path: root/fs/btrfs/extent-tree.c
2014-02-08Btrfs: don't loop forever if we can't run because of the tree mod logJosef Bacik
A user reported a 100% cpu hang with my new delayed ref code. Turns out I forgot to increase the count check when we can't run a delayed ref because of the tree mod log. If we can't run any delayed refs during this there is no point in continuing to look, and we need to break out. Thanks, Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-29Btrfs: fix spin_unlock in check_ref_cleanupChris Mason
Our goto out should have gone a little farther. Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28Btrfs: fix wrong block group in trace during the free space allocationMiao Xie
We allocate the free space from the former block group, not the current one, so should use the former one to output the trace information. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28Btrfs: cleanup the code of used_block_group in find_free_extent()Miao Xie
used_block_group is just used for the space cluster which doesn't belong to the current block group, the other place needn't use it. Or the logic of code seems unclear. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28Btrfs: cleanup the redundant code for the block group allocation and initMiao Xie
2014-01-28Btrfs: fix btrfs boot when compiled as built-inFilipe David Borba Manana
After the change titled "Btrfs: add support for inode properties", if btrfs was built-in the kernel (i.e. not as a module), it would cause a kernel panic, as reported recently by Fengguang: [ 2.024722] BUG: unable to handle kernel NULL pointer dereference at (null) [ 2.027814] IP: [<ffffffff81501594>] crc32c+0xc/0x6b [ 2.028684] PGD 0 [ 2.028684] Oops: 0000 [#1] SMP [ 2.028684] Modules linked in: [ 2.028684] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.13.0-rc7-04795-ga7b57c2 #1 [ 2.028684] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 [ 2.028684] task: ffff88000edba100 ti: ffff88000edd6000 task.ti: ffff88000edd6000 [ 2.028684] RIP: 0010:[<ffffffff81501594>] [<ffffffff81501594>] crc32c+0xc/0x6b [ 2.028684] RSP: 0000:ffff88000edd7e58 EFLAGS: 00010246 [ 2.028684] RAX: 0000000000000000 RBX: ffffffff82295550 RCX: 0000000000000000 [ 2.028684] RDX: 0000000000000011 RSI: ffffffff81efe393 RDI: 00000000fffffffe [ 2.028684] RBP: ffff88000edd7e60 R08: 0000000000000003 R09: 0000000000015d20 [ 2.028684] R10: ffffffff81ef225e R11: ffffffff811b0222 R12: ffffffffffffffff [ 2.028684] R13: 0000000000000239 R14: 0000000000000000 R15: 0000000000000000 [ 2.028684] FS: 0000000000000000(0000) GS:ffff88000fa00000(0000) knlGS:0000000000000000 [ 2.028684] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 2.028684] CR2: 0000000000000000 CR3: 000000000220c000 CR4: 00000000000006f0 [ 2.028684] Stack: [ 2.028684] ffffffff82295550 ffff88000edd7e80 ffffffff8238af62 ffffffff8238ac05 [ 2.028684] 0000000000000000 ffff88000edd7e98 ffffffff8238ac0f ffffffff8238ac05 [ 2.028684] ffff88000edd7f08 ffffffff810002ba ffff88000edd7f00 ffffffff810e2404 [ 2.028684] Call Trace: [ 2.028684] [<ffffffff8238af62>] btrfs_props_init+0x4f/0x96 [ 2.028684] [<ffffffff8238ac05>] ? ftrace_define_fields_btrfs_space_reservation+0x145/0x145 [ 2.028684] [<ffffffff8238ac0f>] init_btrfs_fs+0xa/0xf0 [ 2.028684] [<ffffffff8238ac05>] ? ftrace_define_fields_btrfs_space_reservation+0x145/0x145 [ 2.028684] [<ffffffff810002ba>] do_one_initcall+0xa4/0x13a [ 2.028684] [<ffffffff810e2404>] ? parse_args+0x25f/0x33d [ 2.028684] [<ffffffff8234cf75>] kernel_init_freeable+0x1aa/0x230 [ 2.028684] [<ffffffff8234c785>] ? do_early_param+0x88/0x88 [ 2.028684] [<ffffffff819f61b5>] ? rest_init+0x89/0x89 [ 2.028684] [<ffffffff819f61c3>] kernel_init+0xe/0x109 The issue here is that the initialization function of btrfs (super.c:init_btrfs_fs) started using crc32c (from lib/libcrc32c.c). But when it needs to call crc32c (as part of the properties initialization routine), the libcrc32c is not yet initialized, so crc32c derreferenced a NULL pointer (lib/libcrc32c.c:tfm), causing the kernel panic on boot. The approach to fix this is to use crypto component directly to use its crc32c (which is basically what lib/libcrc32c.c is, a wrapper around crypto). This is what ext4 is doing as well, it uses crypto directly to get crc32c functionality. Verified this works both when btrfs is built-in and when it's loadable kernel module. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28Btrfs: throttle delayed refs betterJosef Bacik
On one of our gluster clusters we noticed some pretty big lag spikes. This turned out to be because our transaction commit was taking like 3 minutes to complete. This is because we have like 30 gigs of metadata, so our global reserve would end up being the max which is like 512 mb. So our throttling code would allow a ridiculous amount of delayed refs to build up and then they'd all get run at transaction commit time, and for a cold mounted file system that could take up to 3 minutes to run. So fix the throttling to be based on both the size of the global reserve and how long it takes us to run delayed refs. This patch tracks the time it takes to run delayed refs and then only allows 1 seconds worth of outstanding delayed refs at a time. This way it will auto-tune itself from cold cache up to when everything is in memory and it no longer has to go to disk. This makes our transaction commits take much less time to run. Thanks, Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28Btrfs: attach delayed ref updates to delayed ref headsJosef Bacik
Currently we have two rb-trees, one for delayed ref heads and one for all of the delayed refs, including the delayed ref heads. When we process the delayed refs we have to hold onto the delayed ref lock for all of the selecting and merging and such, which results in quite a bit of lock contention. This was solved by having a waitqueue and only one flusher at a time, however this hurts if we get a lot of delayed refs queued up. So instead just have an rb tree for the delayed ref heads, and then attach the delayed ref updates to an rb tree that is per delayed ref head. Then we only need to take the delayed ref lock when adding new delayed refs and when selecting a delayed ref head to process, all the rest of the time we deal with a per delayed ref head lock which will be much less contentious. The locking rules for this get a little more complicated since we have to lock up to 3 things to properly process delayed refs, but I will address that problem later. For now this passes all of xfstests and my overnight stress tests. Thanks, Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28Btrfs: handle EAGAIN case properly in btrfs_drop_snapshot()Wang Shilong
We may return early in btrfs_drop_snapshot(), we shouldn't call btrfs_std_err() for this case, fix it. Cc: stable@vger.kernel.org Signed-off-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28Btrfs: return free space to global_rsv as much as possibleLiu Bo
@full is not protected within global_rsv.lock, so we may think global_rsv is already full but in fact it's not, so we miss the opportunity to return free space to global_rsv directly when we release other block_rsvs. Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28Btrfs: stop caching thread if extent_commit_sem is contendedJosef Bacik
We can starve out the transaction commit with a bunch of caching threads all running at the same time. This is because we will only drop the extent_commit_sem if we need_resched(), which isn't likely to happen since we will be reading a lot from the disk so have already schedule()'ed plenty. Alex observed that he could starve out a transaction commit for up to a minute with 32 caching threads all running at once. This will allow us to drop the extent_commit_sem to allow the transaction commit to swap the commit_root out and then all the cachers will start back up. Here is an explanation provided by Igno So, just to fill in what happens in this loop: mutex_unlock(&caching_ctl->mutex); cond_resched(); goto again; where 'again:' takes caching_ctl->mutex and fs_info->extent_commit_sem again: again: mutex_lock(&caching_ctl->mutex); /* need to make sure the commit_root doesn't disappear */ down_read(&fs_info->extent_commit_sem); So, if I'm reading the code correct, there can be a fair amount of concurrency here: there may be multiple 'caching kthreads' per filesystem active, while there's one fs_info->extent_commit_sem per filesystem AFAICS. So, what happens if there are a lot of CPUs all busy holding the ->extent_commit_sem rwsem read-locked and a writer arrives? They'd all rush to try to release the fs_info->extent_commit_sem, and they'd block in the down_read() because there's a writer waiting. So there's a guarantee of forward progress. This should answer akpm's concern I think. Thanks, Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28Btrfs: convert printk to btrfs_ and fix BTRFS prefixFrank Holton
Convert all applicable cases of printk and pr_* to the btrfs_* macros. Fix all uses of the BTRFS prefix. Signed-off-by: Frank Holton <fholton@gmail.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28Btrfs: fix double initialization of the raid kobjectMiao Xie
We met the following oops when doing space balance: kobject (ffff88081b590278): tried to init an initialized object, something is seriously wrong. ... Call Trace: [<ffffffff81937262>] dump_stack+0x49/0x5f [<ffffffff8137d259>] kobject_init+0x89/0xa0 [<ffffffff8137d36a>] kobject_init_and_add+0x2a/0x70 [<ffffffffa009bd79>] ? clear_extent_bit+0x199/0x470 [btrfs] [<ffffffffa005e82c>] __link_block_group+0xfc/0x120 [btrfs] [<ffffffffa006b9db>] btrfs_make_block_group+0x24b/0x370 [btrfs] [<ffffffffa00a899b>] __btrfs_alloc_chunk+0x54b/0x7e0 [btrfs] [<ffffffffa00a8c6f>] btrfs_alloc_chunk+0x3f/0x50 [btrfs] [<ffffffffa0060123>] do_chunk_alloc+0x363/0x440 [btrfs] [<ffffffffa00633d4>] btrfs_check_data_free_space+0x104/0x310 [btrfs] [<ffffffffa0069f4d>] btrfs_write_dirty_block_groups+0x48d/0x600 [btrfs] [<ffffffffa007aad4>] commit_cowonly_roots+0x184/0x250 [btrfs] ... Steps to reproduce: # mkfs.btrfs -f <dev> # mount -o nospace_cache <dev> <mnt> # btrfs balance start <mnt> # dd if=/dev/zero of=<mnt>/tmpfile bs=1M count=1 The reason of this problem is that we initialized the raid kobject when we added a block group into a empty raid list. As we know, when we mounted a btrfs filesystem, the raid list was empty, we would initialize the raid kobject when we added the first block group. But if there was not data stored in the block group, the block group would be freed when doing balance, and the raid list would be empty. And then if we allocated a new block group and added it into the raid list, we would initialize the raid kobject again, the oops happened. Fix this problem by initializing the raid kobject just when mounting the fs. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Reported-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28btrfs: fix static checker warningsJeff Mahoney
This patch fixes the following warnings: fs/btrfs/extent-tree.c:6201:12: sparse: symbol 'get_raid_name' was not declared. Should it be static? fs/btrfs/extent-tree.c:8430:9: error: format not a string literal and no format arguments [-Werror=format-security] get_raid_name(index)); Signed-off-by: Jeff Mahoney <jeffm@suse.com> Reviewed-by: Kees Cook <keescook@chromium.org> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28btrfs: remove unused variable from find_free_extentValentina Giusti
The variable found_uncached_bg in find_free_extent is not used since commit 285ff5af6ce358e73f53b55c9efadd4335f4c2ff (Btrfs: remove the ideal caching code) Signed-off-by: Valentina Giusti <valentina.giusti@microon.de> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28btrfs: publish allocation data in sysfsJeff Mahoney
While trying to debug ENOSPC issues, it's helpful to understand what the kernel's view of the available space is. We export this information via ioctl, but sysfs files are more easily used. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28Btrfs: introduce a head ref rbtreeLiu Bo
The way how we process delayed refs is 1) get a bunch of head refs, 2) pick up one head ref, 3) go one node back for any delayed ref updates. The head ref is also linked in the same rbtree as the delayed ref is, so in 1) stage, we have to walk one by one including not only head refs, but delayed refs. When we have a great number of delayed refs pending to process, this'll cost time a lot. Here we introduce a head ref specific rbtree, it only has head refs, so troubles go away. Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <clm@fb.com>
2013-12-12Btrfs: don't miss skinny extent items on delayed ref head contentionFilipe David Borba Manana
Currently extent-tree.c:btrfs_lookup_extent_info() can miss the lookup of skinny extent items. This can happen when the execution flow is the following: * We do an extent tree lookup and fail to find a skinny extent item; * As a result, we attempt to see if a non-skinny extent item exists, either by looking at previous item in the leaf or by doing another full extent tree search; * We have a transaction and then we check for a matching delayed ref head in the transaction's delayed refs rbtree; * We find such delayed ref head and then we try to lock it with a call to mutex_trylock(); * The lock was contended so we jump to the label "again", which repeats the extent tree search but for a non-skinny extent item, because we set previously metadata variable to 0 and the search key to look for a non-skinny extent-item; * After the jump (and after releasing the transaction's delayed refs lock), a skinny extent item might have been added to the extent tree but we will miss it because metadata is set to 0 and the search key is set for a non-skinny extent-item. The fix here is to not reset metadata to 0 and to jump to the initial search key setup if the delayed ref head is contended, instead of jumping directly to the extent tree search label ("again"). This issue was found while investigating the issue reported at Bugzilla 64961. David Sterba suspected this function was missing extent items, and that this could be caused by the last change to this function, which was made in the following patch: [PATCH] Btrfs: optimize btrfs_lookup_extent_info() (commit 74be9510876a66ad9826613ac8a526d26f9e7f01) But in fact this issue already existed before, because after failing to find a skinny extent item, the code set the search key for a non-skinny extent item, and on contention of a matching delayed ref head it would not search the extent tree for a skinny extent item anymore. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Reviewed-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Chris Mason <clm@fb.com>
2013-11-11Btrfs: rename btrfs_start_all_delalloc_inodesMiao Xie
rename the function -- btrfs_start_all_delalloc_inodes(), and make its name be compatible to btrfs_wait_ordered_roots(), since they are always used at the same place. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: don't wait for the completion of all the ordered extentsMiao Xie
It is very likely that there are lots of ordered extents in the filesytem, if we wait for the completion of all of them when we want to reclaim some space for the metadata space reservation, we would be blocked for a long time. The performance would drop down suddenly for a long time. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: don't wait for all the async delalloc when shrinking delallocMiao Xie
It was very likely that there were lots of async delalloc pages in the filesystem, if we waited until all the pages were flushed, we would be blocked for a long time, and the performance would also drop down. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: fix the confusion between delalloc bytes and metadata bytesMiao Xie
In shrink_delalloc(), what we need reclaim is the metadata space, so flushing pages by to_reclaim is not reasonable, it is very likely that the pages we flush are not enough. And then we had to invoke the flush function for several times, at the worst, we need call flush_space for several times. It wasted time. We improve this problem by converting the metadata space size we need reserve to the delalloc bytes, By this way, we can flush the pages by a reasonable number. (Now we use a fixed number to do conversion, it is not flexible, maybe we can find a good way to improve it in the future.) Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: pick up the code for the item number calculation in flush_space()Miao Xie
This patch picked up the code that was used to calculate the number of the items for which we need reserve space, and we will use it in the next patch. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: wait for the ordered extent only when we wantMiao Xie
2013-11-11Btrfs: remove unnecessary initialization and memory barrior in shrink_delalloc()Miao Xie
2013-11-11btrfs: Fix checkpatch.pl warning of spacing issuesDulshani Gunawardhana
Fix spacing issues detected via checkpatch.pl in accordance with the kernel style guidelines. Signed-off-by: Dulshani Gunawardhana <dulshani.gunawardhana89@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11btrfs: Use WARN_ON()'s return value in place of WARN_ON(1)Dulshani Gunawardhana
Use WARN_ON()'s return value in place of WARN_ON(1) for cleaner source code that outputs a more descriptive warnings. Also fix the styling warning of redundant braces that came up as a result of this fix. Signed-off-by: Dulshani Gunawardhana <dulshani.gunawardhana89@gmail.com> Reviewed-by: Zach Brown <zab@redhat.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: fix the free space write out failure when there is no data spaceMiao Xie
After running space balance on a new fs, the fs check program outputed the following warning message: free space inode generation (0) did not match free space cache generation (20) Steps to reproduce: # mkfs.btrfs -f <dev> # mount <dev> <mnt> # btrfs balance start <mnt> # umount <mnt> # btrfs check <dev> It was because there was no data space after the space balance, and the free space write out task didn't try to allocate a new data chunk for the free space inode when doing the reservation. So the data space reservation failed, and in order to tell the free space loader that this free space inode could not be trusted, the generation of the free space inode wasn't updated. Then the check program found this problem and outputed the above message. But in fact, it is safe that we try to allocate a new data chunk when we find the data space is not enough. The patch fixes the above problem by this way. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: optimize extent item search in run_delayed_extent_opFilipe David Borba Manana
Instead of doing another extent tree search if the first search failed to find a metadata item, check if the previous item in the leaf is an extent item and use it if it is, otherwise do the second tree search for an extent item. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11btrfs: add tracing for failed reservationsJeff Mahoney
When debugging ENOSPC issues, it's nice to be able to see which reservations failed as well as the ones which succeeded. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11btrfs: remove fs/btrfs/compat.hZach Brown
fs/btrfs/compat.h only contained trivial macro wrappers of drop_nlink() and inc_nlink(). This doesn't belong in mainline. Signed-off-by: Zach Brown <zab@redhat.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: fixup error path in __btrfs_inc_extent_refLiu Bo
When we fail to add a reference after a non-inline insertion by some reasons, eg. ENOSPC, we'll abort the transaction, but we don't return this error to the caller who has to walk around again to find something wrong, that's unnecessary. Also fixup other error paths to keep it simple. Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: free reserved space on error in a few placesJosef Bacik
While trying to track down a reserved space leak I noticed a few places where we won't properly clean up reserved space if we have an error, this patch fixes those up. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: fixup reserved trace pointsJosef Bacik
In trying to track down where we were leaking reserved space I noticed our reserve extent tracepoints are a little off. First we were saying that the reserved space had been alloced in btrfs_reserve_extent, which isn't the case, this needs to be triggered when we actually allocate the space when we run the delayed ref. We were also missing a few places where we should have been tracing the btrfs_reserve_extent_free tracepoint. With these in place I was able to put together where we were leaking reserved space. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: don't leak block group on errorFilipe David Borba Manana
In extent-tree.c:btrfs_write_dirty_block_groups(), if the call to write_one_cache_group() failed, we would return without putting the block group first. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: remove path arg from btrfs_truncate_free_space_cacheFilipe David Borba Manana
Not used for anything, and removing it avoids caller's need to allocate a path structure. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-21Btrfs: remove space_info->reservation_progressJosef Bacik
This isn't used for anything anymore, just remove it. Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-21Btrfs: kill delay_iput arg to the wait_ordered functionsJosef Bacik
This is a left over of how we used to wait for ordered extents, which was to grab the inode and then run filemap flush on it. However if we have an ordered extent then we already are holding a ref on the inode, and we just use btrfs_start_ordered_extent anyway, so there is no reason to have an extra ref on the inode to start work on the ordered extent. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-21Revert "Btrfs: rework the overcommit logic to be based on the total size"Josef Bacik
This reverts commit 70afa3998c9baed4186df38988246de1abdab56d. It is causing performance issues and wasn't actually correct. There were problems with the way we flushed delalloc and that was the real cause of the early enospc. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-21Btrfs: allocate the free space by the existed max extent size when ENOSPCMiao Xie
By the current code, if the requested size is very large, and all the extents in the free space cache are small, we will waste lots of the cpu time to cut the requested size in half and search the cache again and again until it gets down to the size the allocator can return. In fact, we can know the max extent size in the cache after the first search, so we needn't cut the size in half repeatedly, and just use the max extent size directly. This way can save lots of cpu time and make the performance grow up when there are only fragments in the free space cache. According to my test, if there are only 4KB free space extents in the fs, and the total size of those extents are 256MB, we can reduce the execute time of the following test from 5.4s to 1.4s. dd if=/dev/zero of=<testfile> bs=1MB count=1 oflag=sync Changelog v2 -> v3: - fix the problem that we skip the block group with the space which is less than we need. Changelog v1 -> v2: - address the problem that we return a wrong start position when searching the free space in a bitmap. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: remove ourselves from the cluster list under lockJosef Bacik
A user was reporting weird warnings from btrfs_put_delayed_ref() and I noticed that we were doing this list_del_init() on our head ref outside of delayed_refs->lock. This is a problem if we have people still on the list, we could end up modifying old pointers and such. Fix this by removing us from the list before we do our run_delayed_ref on our head ref. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: Remove superfluous casts from u64 to unsigned long longGeert Uytterhoeven
u64 is "unsigned long long" on all architectures now, so there's no need to cast it when formatting it using the "ll" length modifier. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: create UUID tree if requiredStefan Behrens
This tree is not created by mkfs.btrfs. Therefore when a filesystem is mounted writable and the UUID tree does not exist, this tree is created if required. The tree is also added to the fs_info structure and initialized, but this commit does not yet read or write UUID tree elements. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: avoid starting a transaction in the write pathJosef Bacik
I noticed while looking at a deadlock that we are always starting a transaction in cow_file_range(). This isn't really needed since we only need a transaction if we are doing an inline extent, or if the allocator needs to allocate a chunk. So push down all the transaction start stuff to be closer to where we actually need a transaction in all of these cases. This will hopefully reduce our write latency when we are committing often. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: return ENOSPC when target space is fullFilipe David Borba Manana
In extent-tree.c:do_chunk_alloc(), early on we returned 0 (success) when the target space was full and when chunk allocation is needed. However, later on in that same function we return ENOSPC if btrfs_alloc_chunk() fails (and chunk allocation was needed) and set the space's full flag. This was inconsistent, as -ENOSPC should be returned if the space is full and a chunk allocation needs to performed. If the space is full but no chunk allocation is needed, just return 0 (success). Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: handle errors when doing slow cachingJosef Bacik
Alex Lyakas reported a bug where wait_block_group_cache_progress() would wait forever if a drive failed. This is because we just bail out if there is an error while trying to cache a block group, we don't update anybody who may be waiting. So this introduces a new enum for the cache state in case of error and makes everybody bail out if we have an error. Alex tested and verified this patch fixed his problem. This fixes bz 59431. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: cleanup reloc roots properly on errorJosef Bacik
I was hitting the BUG_ON() at the end of merge_reloc_roots() because we were aborting the transaction at some point previously and then getting an error when we tried to drop the reloc root. I fixed btrfs_drop_snapshot to re-add us to the dead roots list if we failed, but this isn't the right thing to do for reloc roots since it uses root->root_list for it's own stuff in order to know what needs to be cleaned up. So fix btrfs_drop_snapshot to only do the re-add if we aren't dropping for reloc, and handle errors from merge_reloc_root() by dropping the reloc root we are processing since it won't be on the list of roots to cleanup. With this patch my reproducer no longer panics. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs/tracepoint: update delayed ref tracepointsLiu Bo
This shows exactly how btrfs processes the delayed refs onto disks, which is very helpful on understanding delayed ref mechanism and debugging related bugs. Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01btrfs_read_block_groups: Use enums to indexchandan
btrfs_space_info->block_groups. The current code uses integer literals to index btrfs_space_info->block_groups[] array. Instead use corresponding enums from 'enum btrfs_raid_types'. Signed-off-by: chandan <chandan@linux.vnet.ibm.com> Reviewed-by: David Sterba <dsterba@suse.cz> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: make free space caching faster with many non-inline extent referencesLiu Bo
So to cache free space, we iterate every extent item to gather free space info. When we have say 10,000 non-inline extent refs(such as BTRFS_EXTENT_DATA_REF), it takes quite a long time, and since inline extent refs and non-inline ones have same objectid in their keys, we can just re-search the tree with the next address to skip non-inline references. (This is found by dedup feature because dedup extents can end up with many non-inline extent refs.) Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
