that's the bulk of filesystem drivers dealing with inodes of their own
In spite of different file type,
if file is same name and same inode number, old inode cache is used.
This causes that you can not cd directory, can not cat SymbolicLink.
So this patch is that if file type is different, return error.
Reproducible sample :
1. create file 'a' at cifs client.
2. repeat rm and mkdir 'a' 4 times at server, then direcotry 'a' having same inode number is created.
(Repeat 4 times, then same inode number is recycled.)
(When server is under RHEL 6.6, 1 time is O.K. Always same inode number is recycled.)
3. ls -li at client, then you can not cd directory, can not remove directory.
SymbolicLink has same problem.
Bug link:
https://bugzilla.kernel.org/show_bug.cgi?id=90011
Signed-off-by: Nakajima Akira <nakajima.akira@nttcom.co.jp>
Acked-by: Jeff Layton <jlayton@primarydata.com>
Signed-off-by: Steve French <steve.french@primarydata.com>
Pull VFS changes from Al Viro:
"First pile out of several (there _definitely_ will be more). Stuff in
this one:
- unification of d_splice_alias()/d_materialize_unique()
- iov_iter rewrite
- killing a bunch of ->f_path.dentry users (and f_dentry macro).
Getting that completed will make life much simpler for
unionmount/overlayfs, since then we'll be able to limit the places
sensitive to file _dentry_ to reasonably few. Which allows to have
file_inode(file) pointing to inode in a covered layer, with dentry
pointing to (negative) dentry in union one.
Still not complete, but much closer now.
- crapectomy in lustre (dead code removal, mostly)
- "let's make seq_printf return nothing" preparations
- assorted cleanups and fixes
There _definitely_ will be more piles"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
copy_from_iter_nocache()
new helper: iov_iter_kvec()
csum_and_copy_..._iter()
iov_iter.c: handle ITER_KVEC directly
iov_iter.c: convert copy_to_iter() to iterate_and_advance
iov_iter.c: convert copy_from_iter() to iterate_and_advance
iov_iter.c: get rid of bvec_copy_page_{to,from}_iter()
iov_iter.c: convert iov_iter_zero() to iterate_and_advance
iov_iter.c: convert iov_iter_get_pages_alloc() to iterate_all_kinds
iov_iter.c: convert iov_iter_get_pages() to iterate_all_kinds
iov_iter.c: convert iov_iter_npages() to iterate_all_kinds
iov_iter.c: iterate_and_advance
iov_iter.c: macros for iterating over iov_iter
kill f_dentry macro
dcache: fix kmemcheck warning in switch_names
new helper: audit_file()
nfsd_vfs_write(): use file_inode()
ncpfs: use file_inode()
kill f_dentry uses
lockd: get rid of ->f_path.dentry->d_sb
file->private_data can never be null after calling initiate_cifs_search.
So private null check condition is not needed.
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Ashish Sangwan <a.sangwan@samsung.com>
This is a bigger patch, but its size is mostly due to
a single change for how we check for remapping illegal characters
in file names - a lot of repeated, small changes to
the way callers request converting file names.
The final patch in the series does the following:
1) changes default behavior for cifs to be more intuitive.
Currently we do not map by default to seven reserved characters,
ie those valid in POSIX but not in NTFS/CIFS/SMB3/Windows,
unless a mount option (mapchars) is specified. Change this
to by default always map and map using the SFM maping
(like the Mac uses) unless the server negotiates the CIFS Unix
Extensions (like Samba does when mounting with the cifs protocol)
when the remapping of the characters is unnecessary. This should
help SMB3 mounts in particular since Samba will likely be
able to implement this mapping with its new "vfs_fruit" module
as it will be doing for the Mac.
2) if the user specifies the existing "mapchars" mount option then
use the "SFU" (Microsoft Services for Unix, SUA) style mapping of
the seven characters instead.
3) if the user specifies "nomapposix" then disable SFM/MAC style mapping
(so no character remapping would be used unless the user specifies
"mapchars" on mount as well, as above).
4) change all the places in the code that check for the superblock
flag on the mount which is set by mapchars and passed in on all
path based operation and change it to use a small function call
instead to set the mapping type properly (and check for the
mapping type in the cifs unicode functions)
Signed-off-by: Steve French <smfrench@gmail.com>
This allows directory listings to Mac to display filenames
correctly which have been created with illegal (to Windows)
characters in their filename. It does not allow
converting the other direction yet ie opening files with
these characters (followon patch).
There are seven reserved characters that need to be remapped when
mounting to Windows, Mac (or any server without Unix Extensions) which
are valid in POSIX but not in the other OS.
We used the normal UCS-2 remap range for this in order to convert this
to/from UTF8 as did Windows Services for Unix (basically add 0xF000 to
any of the 7 reserved characters), at least when the "mapchars" mount
option was specified.
Mac used a very slightly different "Services for Mac" remap range
0xF021 through 0xF027. The attached patch allows cifs.ko (the kernel
client) to read directories on macs containing files with these
characters and display their names properly. In theory this even
might be useful on mounts to Samba when the vfs_catia or new
"vfs_fruit" module is loaded.
Currently the 7 reserved characters look very strange in directory
listings from cifs.ko to Mac server. This patch allows these file
name characters to be read (requires specifying mapchars on mount).
Two additional changes are needed:
1) Make it more automatic: a way of detecting enough info so that
we know to try to always remap these characters or not. Various
have suggested that the SFM approach be made the default when
the server does not support POSIX Unix extensions (cifs mounts
to Samba for example) so need to make SFM remapping the default
unless mapchars (SFU style mapping) specified on mount or no
mapping explicitly requested or no mapping needed (cifs mounts to Samba).
2) Adding a patch to map the characters the other direction
(ie UTF-8 to UCS-2 on open). This patch does it for translating
readdir entries (ie UCS-2 to UTF-8)
Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
Now that d_invalidate can no longer fail, stop returning a useless
return code. For the few callers that checked the return code update
remove the handling of d_invalidate failure.
Reviewed-by: Miklos Szeredi <miklos@szeredi.hu>
The existing code calls server->ops->close() that is not
right. This causes XFS test generic/310 to fail. Fix this
by using server->ops->closedir() function.
Cc: <stable@vger.kernel.org> # v3.7+
Signed-off-by: Pavel Shilovsky <pshilovsky@samba.org>
SMB2 servers indicates the end of a directory search with
STATUS_NO_MORE_FILE error code that is not processed now.
This causes generic/257 xfstest to fail. Fix this by triggering
the end of search by this error code in SMB2_query_directory.
Also when negotiating CIFS protocol we tell the server to close
the search automatically at the end and there is no need to do
it itself. In the case of SMB2 protocol, we need to close it
explicitly - separate close directory checks for different
protocols.
Clean up camel case in functionnames.
Signed-off-by: Sachin Prabhu <sprabhu@redhat.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Now we treat any reparse point as a symbolic link and map it to a Unix
one that is not true in a common case due to many reparse point types
supported by SMB servers.
Distinguish reparse point types into two groups:
1) that can be accessed directly through a reparse point
(junctions, deduplicated files, NFS symlinks);
2) that need to be processed manually (Windows symbolic links, DFS);
and map only Windows symbolic links to Unix ones.
Acked-by: Jeff Layton <jlayton@redhat.com>
Reported-and-tested-by: Joao Correia <joaomiguelcorreia@gmail.com>
Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru>
Since we don't get info about the number of links from the readdir
linfo levels, stat() will return 0 for st_nlink, and in particular,
samba re-exported shares will show directories as files (as samba is
keying off st_nlink before evaluating how to set the dos modebits)
when doing a dir or ls.
Copy nlink to the inode, unless it wasn't provided. Provide
sane values if we don't have an existing one and none was provided.
Signed-off-by: Jim McDonough <jmcd@samba.org>
Reviewed-by: David Disseldorp <ddiss@samba.org>
that allows to access files through symlink created on a server.
revalidated immediately
David reported that commit c2b93e06 (cifs: only set ops for inodes in
I_NEW state) caused a regression with mfsymlinks. Prior to that patch,
if a mfsymlink dentry was instantiated at readdir time, the inode would
get a new set of ops when it was revalidated. After that patch, this
did not occur.
This patch addresses this by simply skipping instantiating dentries in
the readdir codepath when we know that they will need to be immediately
revalidated. The next attempt to use that dentry will cause a new lookup
to occur (which is basically what we want to happen anyway).
Cc: "Stefan (metze) Metzmacher" <metze@samba.org>
Cc: Sachin Prabhu <sprabhu@redhat.com>
Reported-and-Tested-by: David McBride <dwm37@cam.ac.uk>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Pull cifs updates from Steve French:
"Various CIFS/SMB2/SMB3 updates for 3.11. Includes bug fixes - SMB3
support should be much more stable with key DFS fix and also signing
possible now (although is more work to do to get SMB3 signing working
well with multiuser).
Mounts using the new SMB 3.02 dialect can now be done (specify
"vers=3.02" on mount) against the most current Microsoft systems.
Also includes a big cleanup of the cifs/smb2/smb3 authentication code
from Jeff which fixes some long standing problems with the way allowed
authentication flavors and signing are configured.
Some followon patches later in the cycle will clean up allocation of
structures for the various security mechanisms depending on what
dialect is chosen (reduces memory usage a little) and to add support
for the secure negotiate fsctl (for smb3) which prevents downgrade
attacks."
* 'for-next' of git://git.samba.org/sfrench/cifs-2.6: (39 commits)
cifs: fill TRANS2_QUERY_FILE_INFO ByteCount fields
cifs: fix SMB2 signing enablement in cifs_enable_signing
[CIFS] Fix build warning
[CIFS] SMB3 Signing enablement
[CIFS] Do not set DFS flag on SMB2 open
[CIFS] fix static checker warning
cifs: try to handle the MUST SecurityFlags sanely
When server doesn't provide SecurityBuffer on SMB2Negotiate pick default
Handle big endianness in NTLM (ntlmv2) authentication
revalidate directories instiantiated via FIND_* in order to handle DFS referrals
SMB2 FSCTL and IOCTL worker function
Charge at least one credit, if server says that it supports multicredit
Remove typo
Some missing share flags
cifs: using strlcpy instead of strncpy
Update headers to update various SMB3 ioctl definitions
Update cifs version number
Add ability to dipslay SMB3 share flags and capabilities for debugging
Add some missing SMB3 and SMB3.02 flags
Add SMB3.02 dialect support
We've had a long-standing problem with DFS referral points. CIFS servers
generally try to make them look like directories in FIND_FIRST/NEXT
responses. When you go to try to do a FIND_FIRST on them though, the
server will then (correctly) return STATUS_PATH_NOT_COVERED. Mostly this
manifests as spurious EREMOTE errors back to userland.
This patch attempts to fix this by marking directories that are
discovered via FIND_FIRST/NEXT for revaldiation. When the lookup code
runs across them again, we'll reissue a QPathInfo against them and that
will make it chase the referral properly.
There is some performance penalty involved here and no I haven't
measured it -- it'll be highly dependent upon the workload and contents
of the mounted share. To try and mitigate that though, the code only
marks the inode for revalidation when it's possible to run across a DFS
referral. i.e.: when the kernel has DFS support built in and the share
is "in DFS"
[At the Microsoft plugfest we noted that usually the DFS links had
the REPARSE attribute tag enabled - DFS junctions are reparse points
after all - so I just added a check for that flag too so the
performance impact should be smaller - Steve]
Reviewed-by: Sachin Prabhu <sprabhu@redhat.com>
It's not obvious from reading the macro names that these macros
are for debugging. Convert the names to a single more typical
kernel style cifs_dbg macro.
cERROR(1, ...) -> cifs_dbg(VFS, ...)
cFYI(1, ...) -> cifs_dbg(FYI, ...)
cFYI(DBG2, ...) -> cifs_dbg(NOISY, ...)
Move the terminating format newline from the macro to the call site.
Add CONFIG_CIFS_DEBUG function cifs_vfs_err to emit the
"CIFS VFS: " prefix for VFS messages.
Size is reduced ~ 1% when CONFIG_CIFS_DEBUG is set (default y)
$ size fs/cifs/cifs.ko*
265245 2525 132 267902 4167e fs/cifs/cifs.ko.new
268359 2525 132 271016 422a8 fs/cifs/cifs.ko.old
Other miscellaneous changes around these conversions:
o Miscellaneous typo fixes
o Add terminating \n's to almost all formats and remove them
from the macros to be more kernel style like. A few formats
previously had defective \n's
o Remove unnecessary OOM messages as kmalloc() calls dump_stack
o Coalesce formats to make grep easier,
added missing spaces when coalescing formats
o Use %s, __func__ instead of embedded function name
o Removed unnecessary "cifs: " prefixes
o Convert kzalloc with multiply to kcalloc
o Remove unused cifswarn macro
* calling conventions change - ERR_PTR() is returned on ->d_hash() errors;
NULL is just for dcache miss now.
* exported, open-coded instances in ncpfs and cifs converted.
numbers are in use
Oliver reported that commit cd60042c caused his cifs mounts to
continually thrash through new inodes on readdir. His servers are not
sending inode numbers (or he's not using them), and the new test in
that function doesn't account for that sort of setup correctly.
If we're not using server inode numbers, then assume that the inode
attached to the dentry hasn't changed. Go ahead and update the
attributes in place, but keep the same inode number.
Cc: <stable@vger.kernel.org> # v3.5+
Reported-and-Tested-by: Oliver Mössinger <Oliver.Moessinger@ichaus.de>
Signed-off-by: Steve French <sfrench@us.ibm.com>
The caller doesn't do anything with the dentry, so there's no point in
holding a reference to it on return. Also cifs_prime_dcache better
describes the actual purpose of the function.
Otherwise, "ls -l" will simply show the ownership of the files as
the default mnt_uid/gid. This may make "ls -l" performance on large
directories super-suck in some cases, but that's the cost of cifsacl.
One possibility to make it suck less would be to somehow proactively
dispatch the ACL requests asynchronously from readdir codepath, but
that's non-trivial to implement.
Rebased and resending the patch.
Path based queries can fail for lack of access, especially during lookup
during open.
open itself would actually succeed becasue of back up intent bit
but queries (either path or file handle based) do not have a means to
specifiy backup intent bit.
So query the file info during lookup using
trans2 / findfirst / file_id_full_dir_info
to obtain file info as well as file_id/inode value.
Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
Acked-by: Jeff Layton <jlayton@samba.org>
This is help us to extend the code for future protocols that can use
another fid mechanism (as SMB2 that has it divided into two parts:
persistent and violatile).
Also rename variables and refactor the code around the changes.
Reviewed-by: Jeff Layton <jlayton@samba.org>
Since both CIFS and SMB2 use ses->capabilities (server->capabilities)
field but flags are different we should make such checks protocol
independent.
When we get back a FIND_FIRST/NEXT result, we have some info about the
dentry that we use to instantiate a new inode. We were ignoring and
discarding that info when we had an existing dentry in the cache.
Fix this by updating the inode in place when we find an existing dentry
and the uniqueid is the same.
Cc: <stable@vger.kernel.org> # .31.x
Reported-and-Tested-by: Andrew Bartlett <abartlet@samba.org>
Reported-by: Bill Robertson <bill_robertson@debortoli.com.au>
Reported-by: Dion Edwards <dion_edwards@debortoli.com.au>
As observed and suggested by Tushar Gosavi...
readdir calls these function to send TRANS2_FIND_FIRST and
TRANS2_FIND_NEXT command to the server. The current cifs module is
not specifying CIFS_SEARCH_BACKUP_SEARCH flag while sending these
command when backupuid/backupgid is specified. This can be resolved
by specifying CIFS_SEARCH_BACKUP_SEARCH flag.
Cc: <stable@kernel.org>
Reported-and-Tested-by: Tushar Gosavi <tugosavi@in.ibm.com>
to reflect the unicode encoding used by CIFS protocol.
Prior to commit eaf35b1, cifs_save_resume_key had some NULL pointer
checks at the top. It turns out that at least one of those NULL
pointer checks is needed after all.
When the LastNameOffset in a FIND reply appears to be beyond the end of
the buffer, CIFSFindFirst and CIFSFindNext will set srch_inf.last_entry
to NULL. Since eaf35b1, the code will now oops in this situation.
Fix this by having the callers check for a NULL last entry pointer
before calling cifs_save_resume_key. No change is needed for the
call site in cifs_readdir as it's not reachable with a NULL
current_entry pointer.
This should fix:
https://bugzilla.redhat.com/show_bug.cgi?id=750247
Cc: stable@vger.kernel.org
Reported-by: Adam G. Metzler <adamgmetzler@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6:
cifs: Cleanup: check return codes of crypto api calls
CIFS: Fix oops while mounting with prefixpath
[CIFS] Redundant null check after dereference
cifs: use cifs_dirent in cifs_save_resume_key
cifs: use cifs_dirent to replace cifs_get_name_from_search_buf
cifs: introduce cifs_dirent
cifs: cleanup cifs_filldir
This allows us to parse the on the wire structures only once in
cifs_filldir.
Introduce a generic directory entry structure, and factor the parsing
of the various on the wire structures that can represent one into
a common helper. Switch cifs_entry_is_dot over to use it as a start.
Use sensible variable names and formatting and remove some superflous
checks on entry.
secMode to sec_mode
and
cifsTconInfo to cifs_tcon
and
cifsSesInfo to cifs_ses
New compiler warnings that I noticed when building a patchset based
on recent Fedora kernel:
fs/cifs/cifssmb.c: In function 'CIFSSMBSetFileSize':
fs/cifs/cifssmb.c:4813:8: warning: variable 'data_offset' set but not used
[-Wunused-but-set-variable]
fs/cifs/file.c: In function 'cifs_open':
fs/cifs/file.c:349:24: warning: variable 'pCifsInode' set but not used
fs/cifs/file.c: In function 'cifs_partialpagewrite':
fs/cifs/file.c:1149:23: warning: variable 'cifs_sb' set but not used
fs/cifs/file.c: In function 'cifs_iovec_write':
fs/cifs/file.c:1740:9: warning: passing argument 6 of 'CIFSSMBWrite2' from
incompatible pointer type [enabled by default]
fs/cifs/cifsproto.h:337:12: note: expected 'unsigned int *' but argument is
of type 'size_t *'
fs/cifs/readdir.c: In function 'cifs_readdir':
fs/cifs/readdir.c:767:23: warning: variable 'cifs_sb' set but not used
fs/cifs/cifs_dfs_ref.c: In function 'cifs_dfs_d_automount':
fs/cifs/cifs_dfs_ref.c:342:2: warning: 'rc' may be used uninitialized in
this function [-Wuninitialized]
fs/cifs/cifs_dfs_ref.c:278:6: note: 'rc' was declared here
Reviewed-by: Pavel Shilovsky <piastry@etersoft.ru>
Reduce false inode collisions by using the CreationTime like an
i_generation field. This way, even if the server ends up reusing
a uniqueid after a delete/create cycle, we can avoid matching
the inode incorrectly.
Reduce some branches and memory accesses in dcache lookup by adding dentry
flags to indicate common d_ops are set, rather than having to check them.
This saves a pointer memory access (dentry->d_op) in common path lookup
situations, and saves another pointer load and branch in cases where we
have d_op but not the particular operation.
Patched with:
git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Change d_hash so it may be called from lock-free RCU lookups. See similar
patch for d_compare for details.
For in-tree filesystems, this is just a mechanical change.
As the FIXME points out correctly, now filldir() itself returns -EOVERFLOW if
it not possible to represent the inode number supplied by the filesystem in
the field provided by userspace.
Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de>
It's possible for initiate_cifs_search to be called on a filp that
already has private_data attached. If this happens, we'll end up
calling cifs_sb_tlink, taking an extra reference to the tlink and
attaching that to the cifsFileInfo. This leads to refcount leaks
that manifest as a "stuck" cifsd at umount time.
Fix this by only looking up the tlink for the cifsFile on the filp's
first pass through this function. When called on a filp that already
has cifsFileInfo associated with it, just use the tlink reference
that it already owns.
This patch fixes samba.org bug 7792:
https://bugzilla.samba.org/show_bug.cgi?id=7792
Reviewed-and-Tested-by: Suresh Jayaraman <sjayaraman@suse.de>
