Btrfs needs to be able to control how filemap_write_and_wait_range() is called
in fsync to make it less of a painful operation, so push down taking i_mutex and
the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some
file systems can drop taking the i_mutex altogether it seems, like ext3 and
ocfs2. For correctness sake I just pushed everything down in all cases to make
sure that we keep the current behavior the same for everybody, and then each
individual fs maintainer can make up their mind about what to do from there.
Thanks,
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Josef Bacik <josef@redhat.com>
In order to handle SEEK_HOLE/SEEK_DATA we need to implement our own llseek.
Basically for the normal SEEK_*'s we will just defer to the generic helper, and
for SEEK_HOLE/SEEK_DATA we will use our fiemap helper to figure out the nearest
hole or data. Currently this helper doesn't check for delalloc bytes for
prealloc space, so for now treat prealloc as data until that is fixed. Thanks,
wrap checking of filesystem 'closing' flag and fix a few missing memory
barriers.
Signed-off-by: David Sterba <dsterba@suse.cz>
commit 4cb5300bc ("Btrfs: add mount -o auto_defrag") accesses inode
number directly while it should use the helper with the new inode
number allocator.
Signed-off-by: Chris Mason <chris.mason@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/josef/btrfs-work into for-linus
fs/btrfs/disk-io.c
fs/btrfs/extent-tree.c
fs/btrfs/free-space-cache.c
fs/btrfs/inode.c
fs/btrfs/transaction.c
This will detect small random writes into files and
queue the up for an auto defrag process. It isn't well suited to
database workloads yet, but works for smaller files such as rpm, sqlite
or bdb databases.
We use trans_mutex for lots of things, here's a basic list
1) To serialize trans_handles joining the currently running transaction
2) To make sure that no new trans handles are started while we are committing
3) To protect the dead_roots list and the transaction lists
Really the serializing trans_handles joining is not too hard, and can really get
bogged down in acquiring a reference to the transaction. So replace the
trans_mutex with a trans_lock spinlock and use it to do the following
1) Protect fs_info->running_transaction. All trans handles have to do is check
this, and then take a reference of the transaction and keep on going.
2) Protect the fs_info->trans_list. This doesn't get used too much, basically
it just holds the current transactions, which will usually just be the currently
committing transaction and the currently running transaction at most.
3) Protect the dead roots list. This is only ever processed by splicing the
list so this is relatively simple.
4) Protect the fs_info->reloc_ctl stuff. This is very lightweight and was using
the trans_mutex before, so this is a pretty straightforward change.
5) Protect fs_info->no_trans_join. Because we don't hold the trans_lock over
the entirety of the commit we need to have a way to block new people from
creating a new transaction while we're doing our work. So we set no_trans_join
and in join_transaction we test to see if that is set, and if it is we do a
wait_on_commit.
6) Make the transaction use count atomic so we don't need to take locks to
modify it when we're dropping references.
7) Add a commit_lock to the transaction to make sure multiple people trying to
commit the same transaction don't race and commit at the same time.
8) Make open_ioctl_trans an atomic so we don't have to take any locks for ioctl
trans.
I have tested this with xfstests, but obviously it is a pretty hairy change so
lots of testing is greatly appreciated. Thanks,
inode_numbers
fs/btrfs/inode.c
fs/btrfs/tree-log.c
parameter tree root it's not used since commit
5f39d397dfbe140a14edecd4e73c34ce23c4f9ee ("Btrfs: Create extent_buffer
interface for large blocksizes")
pass GFP_NOFS directly to kmem_cache_alloc
use IS_ERR_OR_NULL when possible, done by this coccinelle script:
@ match @
identifier id;
- BUG_ON(IS_ERR(id) || !id);
+ BUG_ON(IS_ERR_OR_NULL(id));
- IS_ERR(id) || !id
+ IS_ERR_OR_NULL(id)
- !id || IS_ERR(id)
There's a potential problem in 32bit system when we exhaust 32bit inode
numbers and start to allocate big inode numbers, because btrfs uses
inode->i_ino in many places.
So here we always use BTRFS_I(inode)->location.objectid, which is an
u64 variable.
There are 2 exceptions that BTRFS_I(inode)->location.objectid !=
inode->i_ino: the btree inode (0 vs 1) and empty subvol dirs (256 vs 2),
and inode->i_ino will be used in those cases.
Another reason to make this change is I'm going to use a special inode
to save free ino cache, and the inode number must be > (u64)-256.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Currently we don't handle running out of space in the cache, so to fix this we
keep track of how far in the cache we are. Then we only dirty the pages if we
successfully modify all of them, otherwise if we have an error or run out of
space we can just drop them and not worry about the vm writing them out.
Thanks,
Tested-by Johannes Hirte <johannes.hirte@fem.tu-ilmenau.de>
While compiling Btrfs, I got following messages:
CC [M] fs/btrfs/file.o
fs/btrfs/file.c: In function '__btrfs_buffered_write':
fs/btrfs/file.c:909: warning: 'ret' may be used uninitialized in this function
CC [M] fs/btrfs/tree-defrag.o
This patch fixes compiler warning.
Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com>
Tracepoints can provide insight into why btrfs hits bugs and be greatly
helpful for debugging, e.g
dd-7822 [000] 2121.641088: btrfs_inode_request: root = 5(FS_TREE), gen = 4, ino = 256, blocks = 8, disk_i_size = 0, last_trans = 8, logged_trans = 0
dd-7822 [000] 2121.641100: btrfs_inode_new: root = 5(FS_TREE), gen = 8, ino = 257, blocks = 0, disk_i_size = 0, last_trans = 0, logged_trans = 0
btrfs-transacti-7804 [001] 2146.935420: btrfs_cow_block: root = 2(EXTENT_TREE), refs = 2, orig_buf = 29368320 (orig_level = 0), cow_buf = 29388800 (cow_level = 0)
btrfs-transacti-7804 [001] 2146.935473: btrfs_cow_block: root = 1(ROOT_TREE), refs = 2, orig_buf = 29364224 (orig_level = 0), cow_buf = 29392896 (cow_level = 0)
btrfs-transacti-7804 [001] 2146.972221: btrfs_transaction_commit: root = 1(ROOT_TREE), gen = 8
flush-btrfs-2-7821 [001] 2155.824210: btrfs_chunk_alloc: root = 3(CHUNK_TREE), offset = 1103101952, size = 1073741824, num_stripes = 1, sub_stripes = 0, type = DATA
flush-btrfs-2-7821 [001] 2155.824241: btrfs_cow_block: root = 2(EXTENT_TREE), refs = 2, orig_buf = 29388800 (orig_level = 0), cow_buf = 29396992 (cow_level = 0)
flush-btrfs-2-7821 [001] 2155.824255: btrfs_cow_block: root = 4(DEV_TREE), refs = 2, orig_buf = 29372416 (orig_level = 0), cow_buf = 29401088 (cow_level = 0)
flush-btrfs-2-7821 [000] 2155.824329: btrfs_cow_block: root = 3(CHUNK_TREE), refs = 2, orig_buf = 20971520 (orig_level = 0), cow_buf = 20975616 (cow_level = 0)
btrfs-endio-wri-7800 [001] 2155.898019: btrfs_cow_block: root = 5(FS_TREE), refs = 2, orig_buf = 29384704 (orig_level = 0), cow_buf = 29405184 (cow_level = 0)
btrfs-endio-wri-7800 [001] 2155.898043: btrfs_cow_block: root = 7(CSUM_TREE), refs = 2, orig_buf = 29376512 (orig_level = 0), cow_buf = 29409280 (cow_level = 0)
Here is what I have added:
1) ordere_extent:
btrfs_ordered_extent_add
btrfs_ordered_extent_remove
btrfs_ordered_extent_start
btrfs_ordered_extent_put
These provide critical information to understand how ordered_extents are
updated.
2) extent_map:
btrfs_get_extent
extent_map is used in both read and write cases, and it is useful for tracking
how btrfs specific IO is running.
3) writepage:
__extent_writepage
btrfs_writepage_end_io_hook
Pages are cirtical resourses and produce a lot of corner cases during writeback,
so it is valuable to know how page is written to disk.
4) inode:
btrfs_inode_new
btrfs_inode_request
btrfs_inode_evict
These can show where and when a inode is created, when a inode is evicted.
5) sync:
btrfs_sync_file
btrfs_sync_fs
These show sync arguments.
6) transaction:
In transaction based filesystem, it will be useful to know the generation and
who does commit.
7) back reference and cow:
btrfs_delayed_tree_ref
btrfs_delayed_data_ref
btrfs_delayed_ref_head
btrfs_cow_block
Btrfs natively supports back references, these tracepoints are helpful on
understanding btrfs's COW mechanism.
8) chunk:
btrfs_chunk_alloc
btrfs_chunk_free
Chunk is a link between physical offset and logical offset, and stands for space
infomation in btrfs, and these are helpful on tracing space things.
9) reserved_extent:
btrfs_reserved_extent_alloc
btrfs_reserved_extent_free
These can show how btrfs uses its space.
Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com>
Doing an audit of where we use btrfs_search_slot only showed one place where we
don't check the return value of btrfs_search_slot properly. Just fix
mark_extent_written to see if btrfs_search_slot failed and act accordingly.
Thanks,
->truncate() is going away, instead all of the work needs to be done in
->setattr(). So this converts us over to do this. It's fairly straightforward,
just get rid of our .truncate inode operation and call btrfs_truncate() directly
from btrfs_setsize. This works out better for us since truncate can technically
return ENOSPC, and before we had no way of letting anybody know. Thanks,
Really we don't need to memset the pages array at all, since we know how many
pages we're going to use in the array and pass that around. So don't memset,
just trust we're not idiots and we pass num_pages around properly.
Our aio_write function is huge and kind of hard to follow at times. So this
patch fixes this by breaking out the buffered and direct write paths out into
seperate functions so it's a little clearer what's going on. I've also fixed
some wrong typing that we had and added the ability to handle getting an error
back from btrfs_set_extent_delalloc. Tested this with xfstests and everything
came out fine. Thanks,
Sorry, but these were bugging me. Just cleanup some of the formatting in
file.c.
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable:
Btrfs: break out of shrink_delalloc earlier
btrfs: fix not enough reserved space
btrfs: fix dip leak
Btrfs: make sure not to return overlapping extents to fiemap
Btrfs: deal with short returns from copy_from_user
Btrfs: fix regressions in copy_from_user handling
When copy_from_user is only able to copy some of the bytes we requested,
we may end up creating a partially up to date page. To avoid garbage in
the page, we need to treat a partial copy as a zero length copy.
This makes the rest of the file_write code drop the page and
retry the whole copy instead of marking the partially up to
date page as dirty.
cc: stable@kernel.org
Commit 914ee295af418e936ec20a08c1663eaabe4cd07a fixed deadlocks in
btrfs_file_write where we would catch page faults on pages we had
locked.
But, there were a few problems:
1) The x86-32 iov_iter_copy_from_user_atomic code always fails to copy
data when the amount to copy is more than 4K and the offset to start
copying from is not page aligned. The result was btrfs_file_write
looping forever retrying the iov_iter_copy_from_user_atomic
We deal with this by changing btrfs_file_write to drop down to single
page copies when iov_iter_copy_from_user_atomic starts returning failure.
2) The btrfs_file_write code was leaking delalloc reservations when
iov_iter_copy_from_user_atomic returned zero. The looping above would
result in the entire filesystem running out of delalloc reservations and
constantly trying to flush things to disk.
3) btrfs_file_write will lock down page cache pages, make sure
any writeback is finished, do the copy_from_user and then release them.
Before the loop runs we check the first and last pages in the write to
see if they are only being partially modified. If the start or end of
the write isn't aligned, we make sure the corresponding pages are
up to date so that we don't introduce garbage into the file.
With the copy_from_user changes, we're allowing the VM to reclaim the
pages after a partial update from copy_from_user, but we're not
making sure the page cache page is up to date when we loop around to
resume the write.
We deal with this by pushing the up to date checks down into the page
prep code. This fits better with how the rest of file_write works.
Reported-by: Mitch Harder <mitch.harder@sabayonlinux.org>
Btrfs: check return value of alloc_extent_map()
Btrfs - Fix memory leak in btrfs_init_new_device()
btrfs: prevent heap corruption in btrfs_ioctl_space_info()
Btrfs: Fix balance panic
Btrfs: don't release pages when we can't clear the uptodate bits
Btrfs: fix page->private races
I add the check on the return value of alloc_extent_map() to several places.
In addition, alloc_extent_map() returns only the address or NULL.
Therefore, check by IS_ERR() is unnecessary. So, I remove IS_ERR() checking.
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (33 commits)
Btrfs: Fix page count calculation
btrfs: Drop __exit attribute on btrfs_exit_compress
btrfs: cleanup error handling in btrfs_unlink_inode()
Btrfs: exclude super blocks when we read in block groups
Btrfs: make sure search_bitmap finds something in remove_from_bitmap
btrfs: fix return value check of btrfs_start_transaction()
btrfs: checking NULL or not in some functions
Btrfs: avoid uninit variable warnings in ordered-data.c
Btrfs: catch errors from btrfs_sync_log
Btrfs: make shrink_delalloc a little friendlier
Btrfs: handle no memory properly in prepare_pages
Btrfs: do error checking in btrfs_del_csums
Btrfs: use the global block reserve if we cannot reserve space
Btrfs: do not release more reserved bytes to the global_block_rsv than we need
Btrfs: fix check_path_shared so it returns the right value
btrfs: check return value of btrfs_start_ioctl_transaction() properly
btrfs: fix return value check of btrfs_join_transaction()
fs/btrfs/inode.c: Add missing IS_ERR test
btrfs: fix missing break in switch phrase
btrfs: fix several uncheck memory allocations
take offset of start position into account when calculating page count.
Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com>
Instead of doing a BUG_ON(1) in prepare_pages if grab_cache_page() fails, just
loop through the pages we've already grabbed and unlock and release them, then
return -ENOMEM like we should. Thanks,
To make btrfs more stable, add several missing necessary memory allocation
checks, and when no memory, return proper errno.
We've checked that some of those -ENOMEM errors will be returned to
userspace, and some will be catched by BUG_ON() in the upper callers,
and none will be ignored silently.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (25 commits)
Btrfs: forced readonly mounts on errors
btrfs: Require CAP_SYS_ADMIN for filesystem rebalance
Btrfs: don't warn if we get ENOSPC in btrfs_block_rsv_check
btrfs: Fix memory leak in btrfs_read_fs_root_no_radix()
btrfs: check NULL or not
btrfs: Don't pass NULL ptr to func that may deref it.
btrfs: mount failure return value fix
btrfs: Mem leak in btrfs_get_acl()
btrfs: fix wrong free space information of btrfs
btrfs: make the chunk allocator utilize the devices better
btrfs: restructure find_free_dev_extent()
btrfs: fix wrong calculation of stripe size
btrfs: try to reclaim some space when chunk allocation fails
btrfs: fix wrong data space statistics
fs/btrfs: Fix build of ctree
Btrfs: fix off by one while setting block groups readonly
Btrfs: Add BTRFS_IOC_SUBVOL_GETFLAGS/SETFLAGS ioctls
Btrfs: Add readonly snapshots support
Btrfs: Refactor btrfs_ioctl_snap_create()
btrfs: Extract duplicate decompress code
This patch comes from "Forced readonly mounts on errors" ideas.
As we know, this is the first step in being more fault tolerant of disk
corruptions instead of just using BUG() statements.
The major content:
- add a framework for generating errors that should result in filesystems
going readonly.
- keep FS state in disk super block.
- make sure that all of resource will be freed and released at umount time.
- make sure that fter FS is forced readonly on error, there will be no more
disk change before FS is corrected. For this, we should stop write operation.
After this patch is applied, the conversion from BUG() to such a framework can
happen incrementally.
Currently all filesystems except XFS implement fallocate asynchronously,
while XFS forced a commit. Both of these are suboptimal - in case of O_SYNC
I/O we really want our allocation on disk, especially for the !KEEP_SIZE
case where we actually grow the file with user-visible zeroes. On the
other hand always commiting the transaction is a bad idea for fast-path
uses of fallocate like for example in recent Samba versions. Given
that block allocation is a data plane operation anyway change it from
an inode operation to a file operation so that we have the file structure
available that lets us check for O_SYNC.
This also includes moving the code around for a few of the filesystems,
and remove the already unnedded S_ISDIR checks given that we only wire
up fallocate for regular files.
Make the code aware of compression type, instead of always assuming
zlib compression.
Also make the zlib workspace function as common code for all
compression types.
This problem is found in meego testing:
http://bugs.meego.com/show_bug.cgi?id=6672
A file in btrfs is mmaped and the mmaped buffer is passed to pwrite to write to the same page
of the same file. In btrfs_file_aio_write(), the pages is locked by prepare_pages(). So when
btrfs_copy_from_user() is called, page fault happens and the same page needs to be locked again
in filemap_fault(). The fix is to move iov_iter_fault_in_readable() before prepage_pages() to make page
fault happen before pages are locked. And also disable page fault in critical region in
btrfs_copy_from_user().
Reviewed-by: Yan, Zheng<zheng.z.yan@intel.com>
Signed-off-by: Zhong, Xin <xin.zhong@intel.com>
Since we walk up the path logging all of the parts of the inode's path, we need
to hold i_mutex to make sure that the inode is not renamed while we're logging
everything. btrfs_log_dentry_safe does dget_parent and all of that jazz, but we
may get unexpected results if the rename changes the inode's location while
we're higher up the path logging those dentries, so do this for safety reasons.
Thanks,
Btrfs: The file argument for fsync() is never null
Btrfs: handle ERR_PTR from posix_acl_from_xattr()
Btrfs: avoid BUG when dropping root and reference in same transaction
Btrfs: prohibit a operation of changing acl's mask when noacl mount option used
Btrfs: should add a permission check for setfacl
Btrfs: btrfs_lookup_dir_item() can return ERR_PTR
Btrfs: btrfs_read_fs_root_no_name() returns ERR_PTRs
Btrfs: unwind after btrfs_start_transaction() errors
Btrfs: btrfs_iget() returns ERR_PTR
Btrfs: handle kzalloc() failure in open_ctree()
Btrfs: handle error returns from btrfs_lookup_dir_item()
Btrfs: Fix BUG_ON for fs converted from extN
Btrfs: Fix null dereference in relocation.c
Btrfs: fix remap_file_pages error
Btrfs: uninitialized data is check_path_shared()
Btrfs: fix fallocate regression
Btrfs: fix loop device on top of btrfs
The "file" argument for fsync is never null so we can remove this check.
What drew my attention here is that 7ea8085910e: "drop unused dentry
argument to ->fsync" introduced an unconditional dereference at the
start of the function and that generated a smatch warning.
when we use remap_file_pages() to remap a file, remap_file_pages always return
error. It is because btrfs didn't set VM_CAN_NONLINEAR for vma.
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
We cannot use the loop device which has been connected to a file in the btrf
The reproduce steps is following:
# dd if=/dev/zero of=vdev0 bs=1M count=1024
# losetup /dev/loop0 vdev0
# mkfs.btrfs /dev/loop0
failed to zero device start -5
The reason is that the btrfs don't implement either ->write_begin or ->write
the VFS API, so we fix it by setting ->write to do_sync_write().
This moves the delalloc space reservation done for O_DIRECT
into btrfs_direct_IO. This way we don't leak reserved space
if the generic O_DIRECT write code errors out before it
calls into btrfs_direct_IO.
This changes O_DIRECT write code to mark extents as delalloc
while it is processing them. Yan Zheng has reworked the
enospc accounting based on tracking delalloc extents and
this makes it much easier to track enospc in the O_DIRECT code.
There are a few space cases with the O_DIRECT code though,
it only sets the EXTENT_DELALLOC bits, instead of doing
EXTENT_DELALLOC | EXTENT_DIRTY | EXTENT_UPTODATE, because
we don't want to mess with clearing the dirty and uptodate
bits when things go wrong. This is important because there
are no pages in the page cache, so any extent state structs
that we put in the tree won't get freed by releasepage. We have
to clear them ourselves as the DIO ends.
With this commit, we reserve space at in btrfs_file_aio_write,
and then as each btrfs_direct_IO call progresses it sets
EXTENT_DELALLOC on the range.
btrfs_get_blocks_direct is responsible for clearing the delalloc
at the same time it drops the extent lock.
In order for AIO to work, we need to implement aio_write. This patch converts
our btrfs_file_write to btrfs_aio_write. I've tested this with xfstests and
nothing broke, and the AIO stuff magically started working. Thanks,
This provides basic DIO support for reading and writing. It does not do the
work to recover from mismatching checksums, that will come later. A few design
changes have been made from Jim's code (sorry Jim!)
1) Use the generic direct-io code. Jim originally re-wrote all the generic DIO
code in order to account for all of BTRFS's oddities, but thanks to that work it
seems like the best bet is to just ignore compression and such and just opt to
fallback on buffered IO.
2) Fallback on buffered IO for compressed or inline extents. Jim's code did
it's own buffering to make dio with compressed extents work. Now we just
fallback onto normal buffered IO.
3) Use ordered extents for the writes so that all of the
lock_extent()
lookup_ordered()
type checks continue to work.
4) Do the lock_extent() lookup_ordered() loop in readpage so we don't race with
DIO writes.
I've tested this with fsx and everything works great. This patch depends on my
dio and filemap.c patches to work. Thanks,
Introduce metadata reservation context for delayed allocation
and update various related functions.
This patch also introduces EXTENT_FIRST_DELALLOC control bit for
set/clear_extent_bit. It tells set/clear_bit_hook whether they
are processing the first extent_state with EXTENT_DELALLOC bit
set. This change is important if set/clear_extent_bit involves
multiple extent_state.
Signed-off-by: Yan Zheng <zheng.yan@oracle.com>
Besides simplify the code, this change makes sure all metadata
reservation for normal metadata operations are released after
committing transaction.
Changes since V1:
Add code that check if unlink and rmdir will free space.
Add ENOSPC handling for clone ioctl.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (30 commits)
Btrfs: fix the inode ref searches done by btrfs_search_path_in_tree
Btrfs: allow treeid==0 in the inode lookup ioctl
Btrfs: return keys for large items to the search ioctl
Btrfs: fix key checks and advance in the search ioctl
Btrfs: buffer results in the space_info ioctl
Btrfs: use __u64 types in ioctl.h
Btrfs: fix search_ioctl key advance
Btrfs: fix gfp flags masking in the compression code
Btrfs: don't look at bio flags after submit_bio
btrfs: using btrfs_stack_device_id() get devid
btrfs: use memparse
Btrfs: add a "df" ioctl for btrfs
Btrfs: cache the extent state everywhere we possibly can V2
Btrfs: cache ordered extent when completing io
Btrfs: cache extent state in find_delalloc_range
Btrfs: change the ordered tree to use a spinlock instead of a mutex
Btrfs: finish read pages in the order they are submitted
btrfs: fix btrfs_mkdir goto for no free objectids
Btrfs: flush data on snapshot creation
Btrfs: make df be a little bit more understandable
This patch just goes through and fixes everybody that does
lock_extent()
blah
unlock_extent()
to use
lock_extent_bits()
blah
unlock_extent_cached()
and pass around a extent_state so we only have to do the searches once per
function. This gives me about a 3 mb/s boots on my random write test. I have
not converted some things, like the relocation and ioctl's, since they aren't
heavily used and the relocation stuff is in the middle of being re-written. I
also changed the clear_extent_bit() to only unset the cached state if we are
clearing EXTENT_LOCKED and related stuff, so we can do things like this
lock_extent_bits()
clear delalloc bits
without losing our cached state. I tested this thoroughly and turned on
LEAK_DEBUG to make sure we weren't leaking extent states, everything worked out
fine.
Btrfs: btrfs_mark_extent_written uses the wrong slot
