path: root/fs/btrfs/super.c
2011-02-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: fix fiemap bugs with delalloc Btrfs: set FMODE_EXCL in btrfs_device->mode Btrfs: make btrfs_rm_device() fail gracefully Btrfs: Avoid accessing unmapped kernel address Btrfs: Fix BTRFS_IOC_SUBVOL_SETFLAGS ioctl Btrfs: allow balance to explicitly allocate chunks as it relocates Btrfs: put ENOSPC debugging under a mount option
2011-02-16Btrfs: put ENOSPC debugging under a mount optionChris Mason
ENOSPC in btrfs is getting to the point where the extra debugging isn't required. I've put it under mount -o enospc_debug just in case someone is having difficult problems. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-02-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (33 commits) Btrfs: Fix page count calculation btrfs: Drop __exit attribute on btrfs_exit_compress btrfs: cleanup error handling in btrfs_unlink_inode() Btrfs: exclude super blocks when we read in block groups Btrfs: make sure search_bitmap finds something in remove_from_bitmap btrfs: fix return value check of btrfs_start_transaction() btrfs: checking NULL or not in some functions Btrfs: avoid uninit variable warnings in ordered-data.c Btrfs: catch errors from btrfs_sync_log Btrfs: make shrink_delalloc a little friendlier Btrfs: handle no memory properly in prepare_pages Btrfs: do error checking in btrfs_del_csums Btrfs: use the global block reserve if we cannot reserve space Btrfs: do not release more reserved bytes to the global_block_rsv than we need Btrfs: fix check_path_shared so it returns the right value btrfs: check return value of btrfs_start_ioctl_transaction() properly btrfs: fix return value check of btrfs_join_transaction() fs/btrfs/inode.c: Add missing IS_ERR test btrfs: fix missing break in switch phrase btrfs: fix several uncheck memory allocations ...
2011-02-01btrfs: fix return value check of btrfs_start_transaction()Tsutomu Itoh
The error check of btrfs_start_transaction() is added, and the mistake of the error check on several places is corrected. Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-01-28Merge branch 'bug-fixes' of git://repo.or.cz/linux-btrfs-devel into btrfs-38Chris Mason
2011-01-27Btrfs: Free correct pointer after using strsepTero Roponen
We must save and free the original kstrdup()'ed pointer because strsep() modifies its first argument. Signed-off-by: Tero Roponen <tero.roponen@gmail.com> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
2011-01-27Btrfs: Fix memory leak on finding existing superIan Kent
We missed a memory deallocation in commit 450ba0ea. If an existing super block is found at mount and there is no error condition then the pre-allocated tree_root and fs_info are no not used and are not freeded. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
2011-01-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (25 commits) Btrfs: forced readonly mounts on errors btrfs: Require CAP_SYS_ADMIN for filesystem rebalance Btrfs: don't warn if we get ENOSPC in btrfs_block_rsv_check btrfs: Fix memory leak in btrfs_read_fs_root_no_radix() btrfs: check NULL or not btrfs: Don't pass NULL ptr to func that may deref it. btrfs: mount failure return value fix btrfs: Mem leak in btrfs_get_acl() btrfs: fix wrong free space information of btrfs btrfs: make the chunk allocator utilize the devices better btrfs: restructure find_free_dev_extent() btrfs: fix wrong calculation of stripe size btrfs: try to reclaim some space when chunk allocation fails btrfs: fix wrong data space statistics fs/btrfs: Fix build of ctree Btrfs: fix off by one while setting block groups readonly Btrfs: Add BTRFS_IOC_SUBVOL_GETFLAGS/SETFLAGS ioctls Btrfs: Add readonly snapshots support Btrfs: Refactor btrfs_ioctl_snap_create() btrfs: Extract duplicate decompress code ...
2011-01-17Btrfs: forced readonly mounts on errorsliubo
This patch comes from "Forced readonly mounts on errors" ideas. As we know, this is the first step in being more fault tolerant of disk corruptions instead of just using BUG() statements. The major content: - add a framework for generating errors that should result in filesystems going readonly. - keep FS state in disk super block. - make sure that all of resource will be freed and released at umount time. - make sure that fter FS is forced readonly on error, there will be no more disk change before FS is corrected. For this, we should stop write operation. After this patch is applied, the conversion from BUG() to such a framework can happen incrementally. Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-01-16btrfs: fix wrong free space information of btrfsMiao Xie
When we store data by raid profile in btrfs with two or more different size disks, df command shows there is some free space in the filesystem, but the user can not write any data in fact, df command shows the wrong free space information of btrfs. # mkfs.btrfs -d raid1 /dev/sda9 /dev/sda10 # btrfs-show Label: none uuid: a95cd49e-6e33-45b8-8741-a36153ce4b64 Total devices 2 FS bytes used 28.00KB devid 1 size 5.01GB used 2.03GB path /dev/sda9 devid 2 size 10.00GB used 2.01GB path /dev/sda10 # btrfs device scan /dev/sda9 /dev/sda10 # mount /dev/sda9 /mnt # dd if=/dev/zero of=tmpfile0 bs=4K count=9999999999 (fill the filesystem) # sync # df -TH Filesystem Type Size Used Avail Use% Mounted on /dev/sda9 btrfs 17G 8.6G 5.4G 62% /mnt # btrfs-show Label: none uuid: a95cd49e-6e33-45b8-8741-a36153ce4b64 Total devices 2 FS bytes used 3.99GB devid 1 size 5.01GB used 5.01GB path /dev/sda9 devid 2 size 10.00GB used 4.99GB path /dev/sda10 It is because btrfs cannot allocate chunks when one of the pairing disks has no space, the free space on the other disks can not be used for ever, and should be subtracted from the total space, but btrfs doesn't subtract this space from the total. It is strange to the user. This patch fixes it by calcing the free space that can be used to allocate chunks. Implementation: 1. get all the devices free space, and align them by stripe length. 2. sort the devices by the free space. 3. check the free space of the devices, 3.1. if it is not zero, and then check the number of the devices that has more free space than this device, if the number of the devices is beyond the min stripe number, the free space can be used, and add into total free space. if the number of the devices is below the min stripe number, we can not use the free space, the check ends. 3.2. if the free space is zero, check the next devices, goto 3.1 This implementation is just likely fake chunk allocation. After appling this patch, df can show correct space information: # df -TH Filesystem Type Size Used Avail Use% Mounted on /dev/sda9 btrfs 17G 8.6G 0 100% /mnt Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-01-16btrfs: fix wrong data space statisticsMiao Xie
Josef has implemented mixed data/metadata chunks, we must add those chunks' space just like data chunks. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Reviewed-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-01-12switch btrfs, close racesAl Viro
2010-12-22btrfs: Add lzo compression supportLi Zefan
Lzo is a much faster compression algorithm than gzib, so would allow more users to enable transparent compression, and some users can choose from compression ratio and speed for different applications Usage: # mount -t btrfs -o compress[=<zlib,lzo>] dev /mnt or # mount -t btrfs -o compress-force[=<zlib,lzo>] dev /mnt "-o compress" without argument is still allowed for compatability. Compatibility: If we mount a filesystem with lzo compression, it will not be able be mounted in old kernels. One reason is, otherwise btrfs will directly dump compressed data, which sits in inline extent, to user. Performance: The test copied a linux source tarball (~400M) from an ext4 partition to the btrfs partition, and then extracted it. (time in second) lzo zlib nocompress copy: 10.6 21.7 14.9 extract: 70.1 94.4 66.6 (data size in MB) lzo zlib nocompress copy: 185.87 108.69 394.49 extract: 193.80 132.36 381.21 Changelog: v1 -> v2: - Select LZO_COMPRESS and LZO_DECOMPRESS in btrfs Kconfig. - Add incompability flag. - Fix error handling in compress code. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
2010-12-22btrfs: Allow to add new compression algorithmLi Zefan
Make the code aware of compression type, instead of always assuming zlib compression. Also make the zlib workspace function as common code for all compression types. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
2010-12-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: prevent RAID level downgrades when space is low Btrfs: account for missing devices in RAID allocation profiles Btrfs: EIO when we fail to read tree roots Btrfs: fix compiler warnings Btrfs: Make async snapshot ioctl more generic Btrfs: pwrite blocked when writing from the mmaped buffer of the same page Btrfs: Fix a crash when mounting a subvolume Btrfs: fix sync subvol/snapshot creation Btrfs: Fix page leak in compressed writeback path Btrfs: do not BUG if we fail to remove the orphan item for dead snapshots Btrfs: fixup return code for btrfs_del_orphan_item Btrfs: do not do fast caching if we are allocating blocks for tree_root Btrfs: deal with space cache errors better Btrfs: fix use after free in O_DIRECT
2010-12-10Btrfs: Fix a crash when mounting a subvolumeLi Zefan
We should drop dentry before deactivating the superblock, otherwise we can hit this bug: BUG: Dentry f349a690{i=100,n=/} still in use (1) [unmount of btrfs loop1] ... Steps to reproduce the bug: # mount /dev/loop1 /mnt # mkdir save # btrfs subvolume snapshot /mnt save/snap1 # umount /mnt # mount -o subvol=save/snap1 /dev/loop1 /mnt (crash) Reported-by: Michael Niederle <mniederle@gmx.at> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-11-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (24 commits) Btrfs: don't use migrate page without CONFIG_MIGRATION Btrfs: deal with DIO bios that span more than one ordered extent Btrfs: setup blank root and fs_info for mount time Btrfs: fix fiemap Btrfs - fix race between btrfs_get_sb() and umount Btrfs: update inode ctime when using links Btrfs: make sure new inode size is ok in fallocate Btrfs: fix typo in fallocate to make it honor actual size Btrfs: avoid NULL pointer deref in try_release_extent_buffer Btrfs: make btrfs_add_nondir take parent inode as an argument Btrfs: hold i_mutex when calling btrfs_log_dentry_safe Btrfs: use dget_parent where we can UPDATED Btrfs: fix more ESTALE problems with NFS Btrfs: handle NFS lookups properly btrfs: make 1-bit signed fileds unsigned btrfs: Show device attr correctly for symlinks btrfs: Set file size correctly in file clone btrfs: Check if dest_offset is block-size aligned before cloning file Btrfs: handle the space_cache option properly btrfs: Fix early enospc because 'unused' calculated with wrong sign. ...
2010-11-27Btrfs: setup blank root and fs_info for mount timeJosef Bacik
There is a problem with how we use sget, it searches through the list of supers attached to the fs_type looking for a super with the same fs_devices as what we're trying to mount. This depends on sb->s_fs_info being filled, but we don't fill that in until we get to btrfs_fill_super, so we could hit supers on the fs_type super list that have a null s_fs_info. In order to fix that we need to go ahead and setup a blank root with a blank fs_info to hold fs_devices, that way our test will work out right and then we can set s_fs_info in btrfs_set_super, and then open_ctree will simply use our pre-allocated root and fs_info when setting everything up. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-11-27Btrfs - fix race between btrfs_get_sb() and umountIan Kent
When mounting a btrfs file system btrfs_test_super() may attempt to use sb->s_fs_info, the btrfs root, of a super block that is going away and that has had the btrfs root set to NULL in its ->put_super(). But if the super block is going away it cannot be an existing super block so we can return false in this case. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-11-21Btrfs: handle the space_cache option properlyJosef Bacik
When I added the clear_cache option I screwed up and took the break out of the space_cache case statement, so whenever you mount with space_cache you also get clear_cache, which does you no good if you say set space_cache in fstab so it always gets set. This patch adds the break back in properly. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-10-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (39 commits) Btrfs: deal with errors from updating the tree log Btrfs: allow subvol deletion by unprivileged user with -o user_subvol_rm_allowed Btrfs: make SNAP_DESTROY async Btrfs: add SNAP_CREATE_ASYNC ioctl Btrfs: add START_SYNC, WAIT_SYNC ioctls Btrfs: async transaction commit Btrfs: fix deadlock in btrfs_commit_transaction Btrfs: fix lockdep warning on clone ioctl Btrfs: fix clone ioctl where range is adjacent to extent Btrfs: fix delalloc checks in clone ioctl Btrfs: drop unused variable in block_alloc_rsv Btrfs: cleanup warnings from gcc 4.6 (nonbugs) Btrfs: Fix variables set but not read (bugs found by gcc 4.6) Btrfs: Use ERR_CAST helpers Btrfs: use memdup_user helpers Btrfs: fix raid code for removing missing drives Btrfs: Switch the extent buffer rbtree into a radix tree Btrfs: restructure try_release_extent_buffer() Btrfs: use the flusher threads for delalloc throttling Btrfs: tune the chunk allocation to 5% of the FS as metadata ... Fix up trivial conflicts in fs/btrfs/super.c and fs/fs-writeback.c, and remove use of INIT_RCU_HEAD in fs/btrfs/extent_io.c (that init macro was useless and removed in commit 5e8067adfdba: "rcu head remove init")
2010-10-29Btrfs: allow subvol deletion by unprivileged user with -o user_subvol_rm_allowedSage Weil
Add a mount option user_subvol_rm_allowed that allows users to delete a (potentially non-empty!) subvol when they would otherwise we allowed to do an rmdir(2). We duplicate the may_delete() checks from the core VFS code to implement identical security checks (minus the directory size check). We additionally require that the user has write+exec permission on the subvol root inode. Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-10-29Btrfs: cleanup warnings from gcc 4.6 (nonbugs)Andi Kleen
These are all the cases where a variable is set, but not read which are not bugs as far as I can see, but simply leftovers. Still needs more review. Found by gcc 4.6's new warnings Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-10-29Btrfs: Use ERR_CAST helpersJulia Lawall
Use ERR_CAST(x) rather than ERR_PTR(PTR_ERR(x)). The former makes more clear what is the purpose of the operation, which otherwise looks like a no-op. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ type T; T x; identifier f; @@ T f (...) { <+... - ERR_PTR(PTR_ERR(x)) + x ...+> } @@ expression x; @@ - ERR_PTR(PTR_ERR(x)) + ERR_CAST(x) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-10-29Merge branch 'bug-fixes' of ↵Chris Mason
git://git.kernel.org/pub/scm/linux/kernel/git/josef/btrfs-work Conflicts: fs/btrfs/extent-tree.c Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-10-29Btrfs: Add a clear_cache mount optionJosef Bacik
If something goes wrong with the free space cache we need a way to make sure it's not loaded on mount and that it's cleared for everybody. When you pass the clear_cache option it will make it so all block groups are setup to be cleared, which keeps them from being loaded and then they will be truncated when the transaction is committed. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2010-10-29convert btrfsAl Viro
2010-10-28Btrfs: create special free space cache inodeJosef Bacik
In order to save free space cache, we need an inode to hold the data, and we need a special item to point at the right inode for the right block group. So first, create a special item that will point to the right inode, and the number of extent entries we will have and the number of bitmaps we will have. We truncate and pre-allocate space everytime to make sure it's uptodate. This feature will be turned on as soon as you mount with -o space_cache, however it is safe to boot into old kernels, they will just generate the cache the old fashion way. When you boot back into a newer kernel we will notice that we modified and not the cache and automatically discard the cache. Signed-off-by: Josef Bacik <josef@redhat.com>
2010-10-22Btrfs: fix error handling in btrfs_get_sbJosef Bacik
If we failed to find the root subvol id, or the subvol=<name>, we would deactivate the locked super and close the devices. The problem is at this point we have gotten the SB all setup, which includes setting super_operations, so when we'd deactiveate the super, we'd do a close_ctree() which closes the devices, so we'd end up closing the devices twice. So if you do something like this mount /dev/sda1 /mnt/test1 mount /dev/sda1 /mnt/test2 -o subvol=xxx umount /mnt/test1 it would blow up (if subvol xxx doesn't exist). This patch fixes that problem. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2010-10-22Btrfs: fix df regressionJosef Bacik
The new ENOSPC stuff breaks out the raid types which breaks the way we were reporting df to the system. This fixes it back so that Available is the total space available to data and used is the actual bytes used by the filesystem. This means that Available is Total - data used - all of the metadata space. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-09convert btrfs to ->evict_inode()Al Viro
NB: do we want btrfs_wait_ordered_range() on eviction of inodes with positive i_nlink on subvolume with zero root_refs? If not, btrfs_evict_inode() can be simplified by unconditionally bailing out in case of i_nlink > 0 in the very beginning... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-06-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: The file argument for fsync() is never null Btrfs: handle ERR_PTR from posix_acl_from_xattr() Btrfs: avoid BUG when dropping root and reference in same transaction Btrfs: prohibit a operation of changing acl's mask when noacl mount option used Btrfs: should add a permission check for setfacl Btrfs: btrfs_lookup_dir_item() can return ERR_PTR Btrfs: btrfs_read_fs_root_no_name() returns ERR_PTRs Btrfs: unwind after btrfs_start_transaction() errors Btrfs: btrfs_iget() returns ERR_PTR Btrfs: handle kzalloc() failure in open_ctree() Btrfs: handle error returns from btrfs_lookup_dir_item() Btrfs: Fix BUG_ON for fs converted from extN Btrfs: Fix null dereference in relocation.c Btrfs: fix remap_file_pages error Btrfs: uninitialized data is check_path_shared() Btrfs: fix fallocate regression Btrfs: fix loop device on top of btrfs
2010-06-11Btrfs: btrfs_iget() returns ERR_PTRDan Carpenter
btrfs_iget() returns an ERR_PTR() on failure and not null. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-06-11Btrfs: handle error returns from btrfs_lookup_dir_item()Dan Carpenter
If btrfs_lookup_dir_item() fails, we should can just let the mount fail with an error. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-05-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (27 commits) Btrfs: add more error checking to btrfs_dirty_inode Btrfs: allow unaligned DIO Btrfs: drop verbose enospc printk Btrfs: Fix block generation verification race Btrfs: fix preallocation and nodatacow checks in O_DIRECT Btrfs: avoid ENOSPC errors in btrfs_dirty_inode Btrfs: move O_DIRECT space reservation to btrfs_direct_IO Btrfs: rework O_DIRECT enospc handling Btrfs: use async helpers for DIO write checksumming Btrfs: don't walk around with task->state != TASK_RUNNING Btrfs: do aio_write instead of write Btrfs: add basic DIO read/write support direct-io: do not merge logically non-contiguous requests direct-io: add a hook for the fs to provide its own submit_bio function fs: allow short direct-io reads to be completed via buffered IO Btrfs: Metadata ENOSPC handling for balance Btrfs: Pre-allocate space for data relocation Btrfs: Metadata ENOSPC handling for tree log Btrfs: Metadata reservation for orphan inodes Btrfs: Introduce global metadata reservation ...
2010-05-25driver core: add devname module aliases to allow module on-demand auto-loadingKay Sievers
This adds: alias: devname:<name> to some common kernel modules, which will allow the on-demand loading of the kernel module when the device node is accessed. Ideally all these modules would be compiled-in, but distros seems too much in love with their modularization that we need to cover the common cases with this new facility. It will allow us to remove a bunch of pretty useless init scripts and modprobes from init scripts. The static device node aliases will be carried in the module itself. The program depmod will extract this information to a file in the module directory: $ cat /lib/modules/2.6.34-00650-g537b60d-dirty/modules.devname # Device nodes to trigger on-demand module loading. microcode cpu/microcode c10:184 fuse fuse c10:229 ppp_generic ppp c108:0 tun net/tun c10:200 dm_mod mapper/control c10:235 Udev will pick up the depmod created file on startup and create all the static device nodes which the kernel modules specify, so that these modules get automatically loaded when the device node is accessed: $ /sbin/udevd --debug ... static_dev_create_from_modules: mknod '/dev/cpu/microcode' c10:184 static_dev_create_from_modules: mknod '/dev/fuse' c10:229 static_dev_create_from_modules: mknod '/dev/ppp' c108:0 static_dev_create_from_modules: mknod '/dev/net/tun' c10:200 static_dev_create_from_modules: mknod '/dev/mapper/control' c10:235 udev_rules_apply_static_dev_perms: chmod '/dev/net/tun' 0666 udev_rules_apply_static_dev_perms: chmod '/dev/fuse' 0666 A few device nodes are switched to statically allocated numbers, to allow the static nodes to work. This might also useful for systems which still run a plain static /dev, which is completely unsafe to use with any dynamic minor numbers. Note: The devname aliases must be limited to the *common* and *single*instance* device nodes, like the misc devices, and never be used for conceptually limited systems like the loop devices, which should rather get fixed properly and get a control node for losetup to talk to, instead of creating a random number of device nodes in advance, regardless if they are ever used. This facility is to hide the mess distros are creating with too modualized kernels, and just to hide that these modules are not compiled-in, and not to paper-over broken concepts. Thanks! :) Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: David S. Miller <davem@davemloft.net> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: Chris Mason <chris.mason@oracle.com> Cc: Alasdair G Kergon <agk@redhat.com> Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Cc: Ian Kent <raven@themaw.net> Signed-Off-By: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-25Btrfs: Metadata reservation for orphan inodesYan, Zheng
reserve metadata space for handling orphan inodes Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-05-25Btrfs: Integrate metadata reservation with start_transactionYan, Zheng
Besides simplify the code, this change makes sure all metadata reservation for normal metadata operations are released after committing transaction. Changes since V1: Add code that check if unlink and rmdir will free space. Add ENOSPC handling for clone ioctl. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-05-25Btrfs: Link block groups of different raid typesYan, Zheng
The size of reserved space is stored in space_info. If block groups of different raid types are linked to separate space_info, changing allocation profile will corrupt reserved space accounting. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-04-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: add check for changed leaves in setup_leaf_for_split Btrfs: create snapshot references in same commit as snapshot Btrfs: fix small race with delalloc flushing waitqueue's Btrfs: use add_to_page_cache_lru, use __page_cache_alloc Btrfs: fix chunk allocate size calculation Btrfs: kill max_extent mount option Btrfs: fail to mount if we have problems reading the block groups Btrfs: check btrfs_get_extent return for IS_ERR() Btrfs: handle kmalloc() failure in inode lookup ioctl Btrfs: dereferencing freed memory Btrfs: Simplify num_stripes's calculation logical for __btrfs_alloc_chunk() Btrfs: Add error handle for btrfs_search_slot() in btrfs_read_chunk_tree() Btrfs: Remove unnecessary finish_wait() in wait_current_trans() Btrfs: add NULL check for do_walk_down() Btrfs: remove duplicate include in ioctl.c Fix trivial conflict in fs/btrfs/compression.c due to slab.h include cleanups.
2010-03-30Btrfs: kill max_extent mount optionJosef Bacik
As Yan pointed out, theres not much reason for all this complicated math to account for file extents being split up into max_extent chunks, since they are likely to all end up in the same leaf anyway. Since there isn't much reason to use max_extent, just remove the option altogether so we have one less thing we need to test. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-15btrfs: use memparseAkinobu Mita
Use memparse() instead of its own private implementation. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: linux-btrfs@vger.kernel.org Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: make df be a little bit more understandableJosef Bacik
The way we report df usage is way confusing for everybody, including some other utilities (bacula for one). So this patch makes df a little bit more understandable. First we make used actually count the total amount of used space in all space info's. This will give us a real view of how much disk space is in use. Second, for blocks available, only count data space. This makes things like bacula work because it says 0 when you can no longer write anymore data to the disk. I think this is a nice compromise, since you will end up with something like the following [root@alpha ~]# df -h Filesystem Size Used Avail Use% Mounted on /dev/mapper/VolGroup-lv_root 148G 30G 111G 21% / /dev/sda1 194M 116M 68M 64% /boot tmpfs 985M 12K 985M 1% /dev/shm /dev/mapper/VolGroup-LogVol02 145G 140G 0 100% /mnt/btrfs-test Compare this with btrfsctl -i output [root@alpha btrfs-progs-unstable]# ./btrfsctl -i /mnt/btrfs-test/ Metadata, DUP: total=4.62GB, used=2.46GB System, DUP: total=8.00MB, used=24.00KB Data: total=134.80GB, used=134.80GB Metadata: total=8.00MB, used=0.00 System: total=4.00MB, used=0.00 operation complete This way we show that there is no more data space to be used, but we have another 5GB of space left for metadata. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: make subvolid=0 mount the original default rootJosef Bacik
Since theres not a good way to make sure the user sees the original default root tree id, and not to mention it's 5 so is way different than any other volume, just make subvol=0 mount the original default root. This makes it a bit easier for users to handle in the long run. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: change how we mount subvolumesJosef Bacik
This work is in preperation for being able to set a different root as the default mounting root. There is currently a problem with how we mount subvolumes. We cannot currently mount a subvolume of a subvolume, you can only mount subvolumes/snapshots of the default subvolume. So say you take a snapshot of the default subvolume and call it snap1, and then take a snapshot of snap1 and call it snap2, so now you have / /snap1 /snap1/snap2 as your available volumes. Currently you can only mount / and /snap1, you cannot mount /snap1/snap2. To fix this problem instead of passing subvolid=<name> you must pass in subvolid=<treeid>, where <treeid> is the tree id that gets spit out via the subvolume listing you get from the subvolume listing patches (btrfs filesystem list). This allows us to mount /, /snap1 and /snap1/snap2 as the root volume. In addition to the above, we also now read the default dir item in the tree root to get the root key that it points to. For now this just points at what has always been the default subvolme, but later on I plan to change it to point at whatever root you want to be the new default root, so you can just set the default mount and not have to mount with -o subvolid=<treeid>. I tested this out with the above scenario and it worked perfectly. Thanks, mount -o subvol operates inside the selected subvolid. For example: mount -o subvol=snap1,subvolid=256 /dev/xxx /mnt /mnt will have the snap1 directory for the subvolume with id 256. mount -o subvol=snap /dev/xxx /mnt /mnt will be the snap directory of whatever the default subvolume is. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-08Btrfs: kfree correct pointer during mount option parsingJosef Bacik
We kstrdup the options string, but then strsep screws with the pointer, so when we kfree() it, we're not giving it the right pointer. Tested-by: Andy Lutomirski <luto@mit.edu> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-01-28Btrfs: Add mount -o compress-forceChris Mason
The default btrfs mount -o compress mode will quickly back off compressing a file if it notices that compression does not reduce the size of the data being written. This can save considerable CPU because all future writes to the file go through uncompressed. But some files are both very large and have mixed data stored in them. In that case, we want to add the ability to always try compressing data before writing it. This commit adds mount -o compress-force. A later commit will add a new inode flag that does the same thing. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-12-17Btrfs: Show discard option in /proc/mountsMatthew Wilcox
Christoph's patch e244a0aeb6a599c19a7c802cda6e2d67c847b154 doesn't display the discard option in /proc/mounts, leading to some confusion for me. Here's the missing bit. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
