path: root/fs/btrfs/check-integrity.c
2015-03-25Merge branch 'cleanups-post-3.19' of ↵Chris Mason
git://git.kernel.org/pub/scm/linux/kernel/git/kdave/linux into for-linus-4.1 Signed-off-by: Chris Mason <clm@fb.com> Conflicts: fs/btrfs/disk-io.c
2015-03-03btrfs: cleanup, use kmalloc_array/kcalloc array helpersDavid Sterba
Convert kmalloc(nr * size, ..) to kmalloc_array that does additional overflow checks, the zeroing variant is kcalloc. Signed-off-by: David Sterba <dsterba@suse.cz>
2015-02-16Btrfs: switch to kvfree() helperWang Shilong
A new helper kvfree() in mm/utils.c will do this. Signed-off-by: Wang Shilong <wangshilong1991@gmail.com> Signed-off-by: David Sterba <dsterba@suse.cz>
2014-11-25Btrfs: include vmalloc.h in check-integrity.cChris Mason
Fengguang's build monster reported warnings on some arches because we don't have vmalloc.h included Signed-off-by: Chris Mason <clm@fb.com> Reported-by: fengguang.wu@intel.com
2014-11-20Btrfs: check-int: don't complain about balanced blocksStefan Behrens
The xfstest btrfs/014 which tests the balance operation caused that the check_int module complained that known blocks changed their physical location. Since this is not an error in this case, only print such message if the verbose mode was enabled. Reported-by: Wang Shilong <wangshilong1991@gmail.com> Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Tested-by: Wang Shilong <wangshilong1991@gmail.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-11-20Btrfs: check_int: use the known block locationStefan Behrens
The xfstest btrfs/014 which tests the balance operation caused issues with the check_int module. The attempt was made to use btrfs_map_block() to find the physical location for a written block. However, this was not at all needed since the location of the written block was known since a hook to submit_bio() was the reason for entering the check_int module. Additionally, after a block relocation it happened that btrfs_map_block() failed causing misleading error messages afterwards. This patch changes the check_int module to use the known information of the physical location from the bio. Reported-by: Wang Shilong <wangshilong1991@gmail.com> Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Tested-by: Wang Shilong <wangshilong1991@gmail.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-11-20Btrfs: fix allocationg memory failure for btrfsic_state structureShilong Wang
size of @btrfsic_state needs more than 2M, it is very likely to fail allocating memory using kzalloc(). see following mesage: [91428.902148] Call Trace: [<ffffffff816f6e0f>] dump_stack+0x4d/0x66 [<ffffffff811b1c7f>] warn_alloc_failed+0xff/0x170 [<ffffffff811b66e1>] __alloc_pages_nodemask+0x951/0xc30 [<ffffffff811fd9da>] alloc_pages_current+0x11a/0x1f0 [<ffffffff811b1e0b>] ? alloc_kmem_pages+0x3b/0xf0 [<ffffffff811b1e0b>] alloc_kmem_pages+0x3b/0xf0 [<ffffffff811d1018>] kmalloc_order+0x18/0x50 [<ffffffff811d1074>] kmalloc_order_trace+0x24/0x140 [<ffffffffa06c097b>] btrfsic_mount+0x8b/0xae0 [btrfs] [<ffffffff810af555>] ? check_preempt_curr+0x85/0xa0 [<ffffffff810b2de3>] ? try_to_wake_up+0x103/0x430 [<ffffffffa063d200>] open_ctree+0x1bd0/0x2130 [btrfs] [<ffffffffa060fdde>] btrfs_mount+0x62e/0x8b0 [btrfs] [<ffffffff811fd9da>] ? alloc_pages_current+0x11a/0x1f0 [<ffffffff811b0a5e>] ? __get_free_pages+0xe/0x50 [<ffffffff81230429>] mount_fs+0x39/0x1b0 [<ffffffff812509fb>] vfs_kern_mount+0x6b/0x150 [<ffffffff812537fb>] do_mount+0x27b/0xc30 [<ffffffff811b0a5e>] ? __get_free_pages+0xe/0x50 [<ffffffff812544f6>] SyS_mount+0x96/0xf0 [<ffffffff81701970>] system_call_fastpath+0x16/0x1b Since we are allocating memory for hash table array, so it will be good if we could allocate continuous pages here. Fix this problem by firstly trying kzalloc(), if we fail, use vzalloc() instead. Signed-off-by: Wang Shilong <wangshilong1991@gmail.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-09-17Btrfs: fix wrong disk size when writing super blocksMiao Xie
total_size will be changed when resizing a device, and disk_total_size will be changed if resizing is successful. Meanwhile, the on-disk super blocks of the previous transaction might not be updated. Considering the consistency of the metadata in the previous transaction, We should use the size in the previous transaction to check if the super block is beyond the boundary of the device. Fix it. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-09-17btrfs: use DIV_ROUND_UP instead of open-coded variantsDavid Sterba
The form (value + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT is equivalent to (value + PAGE_CACHE_SIZE - 1) / PAGE_CACHE_SIZE The rest is a simple subsitution, no difference in the generated assembly code. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com>
2014-09-17btrfs: use nodesize everywhere, kill leafsizeDavid Sterba
The nodesize and leafsize were never of different values. Unify the usage and make nodesize the one. Cleanup the redundant checks and helpers. Shaves a few bytes from .text: text data bss dec hex filename 852418 24560 23112 900090 dbbfa btrfs.ko.before 851074 24584 23112 898770 db6d2 btrfs.ko.after Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com>
2014-06-09btrfs: check_int: propagate out-of-memory error upwardsStefan Behrens
This issue was not causing any harm but IMO (and in the opinion of the static code checker) it is better to propagate this error status upwards. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "Filipe is fixing compile and boot problems with our crc32c rework, and Josef has disabled snapshot aware defrag for now. As the number of snapshots increases, we're hitting OOM. For the short term we're disabling things until a bigger fix is ready" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: use late_initcall instead of module_init Btrfs: use btrfs_crc32c everywhere instead of libcrc32c Btrfs: disable snapshot aware defrag for now
2014-02-03Btrfs: use btrfs_crc32c everywhere instead of libcrc32cFilipe David Borba Manana
After the commit titled "Btrfs: fix btrfs boot when compiled as built-in", LIBCRC32C requirement was removed from btrfs' Kconfig. This made it not possible to build a kernel with btrfs enabled (either as module or built-in) if libcrc32c is not enabled as well. So just replace all uses of libcrc32c with the equivalent function in btrfs hash.h - btrfs_crc32c. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs updates from Chris Mason: "This is a pretty big pull, and most of these changes have been floating in btrfs-next for a long time. Filipe's properties work is a cool building block for inheriting attributes like compression down on a per inode basis. Jeff Mahoney kicked in code to export filesystem info into sysfs. Otherwise, lots of performance improvements, cleanups and bug fixes. Looks like there are still a few other small pending incrementals, but I wanted to get the bulk of this in first" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (149 commits) Btrfs: fix spin_unlock in check_ref_cleanup Btrfs: setup inode location during btrfs_init_inode_locked Btrfs: don't use ram_bytes for uncompressed inline items Btrfs: fix btrfs_search_slot_for_read backwards iteration Btrfs: do not export ulist functions Btrfs: rework ulist with list+rb_tree Btrfs: fix memory leaks on walking backrefs failure Btrfs: fix send file hole detection leading to data corruption Btrfs: add a reschedule point in btrfs_find_all_roots() Btrfs: make send's file extent item search more efficient Btrfs: fix to catch all errors when resolving indirect ref Btrfs: fix protection between walking backrefs and root deletion btrfs: fix warning while merging two adjacent extents Btrfs: fix infinite path build loops in incremental send btrfs: undo sysfs when open_ctree() fails Btrfs: fix snprintf usage by send's gen_unique_name btrfs: fix defrag 32-bit integer overflow btrfs: sysfs: list the NO_HOLES feature btrfs: sysfs: don't show reserved incompat feature btrfs: call permission checks earlier in ioctls and return EPERM ...
2014-01-28Btrfs: fix check-integrity to look at the referenced data properlyJosef Bacik
We were looking at file_extent_num_bytes unconditionally when looking at referenced data bytes, but this isn't correct for compression. Fix this by checking the compression of the file extent we are and setting num_bytes to disk_num_bytes in the case of compression so that we are marking the proper bytes as referenced. This fixes check_int_data freaking out when running btrfs/004. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <clm@fb.com>
2013-12-05Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "A small collection of fixes for the current series. It contains: - A fix for a use-after-free of a request in blk-mq. From Ming Lei - A fix for a blk-mq bug that could attempt to dereference a NULL rq if allocation failed - Two xen-blkfront small fixes - Cleanup of submit_bio_wait() type uses in the kernel, unifying that. From Kent - A fix for 32-bit blkg_rwstat reading. I apologize for this one looking mangled in the shortlog, it's entirely my fault for missing an empty line between the description and body of the text" * 'for-linus' of git://git.kernel.dk/linux-block: blk-mq: fix use-after-free of request blk-mq: fix dereference of rq->mq_ctx if allocation fails block: xen-blkfront: Fix possible NULL ptr dereference xen-blkfront: Silence pfn maybe-uninitialized warning block: submit_bio_wait() conversions Update of blkg_stat and blkg_rwstat may happen in bh context
2013-11-24block: submit_bio_wait() conversionsKent Overstreet
It was being open coded in a few places. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Neil Brown <neilb@suse.de> Cc: Chris Mason <chris.mason@fusionio.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-23block: Abstract out bvec iteratorKent Overstreet
Immutable biovecs are going to require an explicit iterator. To implement immutable bvecs, a later patch is going to add a bi_bvec_done member to this struct; for now, this patch effectively just renames things. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Ed L. Cashin" <ecashin@coraid.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Lars Ellenberg <drbd-dev@lists.linbit.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Yehuda Sadeh <yehuda@inktank.com> Cc: Sage Weil <sage@inktank.com> Cc: Alex Elder <elder@inktank.com> Cc: ceph-devel@vger.kernel.org Cc: Joshua Morris <josh.h.morris@us.ibm.com> Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Neil Brown <neilb@suse.de> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mike Snitzer <snitzer@redhat.com> Cc: dm-devel@redhat.com Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com Cc: Boaz Harrosh <bharrosh@panasas.com> Cc: Benny Halevy <bhalevy@tonian.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Chris Mason <chris.mason@fusionio.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Jaegeuk Kim <jaegeuk.kim@samsung.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Dave Kleikamp <shaggy@kernel.org> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Ben Myers <bpm@sgi.com> Cc: xfs@oss.sgi.com Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Guo Chao <yan@linux.vnet.ibm.com> Cc: Tejun Heo <tj@kernel.org> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: "Roger Pau Monné" <roger.pau@citrix.com> Cc: Jan Beulich <jbeulich@suse.com> Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Cc: Ian Campbell <Ian.Campbell@citrix.com> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Jerome Marchand <jmarchand@redhat.com> Cc: Joe Perches <joe@perches.com> Cc: Peng Tao <tao.peng@emc.com> Cc: Andy Adamson <andros@netapp.com> Cc: fanchaoting <fanchaoting@cn.fujitsu.com> Cc: Jie Liu <jeff.liu@oracle.com> Cc: Sunil Mushran <sunil.mushran@gmail.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: Namjae Jeon <namjae.jeon@samsung.com> Cc: Pankaj Kumar <pankaj.km@samsung.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Mel Gorman <mgorman@suse.de>6
2013-11-23block: submit_bio_wait() conversionsKent Overstreet
2013-11-20Btrfs: print bytenr instead of page pointer in check-intStefan Behrens
The page pointer information was useless. The bytenr is what you want when you search for submitted write bios. Additionally, a new bit in the print mask is added that allows to selectively enable the check-int submit_bio verbose mode. Before, the global verbose mode had to be enabled leading to many million useless lines in the kernel log. And a comment is added that explains that LOG_BUF_SHIFT needs to be set to a really high value. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11btrfs: Use WARN_ON()'s return value in place of WARN_ON(1)Dulshani Gunawardhana
Use WARN_ON()'s return value in place of WARN_ON(1) for cleaner source code that outputs a more descriptive warnings. Also fix the styling warning of redundant braces that came up as a result of this fix. Signed-off-by: Dulshani Gunawardhana <dulshani.gunawardhana89@gmail.com> Reviewed-by: Zach Brown <zab@redhat.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: check_int, remove warning for mixed-modeStefan Behrens
In mixed-mode, when a data-block was later reused for metadata, a warning was printed. This condition is now filtered out and the warning is eliminated in this case. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: fix check_int 'leaf item out of bounce' regressionStefan Behrens
Yet another cleanup patch broke code for which no xfstest exists. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: Use %z to format size_tGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: Do not truncate sector_t on 32-bit with CONFIG_LBDAF=yGeert Uytterhoeven
sector_t may be either "u64" (always 64 bit) or "unsigned long" (32 or 64 bit). Casting it to "unsigned long" will truncate it on 32-bit platforms where CONFIG_LBDAF=y. Cast to "unsigned long long" and format using "ll" instead. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: PAGE_CACHE_SIZE is already unsigned longGeert Uytterhoeven
PAGE_CACHE_SIZE == PAGE_SIZE is "unsigned long" everywhere, so there's no need to cast it to "unsigned long". Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: Remove superfluous casts from u64 to unsigned long longGeert Uytterhoeven
u64 is "unsigned long long" on all architectures now, so there's no need to cast it when formatting it using the "ll" length modifier. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: get rid of sparse warningsStefan Behrens
make C=2 fs/btrfs/ CF=-D__CHECK_ENDIAN__ I tried to filter out the warnings for which patches have already been sent to the mailing list, pending for inclusion in btrfs-next. All these changes should be obviously safe. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01btrfs: Cleanup for using BTRFS_SETGET_STACK instead of raw convertQu Wenruo
Some codes still use the cpu_to_lexx instead of the BTRFS_SETGET_STACK_FUNCS declared in ctree.h. Also added some BTRFS_SETGET_STACK_FUNCS for btrfs_header btrfs_timespec and other structures. Signed-off-by: Qu Wenruo <quwenruo@cn.fujitsu.com> Reviewed-by: Miao Xie <miaoxie@cn.fujitsu.com> Reviewed-by: David Sterba <dsterba@suse.cz> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-05-17Btrfs: use a btrfs bioset instead of abusing bio internalsChris Mason
Btrfs has been pointer tagging bi_private and using bi_bdev to store the stripe index and mirror number of failed IOs. As bios bubble back up through the call chain, we use these to decide if and how to retry our IOs. They are also used to count IO failures on a per device basis. Recently a bio tracepoint was added lead to crashes because we were abusing bi_bdev. This commit adds a btrfs bioset, and creates explicit fields for the mirror number and stripe index. The plan is to extend this structure for all of the fields currently in struct btrfs_bio, which will mean one less kmalloc in our IO path. Signed-off-by: Chris Mason <chris.mason@fusionio.com> Reported-by: Tejun Heo <tj@kernel.org>
2013-02-20btrfs: define BTRFS_MAGIC as a u64 valueZach Brown
super.magic is an le64 but it's treated as an unterminated string when compared against BTRFS_MAGIC which is defined as a string. Instead define BTRFS_MAGIC as a normal hex value and use endian helpers to compare it to the super's magic. I tested this by mounting an fs made before the change and made sure that it didn't introduce sparse errors. This matches a similar cleanup that is pending in btrfs-progs. David Sterba pointed out that we should fix the kernel side as well :). Signed-off-by: Zach Brown <zab@redhat.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2012-12-16Btrfs: fix race in check-integrity caused by usage of bitfieldStefan Behrens
The structure member mirror_num is modified concurrently to the structure member is_iodone. This doesn't require any locking by design, unless everything is stored in the same 32 bits of a bit field. This was the case and xfstest 284 was able to trigger false warnings from the checker code. This patch seperates the bits and fixes the race. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2012-12-12Btrfs: handle errors from btrfs_map_bio() everywhereStefan Behrens
With the addition of the device replace procedure, it is possible for btrfs_map_bio(READ) to report an error. This happens when the specific mirror is requested which is located on the target disk, and the copy operation has not yet copied this block. Hence the block cannot be read and this error state is indicated by returning EIO. Some background information follows now. A new mirror is added while the device replace procedure is running. btrfs_get_num_copies() returns one more, and btrfs_map_bio(GET_READ_MIRROR) adds one more mirror if a disk location is involved that was already handled by the device replace copy operation. The assigned mirror num is the highest mirror number, e.g. the value 3 in case of RAID1. If btrfs_map_bio() is invoked with mirror_num == 0 (i.e., select any mirror), the copy on the target drive is never selected because that disk shall be able to perform the write requests as quickly as possible. The parallel execution of read requests would only slow down the disk copy procedure. Second case is that btrfs_map_bio() is called with mirror_num > 0. This is done from the repair code only. In this case, the highest mirror num is assigned to the target disk, since it is used last. And when this mirror is not available because the copy procedure has not yet handled this area, an error is returned. Everywhere in the code the handling of such errors is added now. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2012-12-12Btrfs: pass fs_info to btrfs_map_block() instead of mapping_treeStefan Behrens
This is required for the device replace procedure in a later step. Two calling functions also had to be changed to have the fs_info pointer: repair_io_failure() and scrub_setup_recheck_block(). Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2012-12-12Btrfs: Pass fs_info to btrfs_num_copies() instead of mapping_treeStefan Behrens
This is required for the device replace procedure in a later step. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2012-10-09Btrfs: detect corrupted filesystem after write I/O errorsStefan Behrens
In check-integrity, detect when a superblock is written that points to blocks that have not been written to disk due to I/O write errors. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de>
2012-07-25Btrfs: introduce subvol uuids and timesAlexander Block
This patch introduces uuids for subvolumes. Each subvolume has it's own uuid. In case it was snapshotted, it also contains parent_uuid. In case it was received, it also contains received_uuid. It also introduces subvolume ctime/otime/stime/rtime. The first two are comparable to the times found in inodes. otime is the origin/creation time and ctime is the change time. stime/rtime are only valid on received subvolumes. stime is the time of the subvolume when it was sent. rtime is the time of the subvolume when it was received. Additionally to the times, we have a transid for each time. They are updated at the same place as the times. btrfs receive uses stransid and rtransid to find out if a received subvolume changed in the meantime. If an older kernel mounts a filesystem with the extented fields, all fields become invalid. The next mount with a new kernel will detect this and reset the fields. Signed-off-by: Alexander Block <ablock84@googlemail.com> Reviewed-by: David Sterba <dave@jikos.cz> Reviewed-by: Arne Jansen <sensille@gmx.net> Reviewed-by: Jan Schmidt <list.btrfs@jan-o-sch.net> Reviewed-by: Alex Lyakas <alex.bolshoy.btrfs@gmail.com>
2012-06-14Btrfs: use rcu to protect device->nameJosef Bacik
Al pointed out that we can just toss out the old name on a device and add a new one arbitrarily, so anybody who uses device->name in printk could possibly use free'd memory. Instead of adding locking around all of this he suggested doing it with RCU, so I've introduced a struct rcu_string that does just that and have gone through and protected all accesses to device->name that aren't under the uuid_mutex with rcu_read_lock(). This protects us and I will use it for dealing with removing the device that we used to mount the file system in a later patch. Thanks, Reviewed-by: David Sterba <dsterba@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com>
2012-05-30Btrfs: fix false positive in check-integrity on unmountStefan Behrens
During unmount, it could happen that the integrity checker printed a warning message "attempt to free ... on umount which is not yet iodone" which turned out to be a false positive. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de>
2012-05-30Btrfs: fix runtime warning in check-integrity check data modeStefan Behrens
If a file_extent_item was located at the very end of a leaf and there was not enough space to hold a full item, but there was enough space to hold one of type BTRFS_FILE_EXTENT_INLINE or PREALLOC, and it was only such a short item, a warning was printed anyway. This check is now fixed. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de>
2012-05-11Btrfs: change integrity checker to support big blocksStefan Behrens
The integrity checker used to be coded for nodesize == leafsize == sectorsize == PAGE_CACHE_SIZE. This is now changed to support sizes for nodesize and leafsize which are N * PAGE_CACHE_SIZE. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de>
2012-03-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "It's indeed trivial -- mostly documentation updates and a bunch of typo fixes from Masanari. There are also several linux/version.h include removals from Jesper." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (101 commits) kcore: fix spelling in read_kcore() comment constify struct pci_dev * in obvious cases Revert "char: Fix typo in viotape.c" init: fix wording error in mm_init comment usb: gadget: Kconfig: fix typo for 'different' Revert "power, max8998: Include linux/module.h just once in drivers/power/max8998_charger.c" writeback: fix fn name in writeback_inodes_sb_nr_if_idle() comment header writeback: fix typo in the writeback_control comment Documentation: Fix multiple typo in Documentation tpm_tis: fix tis_lock with respect to RCU Revert "media: Fix typo in mixer_drv.c and hdmi_drv.c" Doc: Update numastat.txt qla4xxx: Add missing spaces to error messages compiler.h: Fix typo security: struct security_operations kerneldoc fix Documentation: broken URL in libata.tmpl Documentation: broken URL in filesystems.tmpl mtd: simplify return logic in do_map_probe() mm: fix comment typo of truncate_inode_pages_range power: bq27x00: Fix typos in comment ...
2012-02-24Btrfs: fix compiler warnings on 32 bit systemsChris Mason
The enospc tracing code added some interesting uses of u64 pointer casts. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2012-02-10BTRFS: Don't include disk-io.h twice in check-integrity.cJesper Juhl
Once should be enough. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-01-26Btrfs: fix warning for 32-bit build of fs/btrfs/check-integrity.cStefan Behrens
There have been 4 warnings on 32-bit build, they are herewith fixed. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-12-21Btrfs: add optional integrity check codeStefan Behrens
The two files added in this patch contain all the code that is required to implement the integrity checks. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de>
