path: root/fs/bio.c
2013-09-10sg: Fix user memory corruption when SG_IO is interrupted by a signalRoland Dreier
commit 35dc248383bbab0a7203fca4d722875bc81ef091 upstream. There is a nasty bug in the SCSI SG_IO ioctl that in some circumstances leads to one process writing data into the address space of some other random unrelated process if the ioctl is interrupted by a signal. What happens is the following: - A process issues an SG_IO ioctl with direction DXFER_FROM_DEV (ie the underlying SCSI command will transfer data from the SCSI device to the buffer provided in the ioctl) - Before the command finishes, a signal is sent to the process waiting in the ioctl. This will end up waking up the sg_ioctl() code: result = wait_event_interruptible(sfp->read_wait, (srp_done(sfp, srp) || sdp->detached)); but neither srp_done() nor sdp->detached is true, so we end up just setting srp->orphan and returning to userspace: srp->orphan = 1; write_unlock_irq(&sfp->rq_list_lock); return result; /* -ERESTARTSYS because signal hit process */ At this point the original process is done with the ioctl and blithely goes ahead handling the signal, reissuing the ioctl, etc. - Eventually, the SCSI command issued by the first ioctl finishes and ends up in sg_rq_end_io(). At the end of that function, we run through: write_lock_irqsave(&sfp->rq_list_lock, iflags); if (unlikely(srp->orphan)) { if (sfp->keep_orphan) srp->sg_io_owned = 0; else done = 0; } srp->done = done; write_unlock_irqrestore(&sfp->rq_list_lock, iflags); if (likely(done)) { /* Now wake up any sg_read() that is waiting for this * packet. */ wake_up_interruptible(&sfp->read_wait); kill_fasync(&sfp->async_qp, SIGPOLL, POLL_IN); kref_put(&sfp->f_ref, sg_remove_sfp); } else { INIT_WORK(&srp->ew.work, sg_rq_end_io_usercontext); schedule_work(&srp->ew.work); } Since srp->orphan *is* set, we set done to 0 (assuming the userspace app has not set keep_orphan via an SG_SET_KEEP_ORPHAN ioctl), and therefore we end up scheduling sg_rq_end_io_usercontext() to run in a workqueue. - In workqueue context we go through sg_rq_end_io_usercontext() -> sg_finish_rem_req() -> blk_rq_unmap_user() -> ... -> bio_uncopy_user() -> __bio_copy_iov() -> copy_to_user(). The key point here is that we are doing copy_to_user() on a workqueue -- that is, we're on a kernel thread with current->mm equal to whatever random previous user process was scheduled before this kernel thread. So we end up copying whatever data the SCSI command returned to the virtual address of the buffer passed into the original ioctl, but it's quite likely we do this copying into a different address space! As suggested by James Bottomley <James.Bottomley@hansenpartnership.com>, add a check for current->mm (which is NULL if we're on a kernel thread without a real userspace address space) in bio_uncopy_user(), and skip the copy if we're on a kernel thread. There's no reason that I can think of for any caller of bio_uncopy_user() to want to do copying on a kernel thread with a random active userspace address space. Huge thanks to Costa Sapuntzakis <costa@purestorage.com> for the original pointer to this bug in the sg code. Signed-off-by: Roland Dreier <roland@purestorage.com> Tested-by: David Milburn <dmilburn@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-09-10block: Add bio_for_each_segment_all()Kent Overstreet
commit d74c6d514fe314b8bdab58b487b25992291577ec upstream. __bio_for_each_segment() iterates bvecs from the specified index instead of bio->bv_idx. Currently, the only usage is to walk all the bvecs after the bio has been advanced by specifying 0 index. For immutable bvecs, we need to split these apart; bio_for_each_segment() is going to have a different implementation. This will also help document the intent of code that's using it - bio_for_each_segment_all() is only legal to use for code that owns the bio. Signed-off-by: Kent Overstreet <koverstreet@google.com> CC: Jens Axboe <axboe@kernel.dk> CC: Neil Brown <neilb@suse.de> CC: Boaz Harrosh <bharrosh@panasas.com> [bwh: Backported to 3.2: drop inapplicable change to drivers/block/rbd.c. This is a prerequisite for commit 35dc248383bb 'sg: Fix user memory corruption when SG_IO is interrupted by a signal'] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-31bio allocation failure due to bio_get_nr_vecs()Bernd Schubert
commit f908ee9463b09ddd05e1c1a0111132212dc05fac upstream. The number of bio_get_nr_vecs() is passed down via bio_alloc() to bvec_alloc_bs(), which fails the bio allocation if nr_iovecs > BIO_MAX_PAGES. For the underlying caller this causes an unexpected bio allocation failure. Limiting to queue_max_segments() is not sufficient, as max_segments also might be very large. bvec_alloc_bs(gfp_mask, nr_iovecs, ) => NULL when nr_iovecs > BIO_MAX_PAGES bio_alloc_bioset(gfp_mask, nr_iovecs, ...) bio_alloc(GFP_NOIO, nvecs) xfs_alloc_ioend_bio() Signed-off-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-31bio: don't overflow in bio_get_nr_vecs()Kent Overstreet
commit 5abebfdd02450fa1349daacf242e70b3736581e3 upstream. There were two places bio_get_nr_vecs() could overflow: First, it did a left shift to convert from sectors to bytes immediately before dividing by PAGE_SIZE. If PAGE_SIZE ever was less than 512 a great many things would break, so dividing by PAGE_SIZE >> 9 is safe and will generate smaller code too. The nastier overflow was in the DIV_ROUND_UP() (that's what the code was effectively doing, anyways). If n + d overflowed, the whole thing would return 0 which breaks things rather effectively. bio_get_nr_vecs() doesn't claim to give an exact value anyways, so the DIV_ROUND_UP() is silly; we could do a straight divide except if a device's queue_max_sectors was less than PAGE_SIZE we'd return 0. So we just add 1; this should always be safe - things will break badly if bio_get_nr_vecs() returns > BIO_MAX_PAGES (bio_alloc() will suddenly start failing) but it's queue_max_segments that must guard against this, if queue_max_sectors is preventing this from happen things are going to explode on architectures with different PAGE_SIZE. Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Tejun Heo <tj@kernel.org> Acked-by: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2011-11-16bio: change some signed vars to unsignedDan Carpenter
This is just a cleanup patch to silence a static checker warning. The problem is that we cap "nr_iovecs" so it can't be larger than "UIO_MAXIOV" but we don't check for negative values. It turns out this is prevented at other layers, but logically it doesn't make sense to have negative nr_iovecs so making it unsigned is nicer. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-24block: Remove the control of complete cpu from bio.Tao Ma
bio originally has the functionality to set the complete cpu, but it is broken. Chirstoph said that "This code is unused, and from the all the discussions lately pretty obviously broken. The only thing keeping it serves is creating more confusion and possibly more bugs." And Jens replied with "We can kill bio_set_completion_cpu(). I'm fine with leaving cpu control to the request based drivers, they are the only ones that can toggle the setting anyway". So this patch tries to remove all the work of controling complete cpu from a bio. Cc: Shaohua Li <shaohua.li@intel.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-05-27vfs: Improve the bio_add_page() and bio_add_pc_page() descriptionsAndreas Gruenbacher
The descriptions of bio_add_page() and bio_add_pc_page() are slightly inconsistent; improve them. Signed-off-by: Andreas Gruenbacher <agruen@kernel.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-22fs: use appropriate printk priority levelsMandeep Singh Baines
printk()s without a priority level default to KERN_WARNING. To reduce noise at KERN_WARNING, this patch set the priority level appriopriately for unleveled printks()s. This should be useful to folks that look at dmesg warnings closely. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-17block: Require subsystems to explicitly allocate bio_set integrity mempoolMartin K. Petersen
MD and DM create a new bio_set for every metadevice. Each bio_set has an integrity mempool attached regardless of whether the metadevice is capable of passing integrity metadata. This is a waste of memory. Instead we defer the allocation decision to MD and DM since we know at metadevice creation time whether integrity passthrough is needed or not. Automatic integrity mempool allocation can then be removed from bioset_create() and we make an explicit integrity allocation for the fs_bio_set. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reported-by: Zdenek Kabelac <zkabelac@redhat.com> Acked-by: Mike Snitzer <snizer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-08block: biovec_slab vs. CONFIG_BLK_DEV_INTEGRITYMartin K. Petersen
The block integrity subsystem no longer uses the bio_vec slabs so this code can safely be compiled in. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-10bio: take care not overflow page count when mapping/copying user dataJens Axboe
If the iovec is being set up in a way that causes uaddr + PAGE_SIZE to overflow, we could end up attempting to map a huge number of pages. Check for this invalid input type. Reported-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-10block: limit vec count in bio_kmalloc() and bio_alloc_map_data()Jens Axboe
2010-08-07block: unify flags for struct bio and struct requestChristoph Hellwig
Remove the current bio flags and reuse the request flags for the bio, too. This allows to more easily trace the type of I/O from the filesystem down to the block driver. There were two flags in the bio that were missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've renamed two request flags that had a superflous RW in them. Note that the flags are in bio.h despite having the REQ_ name - as blkdev.h includes bio.h that is the only way to go for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-03-19Merge branch 'master' into for-linusJens Axboe
Conflicts: block/Kconfig Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-08blkdev: fix merge_bvec_fn return value checks v2Dmitry Monakhov
merge_bvec_fn() returns bvec->bv_len on success. So we have to check against this value. But in case of fs_optimization merge we compare with wrong value. This patch must be included in b428cd6da7e6559aca69aa2e3a526037d3f20403 But accidentally i've forgot to add this in the initial patch. To make things straight let's replace all such checks. In fact this makes code easy to understand. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-03-02Revert "blkdev: fix merge_bvec_fn return value checks"Jens Axboe
This reverts commit 9f7cdbc33f36d28e57eaba0093f68f0d14c38c5b. It's causing oopses om dm setups, so revert it until we investigate. Reported-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Tested-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-02-28blkdev: fix merge_bvec_fn return value checksDmitry Monakhov
2010-02-26block: Consolidate phys_segment and hw_segment limitsMartin K. Petersen
Except for SCSI no device drivers distinguish between physical and hardware segment limits. Consolidate the two into a single segment limit. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-02-05bio: Fix outdated comment about bio_alloc_bioset()Jaak Ristioja
In commit 451a9ebf653d28337ba53ed5b4b70b0b9543cca1 bio_alloc_bioset() was refactored not to take NULL as a valid argument for bs. This patch changes the comment for that function accordingly. Currently, passing NULL as argument to parameter bs would result in a NULL pointer dereference. Signed-off-by: Jaak Ristioja <ristioja@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-28block: fix bio_add_page for non trivial merge_bvec_fn caseDmitry Monakhov
We have to properly decrease bi_size in order to merge_bvec_fn return right result. Otherwise this result in false merge rejects for two absolutely valid bio_vecs. This may cause significant performance penalty for example fs_block_size == 1k and block device is raid0 with small chunk_size = 8k. Then it is impossible to merge 7-th fs-block in to bio which already has 6 fs-blocks. Cc: <stable@kernel.org> Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-01-19fs/bio.c: fix shadows sparse warningThiago Farina
fs/bio.c:81:33: warning: symbol 'bslab' shadows an earlier one fs/bio.c:74:25: originally declared here Signed-off-by: Thiago Farina <tfransosi@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-26block: add helpers to run flush_dcache_page() against a bio and a request's ↵Ilya Loginov
pages Mtdblock driver doesn't call flush_dcache_page for pages in request. So, this causes problems on architectures where the icache doesn't fill from the dcache or with dcache aliases. The patch fixes this. The ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE symbol was introduced to avoid pointless empty cache-thrashing loops on architectures for which flush_dcache_page() is a no-op. Every architecture was provided with this flush pages on architectires where ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE is equal 1 or do nothing otherwise. See "fix mtd_blkdevs problem with caches on some architectures" discussion on LKML for more information. Signed-off-by: Ilya Loginov <isloginov@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Peter Horton <phorton@bitbox.co.uk> Cc: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-11-02Fix bio_alloc() and bio_kmalloc() documentationAlberto Bertogli
Commit 451a9ebf accidentally broke bio_alloc() and bio_kmalloc() comments by (almost) swapping them. This patch fixes that, by placing the comments in the right place. Signed-off-by: Alberto Bertogli <albertito@blitiri.com.ar> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-11-02bio_put(): add bio_clone() to the list of functions in the commentAlberto Bertogli
In bio_put()'s comment, add bio_clone() to the list of functions that can give you a bio reference. Signed-off-by: Alberto Bertogli <albertito@blitiri.com.ar> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01fs/bio.c: move EXPORT* macros to line after functionH Hartley Sweeten
As mentioned in Documentation/CodingStyle, move EXPORT* macro's to the line immediately after the closing function brace line. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-10block: fix sg SG_DXFER_TO_FROM_DEV regressionFUJITA Tomonori
I overlooked SG_DXFER_TO_FROM_DEV support when I converted sg to use the block layer mapping API (2.6.28). Douglas Gilbert explained SG_DXFER_TO_FROM_DEV: http://www.spinics.net/lists/linux-scsi/msg37135.html = The semantics of SG_DXFER_TO_FROM_DEV were: - copy user space buffer to kernel (LLD) buffer - do SCSI command which is assumed to be of the DATA_IN (data from device) variety. This would overwrite some or all of the kernel buffer - copy kernel (LLD) buffer back to the user space. The idea was to detect short reads by filling the original user space buffer with some marker bytes ("0xec" it would seem in this report). The "resid" value is a better way of detecting short reads but that was only added this century and requires co-operation from the LLD. = This patch changes the block layer mapping API to support this semantics. This simply adds another field to struct rq_map_data and enables __bio_copy_iov() to copy data from user space even with READ requests. It's better to add the flags field and kills null_mapped and the new from_user fields in struct rq_map_data but that approach makes it difficult to send this patch to stable trees because st and osst drivers use struct rq_map_data (they were converted to use the block layer in 2.6.29 and 2.6.30). Well, I should clean up the block layer mapping API. zhou sf reported this regiression and tested this patch: http://www.spinics.net/lists/linux-scsi/msg37128.html http://www.spinics.net/lists/linux-scsi/msg37168.html Reported-by: zhou sf <sxzzsf@gmail.com> Tested-by: zhou sf <sxzzsf@gmail.com> Cc: stable@kernel.org Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-01block: Create bip slabs with embedded integrity vectorsMartin K. Petersen
This patch restores stacking ability to the block layer integrity infrastructure by creating a set of dedicated bip slabs. Each bip slab has an embedded bio_vec array at the end. This cuts down on memory allocations and also simplifies the code compared to the original bvec version. Only the largest bip slab is backed by a mempool. The pool is contained in the bio_set so stacking drivers can ensure forward progress. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@carl.(none)>
2009-06-16block: remove some includings of blktrace_api.hLi Zefan
When porting blktrace to tracepoints, we changed to trace/block.h for trace prober declarations. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-12trivial: fix typo in bio_alloc kernel docNikanth Karthikesan
Fix typo in bio_alloc kernel doc. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-11Merge branch 'for-2.6.31' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.31' of git://git.kernel.dk/linux-2.6-block: (153 commits) block: add request clone interface (v2) floppy: fix hibernation ramdisk: remove long-deprecated "ramdisk=" boot-time parameter fs/bio.c: add missing __user annotation block: prevent possible io_context->refcount overflow Add serial number support for virtio_blk, V4a block: Add missing bounce_pfn stacking and fix comments Revert "block: Fix bounce limit setting in DM" cciss: decode unit attention in SCSI error handling code cciss: Remove no longer needed sendcmd reject processing code cciss: change SCSI error handling routines to work with interrupts enabled. cciss: separate error processing and command retrying code in sendcmd_withirq_core() cciss: factor out fix target status processing code from sendcmd functions cciss: simplify interface of sendcmd() and sendcmd_withirq() cciss: factor out core of sendcmd_withirq() for use by SCSI error handling code cciss: Use schedule_timeout_uninterruptible in SCSI error handling code block: needs to set the residual length of a bidi request Revert "block: implement blkdev_readpages" block: Fix bounce limit setting in DM Removed reference to non-existing file Documentation/PCI/PCI-DMA-mapping.txt ... Manually fix conflicts with tracing updates in: block/blk-sysfs.c drivers/ide/ide-atapi.c drivers/ide/ide-cd.c drivers/ide/ide-floppy.c drivers/ide/ide-tape.c include/trace/events/block.h kernel/trace/blktrace.c
2009-06-10fs/bio.c: add missing __user annotationMichal Simek
As reported by sparse: fs/bio.c:720:13: warning: incorrect type in assignment (different address spaces) fs/bio.c:720:13: expected char *iov_addr fs/bio.c:720:13: got void [noderef] <asn:1>* fs/bio.c:724:36: warning: incorrect type in argument 2 (different address spaces) fs/bio.c:724:36: expected void const [noderef] <asn:1>*from fs/bio.c:724:36: got char *iov_addr Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-09tracing/events: convert block trace points to TRACE_EVENT()Li Zefan
TRACE_EVENT is a more generic way to define tracepoints. Doing so adds these new capabilities to this tracepoint: - zero-copy and per-cpu splice() tracing - binary tracing without printf overhead - structured logging records exposed under /debug/tracing/events - trace events embedded in function tracer output and other plugins - user-defined, per tracepoint filter expressions ... Cons: - no dev_t info for the output of plug, unplug_timer and unplug_io events. no dev_t info for getrq and sleeprq events if bio == NULL. no dev_t info for rq_abort,...,rq_requeue events if rq->rq_disk == NULL. This is mainly because we can't get the deivce from a request queue. But this may change in the future. - A packet command is converted to a string in TP_assign, not TP_print. While blktrace do the convertion just before output. Since pc requests should be rather rare, this is not a big issue. - In blktrace, an event can have 2 different print formats, but a TRACE_EVENT has a unique format, which means we have some unused data in a trace entry. The overhead is minimized by using __dynamic_array() instead of __array(). I've benchmarked the ioctl blktrace vs the splice based TRACE_EVENT tracing: dd dd + ioctl blktrace dd + TRACE_EVENT (splice) 1 7.36s, 42.7 MB/s 7.50s, 42.0 MB/s 7.41s, 42.5 MB/s 2 7.43s, 42.3 MB/s 7.48s, 42.1 MB/s 7.43s, 42.4 MB/s 3 7.38s, 42.6 MB/s 7.45s, 42.2 MB/s 7.41s, 42.5 MB/s So the overhead of tracing is very small, and no regression when using those trace events vs blktrace. And the binary output of TRACE_EVENT is much smaller than blktrace: # ls -l -h -rw-r--r-- 1 root root 8.8M 06-09 13:24 sda.blktrace.0 -rw-r--r-- 1 root root 195K 06-09 13:24 sda.blktrace.1 -rw-r--r-- 1 root root 2.7M 06-09 13:25 trace_splice.out Following are some comparisons between TRACE_EVENT and blktrace: plug: kjournald-480 [000] 303.084981: block_plug: [kjournald] kjournald-480 [000] 303.084981: 8,0 P N [kjournald] unplug_io: kblockd/0-118 [000] 300.052973: block_unplug_io: [kblockd/0] 1 kblockd/0-118 [000] 300.052974: 8,0 U N [kblockd/0] 1 remap: kjournald-480 [000] 303.085042: block_remap: 8,0 W 102736992 + 8 <- (8,8) 33384 kjournald-480 [000] 303.085043: 8,0 A W 102736992 + 8 <- (8,8) 33384 bio_backmerge: kjournald-480 [000] 303.085086: block_bio_backmerge: 8,0 W 102737032 + 8 [kjournald] kjournald-480 [000] 303.085086: 8,0 M W 102737032 + 8 [kjournald] getrq: kjournald-480 [000] 303.084974: block_getrq: 8,0 W 102736984 + 8 [kjournald] kjournald-480 [000] 303.084975: 8,0 G W 102736984 + 8 [kjournald] bash-2066 [001] 1072.953770: 8,0 G N [bash] bash-2066 [001] 1072.953773: block_getrq: 0,0 N 0 + 0 [bash] rq_complete: konsole-2065 [001] 300.053184: block_rq_complete: 8,0 W () 103669040 + 16 [0] konsole-2065 [001] 300.053191: 8,0 C W 103669040 + 16 [0] ksoftirqd/1-7 [001] 1072.953811: 8,0 C N (5a 00 08 00 00 00 00 00 24 00) [0] ksoftirqd/1-7 [001] 1072.953813: block_rq_complete: 0,0 N (5a 00 08 00 00 00 00 00 24 00) 0 + 0 [0] rq_insert: kjournald-480 [000] 303.084985: block_rq_insert: 8,0 W 0 () 102736984 + 8 [kjournald] kjournald-480 [000] 303.084986: 8,0 I W 102736984 + 8 [kjournald] Changelog from v2 -> v3: - use the newly introduced __dynamic_array(). Changelog from v1 -> v2: - use __string() instead of __array() to minimize the memory required to store hex dump of rq->cmd(). - support large pc requests. - add missing blk_fill_rwbs_rq() in block_rq_requeue TRACE_EVENT. - some cleanups. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4A2DF669.5070905@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-05-22block: Use accessor functions for queue limitsMartin K. Petersen
Convert all external users of queue limits to using wrapper functions instead of poking the request queue variables directly. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22Merge branch 'master' into for-2.6.31Jens Axboe
Conflicts: drivers/block/hd.c drivers/block/mg_disk.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-19bio: always copy back data for copied kernel requestsTejun Heo
When a read bio_copy_kern() request fails, the content of the bounce buffer is not copied back. However, as request failure doesn't necessarily mean complete failure, the buffer state can be useful. This behavior is also inconsistent with the user map counterpart and causes the subtle difference between bounced and unbounced IO causes confusion. This patch makes bio_copy_kern_endio() ignore @err and always copy back data on request completion. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Boaz Harrosh <bharrosh@panasas.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28bio: fix memcpy corruption in bio_copy_user_iov()FUJITA Tomonori
st driver uses blk_rq_map_user() in order to just build a request out of page frames. In this case, map_data->offset is a non zero value and iov[0].iov_base is NULL. We need to increase nr_pages for that. Cc: stable@kernel.org Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-22bio: use bio_kmalloc() in copy/map functionsTejun Heo
Impact: remove possible deadlock condition There is no reason to use mempool backed allocation for map functions. Also, because kern mapping is used inside LLDs (e.g. for EH), using mempool backed allocation can lead to deadlock under extreme conditions (mempool already consumed by the time a request reached EH and requests are blocked on EH). Switch copy/map functions to bio_kmalloc(). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-22bio: fix bio_kmalloc()Tejun Heo
Impact: fix bio_kmalloc() and its destruction path bio_kmalloc() was broken in two ways. * bvec_alloc_bs() first allocates bvec using kmalloc() and then ignores it and allocates again like non-kmalloc bvecs. * bio_kmalloc_destructor() didn't check for and free bio integrity data. This patch fixes the above problems. kmalloc patch is separated out from bio_alloc_bioset() and allocates the requested number of bvecs as inline bvecs. * bio_alloc_bioset() no longer takes NULL @bs. None other than bio_kmalloc() used it and outside users can't know how it was allocated anyway. * Define and use BIO_POOL_NONE so that pool index check in bvec_free_bs() triggers if inline or kmalloc allocated bvec gets there. * Relocate destructors on top of each allocation function so that how they're used is more clear. Jens Axboe suggested allocating bvecs inline. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15bio: add documentation to bio_alloc()Jens Axboe
Explain that with __GFP_WAIT set it will not fail, and that the caller must never allocate more than 1 bio at the time. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-30trivial: Fix typo in bio_split()'s documentationAlberto Bertogli
Signed-off-by: Alberto Bertogli <albertito@blitiri.com.ar> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-24block: add private bio_set for bio integrity allocationsMartin K. Petersen
The integrity bio allocation needs its own bio_set to avoid violating the mempool allocation rules and risking deadlocks. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-24block: don't create bio_vec slabs of less than the inline numberJens Axboe
If we don't have CONFIG_BLK_DEV_INTEGRITY set, then we don't have any external dependencies on the bio_vec slabs. So don't create the ones that we will inline anyway. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-24block: cleanup bio_alloc_bioset()Ingo Molnar
this warning (which got fixed by commit b2bf968): fs/bio.c: In function ‘bio_alloc_bioset’: fs/bio.c:305: warning: ‘p’ may be used uninitialized in this function Triggered because the code flow in bio_alloc_bioset() is correct but a bit complex for the compiler to see through. Streamline it a bit - this also makes the code a tiny bit more compact: text data bss dec hex filename 7540 256 40 7836 1e9c bio.o.before 7539 256 40 7835 1e9b bio.o.after Also remove an older compiler-warnings annotation from this function, it's not needed. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-14block: fix memory leak in bio_clone()Li Zefan
If bio_integrity_clone() fails, bio_clone() returns NULL without freeing the newly allocated bio. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
