commit d7d824966530acfe32b94d1ed672e6fe1638cd68 upstream.
When changing a file's acl mask, btrfs_set_acl() will first set the
group bits of i_mode to the value of the mask, and only then set the
actual extended attribute representing the new acl.
If the second part fails (due to lack of space, for example) and the
file had no acl attribute to begin with, the system will from now on
assume that the mask permission bits are actual group permission bits,
potentially granting access to the wrong users.
Prevent this by restoring the original mode bits if __btrfs_set_acl
fails.
Signed-off-by: Ernesto A. Fernández <ernesto.mnd.fernandez@gmail.com>
Reviewed-by: David Sterba <dsterba@suse.com>
Signed-off-by: David Sterba <dsterba@suse.com>
Signed-off-by: Nikolay Borisov <nborisov@suse.com>
commit b7f8a09f8097db776b8d160862540e4fc1f51296 upstream.
When new directory 'DIR1' is created in a directory 'DIR0' with SGID bit
set, DIR1 is expected to have SGID bit set (and owning group equal to
the owning group of 'DIR0'). However when 'DIR0' also has some default
ACLs that 'DIR1' inherits, setting these ACLs will result in SGID bit on
'DIR1' to get cleared if user is not member of the owning group.
Fix the problem by moving posix_acl_update_mode() out of
__btrfs_set_acl() into btrfs_set_acl(). That way the function will not be
called when inheriting ACLs which is what we want as it prevents SGID
bit clearing and the mode has been properly set by posix_acl_create()
anyway.
Fixes: 073931017b49d9458aa351605b43a7e34598caef
CC: linux-btrfs@vger.kernel.org
CC: David Sterba <dsterba@suse.com>
When file permissions are modified via chmod(2) and the user is not in
the owning group or capable of CAP_FSETID, the setgid bit is cleared in
inode_change_ok(). Setting a POSIX ACL via setxattr(2) sets the file
permissions as well as the new ACL, but doesn't clear the setgid bit in
a similar way; this allows to bypass the check in chmod(2). Fix that.
References: CVE-2016-7097
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
size contains the value returned by posix_acl_from_xattr(), which
returns -ERANGE, -ENODATA, zero, or an integer greater than zero. So
replace -ENOENT by -ERANGE.
Signed-off-by: Salah Triki <salah.triki@gmail.com>
When get_acl() is called for an inode whose ACL is not cached yet, the
get_acl inode operation is called to fetch the ACL from the filesystem.
The inode operation is responsible for updating the cached acl with
set_cached_acl(). This is done without locking at the VFS level, so
another task can call set_cached_acl() or forget_cached_acl() before the
get_acl inode operation gets to calling set_cached_acl(), and then
get_acl's call to set_cached_acl() results in caching an outdate ACL.
Prevent this from happening by setting the cached ACL pointer to a
task-specific sentinel value before calling the get_acl inode operation.
Move the responsibility for updating the cached ACL from the get_acl
inode operations to get_acl(). There, only set the cached ACL if the
sentinel value hasn't changed.
The sentinel values are chosen to have odd values. Likewise, the value
of ACL_NOT_CACHED is odd. In contrast, ACL object pointers always have
an even value (ACLs are aligned in memory). This allows to distinguish
uncached ACLs values from ACL objects.
In addition, switch from guarding inode->i_acl and inode->i_default_acl
upates by the inode->i_lock spinlock to using xchg() and cmpxchg().
Filesystems that do not want ACLs returned from their get_acl inode
operations to be cached must call forget_cached_acl() to prevent the VFS
from doing so.
(Patch written by Al Viro and Andreas Gruenbacher.)
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs updates from Chris Mason:
"This has our usual assortment of fixes and cleanups, but the biggest
change included is Omar Sandoval's free space tree. It's not the
default yet, mounting -o space_cache=v2 enables it and sets a readonly
compat bit. The tree can actually be deleted and regenerated if there
are any problems, but it has held up really well in testing so far.
For very large filesystems (30T+) our existing free space caching code
can end up taking a huge amount of time during commits. The new tree
based code is faster and less work overall to update as the commit
progresses.
Omar worked on this during the summer and we'll hammer on it in
production here at FB over the next few months"
* 'for-linus-4.5' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (73 commits)
Btrfs: fix fitrim discarding device area reserved for boot loader's use
Btrfs: Check metadata redundancy on balance
btrfs: statfs: report zero available if metadata are exhausted
btrfs: preallocate path for snapshot creation at ioctl time
btrfs: allocate root item at snapshot ioctl time
btrfs: do an allocation earlier during snapshot creation
btrfs: use smaller type for btrfs_path locks
btrfs: use smaller type for btrfs_path lowest_level
btrfs: use smaller type for btrfs_path reada
btrfs: cleanup, use enum values for btrfs_path reada
btrfs: constify static arrays
btrfs: constify remaining structs with function pointers
btrfs tests: replace whole ops structure for free space tests
btrfs: use list_for_each_entry* in backref.c
btrfs: use list_for_each_entry_safe in free-space-cache.c
btrfs: use list_for_each_entry* in check-integrity.c
Btrfs: use linux/sizes.h to represent constants
btrfs: cleanup, remove stray return statements
btrfs: zero out delayed node upon allocation
btrfs: pass proper enum type to start_transaction()
Remove POSIX_ACL_XATTR_{ACCESS,DEFAULT} and GFS2_POSIX_ACL_{ACCESS,DEFAULT}
and replace them with the definitions in <include/uapi/linux/xattr.h>.
Reviewed-by: James Morris <james.l.morris@oracle.com>
We don't have to use GFP_NOFS in context of ACL or XATTR actions, not
possible to loop through the allocator and it's safe to fail with
ENOMEM.
posix_acl_xattr_set() already does the check, and it's the only
way to feed in an ACL from userspace.
So the check here is useless, remove it.
Signed-off-by: zhang zhen <zhenzhang.zhang@huawei.com>
Signed-off-by: Chris Mason <clm@fb.com>
Also don't bother to set up a .get_acl method for symlinks as we do not
support access control (ACLs or even mode bits) for symlinks in Linux.
Rename the current posix_acl_created to __posix_acl_create and add
a fully featured helper to set up the ACLs on file creation that
uses get_acl().
Rename the current posix_acl_chmod to __posix_acl_chmod and add
a fully featured ACL chmod helper that uses the ->set_acl inode
operation.
When a directory has a default ACL and a subdirectory is created
under that directory, btrfs_init_acl() is called when the
subdirectory's inode is created to initialize the inode's ACL
(inherited from the parent directory) but it was clearing the ACL
from the inode after setting it if posix_acl_create() returned
success, instead of clearing it only if it returned an error.
To reproduce this issue:
$ mkfs.btrfs -f /dev/loop0
$ mount /dev/loop0 /mnt
$ mkdir /mnt/acl
$ setfacl -d --set u::rwx,g::rwx,o::- /mnt/acl
$ getfacl /mnt/acl
user::rwx
group::rwx
other::r-x
default:user::rwx
default:group::rwx
default:other::---
$ mkdir /mnt/acl/dir1
$ getfacl /mnt/acl/dir1
user::rwx
group::rwx
other::---
After unmounting and mounting again the filesystem, fgetacl returned the
expected ACL:
$ umount /mnt/acl
user::rwx
group::rwx
other::---
default:user::rwx
default:group::rwx
default:other::---
Meaning that the underlying xattr was persisted.
Reported-by: Giuseppe Fierro <giuseppe@fierro.org>
Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com>
Signed-off-by: Josef Bacik <jbacik@fusionio.com>
Signed-off-by: Chris Mason <chris.mason@fusionio.com>
If the acl can be exactly represented in the traditional file
mode permission bits, we don't set another acl attribute.
Signed-off-by: Liu Bo <bo.li.liu@oracle.com>
- Pass the user namespace the uid and gid values in the xattr are stored
in into posix_acl_from_xattr.
- Pass the user namespace kuid and kgid values should be converted into
when storing uid and gid values in an xattr in posix_acl_to_xattr.
- Modify all callers of posix_acl_from_xattr and posix_acl_to_xattr to
pass in &init_user_ns.
In the short term this change is not strictly needed but it makes the
code clearer. In the longer term this change is necessary to be able to
mount filesystems outside of the initial user namespace that natively
store posix acls in the linux xattr format.
Cc: Theodore Tso <tytso@mit.edu>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Jan Kara <jack@suse.cz>
When running compilebench I noticed we were spending some time looking up
acls on new inodes, which shouldn't be happening since there were no acls.
This is because when we init acls on the inode after creating them we don't
cache the fact there are no acls if there aren't any. Doing this adds a
little bit of a bump to my compilebench runs. Thanks,
Btrfs: cache no acl on new inodes
Signed-off-by: Josef Bacik <josef@redhat.com>
In btrfs_get_acl(), when the second __btrfs_getxattr() call fails,
acl is not correctly set.
Therefore, a wrong value might return to the caller.
Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (31 commits)
Btrfs: don't call writepages from within write_full_page
Btrfs: Remove unused variable 'last_index' in file.c
Btrfs: clean up for find_first_extent_bit()
Btrfs: clean up for wait_extent_bit()
Btrfs: clean up for insert_state()
Btrfs: remove unused members from struct extent_state
Btrfs: clean up code for merging extent maps
Btrfs: clean up code for extent_map lookup
Btrfs: clean up search_extent_mapping()
Btrfs: remove redundant code for dir item lookup
Btrfs: make acl functions really no-op if acl is not enabled
Btrfs: remove remaining ref-cache code
Btrfs: remove a BUG_ON() in btrfs_commit_transaction()
Btrfs: use wait_event()
Btrfs: check the nodatasum flag when writing compressed files
Btrfs: copy string correctly in INO_LOOKUP ioctl
Btrfs: don't print the leaf if we had an error
btrfs: make btrfs_set_root_node void
Btrfs: fix oops while writing data to SSD partitions
Btrfs: Protect the readonly flag of block group
Fix up trivial conflicts (due to acl and writeback cleanups) in
- fs/btrfs/acl.c
- fs/btrfs/ctree.h
- fs/btrfs/extent_io.c
So there's no overhead for something we don't use.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Signed-off-by: Chris Mason <chris.mason@oracle.com>
... so that &inode->i_mode could be passed to it
so we can pass &inode->i_mode to it
Replace the ->check_acl method with a ->get_acl method that simply reads an
ACL from disk after having a cache miss. This means we can replace the ACL
checking boilerplate code with a single implementation in namei.c.
new helper: posix_acl_create(&acl, gfp, mode_p). Replaces acl with
modified clone, on failure releases acl and replaces with NULL.
Returns 0 or -ve on error. All callers of posix_acl_create_masq()
switched.
new helper: posix_acl_chmod(&acl, gfp, mode). Replaces acl with modified
clone or with NULL if that has failed; returns 0 or -ve on error. All
callers of posix_acl_chmod_masq() switched to that - they'd been doing
exactly the same thing.
This moves logic for checking the cached ACL values from low-level
filesystems into generic code. The end result is a streamlined ACL
check that doesn't need to load the inode->i_op->check_acl pointer at
all for the common cached case.
The filesystems also don't need to check for a non-blocking RCU walk
case in their acl_check() functions, because that is all handled at a
VFS layer.
not used in the instances anymore.
inode_numbers
fs/btrfs/extent-tree.c
fs/btrfs/free-space-cache.c
fs/btrfs/inode.c
fs/btrfs/tree-log.c
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable:
Btrfs: fix FS_IOC_SETFLAGS ioctl
Btrfs: fix FS_IOC_GETFLAGS ioctl
fs: remove FS_COW_FL
Btrfs: fix easily get into ENOSPC in mixed case
Prevent oopsing in posix_acl_valid()
If posix_acl_from_xattr() returns an error code, a negative address is
dereferenced causing an oops; fix by checking for error code first.
Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com>
Reviewed-by: Josef Bacik <josef@redhat.com>
use IS_ERR_OR_NULL when possible, done by this coccinelle script:
@ match @
identifier id;
- BUG_ON(IS_ERR(id) || !id);
+ BUG_ON(IS_ERR_OR_NULL(id));
- IS_ERR(id) || !id
+ IS_ERR_OR_NULL(id)
- !id || IS_ERR(id)
Signed-off-by: David Sterba <dsterba@suse.cz>
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (24 commits)
Btrfs: fix free space cache leak
Btrfs: avoid taking the chunk_mutex in do_chunk_alloc
Btrfs end_bio_extent_readpage should look for locked bits
Btrfs: don't force chunk allocation in find_free_extent
Btrfs: Check validity before setting an acl
Btrfs: Fix incorrect inode nlink in btrfs_link()
Btrfs: Check if btrfs_next_leaf() returns error in btrfs_real_readdir()
Btrfs: Check if btrfs_next_leaf() returns error in btrfs_listxattr()
Btrfs: make uncache_state unconditional
btrfs: using cached extent_state in set/unlock combinations
Btrfs: avoid taking the trans_mutex in btrfs_end_transaction
Btrfs: fix subvolume mount by name problem when default mount subvolume is set
fix user annotation in ioctl.c
Btrfs: check for duplicate iov_base's when doing dio reads
btrfs: properly handle overlapping areas in memmove_extent_buffer
Btrfs: fix memory leaks in btrfs_new_inode()
Btrfs: reuse the extent_map we found when calling btrfs_get_extent
Btrfs: do not use async submit for small DIO io's
Btrfs: don't split dio bios if we don't have to
Call posix_acl_valid() to check if an acl is valid or not.
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
And give it a kernel-doc comment.
[akpm@linux-foundation.org: btrfs changed in linux-next]
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Daniel Lezcano <daniel.lezcano@free.fr>
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (33 commits)
Btrfs: Fix page count calculation
btrfs: Drop __exit attribute on btrfs_exit_compress
btrfs: cleanup error handling in btrfs_unlink_inode()
Btrfs: exclude super blocks when we read in block groups
Btrfs: make sure search_bitmap finds something in remove_from_bitmap
btrfs: fix return value check of btrfs_start_transaction()
btrfs: checking NULL or not in some functions
Btrfs: avoid uninit variable warnings in ordered-data.c
Btrfs: catch errors from btrfs_sync_log
Btrfs: make shrink_delalloc a little friendlier
Btrfs: handle no memory properly in prepare_pages
Btrfs: do error checking in btrfs_del_csums
Btrfs: use the global block reserve if we cannot reserve space
Btrfs: do not release more reserved bytes to the global_block_rsv than we need
Btrfs: fix check_path_shared so it returns the right value
btrfs: check return value of btrfs_start_ioctl_transaction() properly
btrfs: fix return value check of btrfs_join_transaction()
fs/btrfs/inode.c: Add missing IS_ERR test
btrfs: fix missing break in switch phrase
btrfs: fix several uncheck memory allocations
Steps to reproduce:
# mkfs.btrfs /dev/sda2
# mount /dev/sda2 /mnt
# touch /mnt/file0
# setfacl -m 'u:root:x,g::x,o::x' /mnt/file0
# umount /mnt
# mount /dev/sda2 -o noacl /mnt
# getfacl /mnt/file0
user::rw-
user:root:--x
group::--x
mask::--x
other::--x
The output should be:
user::rw-
group::--x
other::--x
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (25 commits)
Btrfs: forced readonly mounts on errors
btrfs: Require CAP_SYS_ADMIN for filesystem rebalance
Btrfs: don't warn if we get ENOSPC in btrfs_block_rsv_check
btrfs: Fix memory leak in btrfs_read_fs_root_no_radix()
btrfs: check NULL or not
btrfs: Don't pass NULL ptr to func that may deref it.
btrfs: mount failure return value fix
btrfs: Mem leak in btrfs_get_acl()
btrfs: fix wrong free space information of btrfs
btrfs: make the chunk allocator utilize the devices better
btrfs: restructure find_free_dev_extent()
btrfs: fix wrong calculation of stripe size
btrfs: try to reclaim some space when chunk allocation fails
btrfs: fix wrong data space statistics
fs/btrfs: Fix build of ctree
Btrfs: fix off by one while setting block groups readonly
Btrfs: Add BTRFS_IOC_SUBVOL_GETFLAGS/SETFLAGS ioctls
Btrfs: Add readonly snapshots support
Btrfs: Refactor btrfs_ioctl_snap_create()
btrfs: Extract duplicate decompress code
It seems to me that we leak the memory allocated to 'value' in
btrfs_get_acl() if the call to posix_acl_from_xattr() fails.
Here's a patch that attempts to correct that problem.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
This simple implementation just checks for no ACLs on the inode, and
if so, then the rcu-walk may proceed, otherwise fail it.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Btrfs: The file argument for fsync() is never null
Btrfs: handle ERR_PTR from posix_acl_from_xattr()
Btrfs: avoid BUG when dropping root and reference in same transaction
Btrfs: prohibit a operation of changing acl's mask when noacl mount option used
Btrfs: should add a permission check for setfacl
Btrfs: btrfs_lookup_dir_item() can return ERR_PTR
Btrfs: btrfs_read_fs_root_no_name() returns ERR_PTRs
Btrfs: unwind after btrfs_start_transaction() errors
Btrfs: btrfs_iget() returns ERR_PTR
Btrfs: handle kzalloc() failure in open_ctree()
Btrfs: handle error returns from btrfs_lookup_dir_item()
Btrfs: Fix BUG_ON for fs converted from extN
Btrfs: Fix null dereference in relocation.c
Btrfs: fix remap_file_pages error
Btrfs: uninitialized data is check_path_shared()
Btrfs: fix fallocate regression
Btrfs: fix loop device on top of btrfs
posix_acl_from_xattr() returns both ERR_PTRs and null, but it's OK to
pass null values to set_cached_acl()
when used Posix File System Test Suite(pjd-fstest) to test btrfs,
some cases about setfacl failed when noacl mount option used.
I simplified used commands in pjd-fstest, and the following steps
can reproduce it.
# cd btrfs-part/
# mkdir aaa
# setfacl -m m::rw aaa <- successed, but not expected by pjd-fstest.
I checked ext3, a warning message occured, like as:
setfacl: aaa/: Operation not supported
Certainly, it's expected by pjd-fstest.
So, i compared acl.c of btrfs and ext3. Based on that, a patch created.
Fortunately, it works.
Signed-off-by: Shi Weihua <shiwh@cn.fujitsu.com>
On btrfs, do the following
# su user1
# cd btrfs-part/
# touch aaa
# getfacl aaa
# file: aaa
# owner: user1
# group: user1
user::rw-
group::rw-
other::r--
# su user2
# cd btrfs-part/
# setfacl -m u::rwx aaa
# getfacl aaa
# file: aaa
# owner: user1
# group: user1
user::rwx <- successed to setfacl
group::rw-
other::r--
but we should prohibit it that user2 changing user1's acl.
In fact, on ext3 and other fs, a message occurs:
setfacl: aaa: Operation not permitted
This patch fixed it.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Btrfs: check total number of devices when removing missing
Btrfs: check return value of open_bdev_exclusive properly
Btrfs: do not mark the chunk as readonly if in degraded mode
Btrfs: run orphan cleanup on default fs root
Btrfs: fix a memory leak in btrfs_init_acl
Btrfs: Use correct values when updating inode i_size on fallocate
Btrfs: remove tree_search() in extent_map.c
Btrfs: Add mount -o compress-force
In btrfs_init_acl() cloned acl is not released
Signed-off-by: Yang Hongyang <yanghy@cn.fujitsu.com>
Btrfs: fix possible panic on unmount
Btrfs: deal with NULL acl sent to btrfs_set_acl
Btrfs: fix regression in orphan cleanup
Btrfs: Fix race in btrfs_mark_extent_written
Btrfs, fix memory leaks in error paths
Btrfs: align offsets for btrfs_ordered_update_i_size
btrfs: fix missing last-entry in readdir(3)
