path: root/fs/binfmt_elf_fdpic.c
2007-03-23[PATCH] FDPIC: fix the /proc/pid/stat representation of executable boundariesDavid Howells
Fix the /proc/pid/stat representation of executable boundaries. It should show the bounds of the executable, but instead shows the bounds of the loader. Before the patch is applied, the bug can be seen by examining, say, inetd: # ps | grep inetd 610 root 0 S /usr/sbin/inetd -i # cat /proc/610/maps c0bb0000-c0bba788 r-xs 00000000 00:0b 14582157 /lib/ld-uClibc-0.9.28.so c3180000-c31dede4 r-xs 00000000 00:0b 14582179 /lib/libuClibc-0.9.28.so c328c000-c328ea00 rw-p 00008000 00:0b 14582157 /lib/ld-uClibc-0.9.28.so c3290000-c329b6c0 rw-p 00000000 00:00 0 c32a0000-c32c0000 rwxp 00000000 00:00 0 c32d4000-c32d8000 rw-p 00000000 00:00 0 c3394000-c3398000 rw-p 00000000 00:00 0 c3458000-c345f464 r-xs 00000000 00:0b 16384612 /usr/sbin/inetd c3470000-c34748f8 rw-p 00004000 00:0b 16384612 /usr/sbin/inetd c34cc000-c34d0000 rw-p 00000000 00:00 0 c34d4000-c34d8000 rw-p 00000000 00:00 0 c34d8000-c34dc000 rw-p 00000000 00:00 0 # cat /proc/610/stat 610 (inetd) S 1 610 610 0 -1 256 0 0 0 0 0 8 0 0 19 0 1 0 94392000718 950272 0 4294967295 3233480704 3233523592 3274440352 3274439976 3273467584 0 0 4096 90115 3221712796 0 0 17 0 0 0 0 The code boundaries are 3233480704 to 3233523592, which are: (gdb) p/x 3233480704 $1 = 0xc0bb0000 (gdb) p/x 3233523592 $2 = 0xc0bba788 Which corresponds to this line in the maps file: c0bb0000-c0bba788 r-xs 00000000 00:0b 14582157 /lib/ld-uClibc-0.9.28.so Which is wrong. After the patch is applied, the maps file is pretty much identical (there's some minor shuffling of the location of some of the anonymous VMAs), but the stat file is now: # cat /proc/610/stat 610 (inetd) S 1 610 610 0 -1 256 0 0 0 0 0 7 0 0 18 0 1 0 94392000722 950272 0 4294967295 3276111872 3276141668 3274440352 3274439976 3273467584 0 0 4096 90115 3221712796 0 0 17 0 0 0 0 The code boundaries are then 3276111872 to 3276141668, which are: (gdb) p/x 3276111872 $1 = 0xc3458000 (gdb) p/x 3276141668 $2 = 0xc345f464 And these correspond to this line in the maps file instead: c3458000-c345f464 r-xs 00000000 00:0b 16384612 /usr/sbin/inetd Which is now correct. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Remove final references to deprecated "MAP_ANON" page protection flagRobert P. J. Day
Remove the last vestiges of the long-deprecated "MAP_ANON" page protection flag: use "MAP_ANONYMOUS" instead. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-26[PATCH] core-dumping unreadable binaries via PT_INTERPAlexey Dobriyan
Proposed patch to fix #5 in http://www.isec.pl/vulnerabilities/isec-0017-binfmt_elf.txt aka http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2004-1073 To reproduce, do * grab poc at the end of advisory. * add line "eph.p_memsz = 4096;" after "eph.p_filesz = 4096;" where first "4096" is something equal to or greater than 4096. * ./poc /usr/bin/sudo && ls -l Here I get with 2.6.20-rc5: -rw------- 1 ad ad 102400 2007-01-15 19:17 core ---s--x--x 2 root root 101820 2007-01-15 19:15 /usr/bin/sudo Check for MAY_READ like binfmt_misc.c does. Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-12fs: Convert kmalloc() + memset() to kzalloc() in fs/.Robert P. J. Day
Convert the single available instance of kmalloc() + memset() to kzalloc() in the fs/ directory. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-08[PATCH] add process_session() helper routineCedric Le Goater
Replace occurences of task->signal->session by a new process_session() helper routine. It will be useful for pid namespaces to abstract the session pid number. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] elf: Always define elf_addr_t in linux/elf.hMagnus Damm
Define elf_addr_t in linux/elf.h. The size of the type is determined using ELF_CLASS. This allows us to remove the defines that today are spread all over .c and .h files. Signed-off-by: Magnus Damm <magnus@valinux.co.jp> Cc: Daniel Jacobowitz <drow@false.org> Cc: Roland McGrath <roland@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] elf_fdpic_core_dump: don't take tasklist_lockOleg Nesterov
do_each_thread() is rcu-safe, and all tasks which use this ->mm must sleep in wait_for_completion(&mm->core_done) at this point, so we can use RCU locks. Also, remove unneeded INIT_LIST_HEAD(new) before list_add(new, head). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] FDPIC: Add coredump capability for the ELF-FDPIC binfmtDavid Howells
Add coredump capability for the ELF-FDPIC binfmt. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] FDPIC: Adjust the ELF-FDPIC driver to conform more to the CodingStyleDavid Howells
Adjust the ELF-FDPIC binfmt driver to conform much more to the CodingStyle, silly though it may be. Further changes: (*) Drop the casts to long for addresses in kdebug() statements (they're unsigned long already). (*) Use extra variables to avoid expressions longer than 80 chars by splitting the statement into multiple statements and letting the compiler optimise them back together. (*) Eliminate duplicate call of ksize() when working out how much space was actually allocated for the stack. (*) Discard the commented-out load_shlib prototype and op pointer as this will not be supported in ELF-FDPIC for the foreseeable future. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] FDPIC: Fix FDPIC compile errorsDavid Howells
Fix FDPIC compile errors. (akpm: we suspect it fixes a warning) Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] frv: binfmt_elf_fdpic __user annotationsAl Viro
Add __user annotations to binfmt_elf_fdpic. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24BUG_ON() Conversion in fs/binfmt_elf_fdpic.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner and can better optimized away Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-10[PATCH] fs/binfmt_elf: Remove unneeded kmalloc() return value castsJesper Juhl
Remove unneeded casts of kmalloc() return value in binfmt_elf. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: mm_init set_mm_countersHugh Dickins
How is anon_rss initialized? In dup_mmap, and by mm_alloc's memset; but that's not so good if an mm_counter_t is a special type. And how is rss initialized? By set_mm_counter, all over the place. Come on, we just need to initialize them both at once by set_mm_counter in mm_init (which follows the memcpy when forking). Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
