path: root/fs/btrfs/btrfs_inode.h
2011-03-17Btrfs: change reserved_extents to an atomic_tJosef Bacik
We track delayed allocation per inodes via 2 counters, one is outstanding_extents and reserved_extents. Outstanding_extents is already an atomic_t, but reserved_extents is not and is protected by a spinlock. So convert this to an atomic_t and instead of using a spinlock, use atomic_cmpxchg when releasing delalloc bytes. This makes our inode 72 bytes smaller, and reduces locking overhead (albiet it was minimal to begin with). Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2010-12-22btrfs: Allow to add new compression algorithmLi Zefan
Make the code aware of compression type, instead of always assuming zlib compression. Also make the zlib workspace function as common code for all compression types. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
2010-05-25Btrfs: Metadata reservation for orphan inodesYan, Zheng
reserve metadata space for handling orphan inodes Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-05-25Btrfs: Update metadata reservation for delayed allocationYan, Zheng
Introduce metadata reservation context for delayed allocation and update various related functions. This patch also introduces EXTENT_FIRST_DELALLOC control bit for set/clear_extent_bit. It tells set/clear_bit_hook whether they are processing the first extent_state with EXTENT_DELALLOC bit set. This change is important if set/clear_extent_bit involves multiple extent_state. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: add new defrag-range ioctl.Chris Mason
The btrfs defrag ioctl was limited to doing the entire file. This commit adds a new interface that can defrag a specific range inside the file. It can also force compression on the file, allowing you to selectively compress individual files after they were created, even when mount -o compress isn't turned on. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-12-17Btrfs: Fix disk_i_size update corner caseYan, Zheng
There are some cases file extents are inserted without involving ordered struct. In these cases, we update disk_i_size directly, without checking pending ordered extent and DELALLOC bit. This patch extends btrfs_ordered_update_i_size() to handle these cases. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-13Btrfs: avoid tree log commit when there are no changesChris Mason
rpm has a habit of running fdatasync when the file hasn't changed. We already detect if a file hasn't been changed in the current transaction but it might have been sent to the tree-log in this transaction and not changed since the last call to fsync. In this case, we want to avoid a tree log sync, which includes a number of synchronous writes and barriers. This commit extends the existing tracking of the last transaction to change a file to also track the last sub-transaction. The end result is that rpm -ivh and -Uvh are roughly twice as fast, and on par with ext3. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-08Btrfs: release delalloc reservations on extent item insertionJosef Bacik
This patch fixes an issue with the delalloc metadata space reservation code. The problem is we used to free the reservation as soon as we allocated the delalloc region. The problem with this is if we are not inserting an inline extent, we don't actually insert the extent item until after the ordered extent is written out. This patch does 3 things, 1) It moves the reservation clearing stuff into the ordered code, so when we remove the ordered extent we remove the reservation. 2) It adds a EXTENT_DO_ACCOUNTING flag that gets passed when we clear delalloc bits in the cases where we want to clear the metadata reservation when we clear the delalloc extent, in the case that we do an inline extent or we invalidate the page. 3) It adds another waitqueue to the space info so that when we start a fs wide delalloc flush, anybody else who also hits that area will simply wait for the flush to finish and then try to make their allocation. This has been tested thoroughly to make sure we did not regress on performance. Signed-off-by: Josef Bacik <jbacik@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-09-28Btrfs: proper -ENOSPC handlingJosef Bacik
At the start of a transaction we do a btrfs_reserve_metadata_space() and specify how many items we plan on modifying. Then once we've done our modifications and such, just call btrfs_unreserve_metadata_space() for the same number of items we reserved. For keeping track of metadata needed for data I've had to add an extent_io op for when we merge extents. This lets us track space properly when we are doing sequential writes, so we don't end up reserving way more metadata space than what we need. The only place where the metadata space accounting is not done is in the relocation code. This is because Yan is going to be reworking that code in the near future, so running btrfs-vol -b could still possibly result in a ENOSPC related panic. This patch also turns off the metadata_ratio stuff in order to allow users to more efficiently use their disk space. This patch makes it so we track how much metadata we need for an inode's delayed allocation extents by tracking how many extents are currently waiting for allocation. It introduces two new callbacks for the extent_io tree's, merge_extent_hook and split_extent_hook. These help us keep track of when we merge delalloc extents together and split them up. Reservations are handled prior to any actually dirty'ing occurs, and then we unreserve after we dirty. btrfs_unreserve_metadata_for_delalloc() will make the appropriate unreservations as needed based on the number of reservations we currently have and the number of extents we currently have. Doing the reservation outside of doing any of the actual dirty'ing lets us do things like filemap_flush() the inode to try and force delalloc to happen, or as a last resort actually start allocation on all delalloc inodes in the fs. This has survived dbench, fs_mark and an fsx torture test. Signed-off-by: Josef Bacik <jbacik@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-09-21Btrfs: change how subvolumes are organizedYan, Zheng
btrfs allows subvolumes and snapshots anywhere in the directory tree. If we snapshot a subvolume that contains a link to other subvolume called subvolA, subvolA can be accessed through both the original subvolume and the snapshot. This is similar to creating hard link to directory, and has the very similar problems. The aim of this patch is enforcing there is only one access point to each subvolume. Only the first directory entry (the one added when the subvolume/snapshot was created) is treated as valid access point. The first directory entry is distinguished by checking root forward reference. If the corresponding root forward reference is missing, we know the entry is not the first one. This patch also adds snapshot/subvolume rename support, the code allows rename subvolume link across subvolumes. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-06-24switch btrfs to inode->i_aclAl Viro
2009-06-10Btrfs: implement FS_IOC_GETFLAGS/SETFLAGS/GETVERSIONChristoph Hellwig
Add support for the standard attributes set via chattr and read via lsattr. Currently we store the attributes in the flags value in the btrfs inode, but I wonder whether we should split it into two so that we don't have to keep converting between the two formats. Remove the btrfs_clear_flag/btrfs_set_flag/btrfs_test_flag macros as they were confusing the existing code and got in the way of the new additions. Also add the FS_IOC_GETVERSION ioctl for getting i_generation as it's trivial. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-06-10Btrfs: Mixed back reference (FORWARD ROLLING FORMAT CHANGE)Yan Zheng
This commit introduces a new kind of back reference for btrfs metadata. Once a filesystem has been mounted with this commit, IT WILL NO LONGER BE MOUNTABLE BY OLDER KERNELS. When a tree block in subvolume tree is cow'd, the reference counts of all extents it points to are increased by one. At transaction commit time, the old root of the subvolume is recorded in a "dead root" data structure, and the btree it points to is later walked, dropping reference counts and freeing any blocks where the reference count goes to 0. The increments done during cow and decrements done after commit cancel out, and the walk is a very expensive way to go about freeing the blocks that are no longer referenced by the new btree root. This commit reduces the transaction overhead by avoiding the need for dead root records. When a non-shared tree block is cow'd, we free the old block at once, and the new block inherits old block's references. When a tree block with reference count > 1 is cow'd, we increase the reference counts of all extents the new block points to by one, and decrease the old block's reference count by one. This dead tree avoidance code removes the need to modify the reference counts of lower level extents when a non-shared tree block is cow'd. But we still need to update back ref for all pointers in the block. This is because the location of the block is recorded in the back ref item. We can solve this by introducing a new type of back ref. The new back ref provides information about pointer's key, level and in which tree the pointer lives. This information allow us to find the pointer by searching the tree. The shortcoming of the new back ref is that it only works for pointers in tree blocks referenced by their owner trees. This is mostly a problem for snapshots, where resolving one of these fuzzy back references would be O(number_of_snapshots) and quite slow. The solution used here is to use the fuzzy back references in the common case where a given tree block is only referenced by one root, and use the full back references when multiple roots have a reference on a given block. This commit adds per subvolume red-black tree to keep trace of cached inodes. The red-black tree helps the balancing code to find cached inodes whose inode numbers within a given range. This commit improves the balancing code by introducing several data structures to keep the state of balancing. The most important one is the back ref cache. It caches how the upper level tree blocks are referenced. This greatly reduce the overhead of checking back ref. The improved balancing code scales significantly better with a large number of snapshots. This is a very large commit and was written in a number of pieces. But, they depend heavily on the disk format change and were squashed together to make sure git bisect didn't end up in a bad state wrt space balancing or the format change. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-03-31Btrfs: add extra flushing for renames and truncatesChris Mason
Renames and truncates are both common ways to replace old data with new data. The filesystem can make an effort to make sure the new data is on disk before actually replacing the old data. This is especially important for rename, which many application use as though it were atomic for both the data and the metadata involved. The current btrfs code will happily replace a file that is fully on disk with one that was just created and still has pending IO. If we crash after transaction commit but before the IO is done, we'll end up replacing a good file with a zero length file. The solution used here is to create a list of inodes that need special ordering and force them to disk before the commit is done. This is similar to the ext3 style data=ordering, except it is only done on selected files. Btrfs is able to get away with this because it does not wait on commits very often, even for fsync (which use a sub-commit). For renames, we order the file when it wasn't already on disk and when it is replacing an existing file. Larger files are sent to filemap_flush right away (before the transaction handle is opened). For truncates, we order if the file goes from non-zero size down to zero size. This is a little different, because at the time of the truncate the file has no dirty bytes to order. But, we flag the inode so that it is added to the ordered list on close (via release method). We also immediately add it to the ordered list of the current transaction so that we can try to flush down any writes the application sneaks in before commit. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-03-24Btrfs: tree logging unlink/rename fixesChris Mason
The tree logging code allows individual files or directories to be logged without including operations on other files and directories in the FS. It tries to commit the minimal set of changes to disk in order to fsync the single file or directory that was sent to fsync or O_SYNC. The tree logging code was allowing files and directories to be unlinked if they were part of a rename operation where only one directory in the rename was in the fsync log. This patch adds a few new rules to the tree logging. 1) on rename or unlink, if the inode being unlinked isn't in the fsync log, we must force a full commit before doing an fsync of the directory where the unlink was done. The commit isn't done during the unlink, but it is forced the next time we try to log the parent directory. Solution: record transid of last unlink/rename per directory when the directory wasn't already logged. For renames this is only done when renaming to a different directory. mkdir foo/some_dir normal commit rename foo/some_dir foo2/some_dir mkdir foo/some_dir fsync foo/some_dir/some_file The fsync above will unlink the original some_dir without recording it in its new location (foo2). After a crash, some_dir will be gone unless the fsync of some_file forces a full commit 2) we must log any new names for any file or dir that is in the fsync log. This way we make sure not to lose files that are unlinked during the same transaction. 2a) we must log any new names for any file or dir during rename when the directory they are being removed from was logged. 2a is actually the more important variant. Without the extra logging a crash might unlink the old name without recreating the new one 3) after a crash, we must go through any directories with a link count of zero and redo the rm -rf mkdir f1/foo normal commit rm -rf f1/foo fsync(f1) The directory f1 was fully removed from the FS, but fsync was never called on f1, only its parent dir. After a crash the rm -rf must be replayed. This must be able to recurse down the entire directory tree. The inode link count fixup code takes care of the ugly details. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-02-20Btrfs: add better -ENOSPC handlingJosef Bacik
This is a step in the direction of better -ENOSPC handling. Instead of checking the global bytes counter we check the space_info bytes counters to make sure we have enough space. If we don't we go ahead and try to allocate a new chunk, and then if that fails we return -ENOSPC. This patch adds two counters to btrfs_space_info, bytes_delalloc and bytes_may_use. bytes_delalloc account for extents we've actually setup for delalloc and will be allocated at some point down the line. bytes_may_use is to keep track of how many bytes we may use for delalloc at some point. When we actually set the extent_bit for the delalloc bytes we subtract the reserved bytes from the bytes_may_use counter. This keeps us from not actually being able to allocate space for any delalloc bytes. Signed-off-by: Josef Bacik <jbacik@redhat.com>
2008-12-11Btrfs: fix leaking block group on balanceYan Zheng
The block group structs are referenced in many different places, and it's not safe to free while balancing. So, those block group structs were simply leaked instead. This patch replaces the block group pointer in the inode with the starting byte offset of the block group and adds reference counting to the block group struct. Signed-off-by: Yan Zheng <zheng.yan@oracle.com>
2008-12-08Btrfs: Add inode sequence number for NFS and reserved space in a few structsChris Mason
This adds a sequence number to the btrfs inode that is increased on every update. NFS will be able to use that to detect when an inode has changed, without relying on inaccurate time fields. While we're here, this also: Puts reserved space into the super block and inode Adds a log root transid to the super so we can pick the newest super based on the fsync log as well as the main transaction ID. For now the log root transid is always zero, but that'll get fixed. Adds a starting offset to the dev_item. This will let us do better alignment calculations if we know the start of a partition on the disk. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-29Btrfs: add and improve commentsChris Mason
This improves the comments at the top of many functions. It didn't dive into the guts of functions because I was trying to avoid merging problems with the new allocator and back reference work. extent-tree.c and volumes.c were both skipped, and there is definitely more work todo in cleaning and commenting the code. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Btrfs: Dir fsync optimizationsChris Mason
Drop i_mutex during the commit Don't bother doing the fsync at all unless the dir is marked as dirtied and needing fsync in this transaction. For directories, this means that someone has unlinked a file from the dir without fsyncing the file. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Btrfs: Add a write ahead tree log to optimize synchronous operationsChris Mason
File syncs and directory syncs are optimized by copying their items into a special (copy-on-write) log tree. There is one log tree per subvolume and the btrfs super block points to a tree of log tree roots. After a crash, items are copied out of the log tree and back into the subvolume. See tree-log.c for all the details. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Get rid of BTRFS_I(inode)->index and use local vars insteadChris Mason
rename and link don't always have a lock on the source inode, and our use of a per-inode index variable was racy. This changes things to store the index in a local variable instead. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Btrfs: Maintain a list of inodes that are delalloc and a way to wait on themChris Mason
2008-09-25Btrfs: Create orphan inode records to prevent lost files after a crashJosef Bacik
2008-09-25Btrfs: Add ACL supportJosef Bacik
2008-09-25Btrfs: Implement new dir index formatJosef Bacik
2008-09-25Add a per-inode lock around btrfs_drop_extentsChris Mason
btrfs_drop_extents is always called with a range lock held on the inode. But, it may operate on extents outside that range as it drops and splits them. This patch adds a per-inode mutex that is held while calling btrfs_drop_extents and while inserting new extents into the tree. It prevents races from two procs working against adjacent ranges in the tree. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Btrfs: Update on disk i_size only after pending ordered extents are doneChris Mason
This changes the ordered data code to update i_size after the extent is on disk. An on disk i_size is maintained in the in-memory btrfs inode structures, and this is updated as extents finish. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Btrfs: New data=ordered implementationChris Mason
The old data=ordered code would force commit to wait until all the data extents from the transaction were fully on disk. This introduced large latencies into the commit and stalled new writers in the transaction for a long time. The new code changes the way data allocations and extents work: * When delayed allocation is filled, data extents are reserved, and the extent bit EXTENT_ORDERED is set on the entire range of the extent. A struct btrfs_ordered_extent is allocated an inserted into a per-inode rbtree to track the pending extents. * As each page is written EXTENT_ORDERED is cleared on the bytes corresponding to that page. * When all of the bytes corresponding to a single struct btrfs_ordered_extent are written, The previously reserved extent is inserted into the FS btree and into the extent allocation trees. The checksums for the file data are also updated. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Btrfs: Add a per-inode csum mutex to avoid races creating csum itemsChris Mason
2008-09-25Btrfs: Throttle file_write when data=ordered is flushing the inodeChris Mason
2008-09-25Btrfs: Handle checksumming errors while reading data blocksChris Mason
2008-09-25Btrfs: Fix i_blocks accountingChris Mason
Now that delayed allocation accounting works, i_blocks accounting is changed to only modify i_blocks when extents inserted or removed. The fillattr call is changed to include the delayed allocation byte count in the i_blocks result. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Btrfs: Split the extent_map code into two partsChris Mason
There is now extent_map for mapping offsets in the file to disk and extent_io for state tracking, IO submission and extent_bufers. The new extent_map code shifts from [start,end] pairs to [start,len], and pushes the locking out into the caller. This allows a few performance optimizations and is easier to use. A number of extent_map usage bugs were fixed, mostly with failing to remove extent_map entries when changing the file. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Btrfs: Add inode flags supportYan
This patch adds NODATASUM & NODATACOW inode flags support. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Btrfs: Add data=ordered supportChris Mason
This forces file data extents down the disk along with the metadata that references them. The current implementation is fairly simple, and just writes out all of the dirty pages in an inode before the commit. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2007-08-27Btrfs: Extent based page cache code. This uses an rbtree of extents and testsChris Mason
instead of buffer heads. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2007-08-10Btrfs: delay commits during fsync to allow more writersJosef Bacik
2007-06-13btrfs: Code cleanupAneesh
Attaching below is some of the code cleanups that i came across while reading the code. a) alloc_path already calls init_path. b) Mention that btrfs_inode is the in memory copy.Ext4 have ext4_inode_info as the in memory copy ext4_inode as the disk copy Signed-off-by: Chris Mason <chris.mason@oracle.com>
2007-06-12Btrfs: add GPLv2Chris Mason
2007-04-30Btrfs: allocator improvements, inode block groupsChris Mason
2007-04-10Btrfs: drop the inode map treeChris Mason
2007-04-06Btrfs: start of support for many FS volumesChris Mason
2007-04-02Btrfs: still corruption huntingChris Mason
