path: root/fs/btrfs/super.c
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11enforce ->sync_fs is only called for rw superblockChristoph Hellwig
Make sure a superblock really is writeable by checking MS_RDONLY under s_umount. sync_filesystems needed some re-arragement for that, but all but one sync_filesystem caller had the correct locking already so that we could add that check there. cachefiles grew s_umount locking. I've also added a WARN_ON to sync_filesystem to assert this for future callers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11btrfs: remove ->write_super and stop maintaining ->s_dirtChristoph Hellwig
2009-06-11Btrfs: fix -o nodatasum printk spellingChris Mason
It was printing nodatacsum, which was not the correct option name. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-06-10Btrfs: autodetect SSD devicesChris Mason
During mount, btrfs will check the queue nonrot flag for all the devices found in the FS. If they are all non-rotating, SSD mode is enabled by default. If the FS was mounted with -o nossd, the non-rotating flag is ignored. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-06-10Btrfs: add mount -o ssd_spread to spread allocations outChris Mason
Some SSDs perform best when reusing block numbers often, while others perform much better when clustering strictly allocates big chunks of unused space. The default mount -o ssd will find rough groupings of blocks where there are a bunch of free blocks that might have some allocated blocks mixed in. mount -o ssd_spread will make sure there are no allocated blocks mixed in. It should perform better on lower end SSDs. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-06-10Btrfs: Add mount -o nossdChris Mason
This allows you to turn off the ssd mode via remount. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-06-10Btrfs: Mixed back reference (FORWARD ROLLING FORMAT CHANGE)Yan Zheng
This commit introduces a new kind of back reference for btrfs metadata. Once a filesystem has been mounted with this commit, IT WILL NO LONGER BE MOUNTABLE BY OLDER KERNELS. When a tree block in subvolume tree is cow'd, the reference counts of all extents it points to are increased by one. At transaction commit time, the old root of the subvolume is recorded in a "dead root" data structure, and the btree it points to is later walked, dropping reference counts and freeing any blocks where the reference count goes to 0. The increments done during cow and decrements done after commit cancel out, and the walk is a very expensive way to go about freeing the blocks that are no longer referenced by the new btree root. This commit reduces the transaction overhead by avoiding the need for dead root records. When a non-shared tree block is cow'd, we free the old block at once, and the new block inherits old block's references. When a tree block with reference count > 1 is cow'd, we increase the reference counts of all extents the new block points to by one, and decrease the old block's reference count by one. This dead tree avoidance code removes the need to modify the reference counts of lower level extents when a non-shared tree block is cow'd. But we still need to update back ref for all pointers in the block. This is because the location of the block is recorded in the back ref item. We can solve this by introducing a new type of back ref. The new back ref provides information about pointer's key, level and in which tree the pointer lives. This information allow us to find the pointer by searching the tree. The shortcoming of the new back ref is that it only works for pointers in tree blocks referenced by their owner trees. This is mostly a problem for snapshots, where resolving one of these fuzzy back references would be O(number_of_snapshots) and quite slow. The solution used here is to use the fuzzy back references in the common case where a given tree block is only referenced by one root, and use the full back references when multiple roots have a reference on a given block. This commit adds per subvolume red-black tree to keep trace of cached inodes. The red-black tree helps the balancing code to find cached inodes whose inode numbers within a given range. This commit improves the balancing code by introducing several data structures to keep the state of balancing. The most important one is the back ref cache. It caches how the upper level tree blocks are referenced. This greatly reduce the overhead of checking back ref. The improved balancing code scales significantly better with a large number of snapshots. This is a very large commit and was written in a number of pieces. But, they depend heavily on the disk format change and were squashed together to make sure git bisect didn't end up in a bad state wrt space balancing or the format change. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-05-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: Spelling fix in btrfs_lookup_first_block_group comments Btrfs: make show_options result match actual option names Btrfs: remove outdated comment in btrfs_ioctl_resize() Btrfs: remove some WARN_ONs in the IO failure path Btrfs: Don't loop forever on metadata IO failures Btrfs: init inode ordered_data_close flag properly
2009-05-14Btrfs: make show_options result match actual option namesSage Weil
The notreelog and flushoncommit mount options were being printed slightly differently. Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-05-09Convert obvious places to deactivate_locked_super()Al Viro
2009-04-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: look for acls during btrfs_read_locked_inode Btrfs: fix acl caching Btrfs: Fix a bunch of printk() warnings. Btrfs: Fix a trivial warning using max() of u64 vs ULL. Btrfs: remove unused btrfs_bit_radix slab Btrfs: ratelimit IO error printks Btrfs: remove #if 0 code Btrfs: When shrinking, only update disk size on success Btrfs: fix deadlocks and stalls on dead root removal Btrfs: fix fallocate deadlock on inode extent lock Btrfs: kill btrfs_cache_create Btrfs: don't export symbols Btrfs: simplify makefile Btrfs: try to keep a healthy ratio of metadata vs data block groups
2009-04-27Btrfs: Fix a bunch of printk() warnings.Joel Becker
Just happened to notice a bunch of %llu vs u64 warnings. Here's a patch to cast them all. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-04-24Btrfs: try to keep a healthy ratio of metadata vs data block groupsJosef Bacik
This patch makes the chunk allocator keep a good ratio of metadata vs data block groups. By default for every 8 data block groups, we'll allocate 1 metadata chunk, or about 12% of the disk will be allocated for metadata. This can be changed by specifying the metadata_ratio mount option. This is simply the number of data block groups that have to be allocated to force a metadata chunk allocation. By making sure we allocate metadata chunks more often, we are less likely to get into situations where the whole disk has been allocated as data block groups. Signed-off-by: Josef Bacik <jbacik@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-04-20btrfs: use memdup_user()Li Zefan
Remove open-coded memdup_user(). Note this changes some GFP_NOFS to GFP_KERNEL, since copy_from_user() may cause pagefault, it's pointless to pass GFP_NOFS to kmalloc(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-02Btrfs: add flushoncommit mount optionSage Weil
The 'flushoncommit' mount option forces any data dirtied by a write in a prior transaction to commit as part of the current commit. This makes the committed state a fully consistent view of the file system from the application's perspective (i.e., it includes all completed file system operations). This was previously the behavior only when a snapshot is created. This is used by Ceph to ensure that completed writes make it to the platter along with the metadata operations they are bound to (by BTRFS_IOC_TRANS_{START,END}). Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-04-02Btrfs: notreelog mount optionSage Weil
Add a 'notreelog' mount option to disable the tree log (used by fsync, O_SYNC writes). This is much slower, but the tree logging produces inconsistent views into the FS for ceph. Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-04-02Btrfs: introduce btrfs_show_optionsEric Paris
btrfs options can change at times other than mount, yet /proc/mounts shows the options string used when the fs was mounted (an example would be when btrfs determines that barriers aren't useful and turns them off.) This patch instead outputs the actual options in use by btrfs. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-02-12Btrfs: don't clean old snapshots on sync(1)Chris Mason
Cleaning old snapshots can make sync(1) somewhat slow, and some users and applications still use it in a global fsync kind of workload. This patch changes btrfs not to clean old snapshots during sync, which is safe from a FS consistency point of view. The major downside is that it makes it difficult to tell when old snapshots have been reaped and the space they were using has been reclaimed. A new ioctl will be added for this purpose instead. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-02-12Btrfs: process mount options on mount -o remount,Chris Mason
Btrfs wasn't parsing any new mount options during remount, making it difficult to set mount options on a root drive. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-01-28Merge branch 'master' of ↵Chris Mason
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable Fix fs/btrfs/super.c conflict around #includes
2009-01-21Btrfs: removed unused #include <version.h>'sHuang Weiyi
Removed unused #include <version.h>'s in btrfs Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-01-21Btrfs: cleanup fs/btrfs/super.c::btrfs_control_ioctl()Wang Cong
- Remove the unused local variable 'len'; - Check return value of kmalloc(). Signed-off-by: Wang Cong <wangcong@zeuux.org> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-01-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: fix ioctl arg size (userland incompatible change!) Btrfs: Clear the device->running_pending flag before bailing on congestion
2009-01-16Btrfs: fix ioctl arg size (userland incompatible change!)Chris Mason
The structure used to send device in btrfs ioctl calls was not properly aligned, and so 32 bit ioctls would not work properly on 64 bit kernels. We could fix this with compat ioctls, but we're just one byte away and it doesn't make sense at this stage to carry about the compat ioctls forever at this stage in the project. This patch brings the ioctl arg up to an evenly aligned 4k. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-01-15btrfs & squashfs: Move btrfs and squashfsto's magic number to <linux/magic.h>Qinghuang Feng
Use the standard magic.h for btrfs and squashfs. Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-10btrfs: fix for write_super_lockfs/unlockfs error handlingLinus Torvalds
Commit c4be0c1dc4cdc37b175579be1460f15ac6495e9a added the ability for write_super_lockfs to return errors, and renamed them to match. But btrfs didn't get converted. Do the minimal conversion to make it compile again. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05Btrfs: Fix checkpatch.pl warningsChris Mason
There were many, most are fixed now. struct-funcs.c generates some warnings but these are bogus. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-01-05Btrfs: fix a memory leak in btrfs_get_sbShen Feng
subvol_name should be freed if error occurs. Signed-off-by: Shen Feng <shen@cn.fujitsu.com>
2009-01-05Btrfs: add permission checks to the ioctlsChris Mason
Only root can add/remove devices Only root can defrag subtrees Only files open for writing can be defragged Only files open for writing can be the destination for a clone Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-12-12Btrfs: shared seed deviceYan Zheng
This patch makes seed device possible to be shared by multiple mounted file systems. The sharing is achieved by cloning seed device's btrfs_fs_devices structure. Thanks you, Signed-off-by: Yan Zheng <zheng.yan@oracle.com>
2008-12-02Btrfs: corret fmode_t annotationsChristoph Hellwig
Make sure to propagate fmode_t properly and use the right constants for it. Signed-off-by: Christoph Hellwig <hch@lst.de>
2008-12-02Btrfs: make things static and include the right headersChristoph Hellwig
Shut up various sparse warnings about symbols that should be either static or have their declarations in scope. Signed-off-by: Christoph Hellwig <hch@lst.de>
2008-11-20Btrfs: compat code fixesChris Mason
The btrfs git kernel trees is used to build a standalone tree for compiling against older kernels. This commit makes the standalone tree work with 2.6.27 Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-11-17Btrfs: Allow subvolumes and snapshots anywhere in the directory treeChris Mason
Before, all snapshots and subvolumes lived in a single flat directory. This was awkward and confusing because the single flat directory was only writable with the ioctls. This commit changes the ioctls to create subvols and snapshots at any point in the directory tree. This requires making separate ioctls for snapshot and subvol creation instead of a combining them into one. The subvol ioctl does: btrfsctl -S subvol_name parent_dir After the ioctl is done subvol_name lives inside parent_dir. The snapshot ioctl does: btrfsctl -s path_for_snapshot root_to_snapshot path_for_snapshot can be an absolute or relative path. btrfsctl breaks it up into directory and basename components. root_to_snapshot can be any file or directory in the FS. The snapshot is taken of the entire root where that file lives. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-11-17Btrfs: Seed device supportYan Zheng
Seed device is a special btrfs with SEEDING super flag set and can only be mounted in read-only mode. Seed devices allow people to create new btrfs on top of it. The new FS contains the same contents as the seed device, but it can be mounted in read-write mode. This patch does the following: 1) split code in btrfs_alloc_chunk into two parts. The first part does makes the newly allocated chunk usable, but does not do any operation that modifies the chunk tree. The second part does the the chunk tree modifications. This division is for the bootstrap step of adding storage to the seed device. 2) Update device management code to handle seed device. The basic idea is: For an FS grown from seed devices, its seed devices are put into a list. Seed devices are opened on demand at mounting time. If any seed device is missing or has been changed, btrfs kernel module will refuse to mount the FS. 3) make btrfs_find_block_group not return NULL when all block groups are read-only. Signed-off-by: Yan Zheng <zheng.yan@oracle.com>
2008-11-12Btrfs: mount ro and remount supportYan Zheng
This patch adds mount ro and remount support. The main changes in patch are: adding btrfs_remount and related helper function; splitting the transaction related code out of close_ctree into btrfs_commit_super; updating allocator to properly handle read only block group. Signed-off-by: Yan Zheng <zheng.yan@oracle.com>
2008-11-06Btrfs: Optimize compressed writeback and readsChris Mason
When reading compressed extents, try to put pages into the page cache for any pages covered by the compressed extent that readpages didn't already preload. Add an async work queue to handle transformations at delayed allocation processing time. Right now this is just compression. The workflow is: 1) Find offsets in the file marked for delayed allocation 2) Lock the pages 3) Lock the state bits 4) Call the async delalloc code The async delalloc code clears the state lock bits and delalloc bits. It is important this happens before the range goes into the work queue because otherwise it might deadlock with other work queue items that try to lock those extent bits. The file pages are compressed, and if the compression doesn't work the pages are written back directly. An ordered work queue is used to make sure the inodes are written in the same order that pdflush or writepages sent them down. This changes extent_write_cache_pages to let the writepage function update the wbc nr_written count. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-10-29Btrfs: Add zlib compression supportChris Mason
This is a large change for adding compression on reading and writing, both for inline and regular extents. It does some fairly large surgery to the writeback paths. Compression is off by default and enabled by mount -o compress. Even when the -o compress mount option is not used, it is possible to read compressed extents off the disk. If compression for a given set of pages fails to make them smaller, the file is flagged to avoid future compression attempts later. * While finding delalloc extents, the pages are locked before being sent down to the delalloc handler. This allows the delalloc handler to do complex things such as cleaning the pages, marking them writeback and starting IO on their behalf. * Inline extents are inserted at delalloc time now. This allows us to compress the data before inserting the inline extent, and it allows us to insert an inline extent that spans multiple pages. * All of the in-memory extent representations (extent_map.c, ordered-data.c etc) are changed to record both an in-memory size and an on disk size, as well as a flag for compression. From a disk format point of view, the extent pointers in the file are changed to record the on disk size of a given extent and some encoding flags. Space in the disk format is allocated for compression encoding, as well as encryption and a generic 'other' field. Neither the encryption or the 'other' field are currently used. In order to limit the amount of data read for a single random read in the file, the size of a compressed extent is limited to 128k. This is a software only limit, the disk format supports u64 sized compressed extents. In order to limit the ram consumed while processing extents, the uncompressed size of a compressed extent is limited to 256k. This is a software only limit and will be subject to tuning later. Checksumming is still done on compressed extents, and it is done on the uncompressed version of the data. This way additional encodings can be layered on without having to figure out which encoding to checksum. Compression happens at delalloc time, which is basically singled threaded because it is usually done by a single pdflush thread. This makes it tricky to spread the compression load across all the cpus on the box. We'll have to look at parallel pdflush walks of dirty inodes at a later time. Decompression is hooked into readpages and it does spread across CPUs nicely. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-29Btrfs: add and improve commentsChris Mason
This improves the comments at the top of many functions. It didn't dive into the guts of functions because I was trying to avoid merging problems with the new allocator and back reference work. extent-tree.c and volumes.c were both skipped, and there is definitely more work todo in cleaning and commenting the code. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Remove Btrfs compat code for older kernelsChris Mason
Btrfs had compatibility code for kernels back to 2.6.18. These have been removed, and will be maintained in a separate backport git tree from now on. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Btrfs: Reinstate '-osubvol=.' option to mount entire treeDavid Woodhouse
Date: Tue, 19 Aug 2008 16:49:35 +0100 This disappeared when I removed the special case for '.' in btrfs_lookup() Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Mask root object ID into f_fsid in btrfs_statfs()David Woodhouse
Date: Mon, 18 Aug 2008 13:10:20 +0100 This means that subvolumes get a different fsid, and NFS exporting them works properly. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Fill f_fsid field in btrfs_statfs()David Woodhouse
Date: Mon, 18 Aug 2008 12:01:52 +0100 Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25NFS support for btrfs - v3Balaji Rao
Date: Mon, 21 Jul 2008 02:01:56 +0530 Here's an implementation of NFS support for btrfs. It relies on the fixes which are going in to 2.6.28 for the NFS readdir/lookup deadlock. This uses the btrfs_iget helper introduced previously. [dwmw2: Tidy up a little, switch to d_obtain_alias() w/compat routine, change fh_type, store parent's root object ID where needed, fix some get_parent() and fs_to_dentry() bugs] Signed-off-by: Balaji Rao <balajirrao@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Btrfs: Various small fixes.Yan Zheng
This trivial patch contains two locking fixes and a off by one fix. --- Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Btrfs: Add ACL supportJosef Bacik
2008-09-25Btrfs: Add version strings on module loadChris Mason
2008-09-25Btrfs: Online btree defragmentation fixesChris Mason
The btree defragger wasn't making forward progress because the new key wasn't being saved by the btrfs_search_forward function. This also disables the automatic btree defrag, it wasn't scaling well to huge filesystems. The auto-defrag needs to be done differently. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Btrfs: Replace the transaction work queue with kthreadsChris Mason
This creates one kthread for commits and one kthread for deleting old snapshots. All the work queues are removed. Signed-off-by: Chris Mason <chris.mason@oracle.com>
