path: root/fs/cifs/cifsencrypt.c
2011-04-12cifs: wrap received signature check in srv_mutexJeff Layton
While testing my patchset to fix asynchronous writes, I hit a bunch of signature problems when testing with signing on. The problem seems to be that signature checks on receive can be running at the same time as a process that is sending, or even that multiple receives can be checking signatures at the same time, clobbering the same data structures. While we're at it, clean up the comments over cifs_calculate_signature and add a note that the srv_mutex should be held when calling this function. This patch seems to fix the problems for me, but I'm not clear on whether it's the best approach. If it is, then this should probably go to stable too. Cc: stable@kernel.org Cc: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-04-12Allow user names longer than 32 bytesSteve French
We artificially limited the user name to 32 bytes, but modern servers handle larger. Set the maximum length to a reasonable 256, and make the user name string dynamically allocated rather than a fixed size in session structure. Also clean up old checkpatch warning. Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-31cifs: No need to check crypto blockcipher allocationShirish Pargaonkar
Missed one change as per earlier suggestion. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-27cifs: More crypto cleanup (try #2)Shirish Pargaonkar
Replaced md4 hashing function local to cifs module with kernel crypto APIs. As a result, md4 hashing function and its supporting functions in file md4.c are not needed anymore. Cleaned up function declarations, removed forward function declarations, and removed a header file that is being deleted from being included. Verified that sec=ntlm/i, sec=ntlmv2/i, and sec=ntlmssp/i work correctly. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-25[CIFS] Replace cifs md5 hashing functions with kernel crypto APIsSteve French
Replace remaining use of md5 hash functions local to cifs module with kernel crypto APIs. Remove header and source file containing those local functions. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-09cifs: remove unnecessary locking around sequence_numberJeff Layton
The server->sequence_number is already protected by the srv_mutex. The GlobalMid_lock is unneeded here. Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-29cifs: Cleanup and thus reduce smb session structure and fields used during ↵Shirish Pargaonkar
authentication Removed following fields from smb session structure cryptkey, ntlmv2_hash, tilen, tiblob and ntlmssp_auth structure is allocated dynamically only if the auth mech in NTLMSSP. response field within a session_key structure is used to initially store the target info (either plucked from type 2 challenge packet in case of NTLMSSP or fabricated in case of NTLMv2 without extended security) and then to store Message Authentication Key (mak) (session key + client response). Server challenge or cryptkey needed during a NTLMSSP authentication is now part of ntlmssp_auth structure which gets allocated and freed once authenticaiton process is done. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-29NTLM auth and sign - Use appropriate server challengeShirish Pargaonkar
Need to have cryptkey or server challenge in smb connection (struct TCP_Server_Info) for ntlm and ntlmv2 auth types for which cryptkey (Encryption Key) is supplied just once in Negotiate Protocol response during an smb connection setup for all the smb sessions over that smb connection. For ntlmssp, cryptkey or server challenge is provided for every smb session in type 2 packet of ntlmssp negotiation, the cryptkey provided during Negotiation Protocol response before smb connection does not count. Rename cryptKey to cryptkey and related changes. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-27NTLM auth and sign - minor error corrections and cleanupShirish Pargaonkar
Minor cleanup - Fix spelling mistake, make meaningful (goto) label In function setup_ntlmv2_rsp(), do not return 0 and leak memory, let the tiblob get freed. For function find_domain_name(), pass already available nls table pointer instead of loading and unloading the table again in this function. For ntlmv2, the case sensitive password length is the length of the response, so subtract session key length (16 bytes) from the .len. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-26NTLM auth and sign - Use kernel crypto apis to calculate hashes and smb ↵Shirish Pargaonkar
signatures Use kernel crypto sync hash apis insetead of cifs crypto functions. The calls typically corrospond one to one except that insead of key init, setkey is used. Use crypto apis to generate smb signagtures also. Use hmac-md5 to genereate ntlmv2 hash, ntlmv2 response, and HMAC (CR1 of ntlmv2 auth blob. User crypto apis to genereate signature and to verify signature. md5 hash is used to calculate signature. Use secondary key to calculate signature in case of ntlmssp. For ntlmv2 within ntlmssp, during signature calculation, only 16 bytes key (a nonce) stored within session key is used. during smb signature calculation. For ntlm and ntlmv2 without extended security, 16 bytes key as well as entire response (24 bytes in case of ntlm and variable length in case of ntlmv2) is used for smb signature calculation. For kerberos, there is no distinction between key and response. Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-26NTLM auth and sign - Define crypto hash functions and create and send keys ↵Shirish Pargaonkar
needed for key exchange Mark dependency on crypto modules in Kconfig. Defining per structures sdesc and cifs_secmech which are used to store crypto hash functions and contexts. They are stored per smb connection and used for all auth mechs to genereate hash values and signatures. Allocate crypto hashing functions, security descriptiors, and respective contexts when a smb/tcp connection is established. Release them when a tcp/smb connection is taken down. md5 and hmac-md5 are two crypto hashing functions that are used throught the life of an smb/tcp connection by various functions that calcualte signagure and ntlmv2 hash, HMAC etc. structure ntlmssp_auth is defined as per smb connection. ntlmssp_auth holds ciphertext which is genereated by rc4/arc4 encryption of secondary key, a nonce using ntlmv2 session key and sent in the session key field of the type 3 message sent by the client during ntlmssp negotiation/exchange A key is exchanged with the server if client indicates so in flags in type 1 messsage and server agrees in flag in type 2 message of ntlmssp negotiation. If both client and agree, a key sent by client in type 3 message of ntlmssp negotiation in the session key field. The key is a ciphertext generated off of secondary key, a nonce, using ntlmv2 hash via rc4/arc4. Signing works for ntlmssp in this patch. The sequence number within the server structure needs to be zero until session is established i.e. till type 3 packet of ntlmssp exchange of a to be very first smb session on that smb connection is sent. Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-26NTLM auth and sign - Allocate session key/client response dynamicallyShirish Pargaonkar
Start calculating auth response within a session. Move/Add pertinet data structures like session key, server challenge and ntlmv2_hash in a session structure. We should do the calculations within a session before copying session key and response over to server data structures because a session setup can fail. Only after a very first smb session succeeds, it copy/make its session key, session key of smb connection. This key stays with the smb connection throughout its life. sequence_number within server is set to 0x2. The authentication Message Authentication Key (mak) which consists of session key followed by client response within structure session_key is now dynamic. Every authentication type allocates the key + response sized memory within its session structure and later either assigns or frees it once the client response is sent and if session's session key becomes connetion's session key. ntlm/ntlmi authentication functions are rearranged. A function named setup_ntlm_resp(), similar to setup_ntlmv2_resp(), replaces function cifs_calculate_session_key(). size of CIFS_SESS_KEY_SIZE is changed to 16, to reflect the byte size of the key it holds. Reviewed-by: Jeff Layton <jlayton@samba.org> Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-14NTLM authentication and signing - Calculate auth response per smb sessionShirish Pargaonkar
Start calculation auth response within a session. Move/Add pertinet data structures like session key, server challenge and ntlmv2_hash in a session structure. We should do the calculations within a session before copying session key and response over to server data structures because a session setup can fail. Only after a very first smb session succeeds, it copies/makes its session key, session key of smb connection. This key stays with the smb connection throughout its life. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-12CIFS ntlm authentication and signing - Build a proper av/ti pair blob for ↵Shirish Pargaonkar
ntlmv2 without extended security authentication Build an av pair blob as part of ntlmv2 (without extended security) auth request. Include netbios and dns names for domain and server and a timestamp in the blob. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@samba.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-08cifs: fix module refcount leak in find_domain_nameJeff Layton
find_domain_name() uses load_nls_default which takes a module reference on the appropriate NLS module, but doesn't put it. Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-29cifs NTLMv2/NTLMSSP ntlmv2 within ntlmssp autentication codeShirish Pargaonkar
Attribue Value (AV) pairs or Target Info (TI) pairs are part of ntlmv2 authentication. Structure ntlmv2_resp had only definition for two av pairs. So removed it, and now allocation of av pairs is dynamic. For servers like Windows 7/2008, av pairs sent by server in challege packet (type 2 in the ntlmssp exchange/negotiation) can vary. Server sends them during ntlmssp negotiation. So when ntlmssp is used as an authentication mechanism, type 2 challenge packet from server has this information. Pluck it and use the entire blob for authenticaiton purpose. If user has not specified, extract (netbios) domain name from the av pairs which is used to calculate ntlmv2 hash. Servers like Windows 7 are particular about the AV pair blob. Servers like Windows 2003, are not very strict about the contents of av pair blob used during ntlmv2 authentication. So when security mechanism such as ntlmv2 is used (not ntlmv2 in ntlmssp), there is no negotiation and so genereate a minimal blob that gets used in ntlmv2 authentication as well as gets sent. Fields tilen and tilbob are session specific. AV pair values are defined. To calculate ntlmv2 response we need ti/av pair blob. For sec mech like ntlmssp, the blob is plucked from type 2 response from the server. From this blob, netbios name of the domain is retrieved, if user has not already provided, to be included in the Target String as part of ntlmv2 hash calculations. For sec mech like ntlmv2, create a minimal, two av pair blob. The allocated blob is freed in case of error. In case there is no error, this blob is used in calculating ntlmv2 response (in CalcNTLMv2_response) and is also copied on the response to the server, and then freed. The type 3 ntlmssp response is prepared on a buffer, 5 * sizeof of struct _AUTHENTICATE_MESSAGE, an empirical value large enough to hold _AUTHENTICATE_MESSAGE plus a blob with max possible 10 values as part of ntlmv2 response and lmv2 keys and domain, user, workstation names etc. Also, kerberos gets selected as a default mechanism if server supports it, over the other security mechanisms. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-29cifs NTLMv2/NTLMSSP Change variable name mac_key to session key to reflect ↵Shirish Pargaonkar
the key it holds Change name of variable mac_key to session key. The reason mac_key was changed to session key is, this structure does not hold message authentication code, it holds the session key (for ntlmv2, ntlmv1 etc.). mac is generated as a signature in cifs_calc* functions. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-08[CIFS] ntlmv2/ntlmssp remove-unused-function CalcNTLMv2_partial_mac_keySteve French
This function is not used, so remove the definition and declaration. Reviewed-by: Jeff Layton <jlayton@samba.org> Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-08Revert "[CIFS] Fix ntlmv2 auth with ntlmssp"Steve French
This reverts commit 9fbc590860e75785bdaf8b83e48fabfe4d4f7d58. The change to kernel crypto and fixes to ntlvm2 and ntlmssp series, introduced a regression. Deferring this patch series to 2.6.37 after Shirish fixes it. Signed-off-by: Steve French <sfrench@us.ibm.com> Acked-by: Jeff Layton <jlayton@redhat.com> CC: Shirish Pargaonkar <shirishp@us.ibm.com>
2010-09-08Revert "missing changes during ntlmv2/ntlmssp auth and sign"Steve French
This reverts commit 3ec6bbcdb4e85403f2c5958876ca9492afdf4031. The change to kernel crypto and fixes to ntlvm2 and ntlmssp series, introduced a regression. Deferring this patch series to 2.6.37 after Shirish fixes it. Signed-off-by: Steve French <sfrench@us.ibm.com> Acked-by: Jeff Layton <jlayton@redhat.com> CC: Shirish Pargaonkar <shirishp@us.ibm.com>
2010-09-08Revert "Eliminate sparse warning - bad constant expression"Steve French
This reverts commit 2d20ca835867d93ead6ce61780d883a4b128106d. The change to kernel crypto and fixes to ntlvm2 and ntlmssp series, introduced a regression. Deferring this patch series to 2.6.37 after Shirish fixes it. Signed-off-by: Steve French <sfrench@us.ibm.com> Acked-by: Jeff Layton <jlayton@redhat.com> CC: Shirish Pargaonkar <shirishp@us.ibm.com>
2010-08-24Eliminate sparse warning - bad constant expressionshirishpargaonkar@gmail.com
Eliminiate sparse warning during usage of crypto_shash_* APIs error: bad constant expression Allocate memory for shash descriptors once, so that we do not kmalloc/kfree it for every signature generation (shash descriptor for md5 hash). From ed7538619817777decc44b5660b52268077b74f3 Mon Sep 17 00:00:00 2001 From: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Date: Tue, 24 Aug 2010 11:47:43 -0500 Subject: [PATCH] eliminate sparse warnings during crypto_shash_* APis usage Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-23missing changes during ntlmv2/ntlmssp auth and signShirish Pargaonkar
2010-08-20[CIFS] Fix ntlmv2 auth with ntlmsspSteve French
Make ntlmv2 as an authentication mechanism within ntlmssp instead of ntlmv1. Parse type 2 response in ntlmssp negotiation to pluck AV pairs and use them to calculate ntlmv2 response token. Also, assign domain name from the sever response in type 2 packet of ntlmssp and use that (netbios) domain name in calculation of response. Enable cifs/smb signing using rc4 and md5. Changed name of the structure mac_key to session_key to reflect the type of key it holds. Use kernel crypto_shash_* APIs instead of the equivalent cifs functions. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-04-26cifs: rename "extended_security" to "global_secflags"Jeff Layton
...since that more accurately describes what that variable holds. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-04-21[CIFS] Neaten cERROR and cFYI macros, reduce text spaceJoe Perches
Neaten cERROR and cFYI macros, reduce text space ~2.5K Convert '__FILE__ ": " fmt' to '"%s: " fmt', __FILE__' to save text space Surround macros with do {} while Add parentheses to macros Make statement expression macro from macro with assign Remove now unnecessary parentheses from cFYI and cERROR uses defconfig with CIFS support old $ size fs/cifs/built-in.o text data bss dec hex filename 156012 1760 148 157920 268e0 fs/cifs/built-in.o defconfig with CIFS support old $ size fs/cifs/built-in.o text data bss dec hex filename 153508 1760 148 155416 25f18 fs/cifs/built-in.o allyesconfig old: $ size fs/cifs/built-in.o text data bss dec hex filename 309138 3864 74824 387826 5eaf2 fs/cifs/built-in.o allyesconfig new $ size fs/cifs/built-in.o text data bss dec hex filename 305655 3864 74824 384343 5dd57 fs/cifs/built-in.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-01[CIFS] Memory leak in ntlmv2 hash calculationAlexander Strakh
in function calc_ntlmv2_hash memory is not released. 1. If in the line 333 we successfully allocate memory and assign it to pctxt variable: pctxt = kmalloc(sizeof(struct HMACMD5Context), GFP_KERNEL); then we go to line 376 and exit wihout releasing memory pointed to by pctxt variable. Add a memory releasing for pctxt variable before exit from function calc_ntlmv2_hash. Signed-off-by: Alexander Strakh <strakh@ispras.ru> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-01-29[CIFS] Rename md5 functions to avoid collision with new rt modulesSteve French
When rt modules were added they (each) included their own md5 with names which collided with the existing names of cifs's md5 functions. Renaming cifs's md5 modules so we don't collide with them. > Stephen Rothwell wrote: > When CIFS is built-in (=y) and staging/rt28[67]0 =y, there are multiple > definitions of: > > build-r8250.out:(.text+0x1d8ad0): multiple definition of `MD5Init' > build-r8250.out:(.text+0x1dbb30): multiple definition of `MD5Update' > build-r8250.out:(.text+0x1db9b0): multiple definition of `MD5Final' > > all of which need to have more unique identifiers for their global > symbols (e.g., rt28_md5_init, cifs_md5_init, foo, blah, bar). > CC: Greg K-H <gregkh@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-12-26cifs: have calc_lanman_hash take more granular argsJeff Layton
cifs: have calc_lanman_hash take more granular args We need to use this routine to encrypt passwords associated with the tcon too. Don't assume that the password will be attached to the smb_session. Also, make some of the values in the lower encryption functions const since they aren't changed. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-08-27[CIFS] Fix plaintext authenticationSteve French
The last eight bytes of the password field were not cleared when doing lanman plaintext password authentication. This patch fixes that. I tested it with Samba by setting password encryption to no in the server's smb.conf. Other servers also can be configured to force plaintext authentication. Note that plaintexti authentication requires setting /proc/fs/cifs/SecurityFlags to 0x30030 on the client (enabling both LANMAN and also plaintext password support). Also note that LANMAN support (and thus plaintext password support) requires CONFIG_CIFS_WEAK_PW_HASH to be enabled in menuconfig. CC: Jeff Layton <jlayton@redhat.com> CC: Stable Kernel <stable@vger.kernel.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-07-24[CIFS] Fix warnings from checkpatchShirish Pargaonkar
2007-11-05[CIFS] Fix walking out end of cifs daclSteve French
Acked-by: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-11-03[CIFS] allow cifs_calc_signature2 to deal with a zero length iovecJeff Layton
Currently, cifs_calc_signature2 errors out if it gets a zero-length iovec. Fix it to silently continue in that case. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-10-14[CIFS] Fix endian conversion problem in posix mkdirCyril Gorcunov
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-07-17[CIFS] More whitespace/formatting fixes (noticed by checkpatch)Steve French
2007-07-13[CIFS] whitespace/formatting fixesSteve French
This should be the last big batch of whitespace/formatting fixes. checkpatch warnings for the cifs directory are down about 90% and many of the remaining ones are harder to remove or make the code harder to read. Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-07-09[CIFS] Fix packet signatures for NTLMv2 caseSteve French
Signed-off-by: Yehuda Sadeh Weinraub <Yehuda.Sadeh@expand.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-06-24[CIFS] fix whitespaceSteve French
More whitespace problems found by checkpatch Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-12-08[CIFS] Fix NTLMv2 mounts to Windows serversSteve French
Windows servers are pickier about NTLMv2 than Samba. This enables more secure mounts to Windows (not just Samba) ie when "sec=ntlmv2" is specified on the mount. Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-08-11[CIFS] Fix oops when negotiating lanman and no password specifiedSteve French
Pointed out by Guenter Kukkukk Signed-of-by: Steve French <sfrench@us.ibm.com> (cherry picked from bbf33d512da608c7221fec42b56b9ef89c25a5ee commit)
2006-06-08[CIFS] NTLMv2 support part 5Steve French
NTLMv2 authentication (stronger authentication than default NTLM) which many servers support now works. There was a problem with the construction of the security blob in the older code. Currently requires /proc/fs/cifs/Experimental to be set to 2 and /proc/fs/cifs/SecurityFlags to be set to 0x4004 (to require using NTLMv2 instead of default of NTLM) Next we will check signing to make sure optional NTLMv2 packet signing also works. Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-06-05[CIFS] NTLMv2 support part 4Steve French
2006-06-05[CIFS] NTLMv2 support part 3Steve French
Response struct filled in exacty for 16 byte hash which we need to check more to make sure it works. Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-06-05[CIFS] NTLMv2 support part 2Steve French
Still need to fill in response structure and check that hash works Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-06-02[CIFS] Support for older servers which require plaintext passwordsSteve French
disabled by default, but can be enabled via proc for servers which require such support. Also includes support for setting security flags for cifs. See fs/cifs/README Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-06-01[CIFS] Support for setting up SMB sessions to legacy lanman servers part 2Steve French
2006-05-31[CIFS] Support for setting up SMB sessions to legacy lanman serversSteve French
2006-03-31[CIFS] Incorrect signature sent on SMB ReadSteve French
Fixes Samba bug 3621 and kernel.org bug 6147 For servers which require SMB/CIFS packet signing, we were sending the wrong signature (all zeros) on SMB Read request. The new cifs routine to do signatures across an iovec was not complete - and SMB Read, unlike the new SMBWrite2, did not fall back to the older routine (ie use SendReceive vs. the more efficient SendReceive2 ie used the older cifs_sign_smb vs. the disabled cifs_sign_smb2) for calculating signatures. This finishes up cifs_sign_smb2/cifs_calc_signature2 so that the callers of SendReceive2 can get SMB/CIFS packet signatures. Now that cifs_sign_smb2 is supported, we could start using it in the write path but this smaller fix does not include the change to use SMBWrite2 when signatures are required (which when enabled will make more Writes more efficient and alloc less memory). Currently Write2 is only used when signatures are not required at the moment but after more testing we will enable that as well). Thanks to James Slepicka and Sam Flory for initial investigation. Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-02-14[CIFS] SessionSetup cleanup part 2Steve French
The cifs session setup code has three cases, and a fourth for backlevel LANMAN2 style session setup needed to be added. This new session setup implmentation will eventually replace the other three and should be easier to read while fixing a few minor problems (not setting the LARGE READ/WRITEX flags when NTLMSSP was negotiated for example) and adding support for NTLMv2 (which will be added with the next patch. In the meantime, this code is marked in an CONFIG_CIFS_EXPERIMENTAL block and will not be turned on by default until it is tested against more server types. Signed-off-by: Steve French <sfrench@us.ibm.com>
