path: root/fs/btrfs/disk-io.c
2015-03-03btrfs: cleanup, use kmalloc_array/kcalloc array helpersDavid Sterba
Convert kmalloc(nr * size, ..) to kmalloc_array that does additional overflow checks, the zeroing variant is kcalloc. Signed-off-by: David Sterba <dsterba@suse.cz>
2015-03-03btrfs: cleanup 64bit/32bit divs, compile time constantsDavid Sterba
Switch to div_u64 if the divisor is a numeric constant or sum of sizeof()s. We can remove a few instances of do_div that has the hidden semtantics of changing the 1st argument. Small power-of-two divisors are converted to bitshifts, large values are kept intact for clarity. Signed-off-by: David Sterba <dsterba@suse.cz>
2015-02-02Btrfs: fix race between transaction commit and empty block group removalFilipe Manana
Committing a transaction can race with automatic removal of empty block groups (cleaner kthread), leading to a BUG_ON() in the transaction commit code while running btrfs_finish_extent_commit(). The following sequence diagram shows how it can happen: CPU 1 CPU 2 btrfs_commit_transaction() fs_info->running_transaction = NULL btrfs_finish_extent_commit() find_first_extent_bit() -> found range for block group X in fs_info->freed_extents[] btrfs_delete_unused_bgs() -> found block group X Removed block group X's range from fs_info->freed_extents[] btrfs_remove_chunk() btrfs_remove_block_group(bg X) unpin_extent_range(bg X range) btrfs_lookup_block_group(bg X) -> returns NULL -> BUG_ON() The trace that results from the BUG_ON() is: [48665.187808] ------------[ cut here ]------------ [48665.188032] kernel BUG at fs/btrfs/extent-tree.c:5675! [48665.188032] invalid opcode: 0000 [#1] SMP DEBUG_PAGEALLOC [48665.188032] Modules linked in: dm_flakey dm_mod crc32c_generic btrfs xor raid6_pq nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc loop parport_pc evdev microcode [48665.197388] CPU: 2 PID: 31211 Comm: kworker/u32:16 Tainted: G W 3.19.0-rc5-btrfs-next-4+ #1 [48665.197388] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.7.5-0-ge51488c-20140602_164612-nilsson.home.kraxel.org 04/01/2014 [48665.197388] Workqueue: events_unbound btrfs_async_reclaim_metadata_space [btrfs] [48665.197388] task: ffff880222011810 ti: ffff8801b56a4000 task.ti: ffff8801b56a4000 [48665.197388] RIP: 0010:[<ffffffffa0350d05>] [<ffffffffa0350d05>] unpin_extent_range+0x6a/0x1ba [btrfs] [48665.197388] RSP: 0018:ffff8801b56a7b88 EFLAGS: 00010246 [48665.197388] RAX: 0000000000000000 RBX: ffff8802143a6000 RCX: ffff8802220120c8 [48665.197388] RDX: 0000000000000001 RSI: 0000000000000001 RDI: ffff8800a3c140b0 [48665.197388] RBP: ffff8801b56a7bd8 R08: 0000000000000003 R09: 0000000000000000 [48665.197388] R10: 0000000000000000 R11: 000000000000bbac R12: 0000000012e8e000 [48665.197388] R13: ffff8800a3c14000 R14: 0000000000000000 R15: 0000000000000000 [48665.197388] FS: 0000000000000000(0000) GS:ffff88023ec40000(0000) knlGS:0000000000000000 [48665.197388] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [48665.197388] CR2: 00007f065e42f270 CR3: 0000000206f70000 CR4: 00000000000006e0 [48665.197388] Stack: [48665.197388] ffff8801b56a7bd8 0000000012ea0000 01ff8800a3c14138 0000000012e9ffff [48665.197388] ffff880141df3dd8 ffff8802143a6000 ffff8800a3c14138 ffff880141df3df0 [48665.197388] ffff880141df3dd8 0000000000000000 ffff8801b56a7c08 ffffffffa0354227 [48665.197388] Call Trace: [48665.197388] [<ffffffffa0354227>] btrfs_finish_extent_commit+0xb0/0xd9 [btrfs] [48665.197388] [<ffffffffa0366b4b>] btrfs_commit_transaction+0x791/0x92c [btrfs] [48665.197388] [<ffffffffa0352432>] flush_space+0x43d/0x452 [btrfs] [48665.197388] [<ffffffff814295c3>] ? _raw_spin_unlock+0x28/0x33 [48665.197388] [<ffffffffa035255f>] btrfs_async_reclaim_metadata_space+0x118/0x164 [btrfs] [48665.197388] [<ffffffff81059917>] ? process_one_work+0x14b/0x3ab [48665.197388] [<ffffffff810599ac>] process_one_work+0x1e0/0x3ab [48665.197388] [<ffffffff81079fa9>] ? trace_hardirqs_off+0xd/0xf [48665.197388] [<ffffffff8105a55b>] worker_thread+0x210/0x2d0 [48665.197388] [<ffffffff8105a34b>] ? rescuer_thread+0x2c3/0x2c3 [48665.197388] [<ffffffff8105e5c0>] kthread+0xef/0xf7 [48665.197388] [<ffffffff81429682>] ? _raw_spin_unlock_irq+0x2d/0x39 [48665.197388] [<ffffffff8105e4d1>] ? __kthread_parkme+0xad/0xad [48665.197388] [<ffffffff81429dec>] ret_from_fork+0x7c/0xb0 [48665.197388] [<ffffffff8105e4d1>] ? __kthread_parkme+0xad/0xad [48665.197388] Code: 85 f6 74 14 49 8b 06 49 03 46 09 49 39 c4 72 1d 4c 89 f7 e8 83 ec ff ff 4c 89 e6 4c 89 ef e8 1e f1 ff ff 48 85 c0 49 89 c6 75 02 <0f> 0b 49 8b 1e 49 03 5e 09 48 8b [48665.197388] RIP [<ffffffffa0350d05>] unpin_extent_range+0x6a/0x1ba [btrfs] [48665.197388] RSP <ffff8801b56a7b88> [48665.272246] ---[ end trace b9c6ab9957521376 ]--- Fix this by ensuring that unpining the block group's range in btrfs_finish_extent_commit() is done in a synchronized fashion with removing the block group's range from freed_extents[] in btrfs_delete_unused_bgs() This race got introduced with the change: Btrfs: remove empty block groups automatically commit 47ab2a6c689913db23ccae38349714edf8365e0a Signed-off-by: Filipe Manana <fdmanana@suse.com> Signed-off-by: Chris Mason <clm@fb.com>
2015-02-02btrfs: add checks for sys_chunk_array sizesDavid Sterba
Verify that possible minimum and maximum size is set, validity of contents is checked in btrfs_read_sys_array. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com>
2015-02-02btrfs: more superblock checks, lower bounds on devices and sectorsize/nodesizeDavid Sterba
I received a few crafted images from Jiri, all got through the recently added superblock checks. The lower bounds checks for num_devices and sector/node -sizes were missing and caused a crash during mount. Tools for symbolic code execution were used to prepare the images contents. Reported-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com>
2015-01-21Btrfs: fix unused members in struct btrfs_rootAnand Jain
There isn't any real use of following members of struct btrfs_root so delete them. struct kobject root_kobj; struct completion kobj_unregister; Signed-off-by: Anand Jain <anand.jain@oracle.com> Reviewed-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com>
2015-01-21btrfs: set proper message level for skinny metadataDavid Sterba
This has been confusing people for too long, the message is really just informative. CC: <stable@vger.kernel.org> # 3.10+ Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com>
2015-01-21btrfs: update message levels after checksum errorsDavid Sterba
The errors are worth noting and might get missed with INFO level. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com>
2015-01-21btrfs: update message levels during failed mountDavid Sterba
All error conditions from open_ctree shall be ERR. Warning would suggest that something's wrong and we can continue. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com>
2015-01-21btrfs: update message levels for errorsDavid Sterba
Several messages that point to some internal problem, level INFO is wrong here. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com>
2015-01-21Merge branch 'cleanup/blocksize-diet-part2' of ↵Chris Mason
git://git.kernel.org/pub/scm/linux/kernel/git/kdave/linux into for-linus
2015-01-14btrfs: expand btrfs_find_item if found_key is NULLDavid Sterba
If the found_key is NULL, then btrfs_find_item becomes a verbose wrapper for simple btrfs_search_slot. After we've removed all such callers, passing a NULL key is not valid anymore. Signed-off-by: David Sterba <dsterba@suse.cz>
2015-01-14btrfs: fix leak of path in btrfs_find_itemDavid Sterba
If btrfs_find_item is called with NULL path it allocates one locally but does not free it. Affected paths are inserting an orphan item for a file and for a subvol root. Move the path allocation to the callers. CC: <stable@vger.kernel.org> # 3.14+ Fixes: 3f870c289900 ("btrfs: expand btrfs_find_item() to include find_orphan_item functionality") Signed-off-by: David Sterba <dsterba@suse.cz>
2014-12-12btrfs: sink parameter len to alloc_extent_bufferDavid Sterba
Because we're using globally known nodesize. Do the same for the sanity test function variant. Signed-off-by: David Sterba <dsterba@suse.cz>
2014-12-12btrfs: sink blocksize parameter to btrfs_find_create_tree_blockDavid Sterba
Finally it's clear that the requested blocksize is always equal to nodesize, with one exception, the superblock. Superblock has fixed size regardless of the metadata block size, but uses the same helpers to initialize sys array/chunk tree and to work with the chunk items. So it pretends to be an extent_buffer for a moment, btrfs_read_sys_array is full of special cases, we're adding one more. Signed-off-by: David Sterba <dsterba@suse.cz>
2014-12-12btrfs: sink blocksize parameter to reada_tree_block_flaggedDavid Sterba
2014-12-12btrfs: sink blocksize parameter to readahead_tree_blockDavid Sterba
All callers pass nodesize. Signed-off-by: David Sterba <dsterba@suse.cz>
2014-12-10Btrfs: fix fs corruption on transaction abort if device supports discardFilipe Manana
When we abort a transaction we iterate over all the ranges marked as dirty in fs_info->freed_extents[0] and fs_info->freed_extents[1], clear them from those trees, add them back (unpin) to the free space caches and, if the fs was mounted with "-o discard", perform a discard on those regions. Also, after adding the regions to the free space caches, a fitrim ioctl call can see those ranges in a block group's free space cache and perform a discard on the ranges, so the same issue can happen without "-o discard" as well. This causes corruption, affecting one or multiple btree nodes (in the worst case leaving the fs unmountable) because some of those ranges (the ones in the fs_info->pinned_extents tree) correspond to btree nodes/leafs that are referred by the last committed super block - breaking the rule that anything that was committed by a transaction is untouched until the next transaction commits successfully. I ran into this while running in a loop (for several hours) the fstest that I recently submitted: [PATCH] fstests: add btrfs test to stress chunk allocation/removal and fstrim The corruption always happened when a transaction aborted and then fsck complained like this: _check_btrfs_filesystem: filesystem on /dev/sdc is inconsistent *** fsck.btrfs output *** Check tree block failed, want=94945280, have=0 Check tree block failed, want=94945280, have=0 Check tree block failed, want=94945280, have=0 Check tree block failed, want=94945280, have=0 Check tree block failed, want=94945280, have=0 read block failed check_tree_block Couldn't open file system In this case 94945280 corresponded to the root of a tree. Using frace what I observed was the following sequence of steps happened: 1) transaction N started, fs_info->pinned_extents pointed to fs_info->freed_extents[0]; 2) node/eb 94945280 is created; 3) eb is persisted to disk; 4) transaction N commit starts, fs_info->pinned_extents now points to fs_info->freed_extents[1], and transaction N completes; 5) transaction N + 1 starts; 6) eb is COWed, and btrfs_free_tree_block() called for this eb; 7) eb range (94945280 to 94945280 + 16Kb) is added to fs_info->pinned_extents (fs_info->freed_extents[1]); 8) Something goes wrong in transaction N + 1, like hitting ENOSPC for example, and the transaction is aborted, turning the fs into readonly mode. The stack trace I got for example: [112065.253935] [<ffffffff8140c7b6>] dump_stack+0x4d/0x66 [112065.254271] [<ffffffff81042984>] warn_slowpath_common+0x7f/0x98 [112065.254567] [<ffffffffa0325990>] ? __btrfs_abort_transaction+0x50/0x10b [btrfs] [112065.261674] [<ffffffff810429e5>] warn_slowpath_fmt+0x48/0x50 [112065.261922] [<ffffffffa032949e>] ? btrfs_free_path+0x26/0x29 [btrfs] [112065.262211] [<ffffffffa0325990>] __btrfs_abort_transaction+0x50/0x10b [btrfs] [112065.262545] [<ffffffffa036b1d6>] btrfs_remove_chunk+0x537/0x58b [btrfs] [112065.262771] [<ffffffffa033840f>] btrfs_delete_unused_bgs+0x1de/0x21b [btrfs] [112065.263105] [<ffffffffa0343106>] cleaner_kthread+0x100/0x12f [btrfs] (...) [112065.264493] ---[ end trace dd7903a975a31a08 ]--- [112065.264673] BTRFS: error (device sdc) in btrfs_remove_chunk:2625: errno=-28 No space left [112065.264997] BTRFS info (device sdc): forced readonly 9) The clear kthread sees that the BTRFS_FS_STATE_ERROR bit is set in fs_info->fs_state and calls btrfs_cleanup_transaction(), which in turn calls btrfs_destroy_pinned_extent(); 10) Then btrfs_destroy_pinned_extent() iterates over all the ranges marked as dirty in fs_info->freed_extents[], and for each one it calls discard, if the fs was mounted with "-o discard", and adds the range to the free space cache of the respective block group; 11) btrfs_trim_block_group(), invoked from the fitrim ioctl code path, sees the free space entries and performs a discard; 12) After an umount and mount (or fsck), our eb's location on disk was full of zeroes, and it should have been untouched, because it was marked as dirty in the fs_info->pinned_extents tree, and therefore used by the trees that the last committed superblock points to. Fix this by not performing a discard and not adding the ranges to the free space caches - it's useless from this point since the fs is now in readonly mode and we won't write free space caches to disk anymore (otherwise we would leak space) nor any new superblock. By not adding the ranges to the free space caches, it prevents other code paths from allocating that space and write to it as well, therefore being safer and simpler. This isn't a new problem, as it's been present since 2011 (git commit acce952b0263825da32cf10489413dec78053347). Cc: stable@vger.kernel.org # any kernel released after 2011-01-06 Signed-off-by: Filipe Manana <fdmanana@suse.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-12-02Btrfs: fix race between fs trimming and block group remove/allocationFilipe Manana
Our fs trim operation, which is completely transactionless (doesn't start or joins an existing transaction) consists of visiting all block groups and then for each one to iterate its free space entries and perform a discard operation against the space range represented by the free space entries. However before performing a discard, the corresponding free space entry is removed from the free space rbtree, and when the discard completes it is added back to the free space rbtree. If a block group remove operation happens while the discard is ongoing (or before it starts and after a free space entry is hidden), we end up not waiting for the discard to complete, remove the extent map that maps logical address to physical addresses and the corresponding chunk metadata from the the chunk and device trees. After that and before the discard completes, the current running transaction can finish and a new one start, allowing for new block groups that map to the same physical addresses to be allocated and written to. So fix this by keeping the extent map in memory until the discard completes so that the same physical addresses aren't reused before it completes. If the physical locations that are under a discard operation end up being used for a new metadata block group for example, and dirty metadata extents are written before the discard finishes (the VM might call writepages() of our btree inode's i_mapping for example, or an fsync log commit happens) we end up overwriting metadata with zeroes, which leads to errors from fsck like the following: checking extents Check tree block failed, want=833912832, have=0 Check tree block failed, want=833912832, have=0 Check tree block failed, want=833912832, have=0 Check tree block failed, want=833912832, have=0 Check tree block failed, want=833912832, have=0 read block failed check_tree_block owner ref check failed [833912832 16384] Errors found in extent allocation tree or chunk allocation checking free space cache checking fs roots Check tree block failed, want=833912832, have=0 Check tree block failed, want=833912832, have=0 Check tree block failed, want=833912832, have=0 Check tree block failed, want=833912832, have=0 Check tree block failed, want=833912832, have=0 read block failed check_tree_block root 5 root dir 256 error root 5 inode 260 errors 2001, no inode item, link count wrong unresolved ref dir 256 index 0 namelen 8 name foobar_3 filetype 1 errors 6, no dir index, no inode ref root 5 inode 262 errors 2001, no inode item, link count wrong unresolved ref dir 256 index 0 namelen 8 name foobar_5 filetype 1 errors 6, no dir index, no inode ref root 5 inode 263 errors 2001, no inode item, link count wrong (...) Signed-off-by: Filipe Manana <fdmanana@suse.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-11-25Merge branch 'dev/pending-changes' of ↵Chris Mason
2014-11-21Btrfs: make sure logged extents complete in the current transaction V3Josef Bacik
Liu Bo pointed out that my previous fix would lose the generation update in the scenario I described. It is actually much worse than that, we could lose the entire extent if we lose power right after the transaction commits. Consider the following write extent 0-4k log extent in log tree commit transaction < power fail happens here ordered extent completes We would lose the 0-4k extent because it hasn't updated the actual fs tree, and the transaction commit will reset the log so it isn't replayed. If we lose power before the transaction commit we are save, otherwise we are not. Fix this by keeping track of all extents we logged in this transaction. Then when we go to commit the transaction make sure we wait for all of those ordered extents to complete before proceeding. This will make sure that if we lose power after the transaction commit we still have our data. This also fixes the problem of the improperly updated extent generation. Thanks, cc: stable@vger.kernel.org Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-11-20btrfs: fix typos in btrfs_check_super_validDavid Sterba
Copy&paste errors in some messages and add few more missing macro accessors. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com>
2014-11-12btrfs: switch inode_cache option handling to pending changesDavid Sterba
The pending mount option(s) now share namespace and bits with the normal options, and the existing one for (inode_cache) is unset unconditionally at each transaction commit. Introduce a separate namespace for pending changes and enhance the descriptions of the intended change to use separate bits for each action. Signed-off-by: David Sterba <dsterba@suse.cz>
2014-11-12btrfs: add support for processing pending changesDavid Sterba
There are some actions that modify global filesystem state but cannot be performed at the time of request, but later at the transaction commit time when the filesystem is in a known state. For example enabling new incompat features on-the-fly or issuing transaction commit from unsafe contexts (sysfs handlers). Signed-off-by: David Sterba <dsterba@suse.cz>
2014-11-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "Filipe is nailing down some problems with our skinny extent variation, and Dave's patch fixes endian problems in the new super block checks" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: fix race that makes btrfs_lookup_extent_info miss skinny extent items Btrfs: properly clean up btrfs_end_io_wq_cache Btrfs: fix invalid leaf slot access in btrfs_lookup_extent() btrfs: use macro accessors in superblock validation checks
2014-10-27btrfs: use macro accessors in superblock validation checksDavid Sterba
The initial patch c926093ec516f5d316 (btrfs: add more superblock checks) did not properly use the macro accessors that wrap endianness and the code would not work correctly on big endian machines. Reported-by: Qu Wenruo <quwenruo@cn.fujitsu.com> Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com>
2014-10-18Merge branch 'for-3.18/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block layer changes from Jens Axboe: "This is the core block IO pull request for 3.18. Apart from the new and improved flush machinery for blk-mq, this is all mostly bug fixes and cleanups. - blk-mq timeout updates and fixes from Christoph. - Removal of REQ_END, also from Christoph. We pass it through the ->queue_rq() hook for blk-mq instead, freeing up one of the request bits. The space was overly tight on 32-bit, so Martin also killed REQ_KERNEL since it's no longer used. - blk integrity updates and fixes from Martin and Gu Zheng. - Update to the flush machinery for blk-mq from Ming Lei. Now we have a per hardware context flush request, which both cleans up the code should scale better for flush intensive workloads on blk-mq. - Improve the error printing, from Rob Elliott. - Backing device improvements and cleanups from Tejun. - Fixup of a misplaced rq_complete() tracepoint from Hannes. - Make blk_get_request() return error pointers, fixing up issues where we NULL deref when a device goes bad or missing. From Joe Lawrence. - Prep work for drastically reducing the memory consumption of dm devices from Junichi Nomura. This allows creating clone bio sets without preallocating a lot of memory. - Fix a blk-mq hang on certain combinations of queue depths and hardware queues from me. - Limit memory consumption for blk-mq devices for crash dump scenarios and drivers that use crazy high depths (certain SCSI shared tag setups). We now just use a single queue and limited depth for that" * 'for-3.18/core' of git://git.kernel.dk/linux-block: (58 commits) block: Remove REQ_KERNEL blk-mq: allocate cpumask on the home node bio-integrity: remove the needless fail handle of bip_slab creating block: include func name in __get_request prints block: make blk_update_request print prefix match ratelimited prefix blk-merge: don't compute bi_phys_segments from bi_vcnt for cloned bio block: fix alignment_offset math that assumes io_min is a power-of-2 blk-mq: Make bt_clear_tag() easier to read blk-mq: fix potential hang if rolling wakeup depth is too high block: add bioset_create_nobvec() block: use bio_clone_fast() in blk_rq_prep_clone() block: misplaced rq_complete tracepoint sd: Honor block layer integrity handling flags block: Replace strnicmp with strncasecmp block: Add T10 Protection Information functions block: Don't merge requests if integrity flags differ block: Integrity checksum flag block: Relocate bio integrity flags block: Add a disk flag to block integrity profile block: Add prefix to block integrity profile flags ...
2014-10-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs updates from Chris Mason: "The largest set of changes here come from Miao Xie. He's cleaning up and improving read recovery/repair for raid, and has a number of related fixes. I've merged another set of fsync fixes from Filipe, and he's also improved the way we handle metadata write errors to make sure we force the FS readonly if things go wrong. Otherwise we have a collection of fixes and cleanups. Dave Sterba gets a cookie for removing the most lines (thanks Dave)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (139 commits) btrfs: Fix compile error when CONFIG_SECURITY is not set. Btrfs: fix compiles when CONFIG_BTRFS_FS_RUN_SANITY_TESTS is off btrfs: Make btrfs handle security mount options internally to avoid losing security label. Btrfs: send, don't delay dir move if there's a new parent inode btrfs: add more superblock checks Btrfs: fix race in WAIT_SYNC ioctl Btrfs: be aware of btree inode write errors to avoid fs corruption Btrfs: remove redundant btrfs_verify_qgroup_counts declaration. btrfs: fix shadow warning on cmp Btrfs: fix compilation errors under DEBUG Btrfs: fix crash of btrfs_release_extent_buffer_page Btrfs: add missing end_page_writeback on submit_extent_page failure btrfs: Fix the wrong condition judgment about subset extent map Btrfs: fix build_backref_tree issue with multiple shared blocks Btrfs: cleanup error handling in build_backref_tree btrfs: move checks for DUMMY_ROOT into a helper btrfs: new define for the inline extent data start btrfs: kill extent_buffer_page helper btrfs: drop constant param from btrfs_release_extent_buffer_page btrfs: hide typecast to definition of BTRFS_SEND_TRANS_STUB ...
2014-10-04Merge branch 'cleanup/blocksize-diet-part1' of ↵Chris Mason
2014-10-04Merge branch 'cleanup/misc-for-3.18' of ↵Chris Mason
git://git.kernel.org/pub/scm/linux/kernel/git/kdave/linux into for-linus Signed-off-by: Chris Mason <clm@fb.com> Conflicts: fs/btrfs/extent_io.c
2014-10-03btrfs: add more superblock checksDavid Sterba
Populate btrfs_check_super_valid() with checks that try to verify consistency of superblock by additional conditions that may arise from corrupted devices or bitflips. Some of tests are only hints and issue warnings instead of failing the mount, basically when the checks are derived from the data found in the superblock. Tested on a broken image provided by Qu. Reported-by: Qu Wenruo <quwenruo@cn.fujitsu.com> Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com>
2014-10-03Btrfs: be aware of btree inode write errors to avoid fs corruptionFilipe Manana
While we have a transaction ongoing, the VM might decide at any time to call btree_inode->i_mapping->a_ops->writepages(), which will start writeback of dirty pages belonging to btree nodes/leafs. This call might return an error or the writeback might finish with an error before we attempt to commit the running transaction. If this happens, we might have no way of knowing that such error happened when we are committing the transaction - because the pages might no longer be marked dirty nor tagged for writeback (if a subsequent modification to the extent buffer didn't happen before the transaction commit) which makes filemap_fdata[write|wait]_range unable to find such pages (even if they're marked with SetPageError). So if this happens we must abort the transaction, otherwise we commit a super block with btree roots that point to btree nodes/leafs whose content on disk is invalid - either garbage or the content of some node/leaf from a past generation that got cowed or deleted and is no longer valid (for this later case we end up getting error messages like "parent transid verify failed on 10826481664 wanted 25748 found 29562" when reading btree nodes/leafs from disk). Note that setting and checking AS_EIO/AS_ENOSPC in the btree inode's i_mapping would not be enough because we need to distinguish between log tree extents (not fatal) vs non-log tree extents (fatal) and because the next call to filemap_fdatawait_range() will catch and clear such errors in the mapping - and that call might be from a log sync and not from a transaction commit, which means we would not know about the error at transaction commit time. Also, checking for the eb flag EXTENT_BUFFER_IOERR at transaction commit time isn't done and would not be completely reliable, as the eb might be removed from memory and read back when trying to get it, which clears that flag right before reading the eb's pages from disk, making us not know about the previous write error. Using the new 3 flags for the btree inode also makes us achieve the goal of AS_EIO/AS_ENOSPC when writepages() returns success, started writeback for all dirty pages and before filemap_fdatawait_range() is called, the writeback for all dirty pages had already finished with errors - because we were not using AS_EIO/AS_ENOSPC, filemap_fdatawait_range() would return success, as it could not know that writeback errors happened (the pages were no longer tagged for writeback). Signed-off-by: Filipe Manana <fdmanana@suse.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-10-02btrfs: move checks for DUMMY_ROOT into a helperDavid Sterba
2014-10-02btrfs: hide typecast to definition of BTRFS_SEND_TRANS_STUBDavid Sterba
2014-10-02btrfs: use slab for end_io_wq structuresDavid Sterba
The structure is frequently reused. Rename it according to the slab name. Signed-off-by: David Sterba <dsterba@suse.cz>
2014-10-02btrfs: use enum for wq endio metadata typeDavid Sterba
The enum exists but is not consistently used. Signed-off-by: David Sterba <dsterba@suse.cz>
2014-10-02Btrfs: set default max_inline to 8KiB instead of 8MiBFilipe David Borba Manana
8MiB is way too large and likely set by mistake. This is not a significant issue as in practice the max amount of data added to an inline extent is also limited by the page cache and btree leaf sizes. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Reviewed-by: David Sterba <dsterba@suse.cz> Signed-off-by: David Sterba <dsterba@suse.cz>
2014-10-02btrfs: remove blocksize from btrfs_alloc_free_block and renameDavid Sterba
Rename to btrfs_alloc_tree_block as it fits to the alloc/find/free + _tree_block family. The parameter blocksize was set to the metadata block size, directly or indirectly. Signed-off-by: David Sterba <dsterba@suse.cz>
2014-10-02btrfs: remove unused parameter blocksize from btrfs_find_tree_blockDavid Sterba
2014-10-02btrfs: remove parameter blocksize from read_tree_blockDavid Sterba
We know the tree block size, no need to pass it around. Signed-off-by: David Sterba <dsterba@suse.cz>
2014-10-02btrfs: return void from readahead_tree_blockDavid Sterba
Errors in readahead are not fatal and ignored elsewhere in the code. Signed-off-by: David Sterba <dsterba@suse.cz>
2014-10-02btrfs: remove unused parameter from readahead_tree_blockDavid Sterba
The parent_transid parameter has been unused since its introduction in ca7a79ad8dbe2466 ("Pass down the expected generation number when reading tree blocks"). In reada_tree_block, it was even wrongly set to leafsize. Transid check is done in the proper read and readahead ignores errors. Signed-off-by: David Sterba <dsterba@suse.cz>
2014-09-24Merge branch 'for-linus' of ↵Tejun Heo
git://git.kernel.org/pub/scm/linux/kernel/git/axboe/linux-block into for-3.18 This is to receive 0a30288da1ae ("blk-mq, percpu_ref: implement a kludge for SCSI blk-mq stall during probe") which implements __percpu_ref_kill_expedited() to work around SCSI blk-mq stall. The commit reverted and patches to implement proper fix will be added. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Christoph Hellwig <hch@lst.de>
2014-09-22Btrfs: remove empty block groups automaticallyJosef Bacik
One problem that has plagued us is that a user will use up all of his space with data, remove a bunch of that data, and then try to create a bunch of small files and run out of space. This happens because all the chunks were allocated for data since the metadata requirements were so low. But now there's a bunch of empty data block groups and not enough metadata space to do anything. This patch solves this problem by automatically deleting empty block groups. If we notice the used count go down to 0 when deleting or on mount notice that a block group has a used count of 0 then we will queue it to be deleted. When the cleaner thread runs we will double check to make sure the block group is still empty and then we will delete it. This patch has the side effect of no longer having a bunch of BUG_ON()'s in the chunk delete code, which will be helpful for both this and relocate. Thanks, Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-09-17Btrfs: implement repair function when direct read failsMiao Xie
This patch implement data repair function when direct read fails. The detail of the implementation is: - When we find the data is not right, we try to read the data from the other mirror. - When the io on the mirror ends, we will insert the endio work into the dedicated btrfs workqueue, not common read endio workqueue, because the original endio work is still blocked in the btrfs endio workqueue, if we insert the endio work of the io on the mirror into that workqueue, deadlock would happen. - After we get right data, we write it back to the corrupted mirror. - And if the data on the new mirror is still corrupted, we will try next mirror until we read right data or all the mirrors are traversed. - After the above work, we set the uptodate flag according to the result. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-09-17Btrfs: fix wrong device bytes_used in the super blockMiao Xie
device->bytes_used will be changed when allocating a new chunk, and disk_total_size will be changed if resizing is successful. Meanwhile, the on-disk super blocks of the previous transaction might not be updated. Considering the consistency of the metadata in the previous transaction, We should use the size in the previous transaction to check if the super block is beyond the boundary of the device. Though it is not big problem because we don't use it now, but anyway it is better that we make it be consistent with the common metadata, maybe we will use it in the future. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-09-17Btrfs: fix wrong disk size when writing super blocksMiao Xie
total_size will be changed when resizing a device, and disk_total_size will be changed if resizing is successful. Meanwhile, the on-disk super blocks of the previous transaction might not be updated. Considering the consistency of the metadata in the previous transaction, We should use the size in the previous transaction to check if the super block is beyond the boundary of the device. Fix it. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-09-17btrfs: remove the wrong commentsLi RongQing
This comments became wrong after c3c532[bdi: add helper function for doing init and register of a bdi for a file system], so remove them. Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-09-17btrfs: Drop stray check of fixup_workers creationAndrey Utkin
The issue was introduced in a79b7d4b3e8118f265dcb4bdf9a572c392f02708, adding allocation of extent_workers, so this stray check is surely not meant to be a check of something else. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=82021 Reported-by: Maks Naumov <maksqwe1@ukr.net> Signed-off-by: Andrey Utkin <andrey.krieger.utkin@gmail.com> Reviewed-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-09-17Btrfs: print btrfs specific info for some fatal error casesWang Shilong
Marc argued that if there are several btrfs filesystems mounted, while users even don't know which filesystem hit the corrupted errors something like generation verification failure. Since @extent_buffer structure has a member @fs_info, let's output btrfs device info. Reported-by: Marc MERLIN <marc@merlins.org> Signed-off-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com> Signed-off-by: Chris Mason <clm@fb.com>
