path: root/fs/btrfs/ctree.c
2011-06-09Btrfs: don't map extent buffer if path->skip_locking is setJosef Bacik
Arne's scrub stuff exposed a problem with mapping the extent buffer in reada_for_search. He searches the commit root with multiple threads and with skip_locking set, so we can race and overwrite node->map_token since node isn't locked. So fix this so that we only map the extent buffer if we don't already have a map_token and skip_locking isn't set. Without this patch scrub would panic almost immediately, with the patch it doesn't panic anymore. Thanks, Reported-by: Arne Jansen <sensille@gmx.net> Signed-off-by: Josef Bacik <josef@redhat.com>
2011-05-28Merge branch 'for-chris' ofChris Mason
git://git.kernel.org/pub/scm/linux/kernel/git/josef/btrfs-work into for-linus Conflicts: fs/btrfs/disk-io.c fs/btrfs/extent-tree.c fs/btrfs/free-space-cache.c fs/btrfs/inode.c fs/btrfs/transaction.c Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-23Merge branch 'cleanups_and_fixes' into inode_numbersChris Mason
Conflicts: fs/btrfs/tree-log.c fs/btrfs/volumes.c Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-23Btrfs: BUG_ON is deleted from the caller of btrfs_truncate_item & ↵Tsutomu Itoh
btrfs_extend_item Currently, btrfs_truncate_item and btrfs_extend_item returns only 0. So, the check by BUG_ON in the caller is unnecessary. Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-23Btrfs: don't always do readaheadJosef Bacik
Our readahead is sort of sloppy, and really isn't always needed. For example if ls is doing a stating ls (which is the default) it's going to stat in non-disk order, so if say you have a directory with a stupid amount of files, readahead is going to do nothing but waste time in the case of doing the stat. Taking the unconditional readahead out made my test go from 57 minutes to 36 minutes. This means that everywhere we do loop through the tree we want to make sure we do set path->reada properly, so I went through and found all of the places where we loop through the path and set reada to 1. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-05-23Btrfs: don't look at the extent buffer level 3 times in a rowJosef Bacik
We have a bit of debugging in btrfs_search_slot to make sure the level of the cow block is the same as the original block we were cow'ing. I don't think I've ever seen this tripped, so kill it. This saves us 2 kmap's per level in our search. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-05-23Btrfs: map the node block when looking for readahead targetsJosef Bacik
If we have particularly full nodes, we could call btrfs_node_blockptr up to 32 times, which is 32 pairs of kmap/kunmap, which _sucks_. So go ahead and map the extent buffer while we look for readahead targets. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-05-22Merge branch 'cleanups' of git://repo.or.cz/linux-2.6/btrfs-unstable into ↵Chris Mason
inode_numbers Conflicts: fs/btrfs/extent-tree.c fs/btrfs/free-space-cache.c fs/btrfs/inode.c fs/btrfs/tree-log.c Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-21btrfs: implement delayed inode items operationMiao Xie
Changelog V5 -> V6: - Fix oom when the memory load is high, by storing the delayed nodes into the root's radix tree, and letting btrfs inodes go. Changelog V4 -> V5: - Fix the race on adding the delayed node to the inode, which is spotted by Chris Mason. - Merge Chris Mason's incremental patch into this patch. - Fix deadlock between readdir() and memory fault, which is reported by Itaru Kitayama. Changelog V3 -> V4: - Fix nested lock, which is reported by Itaru Kitayama, by updating space cache inode in time. Changelog V2 -> V3: - Fix the race between the delayed worker and the task which does delayed items balance, which is reported by Tsutomu Itoh. - Modify the patch address David Sterba's comment. - Fix the bug of the cpu recursion spinlock, reported by Chris Mason Changelog V1 -> V2: - break up the global rb-tree, use a list to manage the delayed nodes, which is created for every directory and file, and used to manage the delayed directory name index items and the delayed inode item. - introduce a worker to deal with the delayed nodes. Compare with Ext3/4, the performance of file creation and deletion on btrfs is very poor. the reason is that btrfs must do a lot of b+ tree insertions, such as inode item, directory name item, directory name index and so on. If we can do some delayed b+ tree insertion or deletion, we can improve the performance, so we made this patch which implemented delayed directory name index insertion/deletion and delayed inode update. Implementation: - introduce a delayed root object into the filesystem, that use two lists to manage the delayed nodes which are created for every file/directory. One is used to manage all the delayed nodes that have delayed items. And the other is used to manage the delayed nodes which is waiting to be dealt with by the work thread. - Every delayed node has two rb-tree, one is used to manage the directory name index which is going to be inserted into b+ tree, and the other is used to manage the directory name index which is going to be deleted from b+ tree. - introduce a worker to deal with the delayed operation. This worker is used to deal with the works of the delayed directory name index items insertion and deletion and the delayed inode update. When the delayed items is beyond the lower limit, we create works for some delayed nodes and insert them into the work queue of the worker, and then go back. When the delayed items is beyond the upper bound, we create works for all the delayed nodes that haven't been dealt with, and insert them into the work queue of the worker, and then wait for that the untreated items is below some threshold value. - When we want to insert a directory name index into b+ tree, we just add the information into the delayed inserting rb-tree. And then we check the number of the delayed items and do delayed items balance. (The balance policy is above.) - When we want to delete a directory name index from the b+ tree, we search it in the inserting rb-tree at first. If we look it up, just drop it. If not, add the key of it into the delayed deleting rb-tree. Similar to the delayed inserting rb-tree, we also check the number of the delayed items and do delayed items balance. (The same to inserting manipulation) - When we want to update the metadata of some inode, we cached the data of the inode into the delayed node. the worker will flush it into the b+ tree after dealing with the delayed insertion and deletion. - We will move the delayed node to the tail of the list after we access the delayed node, By this way, we can cache more delayed items and merge more inode updates. - If we want to commit transaction, we will deal with all the delayed node. - the delayed node will be freed when we free the btrfs inode. - Before we log the inode items, we commit all the directory name index items and the delayed inode update. I did a quick test by the benchmark tool[1] and found we can improve the performance of file creation by ~15%, and file deletion by ~20%. Before applying this patch: Create files: Total files: 50000 Total time: 1.096108 Average time: 0.000022 Delete files: Total files: 50000 Total time: 1.510403 Average time: 0.000030 After applying this patch: Create files: Total files: 50000 Total time: 0.932899 Average time: 0.000019 Delete files: Total files: 50000 Total time: 1.215732 Average time: 0.000024 [1] http://marc.info/?l=linux-btrfs&m=128212635122920&q=p3 Many thanks for Kitayama-san's help! Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Reviewed-by: David Sterba <dave@jikos.cz> Tested-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Tested-by: Itaru Kitayama <kitayama@cl.bb4u.ne.jp> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-02btrfs: drop unused parameter from btrfs_release_pathDavid Sterba
parameter tree root it's not used since commit 5f39d397dfbe140a14edecd4e73c34ce23c4f9ee ("Btrfs: Create extent_buffer interface for large blocksizes") Signed-off-by: David Sterba <dsterba@suse.cz>
2011-05-02btrfs: make functions static when possibleDavid Sterba
2011-05-02btrfs: remove nested duplicate variable declarationsDavid Sterba
2011-03-28Btrfs: check return value of read_tree_block()Tsutomu Itoh
This patch is checking return value of read_tree_block(), and if it is NULL, error processing. Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-03-28Btrfs: cleanup some BUG_ON()Tsutomu Itoh
This patch changes some BUG_ON() to the error return. (but, most callers still use BUG_ON()) Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-03-28Btrfs: add initial tracepoint support for btrfsliubo
Tracepoints can provide insight into why btrfs hits bugs and be greatly helpful for debugging, e.g dd-7822 [000] 2121.641088: btrfs_inode_request: root = 5(FS_TREE), gen = 4, ino = 256, blocks = 8, disk_i_size = 0, last_trans = 8, logged_trans = 0 dd-7822 [000] 2121.641100: btrfs_inode_new: root = 5(FS_TREE), gen = 8, ino = 257, blocks = 0, disk_i_size = 0, last_trans = 0, logged_trans = 0 btrfs-transacti-7804 [001] 2146.935420: btrfs_cow_block: root = 2(EXTENT_TREE), refs = 2, orig_buf = 29368320 (orig_level = 0), cow_buf = 29388800 (cow_level = 0) btrfs-transacti-7804 [001] 2146.935473: btrfs_cow_block: root = 1(ROOT_TREE), refs = 2, orig_buf = 29364224 (orig_level = 0), cow_buf = 29392896 (cow_level = 0) btrfs-transacti-7804 [001] 2146.972221: btrfs_transaction_commit: root = 1(ROOT_TREE), gen = 8 flush-btrfs-2-7821 [001] 2155.824210: btrfs_chunk_alloc: root = 3(CHUNK_TREE), offset = 1103101952, size = 1073741824, num_stripes = 1, sub_stripes = 0, type = DATA flush-btrfs-2-7821 [001] 2155.824241: btrfs_cow_block: root = 2(EXTENT_TREE), refs = 2, orig_buf = 29388800 (orig_level = 0), cow_buf = 29396992 (cow_level = 0) flush-btrfs-2-7821 [001] 2155.824255: btrfs_cow_block: root = 4(DEV_TREE), refs = 2, orig_buf = 29372416 (orig_level = 0), cow_buf = 29401088 (cow_level = 0) flush-btrfs-2-7821 [000] 2155.824329: btrfs_cow_block: root = 3(CHUNK_TREE), refs = 2, orig_buf = 20971520 (orig_level = 0), cow_buf = 20975616 (cow_level = 0) btrfs-endio-wri-7800 [001] 2155.898019: btrfs_cow_block: root = 5(FS_TREE), refs = 2, orig_buf = 29384704 (orig_level = 0), cow_buf = 29405184 (cow_level = 0) btrfs-endio-wri-7800 [001] 2155.898043: btrfs_cow_block: root = 7(CSUM_TREE), refs = 2, orig_buf = 29376512 (orig_level = 0), cow_buf = 29409280 (cow_level = 0) Here is what I have added: 1) ordere_extent: btrfs_ordered_extent_add btrfs_ordered_extent_remove btrfs_ordered_extent_start btrfs_ordered_extent_put These provide critical information to understand how ordered_extents are updated. 2) extent_map: btrfs_get_extent extent_map is used in both read and write cases, and it is useful for tracking how btrfs specific IO is running. 3) writepage: __extent_writepage btrfs_writepage_end_io_hook Pages are cirtical resourses and produce a lot of corner cases during writeback, so it is valuable to know how page is written to disk. 4) inode: btrfs_inode_new btrfs_inode_request btrfs_inode_evict These can show where and when a inode is created, when a inode is evicted. 5) sync: btrfs_sync_file btrfs_sync_fs These show sync arguments. 6) transaction: btrfs_transaction_commit In transaction based filesystem, it will be useful to know the generation and who does commit. 7) back reference and cow: btrfs_delayed_tree_ref btrfs_delayed_data_ref btrfs_delayed_ref_head btrfs_cow_block Btrfs natively supports back references, these tracepoints are helpful on understanding btrfs's COW mechanism. 8) chunk: btrfs_chunk_alloc btrfs_chunk_free Chunk is a link between physical offset and logical offset, and stands for space infomation in btrfs, and these are helpful on tracing space things. 9) reserved_extent: btrfs_reserved_extent_alloc btrfs_reserved_extent_free These can show how btrfs uses its space. Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-03-28Btrfs: use RCU instead of a spinlock to protect the root nodeChris Mason
The pointer to the extent buffer for the root of each tree is protected by a spinlock so that we can safely read the pointer and take a reference on the extent buffer. But now that the extent buffers are freed via RCU, we can safely use rcu_read_lock instead. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-03-17Btrfs: check items for correctness as we searchJosef Bacik
Currently if we have corrupted items things will blow up in spectacular ways. So as we read in blocks and they are leaves, check the entire leaf to make sure all of the items are correct and point to valid parts in the leaf for the item data the are responsible for. If the item is corrupt we will kick back EIO and not read any of the copies since they are likely to not be correct either. This will catch generic corruptions, it will be up to the individual callers of btrfs_search_slot to make sure their items are right. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-01-16btrfs: check NULL or notTsutomu Itoh
Should check if functions returns NULL or not. Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-01-16btrfs: Don't pass NULL ptr to func that may deref it.Jesper Juhl
Hi, In fs/btrfs/inode.c::fixup_tree_root_location() we have this code: ... if (!path) { err = -ENOMEM; goto out; } ... out: btrfs_free_path(path); return err; btrfs_free_path() passes its argument on to other functions and some of them end up dereferencing the pointer. In the code above that pointer is clearly NULL, so btrfs_free_path() will eventually cause a NULL dereference. There are many ways to cut this cake (fix the bug). The one I chose was to make btrfs_free_path() deal gracefully with NULL pointers. If you disagree, feel free to come up with an alternative patch. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-10-29Btrfs: cleanup warnings from gcc 4.6 (nonbugs)Andi Kleen
These are all the cases where a variable is set, but not read which are not bugs as far as I can see, but simply leftovers. Still needs more review. Found by gcc 4.6's new warnings Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-10-29Btrfs: don't loop forever on bad btree blocksChris Mason
When btrfs discovers the generation number in a btree block is incorrect, it can loop forever without forcing the RAID code to try a valid mirror, and without returning EIO. This changes things to properly kick out the EIO. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-07-19Btrfs: fix split_leaf double split corner caseChris Mason
split_leaf was not properly balancing leaves when it was forced to split a leaf twice. This commit adds an extra push left and right before forcing the double split in hopes of getting the slot where we want to insert at either the start or end of the leaf. If the extra pushes do work, then we are able to avoid splitting twice and we keep the tree properly balanced. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-05-26Btrfs: Fix block generation verification raceYan, Zheng
After the path is released, the generation number got from block pointer is no long valid. The race may cause disk corruption, because verify_parent_transid() calls clear_extent_buffer_uptodate() when generation numbers mismatch. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-05-25Btrfs: Metadata ENOSPC handling for balanceYan, Zheng
This patch adds metadata ENOSPC handling for the balance code. It is consisted by following major changes: 1. Avoid COW tree leave in the phrase of merging tree. 2. Handle interaction with snapshot creation. 3. make the backref cache can live across transactions. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-05-25Btrfs: Introduce contexts for metadata reservationYan, Zheng
Introducing metadata reseravtion contexts has two major advantages. First, it makes metadata reseravtion more traceable. Second, it can reclaim freed space and re-add them to the itself after transaction committed. Besides add btrfs_block_rsv structure and related helper functions, This patch contains following changes: Move code that decides if freed tree block should be pinned into btrfs_free_tree_block(). Make space accounting more accurate, mainly for handling read only block groups. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-04-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: add check for changed leaves in setup_leaf_for_split Btrfs: create snapshot references in same commit as snapshot Btrfs: fix small race with delalloc flushing waitqueue's Btrfs: use add_to_page_cache_lru, use __page_cache_alloc Btrfs: fix chunk allocate size calculation Btrfs: kill max_extent mount option Btrfs: fail to mount if we have problems reading the block groups Btrfs: check btrfs_get_extent return for IS_ERR() Btrfs: handle kmalloc() failure in inode lookup ioctl Btrfs: dereferencing freed memory Btrfs: Simplify num_stripes's calculation logical for __btrfs_alloc_chunk() Btrfs: Add error handle for btrfs_search_slot() in btrfs_read_chunk_tree() Btrfs: Remove unnecessary finish_wait() in wait_current_trans() Btrfs: add NULL check for do_walk_down() Btrfs: remove duplicate include in ioctl.c Fix trivial conflict in fs/btrfs/compression.c due to slab.h include cleanups.
2010-04-05Btrfs: add check for changed leaves in setup_leaf_for_splitChris Mason
setup_leaf_for_split needs to drop the path and search again, and has checks to see if the item we want to split changed size. But, it misses the case where the leaf changed and now has enough room for the item we want to insert. This adds an extra check to make sure the leaf really needs splitting before we call btrfs_split_leaf(), which keeps us from trying to split a leaf with a single item. btrfs_split_leaf() will blindly split the single item leaf, leaving us with one good leaf and one empty leaf and then a crash. Signed-off-by: Chris Mason <chris.mason@oracle.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-17Btrfs: Fix per root used space accountingYan, Zheng
The bytes_used field in root item was originally planned to trace the amount of used data and tree blocks. But it never worked right since we can't trace freeing of data accurately. This patch changes it to only trace the amount of tree blocks. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-12-15Btrfs: Add btrfs_duplicate_itemYan, Zheng
btrfs_duplicate_item duplicates item with new key, guaranteeing the source item and the new items are in the same tree leaf and contiguous. It allows us to split file extent in place, without using lock_extent to prevent bookend extent race. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-09-24Btrfs: check size of inode backref before adding hardlinkYan, Zheng
For every hardlink in btrfs, there is a corresponding inode back reference. All inode back references for hardlinks in a given directory are stored in single b-tree item. The size of b-tree item is limited by the size of b-tree leaf, so we can only create limited number of hardlinks to a given file in a directory. The original code lacks of the check, it oops if the number of hardlinks goes over the limit. This patch fixes the issue by adding check to btrfs_link and btrfs_rename. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-07-24Btrfs: Avoid delayed reference update loopingYan Zheng
btrfs_split_leaf and btrfs_del_items can end up in a loop where one is constantly spliting a given leaf and the other is constantly merging it back with the adjacent nodes. There is a better fix for this, but in the interest of something small, this patch just changes btrfs_del_items back to balancing less often. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-07-24Btrfs: Fix ordering of key field checks in btrfs_previous_itemYan Zheng
Check objectid of item before checking the item type, otherwise we may return zero for a key that is actually too low. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-07-24Btrfs: Remove code duplication in comp_keysDiego Calleja
comp_keys is duplicating what is done in btrfs_comp_cpu_keys, so just call it. Signed-off-by: Diego Calleja <diegocg@gmail.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-07-22Btrfs: fix locking issue in btrfs_find_next_keyYan Zheng
When walking up the tree, btrfs_find_next_key assumes the upper level tree block is properly locked. This isn't always true even path->keep_locks is 1. This is because btrfs_find_next_key may advance path->slots[] several times instead of only once. When 'path->slots[level] >= btrfs_header_nritems(path->nodes[level])' is found, we can't guarantee the original value of 'path->slots[level]' is 'btrfs_header_nritems(path->nodes[level]) - 1'. If it's not, the tree block at 'level + 1' isn't locked. This patch fixes the issue by explicitly checking the locking state, re-searching the tree if it's not locked. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-07-22Btrfs: fix double increment of path->slots[0] in btrfs_next_leafYan Zheng
if 1 is returned by btrfs_search_slot, the path already points to the first item with 'key > searching key'. So increasing path->slots[0] by one is superfluous in that case. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-06-10Btrfs: balance btree more oftenChris Mason
With the new back reference code, the cost of a balance has gone down in terms of the number of back reference updates done. This commit makes us more aggressively balance leaves and nodes as they become less full. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-06-10Btrfs: stop avoiding balancing at the end of the transaction.Chris Mason
When the delayed reference code was added, some checks were added to avoid extra balancing while the delayed references were being flushed. This made for less efficient btrees, but it reduced the chances of loops where no forward progress was made because the balances made more delayed ref updates. With the new dead root removal code and the mixed back references, the extent allocation tree is no longer using precise back refs, and the delayed reference updates don't carry the risk of looping forever anymore. So, the balance avoidance is no longer required. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-06-10Btrfs: Mixed back reference (FORWARD ROLLING FORMAT CHANGE)Yan Zheng
This commit introduces a new kind of back reference for btrfs metadata. Once a filesystem has been mounted with this commit, IT WILL NO LONGER BE MOUNTABLE BY OLDER KERNELS. When a tree block in subvolume tree is cow'd, the reference counts of all extents it points to are increased by one. At transaction commit time, the old root of the subvolume is recorded in a "dead root" data structure, and the btree it points to is later walked, dropping reference counts and freeing any blocks where the reference count goes to 0. The increments done during cow and decrements done after commit cancel out, and the walk is a very expensive way to go about freeing the blocks that are no longer referenced by the new btree root. This commit reduces the transaction overhead by avoiding the need for dead root records. When a non-shared tree block is cow'd, we free the old block at once, and the new block inherits old block's references. When a tree block with reference count > 1 is cow'd, we increase the reference counts of all extents the new block points to by one, and decrease the old block's reference count by one. This dead tree avoidance code removes the need to modify the reference counts of lower level extents when a non-shared tree block is cow'd. But we still need to update back ref for all pointers in the block. This is because the location of the block is recorded in the back ref item. We can solve this by introducing a new type of back ref. The new back ref provides information about pointer's key, level and in which tree the pointer lives. This information allow us to find the pointer by searching the tree. The shortcoming of the new back ref is that it only works for pointers in tree blocks referenced by their owner trees. This is mostly a problem for snapshots, where resolving one of these fuzzy back references would be O(number_of_snapshots) and quite slow. The solution used here is to use the fuzzy back references in the common case where a given tree block is only referenced by one root, and use the full back references when multiple roots have a reference on a given block. This commit adds per subvolume red-black tree to keep trace of cached inodes. The red-black tree helps the balancing code to find cached inodes whose inode numbers within a given range. This commit improves the balancing code by introducing several data structures to keep the state of balancing. The most important one is the back ref cache. It caches how the upper level tree blocks are referenced. This greatly reduce the overhead of checking back ref. The improved balancing code scales significantly better with a large number of snapshots. This is a very large commit and was written in a number of pieces. But, they depend heavily on the disk format change and were squashed together to make sure git bisect didn't end up in a bad state wrt space balancing or the format change. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-05-14Btrfs: Don't loop forever on metadata IO failuresChris Mason
When a btrfs metadata read fails, the first thing we try to do is find a good copy on another mirror of the block. If this fails, read_tree_block() ends up returning a buffer that isn't up to date. The btrfs btree reading code was reworked to drop locks and repeat the search when IO was done, but the changes didn't add a check for failed reads. The end result was looping forever on buffers that were never going to become up to date. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-04-20Btrfs: use the right node in reada_for_balanceChris Mason
reada_for_balance was using the wrong index into the path node array, so it wasn't reading the right blocks. We never directly used the results of the read done by this function because the btree search is started over at the end. This fixes reada_for_balance to reada in the correct node and to avoid searching past the last slot in the node. It also makes sure to hold the parent lock while we are finding the nodes to read. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-04-02Btrfs: BUG to BUG_ON changesStoyan Gaydarov
2009-04-03Btrfs: Optimize locking in btrfs_next_leaf()Chris Mason
btrfs_next_leaf was using blocking locks when it could have been using faster spinning ones instead. This adds a few extra checks around the pieces that block and switches over to spinning locks. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-04-03Btrfs: break up btrfs_search_slot into smaller piecesChris Mason
btrfs_search_slot was doing too many things at once. This breaks it up into more reasonable units. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-03-24Btrfs: limit balancing work while flushing delayed refsChris Mason
The delayed reference mechanism is responsible for all updates to the extent allocation trees, including those updates created while processing the delayed references. This commit tries to limit the amount of work that gets created during the final run of delayed refs before a commit. It avoids cowing new blocks unless it is required to finish the commit, and so it avoids new allocations that were not really required. The goal is to avoid infinite loops where we are always making more work on the final run of delayed refs. Over the long term we'll make a special log for the last delayed ref updates as well. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-03-24Btrfs: leave btree locks spinning more oftenChris Mason
btrfs_mark_buffer dirty would set dirty bits in the extent_io tree for the buffers it was dirtying. This may require a kmalloc and it was not atomic. So, anyone who called btrfs_mark_buffer_dirty had to set any btree locks they were holding to blocking first. This commit changes dirty tracking for extent buffers to just use a flag in the extent buffer. Now that we have one and only one extent buffer per page, this can be safely done without losing dirty bits along the way. This also introduces a path->leave_spinning flag that callers of btrfs_search_slot can use to indicate they will properly deal with a path returned where all the locks are spinning instead of blocking. Many of the btree search callers now expect spinning paths, resulting in better btree concurrency overall. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-03-24Btrfs: reduce stack usage in some crucial tree balancing functionsChris Mason
Many of the tree balancing functions follow the same pattern. 1) cow a block 2) do something to the result This commit breaks them up into two functions so the variables and code required for part two don't suck down stack during part one. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-03-24Btrfs: do extent allocation and reference count updates in the backgroundChris Mason
The extent allocation tree maintains a reference count and full back reference information for every extent allocated in the filesystem. For subvolume and snapshot trees, every time a block goes through COW, the new copy of the block adds a reference on every block it points to. If a btree node points to 150 leaves, then the COW code needs to go and add backrefs on 150 different extents, which might be spread all over the extent allocation tree. These updates currently happen during btrfs_cow_block, and most COWs happen during btrfs_search_slot. btrfs_search_slot has locks held on both the parent and the node we are COWing, and so we really want to avoid IO during the COW if we can. This commit adds an rbtree of pending reference count updates and extent allocations. The tree is ordered by byte number of the extent and byte number of the parent for the back reference. The tree allows us to: 1) Modify back references in something close to disk order, reducing seeks 2) Significantly reduce the number of modifications made as block pointers are balanced around 3) Do all of the extent insertion and back reference modifications outside of the performance critical btrfs_search_slot code. #3 has the added benefit of greatly reducing the btrfs stack footprint. The extent allocation tree modifications are done without the deep (and somewhat recursive) call chains used in the past. These delayed back reference updates must be done before the transaction commits, and so the rbtree is tied to the transaction. Throttling is implemented to help keep the queue of backrefs at a reasonable size. Since there was a similar mechanism in place for the extent tree extents, that is removed and replaced by the delayed reference tree. Yan Zheng <yan.zheng@oracle.com> helped review and fixup this code. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-03-24Btrfs: don't preallocate metadata blocks during btrfs_search_slotChris Mason
In order to avoid doing expensive extent management with tree locks held, btrfs_search_slot will preallocate tree blocks for use by COW without any tree locks held. A later commit moves all of the extent allocation work for COW into a delayed update mechanism, and this preallocation will no longer be required. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-03-09Btrfs: fix spinlock assertions on UP systemsChris Mason
btrfs_tree_locked was being used to make sure a given extent_buffer was properly locked in a few places. But, it wasn't correct for UP compiled kernels. This switches it to using assert_spin_locked instead, and renames it to btrfs_assert_tree_locked to better reflect how it was really being used. Signed-off-by: Chris Mason <chris.mason@oracle.com>
