We get lock inversion with umount if we allow iputs from sync_fs, so use the
delay iput flag to keep this from happening. Thanks,
Reported-by: David Sterba <dsterba@suse.cz>
Signed-off-by: Josef Bacik <jbacik@fusionio.com>
The reason we introduce per-subvolume ordered extent list is the same
as the per-subvolume delalloc inode list.
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
btrfs_read_fs_root_no_name() already checks if btrfs_root_refs()
is zero and returns ENOENT in this case. There is no need to do
it again in six places.
Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de>
We want to know if there are debugging features compiled in, this may
affect performance. The message is printed before the sanity checks.
Also kill version.h file that serves no purpose, we don't use any
version tag for kernel module.
Signed-off-by: David Sterba <dsterba@suse.cz>
The locking order for stuff is
__sb_start_write
ordered_mutex
but with sync() we don't do __sb_start_write for some strange reason, which
means that our iput in wait_ordered_extents could start a transaction which does
the __sb_start_write while we're holding the ordered_mutex. Fix this by using
delayed iput in sync. Thanks,
The new mount option is set after parsing the remount arguments,
so it is wrong that checking the autodefrag is close or not at
btrfs_remount_prepare(). Fix it.
Testing my enospc log code I managed to abort a transaction during mount, which
put me into an infinite loop. This is because of two things, first we don't
reset trans_no_join if we abort during transaction commit, which will force
anybody trying to start a transaction to just loop endlessly waiting for it to
be set to 0. But this is still just a symptom, the second issue is we don't set
the fs state to error during errors on mount. This is because we don't want to
do the flip read only thing during mount, but we still really want to set the fs
state to an error to keep us from even getting to the trans_no_join check. So
fix both of these things, make sure to reset trans_no_join if we abort during a
commit, and make sure we set the fs state to error no matter if we're mounting
or not. This should keep us from getting into this infinite loop again.
Thanks,
This mount option was a workaround when subvol= assumed path relative
to the default subvolume, not the toplevel one. This was fixed long time
ago and subvolrootid has no effect.
With more than one btrfs volume mounted, it can be very difficult to find
out which volume is hitting an error. btrfs_error() will print this, but
it is currently rigged as more of a fatal error handler, while many of
the printk()s are currently for debugging and yet-unhandled cases.
This patch just changes the functions where the device information is
already available. Some cases remain where the root or fs_info is not
passed to the function emitting the error.
This may introduce some confusion with volumes backed by multiple devices
emitting errors referring to the primary device in the set instead of the
one on which the error occurred.
Use btrfs_printk(fs_info, format, ...) rather than writing the device
string every time, and introduce macro wrappers ala XFS for brevity.
Since the function already cannot be used for continuations, print a
newline as part of the btrfs_printk() message rather than at each caller.
Signed-off-by: Simon Kirby <sim@hostway.ca>
Reviewed-by: David Sterba <dsterba@suse.cz>
The transaction abort stacktrace is printed only once per module
lifetime, but we'd like to see it each time it happens per mounted
filesystem. Introduce a fs_state flag that records it.
Tweak the messages around abort:
* add error number to the first abort
* print the exact negative errno from btrfs_decode_error
* clean up btrfs_decode_error and callers
* no dots at the end of the messages
We keep hitting bugs in the tree log replay because btrfs_remove_free_space
doesn't account for some corner case. So add a bunch of tests to try and fully
test btrfs_remove_free_space since the only time it is called is during tree log
replay. These tests all finish successfully, so as we find more of these bugs
we need to add to these tests to make sure we don't regress in fixing things.
I've hidden the tests behind a Kconfig option, but they take no time to run so
all btrfs developers should have this turned on all the time. Thanks,
Modify the request_module to prefix the file system type with "fs-"
and add aliases to all of the filesystems that can be built as modules
to match.
A common practice is to build all of the kernel code and leave code
that is not commonly needed as modules, with the result that many
users are exposed to any bug anywhere in the kernel.
Looking for filesystems with a fs- prefix limits the pool of possible
modules that can be loaded by mount to just filesystems trivially
making things safer with no real cost.
Using aliases means user space can control the policy of which
filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf
with blacklist and alias directives. Allowing simple, safe,
well understood work-arounds to known problematic software.
This also addresses a rare but unfortunate problem where the filesystem
name is not the same as it's module name and module auto-loading
would not work. While writing this patch I saw a handful of such
cases. The most significant being autofs that lives in the module
autofs4.
This is relevant to user namespaces because we can reach the request
module in get_fs_type() without having any special permissions, and
people get uncomfortable when a user specified string (in this case
the filesystem type) goes all of the way to request_module.
After having looked at this issue I don't think there is any
particular reason to perform any filtering or permission checks beyond
making it clear in the module request that we want a filesystem
module. The common pattern in the kernel is to call request_module()
without regards to the users permissions. In general all a filesystem
module does once loaded is call register_filesystem() and go to sleep.
Which means there is not much attack surface exposed by loading a
filesytem module unless the filesystem is mounted. In a user
namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT,
which most filesystems do not set today.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Reported-by: Kees Cook <keescook@google.com>
If we remount the fs to close the auto defragment or make the fs R/O,
we should stop the auto defragment.
Signed-off-by: Chris Mason <chris.mason@fusionio.com>
In some cases, we need commit the current transaction, but don't want
to start a new one if there is no running transaction, so we introduce
the function - btrfs_attach_transaction(), which can catch the current
transaction, and return -ENOENT if there is no running transaction.
But no running transaction doesn't mean the current transction completely,
because we removed the running transaction before it completes. In some
cases, it doesn't matter. But in some special cases, such as freeze fs, we
hope the transaction is fully on disk, it will introduce some bugs, for
example, we may feeze the fs and dump the data in the disk, if the transction
doesn't complete, we would dump inconsistent data. So we need fix the above
problem for those cases.
We fixes this problem by introducing a function:
btrfs_attach_transaction_barrier()
if we hope all the transaction is fully on the disk, even they are not
running, we can use this function.
__btrfs_std_error didn't always properly call va_end,
and might call va_start even if fmt was NULL.
Move all the varargs handling into the block where we
have fmt.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
This keeps static checkers happy.
At least backref_tree_panic() can apparently pass
in a null fs_info, so handle that in __btrfs_panic
to get the message out on the console.
The btrfs_panic macro also uses fs_info, but that's
largely pointless; it's testing to see if
BTRFS_MOUNT_PANIC_ON_FATAL_ERROR is not set.
But if it *were* set, __btrfs_panic() would have,
well, paniced and we wouldn't be here, testing it!
So just BUG() at this point.
And since we only use fs_info once now, just use it
directly.
There is no lock to protect fs_info->fs_state, it will introduce
some problems, such as the value may be covered by the other task
when several tasks modify it. For example:
Task0 - CPU0 Task1 - CPU1
mov %fs_state rax
or $0x1 rax
mov %fs_state rax
or $0x2 rax
mov rax %fs_state
mov rax %fs_state
The expected value is 3, but in fact, it is 2.
Though this problem doesn't happen now (because there is only one
flag currently), the code is error prone, if we add other flags,
the above problem will happen to a certainty.
Now we use bit operation for it to fix the above problem.
In this way, we can make the code more robust and be easy to
add new flags.
fs_info->alloc_start is a 64bits variant, can be accessed by
multi-task, but it is not protected strictly, it can be changed
while we are accessing it. On 32bit machine, we will get wrong
value because we access it by two instructions.(In fact, it is
also possible that the same problem happens on the 64bit machine,
because the compiler may split the 64bit operation into two 32bit
operation.)
For example:
Assuming -> alloc_start is 0x0000 0000 0001 0000 at the beginning,
then we remount and set ->alloc_start to 0x0000 0100 0000 0000.
Task0 Task1
load high 32 bits
set high 32 bits
set low 32 bits
load low 32 bits
Task1 will get 0.
This patch fixes this problem by using two locks to protect it
fs_info->chunk_mutex
sb->s_umount
On the read side, we just need get one of these two locks, and on
the write side, we must lock all of them.
The header file will then be installed under /usr/include/linux so that
userspace applications can refer to Btrfs ioctls by name and use the same
structs used internally in the kernel.
Signed-off-by: Filipe Brandenburger <filbranden@google.com>
The delayed reference allocation is in the fast path of the IO, so use slabs
to improve the speed of the allocation.
And besides that, it can do check for leaked objects when the module is removed.
We may access and update transaction->aborted on the different CPUs without
lock, so we need ACCESS_ONCE() wrapper to prevent the compiler from creating
unsolicited accesses and make sure we can get the right value.
The auto defrag allocation is in the fast path of the IO, so use slabs
This commit contains all the essential changes to the core code
of Btrfs for support of the device replace procedure.
The device replace procedure makes use of the scrub code. The scrub
code is the most efficient code to read the allocated data of a disk,
i.e. it reads sequentially in order to avoid disk head movements, it
skips unallocated blocks, it uses read ahead mechanisms, and it
contains all the code to detect and repair defects.
This commit adds code to scrub to allow the scrub code to copy read
data to another disk.
One goal is to be able to perform as fast as possible. Therefore the
write requests are collected until huge bios are built, and the
write process is decoupled from the read process with some kind of
flow control, of course, in order to limit the allocated memory.
The best performance on spinning disks could by reached when the
head movements are avoided as much as possible. Therefore a single
worker is used to interface the read process with the write process.
The regular scrub operation works as fast as before, it is not
negatively influenced and actually it is more or less unchanged.
This patch adds some code to disallow operations on the device that
is used as the target for the device replace operation.
Remove the attempt to cancel a running scrub or device replace
operation in btrfs_handle_error() because it adds the risk of
a deadlock. The only penalty of not canceling the operation is
that some I/O remains active until the procedure completes.
This is basically the same thing that happens to other tasks
that are running in user mode context, they are not affected
or stopped in btrfs_handle_error(), these tasks just need to
handle write errors correctly.
A small number of functions that are used in a device replace
procedure when the operation is resumed at mount time are unable
to pass the same root pointer that would be used in the regular
(ioctl) context. And since the root pointer is not required, only
the fs_info is, the root pointer argument is replaced with the
fs_info pointer argument.
The current behavior is to allow mounting or remounting a filesystem
writeable in degraded mode if at least one writeable device is
present.
The next failed write access to a missing device which is above
the tolerance of the configured level of redundancy results in an
read-only enforcement. Even without this, the next time
barrier_all_devices() is called and more devices are missing than
tolerable, the switch to read-only mode takes place.
In order to behave predictably and to provide proper feedback to
the user at mount time, this patch compares the number of missing
devices with the number of devices that are tolerated to be missing
according to the configured RAID level. If more devices are missing
than tolerated, e.g. if two devices are missing in case of RAID1,
only a read-only mount and remount is allowed.
If a filesystem is mounted with compression and then remounted by adding nodatacow,
the compression is disabled but the compress flag is still visible.
Also, if a filesystem is mounted with nodatacow and then remounted with compression,
nodatacow flag is still present but it's not active.
This patch:
- removes compress flags and notifies that the compression has been disabled if the
- removes nodatacow and nodatasum flags if mounted with compress.
Signed-off-by: Andrei Popa <andrei.popa@i-neo.ro>
Fix various messages to include newline and module prefix.
Signed-off-by: Daniel J Blueman <daniel@quora.org>
With the following debug patch:
static int btrfs_freeze(struct super_block *sb)
+ struct btrfs_fs_info *fs_info = btrfs_sb(sb);
+ struct btrfs_transaction *trans;
+ spin_lock(&fs_info->trans_lock);
+ trans = fs_info->running_transaction;
+ if (trans) {
+ printk("Transid %llu, use_count %d, num_writer %d\n",
+ trans->transid, atomic_read(&trans->use_count),
+ atomic_read(&trans->num_writers));
+ spin_unlock(&fs_info->trans_lock);
return 0;
I found there was a orphan transaction after the freeze operation was done.
It is because the transaction may not be committed when the transaction handle
end even though it is the last handle of the current transaction. This design
avoid committing the transaction frequently, but also introduce the above
problem.
So I add btrfs_attach_transaction() which can catch the current transaction
and commit it. If there is no transaction, it will return ENOENT, and do not
anything.
This function also can be used to instead of btrfs_join_transaction_freeze()
because it don't increase the writer counter and don't start a new transaction,
so it also can fix the deadlock between sync and freeze.
Besides that, it is used to instead of btrfs_join_transaction() in
transaction_kthread(), because if there is no transaction, the transaction
kthread needn't anything.
We do not need to do anything special to freeze or unfreeze, it's all taken
care of by the generic work, and what we currently have is wrong anyway
since we shouldn't be returnning to userspace with mutexes held anyway.
Thanks,
nocow_only is now an obsolete argument.
Signed-off-by: Liu Bo <bo.li.liu@oracle.com>
I screwed this up, there is a race between checking if there is a running
transaction and actually starting a transaction in sync where we could race
with a freezer and get ourselves into trouble. To fix this we need to make
a new join type to only do the try lock on the freeze stuff. If it fails
we'll return EPERM and just return from sync. This fixes a hang Liu Bo
reported when running xfstest 68 in a loop. Thanks,
Reported-by: Liu Bo <bo.li.liu@oracle.com>
Though we dump the stack information when aborting a unused transaction
handle, we don't know the correct place where we decide to abort the
transaction handle if one function has several place where the transaction
abort function is invoked and jumps to the same place after this call.
And beside that we also don't know the reason why we jump to abort
the current handle. So I modify the transaction abort function and make
it output the function name, line and error information.
The ordered extent allocation is in the fast path of the IO, so use a slab
"Size of the struct is 280, so this will fall into the size-512 bucket,
giving 8 objects per page, while own slab will pack 14 objects into a page.
Another benefit I see is to check for leaked objects when the module is
removed (and the cache destroy takes place)."
-- David Sterba
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs fixes from Chris Mason:
"I've split out the big send/receive update from my last pull request
and now have just the fixes in my for-linus branch. The send/recv
branch will wander over to linux-next shortly though.
The largest patches in this pull are Josef's patches to fix DIO
locking problems and his patch to fix a crash during balance. They
are both well tested.
The rest are smaller fixes that we've had queued. The last rc came
out while I was hacking new and exciting ways to recover from a
misplaced rm -rf on my dev box, so these missed rc3."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (25 commits)
Btrfs: fix that repair code is spuriously executed for transid failures
Btrfs: fix ordered extent leak when failing to start a transaction
Btrfs: fix a dio write regression
Btrfs: fix deadlock with freeze and sync V2
Btrfs: revert checksum error statistic which can cause a BUG()
Btrfs: remove superblock writing after fatal error
Btrfs: allow delayed refs to be merged
Btrfs: fix enospc problems when deleting a subvol
Btrfs: fix wrong mtime and ctime when creating snapshots
Btrfs: fix race in run_clustered_refs
Btrfs: don't run __tree_mod_log_free_eb on leaves
Btrfs: increase the size of the free space cache
Btrfs: barrier before waitqueue_active
Btrfs: fix deadlock in wait_for_more_refs
btrfs: fix second lock in btrfs_delete_delayed_items()
Btrfs: don't allocate a seperate csums array for direct reads
Btrfs: do not strdup non existent strings
Btrfs: do not use missing devices when showing devname
Btrfs: fix that error value is changed by mistake
Btrfs: lock extents as we map them in DIO
We can deadlock with freeze right now because we unconditionally start a
transaction in our ->sync_fs() call. To fix this just check and see if we
have a running transaction to commit. This saves us from the deadlock
because at this point we'll have the umount sem for the sb so we're safe
from freezes coming in after we've done our check. With this patch the
freeze xfstests no longer deadlocks. Thanks,
Signed-off-by: Chris Mason <chris.mason@oracle.com>
If you do the following
mkfs.btrfs /dev/sdb /dev/sdc
rmmod btrfs
dd if=/dev/zero of=/dev/sdb bs=1M count=1
mount -o degraded /dev/sdc /mnt/btrfs-test
the box will panic trying to deref the name for the missing dev since it is
the lower numbered devid. So fix show_devname to not use missing devices.
Thanks,
The '->write_super' superblock method is gone, and this patch removes all the
references to 'write_super' from btrfs.
Cc: Chris Mason <chris.mason@fusionio.com>
Cc: linux-btrfs@vger.kernel.org
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Use the generic printk_get_level() to search a message for a kern_level.
Add __printf to verify format and arguments. Fix a few messages that
had mismatches in format and arguments. Add #ifdef CONFIG_PRINTK blocks
to shrink the object size a bit when not using printk.
[akpm@linux-foundation.org: whitespace tweak]
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Chris Mason <chris.mason@oracle.com>
Pull large btrfs update from Chris Mason:
"This pull request is very large, and the two main features in here
have been under testing/devel for quite a while.
We have subvolume quotas from the strato developers. This enables
full tracking of how many blocks are allocated to each subvolume (and
all snapshots) and you can set limits on a per-subvolume basis. You
can also create quota groups and toss multiple subvolumes into a big
group. It's everything you need to be a web hosting company and give
each user their own subvolume.
The userland side of the quotas is being refreshed, they'll send out
details on where to grab it soon.
Next is the kernel side of btrfs send/receive from Alexander Block.
This leverages the same infrastructure as the quota code to figure out
relationships between blocks and their owners. It can then compute
the difference between two snapshots and sends the diffs in a neutral
format into userland.
The basic model:
create a snapshot
send that snapshot as the initial backup
make changes
create a second snapshot
send the incremental as a backup
delete the first snapshot
(use the second snapshot for the next incremental)
The receive portion is all in userland, and in the 'next' branch of my
btrfs-progs repo.
There's still some work to do in terms of optimizing the send side
from kernel to userland. The really important part is figuring out
how two snapshots are different, and this is where we are
concentrating right now. The initial send of a dataset is a little
slower than tar, but the incremental sends are dramatically faster
than what rsync can do.
On top of all of that, we have a nice queue of fixes, cleanups and
optimizations."
Fix up trivial modify/del conflict in fs/btrfs/ioctl.c
Also fix up semantic conflict in fs/btrfs/send.c: the interface to
dentry_open() changed in commit 765927b2d508 ("switch dentry_open() to
struct path, make it grab references itself"), and since it now grabs
whatever references it needs, we should no longer do the mntget() on the
mnt (and we need to dput() the dentry reference we took).
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (65 commits)
Btrfs: uninit variable fixes in send/receive
Btrfs: introduce BTRFS_IOC_SEND for btrfs send/receive
Btrfs: add btrfs_compare_trees function
Btrfs: introduce subvol uuids and times
Btrfs: make iref_to_path non static
Btrfs: add a barrier before a waitqueue_active check
Btrfs: call the ordered free operation without any locks held
Btrfs: Check INCOMPAT flags on remount and add helper function
Btrfs: add helper for tree enumeration
btrfs: allow cross-subvolume file clone
Btrfs: improve multi-thread buffer read
Btrfs: make btrfs's allocation smoothly with preallocation
Btrfs: lock the transition from dirty to writeback for an eb
Btrfs: fix potential race in extent buffer freeing
Btrfs: don't return true in releasepage unless we actually freed the eb
Btrfs: suppress printk() if all device I/O stats are zero
Btrfs: remove unwanted printk() for btrfs device I/O stats
Btrfs: rewrite BTRFS_SETGET_FUNCS
Btrfs: zero unused bytes in inode item
Btrfs: kill free_space pointer from inode structure
fs/btrfs/ioctl.c
In support of the recently added capability to remount with lzo
compression, provide a helper function to check the compression
INCOMPAT flags when remounting with lzo compression, and set
the flags if necessary.
Also, implement the new helper function when defragmenting with
explicit lzo compression and when setting the default subvolume.
Signed-off-by: Mitch Harder <mitch.harder@sabayonlinux.org>
This will be used in conjunction with btrfs device ready <dev>. This is
needed for initrd's to have a nice and lightweight way to tell if all of the
devices needed for a file system are in the cache currently. This keeps
them from having to do mount+sleep loops waiting for devices to show up.
Thanks,
