlm
longer user and domain names and allow passing sec options on mount
CIFS takes/releases f_owner.lock - why? It does not change anything in the
fowner state. Remove this locking.
some of them pointed out by Dave Jones
fs/nfs/inode.c
fs/super.c
Fix conflicts between patch 'NFS: Split fs/nfs/inode.c' and patch
'VFS: Permit filesystem to override root dentry on mount'
Pass the POSIX lock owner ID to the flush operation.
This is useful for filesystems which don't want to store any locking state
in inode->i_flock but want to handle locking/unlocking POSIX locks
internally. FUSE is one such filesystem but I think it possible that some
network filesystems would need this also.
Also add a flag to indicate that a POSIX locking request was generated by
close(), so filesystems using the above feature won't send an extra locking
request in this case.
Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
When a writeback_control's `start' and `end' fields are used to
indicate a one-byte-range starting at file offset zero, the required
values of .start=0,.end=0 mean that the ->writepages() implementation
has no way of telling that it is being asked to perform a range
request. Because we're currently overloading (start == 0 && end == 0)
to mean "this is not a write-a-range request".
To make all this sane, the patch changes range of writeback_control.
So caller does: If it is calling ->writepages() to write pages, it
sets range (range_start/end or range_cyclic) always.
And if range_cyclic is true, ->writepages() thinks the range is
cyclic, otherwise it just uses range_start and range_end.
This patch does,
- Add LLONG_MAX, LLONG_MIN, ULLONG_MAX to include/linux/kernel.h
-1 is usually ok for range_end (type is long long). But, if someone did,
range_end += val; range_end is "val - 1"
u64val = range_end >> bits; u64val is "~(0ULL)"
or something, they are wrong. So, this adds LLONG_MAX to avoid nasty
things, and uses LLONG_MAX for range_end.
- All callers of ->writepages() sets range_start/end or range_cyclic.
- Fix updates of ->writeback_index. It seems already bit strange.
If it starts at 0 and ended by check of nr_to_write, this last
index may reduce chance to scan end of file. So, this updates
->writeback_index only if range_cyclic is true or whole-file is
scanned.
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Nathan Scott <nathans@sgi.com>
Cc: Anton Altaparmakov <aia21@cantab.net>
Cc: "Vladimir V. Saveliev" <vs@namesys.com>
Give the statfs superblock operation a dentry pointer rather than a superblock
pointer.
This complements the get_sb() patch. That reduced the significance of
sb->s_root, allowing NFS to place a fake root there. However, NFS does
require a dentry to use as a target for the statfs operation. This permits
the root in the vfsmount to be used instead.
linux/mount.h has been added where necessary to make allyesconfig build
successfully.
Interest has also been expressed for use with the FUSE and XFS filesystems.
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Extend the get_sb() filesystem operation to take an extra argument that
permits the VFS to pass in the target vfsmount that defines the mountpoint.
The filesystem is then required to manually set the superblock and root dentry
pointers. For most filesystems, this should be done with simple_set_mnt()
which will set the superblock pointer and then set the root dentry to the
superblock's s_root (as per the old default behaviour).
The get_sb() op now returns an integer as there's now no need to return the
superblock pointer.
This patch permits a superblock to be implicitly shared amongst several mount
points, such as can be done with NFS to avoid potential inode aliasing. In
such a case, simple_set_mnt() would not be called, and instead the mnt_root
and mnt_sb would be set directly.
The patch also makes the following changes:
(*) the get_sb_*() convenience functions in the core kernel now take a vfsmount
pointer argument and return an integer, so most filesystems have to change
very little.
(*) If one of the convenience function is not used, then get_sb() should
normally call simple_set_mnt() to instantiate the vfsmount. This will
always return 0, and so can be tail-called from get_sb().
(*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the
dcache upon superblock destruction rather than shrink_dcache_anon().
This is required because the superblock may now have multiple trees that
aren't actually bound to s_root, but that still need to be cleaned up. The
currently called functions assume that the whole tree is rooted at s_root,
and that anonymous dentries are not the roots of trees which results in
dentries being left unculled.
However, with the way NFS superblock sharing are currently set to be
implemented, these assumptions are violated: the root of the filesystem is
simply a dummy dentry and inode (the real inode for '/' may well be
inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries
with child trees.
[*] Anonymous until discovered from another tree.
(*) The documentation has been adjusted, including the additional bit of
changing ext2_* into foo_* in the documentation.
[akpm@osdl.org: convert ipath_fs, do other stuff]
Cc: Roland Dreier <rolandd@cisco.com>
the mount.
Signed-off-by: Pavel Machek <pavel@suse.de>
Allow filesystems to decide to perform pre-umount processing whether or not
MNT_FORCE is set.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
NTLMv2 authentication (stronger authentication than default NTLM) which
many servers support now works. There was a problem with the construction
of the security blob in the older code. Currently requires
/proc/fs/cifs/Experimental to be set to 2
and
/proc/fs/cifs/SecurityFlags to be set to 0x4004 (to require using
NTLMv2 instead of default of NTLM)
Next we will check signing to make sure optional NTLMv2 packet signing also
works.
Fixes oops to OS/2 on ls and removes redundant NTCreateX calls to servers
which do not support NT SMBs. Key operations to OS/2 work.
Response struct filled in exacty for 16 byte hash which we need to check
more to make sure it works.
Still need to fill in response structure and check that hash works
disabled by default, but can be enabled via proc for servers which
require such support. Also includes support for setting security
flags for cifs. See fs/cifs/README
recognized on mount
the old mapping of this was to ENODEV (instead of ENXIO) - but
ENODEV is what mount returns when the cifs driver will not load
so change this to map to ENXIO (which was what the equivalent
condition returned for mapping errors from more modern servers)
cifs should not be overwriting an element of the aops structure, since the
structure is shared by all cifs inodes. Instead define a separate aops
structure to suit each purpose.
I also took the liberty of replacing a hard-coded 4096 with PAGE_CACHE_SIZE
Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
Signed-off-by: Steven French <sfrench@us.ibm.com>
on set size to zero.
Signed-off-by: Sebastian Voitzsch <sebastoam/vpotzscj@web.de>
