No reason to bug on in here, fs corruption could easily cause these things to
happen.
Signed-off-by: Josef Bacik <jbacik@fb.com>
Signed-off-by: David Sterba <dsterba@suse.com>
dedupe and subpage size patchset
Extend btrfs_set_extent_delalloc() and extent_clear_unlock_delalloc()
parameters for both in-band dedupe and subpage sector size patchset.
This should reduce conflict of both patchset and the effort to rebase
them.
Cc: Chandan Rajendra <chandan@linux.vnet.ibm.com>
Cc: David Sterba <dsterba@suse.cz>
Signed-off-by: Qu Wenruo <quwenruo@cn.fujitsu.com>
Commit 44f714dae50a ("Btrfs: improve performance on fsync against new
inode after rename/unlink"), which landed in 4.8-rc2, introduced a
possibility for a deadlock due to double locking of an inode's log mutex
by the same task, which lockdep reports with:
[23045.433975] =============================================
[23045.434748] [ INFO: possible recursive locking detected ]
[23045.435426] 4.7.0-rc6-btrfs-next-34+ #1 Not tainted
[23045.436044] ---------------------------------------------
[23045.436044] xfs_io/3688 is trying to acquire lock:
[23045.436044] (&ei->log_mutex){+.+...}, at: [<ffffffffa038552d>] btrfs_log_inode+0x13a/0xc95 [btrfs]
[23045.436044]
but task is already holding lock:
[23045.436044]
[23045.436044] Possible unsafe locking scenario:
[23045.436044] CPU0
[23045.436044] ----
[23045.436044] lock(&ei->log_mutex);
[23045.436044]
*** DEADLOCK ***
[23045.436044] May be due to missing lock nesting notation
[23045.436044] 3 locks held by xfs_io/3688:
[23045.436044] #0: (&sb->s_type->i_mutex_key#15){+.+...}, at: [<ffffffffa035f2ae>] btrfs_sync_file+0x14e/0x425 [btrfs]
[23045.436044] #1: (sb_internal#2){.+.+.+}, at: [<ffffffff8118446b>] __sb_start_write+0x5f/0xb0
[23045.436044] #2: (&ei->log_mutex){+.+...}, at: [<ffffffffa038552d>] btrfs_log_inode+0x13a/0xc95 [btrfs]
[23045.436044]
stack backtrace:
[23045.436044] CPU: 4 PID: 3688 Comm: xfs_io Not tainted 4.7.0-rc6-btrfs-next-34+ #1
[23045.436044] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.9.1-0-gb3ef39f-prebuilt.qemu-project.org 04/01/2014
[23045.436044] 0000000000000000 ffff88022f5f7860 ffffffff8127074d ffffffff82a54b70
[23045.436044] ffffffff82a54b70 ffff88022f5f7920 ffffffff81092897 ffff880228015d68
[23045.436044] 0000000000000000 ffffffff82a54b70 ffffffff829c3f00 ffff880228015d68
[23045.436044] Call Trace:
[23045.436044] [<ffffffff8127074d>] dump_stack+0x67/0x90
[23045.436044] [<ffffffff81092897>] __lock_acquire+0xcbb/0xe4e
[23045.436044] [<ffffffff8109155f>] ? mark_lock+0x24/0x201
[23045.436044] [<ffffffff8109179a>] ? mark_held_locks+0x5e/0x74
[23045.436044] [<ffffffff81092de0>] lock_acquire+0x12f/0x1c3
[23045.436044] [<ffffffff81092de0>] ? lock_acquire+0x12f/0x1c3
[23045.436044] [<ffffffffa038552d>] ? btrfs_log_inode+0x13a/0xc95 [btrfs]
[23045.436044] [<ffffffff814a51a4>] mutex_lock_nested+0x77/0x3a7
[23045.436044] [<ffffffffa039705e>] ? btrfs_release_delayed_node+0xb/0xd [btrfs]
[23045.436044] [<ffffffffa038552d>] btrfs_log_inode+0x13a/0xc95 [btrfs]
[23045.436044] [<ffffffff810a0ed1>] ? vprintk_emit+0x453/0x465
[23045.436044] [<ffffffffa0385a61>] btrfs_log_inode+0x66e/0xc95 [btrfs]
[23045.436044] [<ffffffffa03c084d>] log_new_dir_dentries+0x26c/0x359 [btrfs]
[23045.436044] [<ffffffffa03865aa>] btrfs_log_inode_parent+0x4a6/0x628 [btrfs]
[23045.436044] [<ffffffffa0387552>] btrfs_log_dentry_safe+0x5a/0x75 [btrfs]
[23045.436044] [<ffffffffa035f464>] btrfs_sync_file+0x304/0x425 [btrfs]
[23045.436044] [<ffffffff811acaf4>] vfs_fsync_range+0x8c/0x9e
[23045.436044] [<ffffffff811acb22>] vfs_fsync+0x1c/0x1e
[23045.436044] [<ffffffff811acc79>] do_fsync+0x31/0x4a
[23045.436044] [<ffffffff811ace99>] SyS_fsync+0x10/0x14
[23045.436044] [<ffffffff814a88e5>] entry_SYSCALL_64_fastpath+0x18/0xa8
[23045.436044] [<ffffffff8108f039>] ? trace_hardirqs_off_caller+0x3f/0xaa
An example reproducer for this is:
$ mkfs.btrfs -f /dev/sdb
$ mount /dev/sdb /mnt
$ mkdir /mnt/dir
$ touch /mnt/dir/foo
$ sync
$ mv /mnt/dir/foo /mnt/dir/bar
$ xfs_io -c "fsync" /mnt/dir/bar
This is because while logging the inode of file bar we end up logging its
parent directory (since its inode has an unlink_trans field matching the
current transaction id due to the rename operation), which in turn logs
the inodes for all its new dentries, so that the new inode for the new
file named foo gets logged which in turn triggered another logging attempt
for the inode we are fsync'ing, since that inode had an old name that
corresponds to the name of the new inode.
So fix this by ensuring that when logging the inode for a new dentry that
has a name matching an old name of some other inode, we don't log again
the original inode that we are fsync'ing.
Fixes: 44f714dae50a ("Btrfs: improve performance on fsync against new inode after rename/unlink")
Signed-off-by: Filipe Manana <fdmanana@suse.com>
Signed-off-by: Chris Mason <clm@fb.com>
This patch can fix some false ENOSPC errors, below test script can
reproduce one false ENOSPC error:
#!/bin/bash
dd if=/dev/zero of=fs.img bs=$((1024*1024)) count=128
dev=$(losetup --show -f fs.img)
mkfs.btrfs -f -M $dev
mkdir /tmp/mntpoint
mount $dev /tmp/mntpoint
cd /tmp/mntpoint
xfs_io -f -c "falloc 0 $((64*1024*1024))" testfile
Above script will fail for ENOSPC reason, but indeed fs still has free
space to satisfy this request. Please see call graph:
btrfs_fallocate()
|-> btrfs_alloc_data_chunk_ondemand()
| bytes_may_use += 64M
|-> btrfs_prealloc_file_range()
|-> btrfs_reserve_extent()
|-> btrfs_add_reserved_bytes()
| alloc_type is RESERVE_ALLOC_NO_ACCOUNT, so it does not
| change bytes_may_use, and bytes_reserved += 64M. Now
| bytes_may_use + bytes_reserved == 128M, which is greater
| than btrfs_space_info's total_bytes, false enospc occurs.
| Note, the bytes_may_use decrease operation will be done in
| end of btrfs_fallocate(), which is too late.
Here is another simple case for buffered write:
CPU 1 | CPU 2
|-> cow_file_range() |-> __btrfs_buffered_write()
|-> btrfs_reserve_extent() | |
| ..... | |-> btrfs_check_data_free_space()
|-> extent_clear_unlock_delalloc() |
In CPU 1, btrfs_reserve_extent()->find_free_extent()->
btrfs_add_reserved_bytes() do not decrease bytes_may_use, the decrease
operation will be delayed to be done in extent_clear_unlock_delalloc().
Assume in this case, btrfs_reserve_extent() reserved 128MB data, CPU2's
btrfs_check_data_free_space() tries to reserve 100MB data space.
If
100MB > data_sinfo->total_bytes - data_sinfo->bytes_used -
data_sinfo->bytes_reserved - data_sinfo->bytes_pinned -
data_sinfo->bytes_readonly - data_sinfo->bytes_may_use
btrfs_check_data_free_space() will try to allcate new data chunk or call
btrfs_start_delalloc_roots(), or commit current transaction in order to
reserve some free space, obviously a lot of work. But indeed it's not
necessary as long as decreasing bytes_may_use timely, we still have
free space, decreasing 128M from bytes_may_use.
To fix this issue, this patch chooses to update bytes_may_use for both
data and metadata in btrfs_add_reserved_bytes(). For compress path, real
extent length may not be equal to file content length, so introduce a
ram_bytes argument for btrfs_reserve_extent(), find_free_extent() and
btrfs_add_reserved_bytes(), it's becasue bytes_may_use is increased by
file content length. Then compress path can update bytes_may_use
correctly. Also now we can discard RESERVE_ALLOC_NO_ACCOUNT, RESERVE_ALLOC
and RESERVE_FREE.
As we know, usually EXTENT_DO_ACCOUNTING is used for error path. In
run_delalloc_nocow(), for inode marked as NODATACOW or extent marked as
PREALLOC, we also need to update bytes_may_use, but can not pass
EXTENT_DO_ACCOUNTING, because it also clears metadata reservation, so
here we introduce EXTENT_CLEAR_DATA_RESV flag to indicate btrfs_clear_bit_hook()
to update btrfs_space_info's bytes_may_use.
Meanwhile __btrfs_prealloc_file_range() will call
btrfs_free_reserved_data_space() internally for both sucessful and failed
path, btrfs_prealloc_file_range()'s callers does not need to call
btrfs_free_reserved_data_space() any more.
Signed-off-by: Wang Xiaoguang <wangxg.fnst@cn.fujitsu.com>
Reviewed-by: Josef Bacik <jbacik@fb.com>
git://git.kernel.org/pub/scm/linux/kernel/git/fdmanana/linux into for-linus-4.8
When we start an fsync we start ordered extents for all delalloc ranges.
However before attempting to log the inode, we only wait for those ordered
extents if we are not doing a full sync (bit BTRFS_INODE_NEEDS_FULL_SYNC
is set in the inode's flags). This means that if an ordered extent
completes with an IO error before we check if we can skip logging the
inode, we will not catch and report the IO error to user space. This is
because on an IO error, when the ordered extent completes we do not
update the inode, so if the inode was not previously updated by the
current transaction we end up not logging it through calls to fsync and
therefore not check its mapping flags for the presence of IO errors.
Fix this by checking for errors in the flags of the inode's mapping when
we notice we can skip logging the inode.
This caused sporadic failures in the test generic/331 (which explicitly
tests for IO errors during an fsync call).
Reviewed-by: Liu Bo <bo.li.liu@oracle.com>
__btrfs_abort_transaction doesn't use its root parameter except to
obtain an fs_info pointer. We can obtain that from trans->root->fs_info
for now and from trans->fs_info in a later patch.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
btrfs_test_opt and friends only use the root pointer to access
the fs_info. Let's pass the fs_info directly in preparation to
eliminate similar patterns all over btrfs.
BTRFS is using a variety of slab caches to satisfy internal needs.
Those slab caches are always allocated with the SLAB_RECLAIM_ACCOUNT,
meaning allocations from the caches are going to be accounted as
SReclaimable. At the same time btrfs is not registering any shrinkers
whatsoever, thus preventing memory from the slabs to be shrunk. This
means those caches are not in fact reclaimable.
To fix this remove the SLAB_RECLAIM_ACCOUNT on all caches apart from the
inode cache, since this one is being freed by the generic VFS super_block
shrinker. Also set the transaction related caches as SLAB_TEMPORARY,
to better document the lifetime of the objects (it just translates
to SLAB_RECLAIM_ACCOUNT).
Signed-off-by: Nikolay Borisov <n.borisov.lkml@gmail.com>
Reviewed-by: David Sterba <dsterba@suse.com>
Commit 56244ef151c3cd11 was almost but not quite enough to fix the
reservation math after btrfs_copy_from_user returned partial copies.
Some users are still seeing warnings in btrfs_destroy_inode, and with a
long enough test run I'm able to trigger them as well.
This patch fixes the accounting math again, bringing it much closer to
the way it was before the sectorsize conversion Chandan did. The
problem is accounting for the offset into the page/sector when we do a
partial copy. This one just uses the dirty_sectors variable which
should already be updated properly.
cc: stable@vger.kernel.org # v4.6+
So btrfs_block_rsv_migrate just unconditionally calls block_rsv_migrate_bytes.
Not only this but it unconditionally changes the size of the block_rsv. This
isn't a bug strictly speaking, but it makes truncate block rsv's look funny
because every time we migrate bytes over its size grows, even though we only
want it to be a specific size. So collapse this into one function that takes an
update_size argument and make truncate and evict not update the size for
consistency sake. Thanks,
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs fixes from Chris Mason:
"I have a two part pull this time because one of the patches Dave
Sterba collected needed to be against v4.7-rc2 or higher (we used
rc4). I try to make my for-linus-xx branch testable on top of the
last major so we can hand fixes to people on the list more easily, so
I've split this pull in two.
This first part has some fixes and two performance improvements that
we've been testing for some time.
Josef's two performance fixes are most notable. The transid tracking
patch makes a big improvement on pretty much every workload"
* 'for-linus-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
Btrfs: Force stripesize to the value of sectorsize
btrfs: fix disk_i_size update bug when fallocate() fails
Btrfs: fix error handling in map_private_extent_buffer
Btrfs: fix error return code in btrfs_init_test_fs()
Btrfs: don't do nocow check unless we have to
btrfs: fix deadlock in delayed_ref_async_start
Btrfs: track transid for delayed ref flushing
Before we write into prealloc/nocow space we have to make sure that there are no
references to the extents we are writing into, which means checking the extent
tree and csum tree in the case of nocow. So we don't want to do the nocow dance
unless we can't reserve data space, since it's a serious drag on performance.
With the following sequence
fallocate -l10737418240 /mnt/btrfs-test/file
cp --reflink /mnt/btrfs-test/file /mnt/btrfs-test/link
fio --name=randwrite --rw=randwrite --bs=4k --filename=/mnt/btrfs-test/file \
--end_fsync=1
we get the worst case scenario where we have to fall back on to doing the check
anyway.
Without this patch
lat (usec): min=5, max=111598, avg=27.65, stdev=124.51
write: io=10240MB, bw=126876KB/s, iops=31718, runt= 82646msec
With this patch
lat (usec): min=3, max=91210, avg=14.09, stdev=110.62
write: io=10240MB, bw=212753KB/s, iops=53188, runt= 49286msec
We get twice the throughput, half of the runtime, and half of the average
latency. Thanks,
[ PAGE_CACHE_ removal related fixups ]
Pull btrfs cleanups and fixes from Chris Mason:
"We have another round of fixes and a few cleanups.
I have a fix for short returns from btrfs_copy_from_user, which
finally nails down a very hard to find regression we added in v4.6.
Dave is pushing around gfp parameters, mostly to cleanup internal apis
and make it a little more consistent.
The rest are smaller fixes, and one speelling fixup patch"
* 'for-linus-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (22 commits)
Btrfs: fix handling of faults from btrfs_copy_from_user
btrfs: fix string and comment grammatical issues and typos
btrfs: scrub: Set bbio to NULL before calling btrfs_map_block
Btrfs: fix unexpected return value of fiemap
Btrfs: free sys_array eb as soon as possible
btrfs: sink gfp parameter to convert_extent_bit
btrfs: make state preallocation more speculative in __set_extent_bit
btrfs: untangle gotos a bit in convert_extent_bit
btrfs: untangle gotos a bit in __clear_extent_bit
btrfs: untangle gotos a bit in __set_extent_bit
btrfs: sink gfp parameter to set_record_extent_bits
btrfs: sink gfp parameter to set_extent_new
btrfs: sink gfp parameter to set_extent_defrag
btrfs: sink gfp parameter to set_extent_delalloc
btrfs: sink gfp parameter to clear_extent_dirty
btrfs: sink gfp parameter to clear_record_extent_bits
btrfs: sink gfp parameter to clear_extent_bits
btrfs: sink gfp parameter to set_extent_bits
btrfs: make find_workspace warn if there are no workspaces
btrfs: make find_workspace always succeed
When btrfs_copy_from_user isn't able to copy all of the pages, we need
to adjust our accounting to reflect the work that was actually done.
Commit 2e78c927d79 changed around the decisions a little and we ended up
skipping the accounting adjustments some of the time. This commit makes
sure that when we don't copy anything at all, we still hop into
the adjustments, and switches to release_bytes instead of write_bytes,
since write_bytes isn't aligned.
The accounting errors led to warnings during btrfs_destroy_inode:
[ 70.847532] WARNING: CPU: 10 PID: 514 at fs/btrfs/inode.c:9350 btrfs_destroy_inode+0x2b3/0x2c0
[ 70.847536] Modules linked in: i2c_piix4 virtio_net i2c_core input_leds button led_class serio_raw acpi_cpufreq sch_fq_codel autofs4 virtio_blk
[ 70.847538] CPU: 10 PID: 514 Comm: umount Tainted: G W 4.6.0-rc6_00062_g2997da1-dirty #23
[ 70.847539] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.9.0-1.fc24 04/01/2014
[ 70.847542] 0000000000000000 ffff880ff5cafab8 ffffffff8149d5e9 0000000000000202
[ 70.847543] 0000000000000000 0000000000000000 0000000000000000 ffff880ff5cafb08
[ 70.847547] ffffffff8107bdfd ffff880ff5cafaf8 000024868120013d ffff880ff5cafb28
[ 70.847547] Call Trace:
[ 70.847550] [<ffffffff8149d5e9>] dump_stack+0x51/0x78
[ 70.847551] [<ffffffff8107bdfd>] __warn+0xfd/0x120
[ 70.847553] [<ffffffff8107be3d>] warn_slowpath_null+0x1d/0x20
[ 70.847555] [<ffffffff8139c9e3>] btrfs_destroy_inode+0x2b3/0x2c0
[ 70.847556] [<ffffffff812003a1>] ? __destroy_inode+0x71/0x140
[ 70.847558] [<ffffffff812004b3>] destroy_inode+0x43/0x70
[ 70.847559] [<ffffffff810b7b5f>] ? wake_up_bit+0x2f/0x40
[ 70.847560] [<ffffffff81200c68>] evict+0x148/0x1d0
[ 70.847562] [<ffffffff81398ade>] ? start_transaction+0x3de/0x460
[ 70.847564] [<ffffffff81200d49>] dispose_list+0x59/0x80
[ 70.847565] [<ffffffff81201ba0>] evict_inodes+0x180/0x190
[ 70.847566] [<ffffffff812191ff>] ? __sync_filesystem+0x3f/0x50
[ 70.847568] [<ffffffff811e95f8>] generic_shutdown_super+0x48/0x100
[ 70.847569] [<ffffffff810b75c0>] ? woken_wake_function+0x20/0x20
[ 70.847571] [<ffffffff811e9796>] kill_anon_super+0x16/0x30
[ 70.847573] [<ffffffff81365cde>] btrfs_kill_super+0x1e/0x130
[ 70.847574] [<ffffffff811e99be>] deactivate_locked_super+0x4e/0x90
[ 70.847576] [<ffffffff811e9e61>] deactivate_super+0x51/0x70
[ 70.847577] [<ffffffff8120536f>] cleanup_mnt+0x3f/0x80
[ 70.847579] [<ffffffff81205402>] __cleanup_mnt+0x12/0x20
[ 70.847581] [<ffffffff81098358>] task_work_run+0x68/0xa0
[ 70.847582] [<ffffffff810022b6>] exit_to_usermode_loop+0xd6/0xe0
[ 70.847583] [<ffffffff81002e1d>] do_syscall_64+0xbd/0x170
[ 70.847586] [<ffffffff817d4dbc>] entry_SYSCALL64_slow_path+0x25/0x25
This is the test program I used to force short returns from
void *dontneed(void *arg)
char *p = arg;
int ret;
while(1) {
ret = madvise(p, BUFSIZE/4, MADV_DONTNEED);
if (ret) {
perror("madvise");
exit(1);
int main(int ac, char **av) {
int ret;
int fd;
char *filename;
unsigned long offset;
char *buf;
int i;
pthread_t tid;
if (ac != 2) {
fprintf(stderr, "usage: dammitdave filename\n");
exit(1);
buf = mmap(NULL, BUFSIZE, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_ANONYMOUS, -1, 0);
if (buf == MAP_FAILED) {
perror("mmap");
exit(1);
memset(buf, 'a', BUFSIZE);
filename = av[1];
ret = pthread_create(&tid, NULL, dontneed, buf);
if (ret) {
fprintf(stderr, "error %d from pthread_create\n", ret);
exit(1);
ret = pthread_detach(tid);
if (ret) {
fprintf(stderr, "pthread detach failed %d\n", ret);
exit(1);
while (1) {
fd = open(filename, O_RDWR | O_CREAT, 0600);
if (fd < 0) {
perror("open");
exit(1);
for (i = 0; i < ROUNDS; i++) {
int this_write = BUFSIZE;
offset = rand() % MAXSIZE;
ret = pwrite(fd, buf, this_write, offset);
if (ret < 0) {
perror("pwrite");
exit(1);
} else if (ret != this_write) {
fprintf(stderr, "short write to %s offset %lu ret %d\n",
filename, offset, ret);
exit(1);
if (i == ROUNDS - 1) {
ret = sync_file_range(fd, offset, 4096,
SYNC_FILE_RANGE_WRITE);
if (ret < 0) {
perror("sync_file_range");
exit(1);
ret = ftruncate(fd, 0);
if (ret < 0) {
perror("ftruncate");
exit(1);
ret = close(fd);
if (ret) {
perror("close");
exit(1);
ret = unlink(filename);
if (ret) {
perror("unlink");
exit(1);
return 0;
Reported-by: Dave Jones <dsj@fb.com>
Fixes: 2e78c927d79333f299a8ac81c2fd2952caeef335
Signed-off-by: Nicholas D Steeves <nsteeves@gmail.com>
Pull btrfs updates from Chris Mason:
"This has our merge window series of cleanups and fixes. These target
a wide range of issues, but do include some important fixes for
qgroups, O_DIRECT, and fsync handling. Jeff Mahoney moved around a
few definitions to make them easier for userland to consume.
Also whiteout support is included now that issues with overlayfs have
been cleared up.
I have one more fix pending for page faults during btrfs_copy_from_user,
but I wanted to get this bulk out the door first"
* 'for-linus-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (90 commits)
btrfs: fix memory leak during RAID 5/6 device replacement
Btrfs: add semaphore to synchronize direct IO writes with fsync
Btrfs: fix race between block group relocation and nocow writes
Btrfs: fix race between fsync and direct IO writes for prealloc extents
Btrfs: fix number of transaction units for renames with whiteout
Btrfs: pin logs earlier when doing a rename exchange operation
Btrfs: unpin logs if rename exchange operation fails
Btrfs: fix inode leak on failure to setup whiteout inode in rename
btrfs: add support for RENAME_EXCHANGE and RENAME_WHITEOUT
Btrfs: pin log earlier when renaming
Btrfs: unpin log if rename operation fails
Btrfs: don't do unnecessary delalloc flushes when relocating
Btrfs: don't wait for unrelated IO to finish before relocation
Btrfs: fix empty symlink after creating symlink and fsync parent dir
Btrfs: fix for incorrect directory entries after fsync log replay
btrfs: build fixup for qgroup_account_snapshot
btrfs: qgroup: Fix qgroup accounting when creating snapshot
Btrfs: fix fspath error deallocation
The kiocb already has the new position, so use that. The only interesting
case is AIO, where we currently don't bother updating ki_pos. We're about
to free the kiocb after we're done, so we might as well update it to make
everyone's life simpler.
While we're at it also return the bytes written argument passed in if
we were successful so that the boilerplate error switch code in the
callers can go away.
This will allow us to do per-I/O sync file writes, as required by a lot
of fileservers or storage targets.
XXX: Will need a few additional audits for O_DSYNC
delalloc space
The delalloc reserved space is calculated in terms of number of bytes
used by an integral number of blocks. This is done by rounding down the
value of 'pos' to the nearest multiple of sectorsize.
The file offset value held by 'pos' variable may not be aligned to
sectorsize and hence when passing it as an argument to
btrfs_delalloc_release_space(), we may end up releasing larger delalloc
space than we originally had reserved.
Signed-off-by: Chandan Rajendra <chandan@linux.vnet.ibm.com>
32-bit ioctl uses these rather than the regular FS_IOC_* versions. They can
be handled in btrfs using the same code. Without this, 32-bit {ch,ls}attr
fail.
Signed-off-by: Luke Dashjr <luke-jr+git@utopios.org>
Cc: stable@vger.kernel.org
"These are bug fixes, including a really old fsync bug, and a few trace
points to help us track down problems in the quota code"
* 'for-linus-4.6' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
Btrfs: fix file/data loss caused by fsync after rename and new inode
btrfs: Reset IO error counters before start of device replacing
btrfs: Add qgroup tracing
Btrfs: don't use src fd for printk
btrfs: fallback to vmalloc in btrfs_compare_tree
btrfs: handle non-fatal errors in btrfs_qgroup_inherit()
btrfs: Output more info for enospc_debug mount option
Btrfs: fix invalid reference in replace_path
Btrfs: Improve FL_KEEP_SIZE handling in fallocate
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 bugfixes from Ted Ts'o:
"These changes contains a fix for overlayfs interacting with some
(badly behaved) dentry code in various file systems. These have been
reviewed by Al and the respective file system mtinainers and are going
through the ext4 tree for convenience.
This also has a few ext4 encryption bug fixes that were discovered in
Android testing (yes, we will need to get these sync'ed up with the
fs/crypto code; I'll take care of that). It also has some bug fixes
and a change to ignore the legacy quota options to allow for xfstests
regression testing of ext4's internal quota feature and to be more
consistent with how xfs handles this case"
* tag 'ext4_for_linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: ignore quota mount options if the quota feature is enabled
ext4 crypto: fix some error handling
ext4: avoid calling dquot_get_next_id() if quota is not enabled
ext4: retry block allocation for failed DIO and DAX writes
ext4: add lockdep annotations for i_data_sem
ext4: allow readdir()'s of large empty directories to be interrupted
btrfs: fix crash/invalid memory access on fsync when using overlayfs
ext4 crypto: use dget_parent() in ext4_d_revalidate()
ext4: use file_dentry()
ext4: use dget_parent() in ext4_file_open()
nfs: use file_dentry()
fs: add file_dentry()
ext4 crypto: don't let data integrity writebacks fail with ENOMEM
ext4: check if in-inode xattr is corrupted in ext4_expand_extra_isize_ea()
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
- We call inode_size_ok() only if FL_KEEP_SIZE isn't specified.
- As an optimisation we can skip the call if (off + len)
isn't greater than the current size of the file. This operation
is called under the lock so the less work we do, the better.
- If we call inode_size_ok() pass to it the correct value rather
than a more conservative estimation.
Signed-off-by: Davide Italiano <dccitaliano@gmail.com>
If the lower or upper directory of an overlayfs mount belong to a btrfs
file system and we fsync the file through the overlayfs' merged directory
we ended up accessing an inode that didn't belong to btrfs as if it were
a btrfs inode at btrfs_sync_file() resulting in a crash like the following:
[ 7782.588845] BUG: unable to handle kernel NULL pointer dereference at 0000000000000544
[ 7782.590624] IP: [<ffffffffa030b7ab>] btrfs_sync_file+0x11b/0x3e9 [btrfs]
[ 7782.591931] PGD 4d954067 PUD 1e878067 PMD 0
[ 7782.592016] Oops: 0002 [#6] PREEMPT SMP DEBUG_PAGEALLOC
[ 7782.592016] Modules linked in: btrfs overlay ppdev crc32c_generic evdev xor raid6_pq psmouse pcspkr sg serio_raw acpi_cpufreq parport_pc parport tpm_tis i2c_piix4 tpm i2c_core processor button loop autofs4 ext4 crc16 mbcache jbd2 sr_mod cdrom sd_mod ata_generic virtio_scsi ata_piix virtio_pci libata virtio_ring virtio scsi_mod e1000 floppy [last unloaded: btrfs]
[ 7782.592016] CPU: 10 PID: 16437 Comm: xfs_io Tainted: G D 4.5.0-rc6-btrfs-next-26+ #1
[ 7782.592016] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS by qemu-project.org 04/01/2014
[ 7782.592016] task: ffff88001b8d40c0 ti: ffff880137488000 task.ti: ffff880137488000
[ 7782.592016] RIP: 0010:[<ffffffffa030b7ab>] [<ffffffffa030b7ab>] btrfs_sync_file+0x11b/0x3e9 [btrfs]
[ 7782.592016] RSP: 0018:ffff88013748be40 EFLAGS: 00010286
[ 7782.592016] RAX: 0000000080000000 RBX: ffff880133b30c88 RCX: 0000000000000001
[ 7782.592016] RDX: 0000000000000001 RSI: ffffffff8148fec0 RDI: 00000000ffffffff
[ 7782.592016] RBP: ffff88013748bec0 R08: 0000000000000001 R09: 0000000000000000
[ 7782.624248] R10: ffff88013748be40 R11: 0000000000000246 R12: 0000000000000000
[ 7782.624248] R13: 0000000000000000 R14: 00000000009305a0 R15: ffff880015e3be40
[ 7782.624248] FS: 00007fa83b9cb700(0000) GS:ffff88023ed40000(0000) knlGS:0000000000000000
[ 7782.624248] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 7782.624248] CR2: 0000000000000544 CR3: 00000001fa652000 CR4: 00000000000006e0
[ 7782.624248] Stack:
[ 7782.624248] ffffffff8108b5cc ffff88013748bec0 0000000000000246 ffff8800b005ded0
[ 7782.624248] ffff880133b30d60 8000000000000000 7fffffffffffffff 0000000000000246
[ 7782.624248] 0000000000000246 ffffffff81074f9b ffffffff8104357c ffff880015e3be40
[ 7782.624248] Call Trace:
[ 7782.624248] [<ffffffff8108b5cc>] ? arch_local_irq_save+0x9/0xc
[ 7782.624248] [<ffffffff81074f9b>] ? ___might_sleep+0xce/0x217
[ 7782.624248] [<ffffffff8104357c>] ? __do_page_fault+0x3c0/0x43a
[ 7782.624248] [<ffffffff811a2351>] vfs_fsync_range+0x8c/0x9e
[ 7782.624248] [<ffffffff811a237f>] vfs_fsync+0x1c/0x1e
[ 7782.624248] [<ffffffff811a24d6>] do_fsync+0x31/0x4a
[ 7782.624248] [<ffffffff811a2700>] SyS_fsync+0x10/0x14
[ 7782.624248] [<ffffffff81493617>] entry_SYSCALL_64_fastpath+0x12/0x6b
[ 7782.624248] Code: 85 c0 0f 85 e2 02 00 00 48 8b 45 b0 31 f6 4c 29 e8 48 ff c0 48 89 45 a8 48 8d 83 d8 00 00 00 48 89 c7 48 89 45 a0 e8 fc 43 18 e1 <f0> 41 ff 84 24 44 05 00 00 48 8b 83 58 ff ff ff 48 c1 e8 07 83
[ 7782.624248] RIP [<ffffffffa030b7ab>] btrfs_sync_file+0x11b/0x3e9 [btrfs]
[ 7782.624248] RSP <ffff88013748be40>
[ 7782.661994] ---[ end trace 721e14960eb939bc ]---
This started happening since commit 4bacc9c9234 (overlayfs: Make f_path
always point to the overlay and f_inode to the underlay) and even though
after this change we could still access the btrfs inode through
struct file->f_mapping->host or struct file->f_inode, we would end up
resulting in more similar issues later on at check_parent_dirs_for_sync()
because the dentry we got (from struct file->f_path.dentry) was from
overlayfs and not from btrfs, that is, we had no way of getting the dentry
that belonged to btrfs (we always got the dentry that belonged to
overlayfs).
The new patch from Miklos Szeredi, titled "vfs: add file_dentry()" and
recently submitted to linux-fsdevel, adds a file_dentry() API that allows
us to get the btrfs dentry from the input file and therefore being able
to fsync when the upper and lower directories belong to btrfs filesystems.
This issue has been reported several times by users in the mailing list
and bugzilla. A test case for xfstests is being submitted as well.
Fixes: 4bacc9c9234c ("overlayfs: Make f_path always point to the overlay and f_inode to the underlay")
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=101951
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=109791
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
So that its better organized.
Signed-off-by: Anand Jain <anand.jain@oracle.com>
If we're about to do a fast fsync for an inode and btrfs_inode_in_log()
returns false, it's possible that we had an ordered extent in progress
(btrfs_finish_ordered_io() not run yet) when we noticed that the inode's
last_trans field was not greater than the id of the last committed
transaction, but shortly after, before we checked if there were any
ongoing ordered extents, the ordered extent had just completed and
removed itself from the inode's ordered tree, in which case we end up not
logging the inode, losing some data if a power failure or crash happens
after the fsync handler returns and before the transaction is committed.
Fix this by checking first if there are any ongoing ordered extents
before comparing the inode's last_trans with the id of the last committed
transaction - when it completes, an ordered extent always updates the
inode's last_trans before it removes itself from the inode's ordered
tree (at btrfs_finish_ordered_io()).
# Conflicts:
# fs/btrfs/file.c
# Conflicts:
# fs/btrfs/file.c
btrfs failed in xfstests btrfs/080 with -o nodatacow.
Can be reproduced by following script:
DEV=/dev/vdg
MNT=/mnt/tmp
umount $DEV &>/dev/null
mkfs.btrfs -f $DEV
mount -o nodatacow $DEV $MNT
dd if=/dev/zero of=$MNT/test bs=1 count=2048 &
btrfs subvolume snapshot -r $MNT $MNT/test_snap &
wait
We can see dd failed on NO_SPACE.
Reason:
__btrfs_buffered_write should run cow write when no_cow impossible,
and current code is designed with above logic.
But check_can_nocow() have 2 type of return value(0 and <0) on
can_not_no_cow, and current code only continue write on first case,
the second case happened in doing subvolume.
Fix:
Continue write when check_can_nocow() return 0 and <0.
Reviewed-by: Filipe Manana <fdmanana@suse.com>
Signed-off-by: Zhao Lei <zhaolei@cn.fujitsu.com>
Cleanup.
kmem_cache_destroy has support NULL argument checking,
so drop the double null testing before calling it.
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
CURRENT_TIME macro is not appropriate for filesystems as it
doesn't use the right granularity for filesystem timestamps.
Use current_fs_time() instead.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Cc: Chris Mason <clm@fb.com>
Cc: Josef Bacik <jbacik@fb.com>
Cc: linux-btrfs@vger.kernel.org
Fallocate is initiated from userspace and is not on the critical
writeback path, we don't need to use GFP_NOFS for allocations.
When extending a file by either "truncate up" or by writing beyond i_size, the
page which had i_size needs to be marked "read only" so that future writes to
the page via mmap interface causes btrfs_page_mkwrite() to be invoked. If not,
a write performed after extending the file via the mmap interface will find
the page to be writaeable and continue writing to the page without invoking
btrfs_page_mkwrite() i.e. we end up writing to a file without reserving disk
space.
While at it, this commit changes btrfs_truncate_page() to truncate sectorsized
blocks instead of pages. Hence the function has been renamed to
btrfs_truncate_block().
Currently, the code reserves/releases extents in multiples of PAGE_CACHE_SIZE
units. Fix this by doing reservation/releases in block size units.
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested},
inode_foo(inode) being mutex_foo(&inode->i_mutex).
Please, use those for access to ->i_mutex; over the coming cycle
->i_mutex will become rwsem, with ->lookup() done with it held
only shared.
Pull more btrfs updates from Chris Mason:
"These are mostly fixes that we've been testing, but also we grabbed
and tested a few small cleanups that had been on the list for a while.
Zhao Lei's patchset also fixes some early ENOSPC buglets"
* 'for-linus-4.5' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (21 commits)
btrfs: raid56: Use raid_write_end_io for scrub
btrfs: Remove unnecessary ClearPageUptodate for raid56
btrfs: use rbio->nr_pages to reduce calculation
btrfs: Use unified stripe_page's index calculation
btrfs: Fix calculation of rbio->dbitmap's size calculation
btrfs: Fix no_space in write and rm loop
btrfs: merge functions for wait snapshot creation
btrfs: delete unused argument in btrfs_copy_from_user
btrfs: Use direct way to determine raid56 write/recover mode
btrfs: Small cleanup for get index_srcdev loop
btrfs: Enhance chunk validation check
btrfs: Enhance super validation check
Btrfs: fix deadlock running delayed iputs at transaction commit time
Btrfs: fix typo in log message when starting a balance
btrfs: remove duplicate const specifier
btrfs: initialize the seq counter in struct btrfs_device
Btrfs: clean up an error code in btrfs_init_space_info()
btrfs: fix iterator with update error in backref.c
Btrfs: fix output of compression message in btrfs_parse_options()
Btrfs: Initialize btrfs_root->highest_objectid when loading tree root and subvolume roots
size_t write_bytes is not necessary for btrfs_copy_from_user(),
delete it.
"This has our usual assortment of fixes and cleanups, but the biggest
change included is Omar Sandoval's free space tree. It's not the
default yet, mounting -o space_cache=v2 enables it and sets a readonly
compat bit. The tree can actually be deleted and regenerated if there
are any problems, but it has held up really well in testing so far.
For very large filesystems (30T+) our existing free space caching code
can end up taking a huge amount of time during commits. The new tree
based code is faster and less work overall to update as the commit
progresses.
Omar worked on this during the summer and we'll hammer on it in
production here at FB over the next few months"
* 'for-linus-4.5' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (73 commits)
Btrfs: fix fitrim discarding device area reserved for boot loader's use
Btrfs: Check metadata redundancy on balance
btrfs: statfs: report zero available if metadata are exhausted
btrfs: preallocate path for snapshot creation at ioctl time
btrfs: allocate root item at snapshot ioctl time
btrfs: do an allocation earlier during snapshot creation
btrfs: use smaller type for btrfs_path locks
btrfs: use smaller type for btrfs_path lowest_level
btrfs: use smaller type for btrfs_path reada
btrfs: cleanup, use enum values for btrfs_path reada
btrfs: constify static arrays
btrfs: constify remaining structs with function pointers
btrfs tests: replace whole ops structure for free space tests
btrfs: use list_for_each_entry* in backref.c
btrfs: use list_for_each_entry_safe in free-space-cache.c
btrfs: use list_for_each_entry* in check-integrity.c
Btrfs: use linux/sizes.h to represent constants
btrfs: cleanup, remove stray return statements
btrfs: zero out delayed node upon allocation
btrfs: pass proper enum type to start_transaction()
Pull vfs copy_file_range updates from Al Viro:
"Several series around copy_file_range/CLONE"
* 'work.copy_file_range' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
btrfs: use new dedupe data function pointer
vfs: hoist the btrfs deduplication ioctl to the vfs
vfs: wire up compat ioctl for CLONE/CLONE_RANGE
cifs: avoid unused variable and label
nfsd: implement the NFSv4.2 CLONE operation
nfsd: Pass filehandle to nfs4_preprocess_stateid_op()
vfs: pull btrfs clone API to vfs layer
locks: new locks_mandatory_area calling convention
vfs: Add vfs_copy_file_range() support for pagecache copies
btrfs: add .copy_file_range file operation
x86: add sys_copy_file_range to syscall tables
vfs: add copy_file_range syscall and vfs helper
Now that the VFS encapsulates the dedupe ioctl, wire up btrfs to it.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kdave/linux into for-linus-4.5
"A couple of small fixes"
* 'for-linus-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
Btrfs: check prepare_uptodate_page() error code earlier
Btrfs: check for empty bitmap list in setup_cluster_bitmaps
btrfs: fix misleading warning when space cache failed to load
Btrfs: fix transaction handle leak in balance
Btrfs: fix unprotected list move from unused_bgs to deleted_bgs list
